[PATCH 1/3] prepared patch
Robin.Mueller robin.mueller.m at gmail.com
Mon Jan 4 15:10:19 UTC 2021
I added the weak attribute to some configuration structs so users can can supply their own configuration
structs (otherwise I got redeclaration linker errors).
 bsps/arm/stm32h7/console/console-usart3.c     | 23 ++++++++++++++++++-
 bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h |  8 +++++++
 bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h |  1 +
 bsps/arm/stm32h7/start/stm32h7-config.c       | 11 ++++++---
 bsps/arm/stm32h7/start/system_stm32h7xx.c     |  6 +++++
 spec/build/bsps/arm/stm32h7/bspstm32h7.yml    |  2 ++
 spec/build/bsps/arm/stm32h7/opth743nucleo.yml | 13 +++++++++++
 7 files changed, 60 insertions(+), 4 deletions(-)
 create mode 100644 spec/build/bsps/arm/stm32h7/opth743nucleo.yml
diff --git a/bsps/arm/stm32h7/console/console-usart3.c b/bsps/arm/stm32h7/console/console-usart3.c
index 6e0a10fe46..c84f6eb417 100644
--- a/bsps/arm/stm32h7/console/console-usart3.c
+++ b/bsps/arm/stm32h7/console/console-usart3.c
@@ -25,13 +25,33 @@
  * POSSIBILITY OF SUCH DAMAGE.
+#ifdef __rtems__
+#include <bspopts.h>
+#endif
 #ifdef HAVE_CONFIG_H
 #include "config.h"
 #endif
 #include <stm32h7/hal.h>
-static const stm32h7_uart_config stm32h7_usart3_config = {
+#if STM32H743ZI_NUCLEO == 1
+__attribute__((weak)) static const stm32h7_uart_config stm32h7_usart3_config = {
+  .gpio = {
+    .regs = GPIOD,
+    .config = {
+      .Pin = GPIO_PIN_8 | GPIO_PIN_9,
+      .Mode = GPIO_MODE_AF_PP,
+      .Pull = GPIO_NOPULL,
+      .Speed = GPIO_SPEED_FREQ_LOW,
+      .Alternate = GPIO_AF7_USART3
+  .irq = USART3_IRQn,
+  .device_index = 2
+#else
   .gpio = {
     .regs = GPIOB,
     .config = {
@@ -45,6 +65,7 @@ static const stm32h7_uart_config stm32h7_usart3_config = {
   .irq = USART3_IRQn,
   .device_index = 2
+#endif
 stm32h7_uart_context stm32h7_usart3_instance = {
   .uart = {
diff --git a/bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h b/bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h
index d423e4f782..7dd73075ba 100644
--- a/bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h
+++ b/bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h
@@ -21,6 +21,9 @@
 #ifndef __STM32H7xx_HAL_CONF_H
 #define __STM32H7xx_HAL_CONF_H
+#ifdef __rtems__
+#endif /* __rtems__ */
 #ifdef __cplusplus
  extern "C" {
 #endif
@@ -103,7 +106,12 @@
   *        (when HSE is used as system clock source, directly or through the PLL).
 #if !defined  (HSE_VALUE)
+// HSE for the STM32H743ZI Nucleo
+#define HSE_VALUE    ((uint32_t)8000000)
+#else
 #define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External oscillator in Hz : FPGA case fixed to 60MHZ */
+#endif
 #endif /* HSE_VALUE */
 #if !defined  (HSE_STARTUP_TIMEOUT)
diff --git a/bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h b/bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h
index e9fecc4aa0..b171f7dac7 100644
--- a/bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h
+++ b/bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h
@@ -27,6 +27,7 @@ extern "C" {
 /* Includes ------------------------------------------------------------------*/
 #include "stm32h7xx_hal_def.h"
+#include "stm32h7xx_hal_dma.h"
 /** @addtogroup STM32H7xx_HAL_Driver
diff --git a/bsps/arm/stm32h7/start/stm32h7-config.c b/bsps/arm/stm32h7/start/stm32h7-config.c
index 874ad047db..22422f2c38 100644
--- a/bsps/arm/stm32h7/start/stm32h7-config.c
+++ b/bsps/arm/stm32h7/start/stm32h7-config.c
@@ -29,12 +29,17 @@
 #include "config.h"
 #endif
+#ifdef __rtems__
+#endif
 const uint32_t stm32h7_config_pwr_regulator_voltagescaling =
   PWR_REGULATOR_VOLTAGE_SCALE0;
-const RCC_OscInitTypeDef stm32h7_config_oscillator = {
+__attribute__((weak)) const RCC_OscInitTypeDef stm32h7_config_oscillator = {
   .OscillatorType = RCC_OSCILLATORTYPE_HSI | RCC_OSCILLATORTYPE_HSE
     | RCC_OSCILLATORTYPE_LSE | RCC_OSCILLATORTYPE_HSI48,
   .HSEState = RCC_HSE_ON,
@@ -54,7 +59,7 @@ const RCC_OscInitTypeDef stm32h7_config_oscillator = {
   .PLL.PLLFRACN = 0
-const RCC_ClkInitTypeDef stm32h7_config_clocks = {
+__attribute__((weak)) const RCC_ClkInitTypeDef stm32h7_config_clocks = {
   .ClockType = RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_SYSCLK
     | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2
     | RCC_CLOCKTYPE_D3PCLK1 | RCC_CLOCKTYPE_D1PCLK1,
@@ -69,7 +74,7 @@ const RCC_ClkInitTypeDef stm32h7_config_clocks = {
 const uint32_t stm32h7_config_flash_latency = FLASH_LATENCY_4;
-const RCC_PeriphCLKInitTypeDef stm32h7_config_peripheral_clocks = {
+__attribute__((weak)) const RCC_PeriphCLKInitTypeDef stm32h7_config_peripheral_clocks = {
   .PeriphClockSelection = RCC_PERIPHCLK_RTC | RCC_PERIPHCLK_USART3
     | RCC_PERIPHCLK_FDCAN | RCC_PERIPHCLK_USART1 | RCC_PERIPHCLK_I2C1
     | RCC_PERIPHCLK_USB | RCC_PERIPHCLK_FMC | RCC_PERIPHCLK_RNG,
diff --git a/bsps/arm/stm32h7/start/system_stm32h7xx.c b/bsps/arm/stm32h7/start/system_stm32h7xx.c
index 092d853720..65c5a65ef0 100644
--- a/bsps/arm/stm32h7/start/system_stm32h7xx.c
+++ b/bsps/arm/stm32h7/start/system_stm32h7xx.c
@@ -48,10 +48,16 @@
 #include "stm32h7xx.h"
 #include <math.h>
 #ifdef __rtems__
 #include <bsp/linker-symbols.h>
+#define HSE_VALUE    ((uint32_t)8000000) /*!< Value of the External oscillator in Hz */
+#else
 #define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External oscillator in Hz */
+#endif
 #if !defined  (CSI_VALUE)
diff --git a/spec/build/bsps/arm/stm32h7/bspstm32h7.yml b/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
index 835247316c..cd3446d1d4 100644
--- a/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
+++ b/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
@@ -244,6 +244,8 @@ links:
   uid: ../../optconsolebaud
 - role: build-dependency
   uid: ../../optconsoleirq
+- role: build-dependency
+  uid: opth743nucleo
   uid: ../grp
diff --git a/spec/build/bsps/arm/stm32h7/opth743nucleo.yml b/spec/build/bsps/arm/stm32h7/opth743nucleo.yml
new file mode 100644
index 0000000000..3e68455893
--- /dev/null
+++ b/spec/build/bsps/arm/stm32h7/opth743nucleo.yml
@@ -0,0 +1,13 @@
+actions:
+- get-boolean: null
+- define-condition: null
+build-type: option
+default: false
+default-by-variant: []
+enabled-by: true
+format: '{}'
+links: []
+name: STM32H743ZI_NUCLEO
+description: |
+  Nucleo board. Use 8 MHz HSE external clock.
+type: build
2.25.1
>From 4e2645f7586508b0f68e2fb19f888e92d4ac5530 Mon Sep 17 00:00:00 2001
From: "Robin.Mueller" <robin.mueller.m at gmail.com>
Date: Mon, 4 Jan 2021 16:00:46 +0100
Subject: [PATCH 2/3] functions made public
 bsps/arm/stm32h7/console/console-usart3.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
index c84f6eb417..555669436e 100644
@@ -36,7 +36,7 @@
-__attribute__((weak)) static const stm32h7_uart_config stm32h7_usart3_config = {
+__attribute__((weak)) const stm32h7_uart_config stm32h7_usart3_config = {
   .gpio = {
     .regs = GPIOD,
     .config = {
@@ -51,7 +51,7 @@ __attribute__((weak)) static const stm32h7_uart_config stm32h7_usart3_config = {
   .device_index = 2
 #else
   .gpio = {
     .regs = GPIOB,
     .config = {
2.25.1
>From 0cb2f4f4deb0015f96866bc00869095b2e637437 Mon Sep 17 00:00:00 2001
Date: Mon, 4 Jan 2021 16:04:03 +0100
Subject: [PATCH 3/3] better help output
 spec/build/bsps/arm/stm32h7/opth743nucleo.yml | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
index 3e68455893..2c4176bf00 100644
--- a/spec/build/bsps/arm/stm32h7/opth743nucleo.yml
@@ -9,5 +9,5 @@ format: '{}'
 links: []
 description: |
-  Nucleo board. Use 8 MHz HSE external clock.
+  Nucleo board. Use 8 MHz HSE external clock and different pins for the UART console.
 type: build
2.25.1
