[rtems commit] getgrent.c: Fix Unchecked return value error (CID #1459004)
Vijay Kumar Banerjee
vijay at rtems.org
Sat Feb 27 15:57:17 UTC 2021
Pushed the fix. Thanks!
On Sat, Feb 27, 2021 at 8:15 AM Joel Sherrill <joel at rtems.org> wrote:
> Sorry and thanks.
> On Sat, Feb 27, 2021, 8:35 AM Gedare Bloom <gedare at rtems.org> wrote:
>> The fix looks right, please push it to get the build working again.
>> On Fri, Feb 26, 2021 at 11:11 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
>> > Hi,
>> > I'm getting build error after this commit.
>> > /home/vijay/development/rtems/6/lib/gcc/i386-rtems6/10.2.1/../../../../i386-rtems6/bin/ld:
>> > ./librtemscpu.a(getgrent.c.57.o): in function `endgrent':
>> > /home/vijay/rtems-class/rtems/build/i386/pc386/../../../cpukit/libcsupport/src/getgrent.c:109:
>> > undefined reference to `_Assert_Unused_variable_equals'
>> > collect2: error: ld returned 1 exit status
>> > Looks like assert.h isn't included from getgrent.c . I have attached a
>> > patch to add the header files and checked that it's building now.
>> > Best regards,
>> > Vijay
>> > On Fri, Feb 26, 2021 at 3:56 PM Joel Sherrill <joel at rtems.org> wrote:
>> > > Module: rtems
>> > > Branch: master
>> > > Commit: e5e58da6dfbdfa78ad499c2f52ec53c88538aa1c
>> > > Changeset: http://git.rtems.org/rtems/commit/?id=e5e58da6dfbdfa78ad499c2f52ec53c88538aa1c
>> > > Author: Ryan Long <ryan.long at oarcorp.com>
>> > > Date: Fri Feb 19 17:30:13 2021 -0500
>> > > CID 1459004: Unchecked return value in endgrent().
>> > > Closes #4261
>> > > cpukit/libcsupport/src/getgrent.c | 4 +++-
>> > > 1 file changed, 3 insertions(+), 1 deletion(-)
>> > > diff --git a/cpukit/libcsupport/src/getgrent.c b/cpukit/libcsupport/src/getgrent.c
>> > > index b358cb9..de56430 100644
>> > > --- a/cpukit/libcsupport/src/getgrent.c
>> > > +++ b/cpukit/libcsupport/src/getgrent.c
>> > > @@ -95,6 +95,7 @@ void setgrent(void)
>> > > void endgrent(void)
>> > > grp_context *ctx = grp_get_context();
>> > > + int sc;
>> > > if (ctx == NULL)
>> > > return;
>> > > @@ -104,5 +105,6 @@ void endgrent(void)
>> > > free(ctx);
>> > > - pthread_setspecific(grp_key, NULL);
>> > > + sc = pthread_setspecific(grp_key, NULL);
>> > > + _Assert_Unused_variable_equals(sc, 0);
>> > > _______________________________________________
>> > > vc mailing list
>> > > vc at rtems.org
>> > > http://lists.rtems.org/mailman/listinfo/vc
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
