[PATCH 01/19] added nucleo adaption
Robin.Mueller robin.mueller.m at gmail.com
Tue Jan 5 11:59:44 UTC 2021
This patch was updated after the configuration structs for the STM32
were moved into separate files.
 bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h b/bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h
index d423e4f782..715a36d807 100644
--- a/bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h
+++ b/bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h
@@ -103,7 +103,9 @@
   *        (when HSE is used as system clock source, directly or through the PLL).
 #if !defined  (HSE_VALUE)
-#define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External oscillator in Hz : FPGA case fixed to 60MHZ */
+//#define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External oscillator in Hz : FPGA case fixed to 60MHZ */
+// Correction for the STM32H743ZI Nucleo
+#define HSE_VALUE      ((uint32_t)8000000)
 #endif /* HSE_VALUE */
 #if !defined  (HSE_STARTUP_TIMEOUT)
2.25.1
>From 4e5c1404ce9277eaadd1b7e697310fc97206000f Mon Sep 17 00:00:00 2001
From: "Robin.Mueller" <robin.mueller.m at gmail.com>
Date: Wed, 25 Nov 2020 20:16:45 +0100
Subject: [PATCH 02/19] trying to make it externally configurable
 .gitignore                                    |  1 +
 bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h |  8 ++++++--
 spec/build/bsps/arm/stm32h7/opth743nucleo.yml | 13 +++++++++++++
 3 files changed, 20 insertions(+), 2 deletions(-)
 create mode 100644 spec/build/bsps/arm/stm32h7/opth743nucleo.yml
diff --git a/.gitignore b/.gitignore
index 8b28b186e1..ec719d4cf0 100644
--- a/.gitignore
+++ b/.gitignore
@@ -12,3 +12,4 @@ Makefile.in
 /testsuites/build/build
 /testsuites/build/wscript
 .waf*
+.project
index 715a36d807..ff59180d72 100644
@@ -103,9 +103,13 @@
-//#define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External oscillator in Hz : FPGA case fixed to 60MHZ */
+#ifdef STM32H743ZI_NUCLEO
+#else
+#define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External oscillator in Hz : FPGA case fixed to 60MHZ */
+#endif
-#define HSE_VALUE      ((uint32_t)8000000)
diff --git a/spec/build/bsps/arm/stm32h7/opth743nucleo.yml b/spec/build/bsps/arm/stm32h7/opth743nucleo.yml
new file mode 100644
index 0000000000..3e68455893
--- /dev/null
+++ b/spec/build/bsps/arm/stm32h7/opth743nucleo.yml
@@ -0,0 +1,13 @@
+actions:
+- get-boolean: null
+- define-condition: null
+build-type: option
+default: false
+default-by-variant: []
+enabled-by: true
+format: '{}'
+links: []
+name: STM32H743ZI_NUCLEO
+description: |
+  Nucleo board. Use 8 MHz HSE external clock.
+type: build
2.25.1
>From ede140e783479c09fc82a0008651e07b612dc488 Mon Sep 17 00:00:00 2001
Date: Wed, 25 Nov 2020 21:37:31 +0100
Subject: [PATCH 03/19] added build dependency
 spec/build/bsps/arm/stm32h7/bspstm32h7.yml | 2 ++
 1 file changed, 2 insertions(+)
diff --git a/spec/build/bsps/arm/stm32h7/bspstm32h7.yml b/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
index 835247316c..d2573d89fe 100644
--- a/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
+++ b/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
@@ -226,6 +226,8 @@ links:
   uid: optmemsdram2sz
 - role: build-dependency
   uid: optmemsram1sz
+- role: build-dependency
+  uid: opth743nucleo
   uid: optmemsram2sz
2.25.1
>From bd8359bbd7c3d154f401a1ffdf16d90a6e8b34dd Mon Sep 17 00:00:00 2001
Date: Wed, 25 Nov 2020 21:40:19 +0100
Subject: [PATCH 04/19] moved config option
 spec/build/bsps/arm/stm32h7/bspstm32h7.yml | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
index d2573d89fe..cd3446d1d4 100644
@@ -226,8 +226,6 @@ links:
   uid: optmemsdram2sz
   uid: optmemsram1sz
-- role: build-dependency
-  uid: opth743nucleo
   uid: optmemsram2sz
@@ -246,6 +244,8 @@ links:
   uid: ../../optconsolebaud
   uid: ../../optconsoleirq
   uid: ../grp
2.25.1
>From 706a4542c3bdc963497d6404602dcf24391dea01 Mon Sep 17 00:00:00 2001
Date: Wed, 25 Nov 2020 23:48:36 +0100
Subject: [PATCH 05/19] comment moved
 bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
index ff59180d72..6c840ed12b 100644
@@ -104,11 +104,11 @@
+// HSE for the STM32H743ZI Nucleo
 #else
 #endif
-// Correction for the STM32H743ZI Nucleo
2.25.1
>From 2d96d82a84ca4f96a1b17406a0aefe07bb52510e Mon Sep 17 00:00:00 2001
Date: Thu, 26 Nov 2020 11:15:38 +0100
Subject: [PATCH 06/19] define not propagated to header
 bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
index 6c840ed12b..a7e0dcaf8b 100644
@@ -103,11 +103,9 @@
-#ifdef STM32H743ZI_NUCLEO
-#else
 #endif
2.25.1
>From 51104ac6a5b700a65efb3ecca22b3c5df41a80f5 Mon Sep 17 00:00:00 2001
Date: Thu, 26 Nov 2020 11:25:22 +0100
Subject: [PATCH 07/19] value hardcoded again
 bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h | 2 --
 1 file changed, 2 deletions(-)
index a7e0dcaf8b..56b45d751f 100644
@@ -106,8 +106,6 @@
-#endif
2.25.1
>From b6f27f08107450e832fa2dea30f8e7dae925fd31 Mon Sep 17 00:00:00 2001
Date: Sat, 2 Jan 2021 16:39:25 +0100
Subject: [PATCH 08/19] trying to load bspopts
 bsps/arm/stm32h7/console/console-usart3.c     | 19 +++++++++++++++++++
 bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h |  8 +++++++-
 bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h |  1 +
 3 files changed, 27 insertions(+), 1 deletion(-)
diff --git a/bsps/arm/stm32h7/console/console-usart3.c b/bsps/arm/stm32h7/console/console-usart3.c
index 6e0a10fe46..08962dae81 100644
--- a/bsps/arm/stm32h7/console/console-usart3.c
+++ b/bsps/arm/stm32h7/console/console-usart3.c
@@ -25,12 +25,30 @@
  * POSSIBILITY OF SUCH DAMAGE.
+#include <bspopts.h>
 #ifdef HAVE_CONFIG_H
 #include "config.h"
 #endif
 #include <stm32h7/hal.h>
+#if STM32H743ZI_NUCLEO == 1
+static const stm32h7_uart_config stm32h7_usart3_config = {
+  .gpio = {
+    .regs = GPIOB,
+    .config = {
+      .Pin = GPIO_PIN_8 | GPIO_PIN_9,
+      .Mode = GPIO_MODE_AF_PP,
+      .Pull = GPIO_NOPULL,
+      .Speed = GPIO_SPEED_FREQ_LOW,
+      .Alternate = GPIO_AF7_USART3
+  .irq = USART3_IRQn,
+  .device_index = 2
+#else
   .gpio = {
     .regs = GPIOB,
@@ -45,6 +63,7 @@ static const stm32h7_uart_config stm32h7_usart3_config = {
   .irq = USART3_IRQn,
   .device_index = 2
+#endif
 stm32h7_uart_context stm32h7_usart3_instance = {
   .uart = {
index 56b45d751f..4d54f074ba 100644
@@ -21,6 +21,9 @@
 #ifndef __STM32H7xx_HAL_CONF_H
 #define __STM32H7xx_HAL_CONF_H
+//#ifdef __rtems__
+//#endif /* __rtems__ */
 #ifdef __cplusplus
  extern "C" {
 #endif
@@ -103,9 +106,12 @@
+#else
+#endif
diff --git a/bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h b/bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h
index e9fecc4aa0..b171f7dac7 100644
--- a/bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h
+++ b/bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h
@@ -27,6 +27,7 @@ extern "C" {
 /* Includes ------------------------------------------------------------------*/
 #include "stm32h7xx_hal_def.h"
+#include "stm32h7xx_hal_dma.h"
 /** @addtogroup STM32H7xx_HAL_Driver
2.25.1
>From 3f460f0073d67f75bdd8ded2c02c0391bef9a131 Mon Sep 17 00:00:00 2001
Date: Sat, 2 Jan 2021 18:51:47 +0100
Subject: [PATCH 09/19] correct uart chosen
 bsps/arm/stm32h7/console/console-usart3.c | 2 +-
index 08962dae81..c1b787e71c 100644
@@ -36,7 +36,7 @@
   .gpio = {
-    .regs = GPIOB,
+    .regs = GPIOD,
     .config = {
2.25.1
>From ce36d0583959c146e48b3215b3b9000bd4a9ab66 Mon Sep 17 00:00:00 2001
Date: Mon, 4 Jan 2021 11:24:03 +0100
Subject: [PATCH 10/19] stm32h7 config
 bsps/arm/stm32h7/start/stm32h7-config.c   | 57 +++++++++++++++++++++++
 bsps/arm/stm32h7/start/system_stm32h7xx.c |  6 +++
 2 files changed, 63 insertions(+)
diff --git a/bsps/arm/stm32h7/start/stm32h7-config.c b/bsps/arm/stm32h7/start/stm32h7-config.c
index 874ad047db..ce49f71d8a 100644
--- a/bsps/arm/stm32h7/start/stm32h7-config.c
+++ b/bsps/arm/stm32h7/start/stm32h7-config.c
@@ -29,11 +29,34 @@
 #include "config.h"
 #endif
+//#ifdef __rtems__
+#include <bspopts>
+//#endif
 const uint32_t stm32h7_config_pwr_regulator_voltagescaling =
   PWR_REGULATOR_VOLTAGE_SCALE0;
+const RCC_OscInitTypeDef stm32h7_config_oscillator = {
+  .OscillatorType = RCC_OSCILLATORTYPE_HSE,
+  .HSEState = RCC_HSE_BYPASS,
+  .HSIState = RCC_HSI_OFF,
+  .CSIState = RCC_CSI_OFF,
+  .PLL.PLLState = RCC_PLL_ON,
+  .PLL.PLLSource = RCC_PLLSOURCE_HSE,
+  .PLL.PLLM = 4,
+  .PLL.PLLN = 400,
+  .PLL.PLLP = 2,
+  .PLL.PLLQ = 4,
+  .PLL.PLLR = 2,
+  .PLL.PLLRGE = RCC_PLL1VCIRANGE_1,
+  .PLL.PLLVCOSEL = RCC_PLL1VCOWIDE,
+  .PLL.PLLFRACN = 0
+#else
   .OscillatorType = RCC_OSCILLATORTYPE_HSI | RCC_OSCILLATORTYPE_HSE
     | RCC_OSCILLATORTYPE_LSE | RCC_OSCILLATORTYPE_HSI48,
@@ -53,6 +76,7 @@ const RCC_OscInitTypeDef stm32h7_config_oscillator = {
   .PLL.PLLFRACN = 0
+#endif /* STM32H743ZI_NUCLEO == 1 */
 const RCC_ClkInitTypeDef stm32h7_config_clocks = {
   .ClockType = RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_SYSCLK
@@ -69,6 +93,8 @@ const RCC_ClkInitTypeDef stm32h7_config_clocks = {
 const uint32_t stm32h7_config_flash_latency = FLASH_LATENCY_4;
 const RCC_PeriphCLKInitTypeDef stm32h7_config_peripheral_clocks = {
   .PeriphClockSelection = RCC_PERIPHCLK_RTC | RCC_PERIPHCLK_USART3
     | RCC_PERIPHCLK_FDCAN | RCC_PERIPHCLK_USART1 | RCC_PERIPHCLK_I2C1
@@ -98,3 +124,34 @@ const RCC_PeriphCLKInitTypeDef stm32h7_config_peripheral_clocks = {
   .RTCClockSelection = RCC_RTCCLKSOURCE_LSE,
   .RngClockSelection = RCC_RNGCLKSOURCE_HSI48
+#else
+const RCC_PeriphCLKInitTypeDef stm32h7_config_peripheral_clocks = {
+  .PeriphClockSelection = RCC_PERIPHCLK_RTC | RCC_PERIPHCLK_USART3
+    | RCC_PERIPHCLK_FDCAN | RCC_PERIPHCLK_USART1 | RCC_PERIPHCLK_I2C1
+    | RCC_PERIPHCLK_USB | RCC_PERIPHCLK_FMC | RCC_PERIPHCLK_RNG,
+  .PLL2.PLL2M = 3,
+  .PLL2.PLL2N = 48,
+  .PLL2.PLL2P = 1,
+  .PLL2.PLL2Q = 2,
+  .PLL2.PLL2R = 2,
+  .PLL2.PLL2RGE = RCC_PLL2VCIRANGE_3,
+  .PLL2.PLL2VCOSEL = RCC_PLL2VCOWIDE,
+  .PLL2.PLL2FRACN = 0,
+  .PLL3.PLL3M = 25,
+  .PLL3.PLL3N = 192,
+  .PLL3.PLL3P = 2,
+  .PLL3.PLL3Q = 4,
+  .PLL3.PLL3R = 2,
+  .PLL3.PLL3RGE = RCC_PLL3VCIRANGE_0,
+  .PLL3.PLL3VCOSEL = RCC_PLL3VCOWIDE,
+  .PLL3.PLL3FRACN = 0,
+  .FmcClockSelection = RCC_FMCCLKSOURCE_PLL2,
+  .FdcanClockSelection = RCC_FDCANCLKSOURCE_PLL,
+  .Usart234578ClockSelection = RCC_USART234578CLKSOURCE_D2PCLK1,
+  .Usart16ClockSelection = RCC_USART16CLKSOURCE_D2PCLK2,
+  .I2c123ClockSelection = RCC_I2C123CLKSOURCE_D2PCLK1,
+  .UsbClockSelection = RCC_USBCLKSOURCE_PLL3,
+  .RTCClockSelection = RCC_RTCCLKSOURCE_LSE,
+  .RngClockSelection = RCC_RNGCLKSOURCE_HSI48
+#endif
diff --git a/bsps/arm/stm32h7/start/system_stm32h7xx.c b/bsps/arm/stm32h7/start/system_stm32h7xx.c
index 092d853720..65c5a65ef0 100644
--- a/bsps/arm/stm32h7/start/system_stm32h7xx.c
+++ b/bsps/arm/stm32h7/start/system_stm32h7xx.c
@@ -48,10 +48,16 @@
 #include "stm32h7xx.h"
 #include <math.h>
 #ifdef __rtems__
 #include <bsp/linker-symbols.h>
+#define HSE_VALUE    ((uint32_t)8000000) /*!< Value of the External oscillator in Hz */
+#else
 #define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External oscillator in Hz */
+#endif
 #if !defined  (CSI_VALUE)
2.25.1
>From d920a820d4ad442dfb10ff733cef43b65b4bdea7 Mon Sep 17 00:00:00 2001
Date: Mon, 4 Jan 2021 12:59:25 +0100
Subject: [PATCH 11/19] reverted stuff and made definitions weak
 bsps/arm/stm32h7/start/stm32h7-config.c | 64 +++----------------------
 1 file changed, 6 insertions(+), 58 deletions(-)
index ce49f71d8a..22422f2c38 100644
@@ -29,9 +29,9 @@
 #include "config.h"
 #endif
-//#ifdef __rtems__
-#include <bspopts>
-//#endif
+#ifdef __rtems__
+#endif
@@ -39,25 +39,7 @@
-#if STM32H743ZI_NUCLEO == 1
-const RCC_OscInitTypeDef stm32h7_config_oscillator = {
-  .OscillatorType = RCC_OSCILLATORTYPE_HSE,
-  .HSEState = RCC_HSE_BYPASS,
-  .HSIState = RCC_HSI_OFF,
-  .CSIState = RCC_CSI_OFF,
-  .PLL.PLLState = RCC_PLL_ON,
-  .PLL.PLLSource = RCC_PLLSOURCE_HSE,
-  .PLL.PLLM = 4,
-  .PLL.PLLN = 400,
-  .PLL.PLLP = 2,
-  .PLL.PLLQ = 4,
-  .PLL.PLLR = 2,
-  .PLL.PLLRGE = RCC_PLL1VCIRANGE_1,
-  .PLL.PLLVCOSEL = RCC_PLL1VCOWIDE,
-  .PLL.PLLFRACN = 0
-#else
+__attribute__((weak)) const RCC_OscInitTypeDef stm32h7_config_oscillator = {
   .HSEState = RCC_HSE_ON,
@@ -76,9 +58,8 @@ const RCC_OscInitTypeDef stm32h7_config_oscillator = {
   .PLL.PLLFRACN = 0
-#endif /* STM32H743ZI_NUCLEO == 1 */
-const RCC_ClkInitTypeDef stm32h7_config_clocks = {
+__attribute__((weak)) const RCC_ClkInitTypeDef stm32h7_config_clocks = {
     | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2
     | RCC_CLOCKTYPE_D3PCLK1 | RCC_CLOCKTYPE_D1PCLK1,
@@ -93,39 +74,7 @@ const RCC_ClkInitTypeDef stm32h7_config_clocks = {
-const RCC_PeriphCLKInitTypeDef stm32h7_config_peripheral_clocks = {
-  .PeriphClockSelection = RCC_PERIPHCLK_RTC | RCC_PERIPHCLK_USART3
-    | RCC_PERIPHCLK_FDCAN | RCC_PERIPHCLK_USART1 | RCC_PERIPHCLK_I2C1
-    | RCC_PERIPHCLK_USB | RCC_PERIPHCLK_FMC | RCC_PERIPHCLK_RNG,
-  .PLL2.PLL2M = 3,
-  .PLL2.PLL2N = 48,
-  .PLL2.PLL2P = 1,
-  .PLL2.PLL2Q = 2,
-  .PLL2.PLL2R = 2,
-  .PLL2.PLL2RGE = RCC_PLL2VCIRANGE_3,
-  .PLL2.PLL2VCOSEL = RCC_PLL2VCOWIDE,
-  .PLL2.PLL2FRACN = 0,
-  .PLL3.PLL3M = 25,
-  .PLL3.PLL3N = 192,
-  .PLL3.PLL3P = 2,
-  .PLL3.PLL3Q = 4,
-  .PLL3.PLL3R = 2,
-  .PLL3.PLL3RGE = RCC_PLL3VCIRANGE_0,
-  .PLL3.PLL3VCOSEL = RCC_PLL3VCOWIDE,
-  .PLL3.PLL3FRACN = 0,
-  .FmcClockSelection = RCC_FMCCLKSOURCE_PLL2,
-  .FdcanClockSelection = RCC_FDCANCLKSOURCE_PLL,
-  .Usart234578ClockSelection = RCC_USART234578CLKSOURCE_D2PCLK1,
-  .Usart16ClockSelection = RCC_USART16CLKSOURCE_D2PCLK2,
-  .I2c123ClockSelection = RCC_I2C123CLKSOURCE_D2PCLK1,
-  .UsbClockSelection = RCC_USBCLKSOURCE_PLL3,
-  .RTCClockSelection = RCC_RTCCLKSOURCE_LSE,
-  .RngClockSelection = RCC_RNGCLKSOURCE_HSI48
-#else
+__attribute__((weak)) const RCC_PeriphCLKInitTypeDef stm32h7_config_peripheral_clocks = {
@@ -154,4 +103,3 @@ const RCC_PeriphCLKInitTypeDef stm32h7_config_peripheral_clocks = {
-#endif
2.25.1
>From 50a549d4938dc2681ec0cf18aa49bd1c74e1d13d Mon Sep 17 00:00:00 2001
Date: Mon, 4 Jan 2021 13:01:31 +0100
Subject: [PATCH 12/19] small tweak
 bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h | 4 ++--
index 4d54f074ba..7dd73075ba 100644
@@ -21,9 +21,9 @@
-//#ifdef __rtems__
+#ifdef __rtems__
-//#endif /* __rtems__ */
+#endif /* __rtems__ */
 #ifdef __cplusplus
  extern "C" {
 #endif
2.25.1
>From a6675d388e174ad23ce6d61b3084742c056186be Mon Sep 17 00:00:00 2001
Date: Mon, 4 Jan 2021 15:51:39 +0100
Subject: [PATCH 13/19] prepared patch
 bsps/arm/stm32h7/console/console-usart3.c     | 23 ++++++++++++++++++-
 bsps/arm/stm32h7/start/stm32h7-config.c       | 11 ++++++---
 bsps/arm/stm32h7/start/system_stm32h7xx.c     |  6 +++++
 7 files changed, 60 insertions(+), 4 deletions(-)
index 6e0a10fe46..c84f6eb417 100644
@@ -25,13 +25,33 @@
+#ifdef __rtems__
+#endif
 #include "config.h"
 #endif
-static const stm32h7_uart_config stm32h7_usart3_config = {
+__attribute__((weak)) static const stm32h7_uart_config stm32h7_usart3_config = {
+  .gpio = {
+    .regs = GPIOD,
+    .config = {
+  .device_index = 2
+#else
   .gpio = {
     .regs = GPIOB,
     .config = {
@@ -45,6 +65,7 @@ static const stm32h7_uart_config stm32h7_usart3_config = {
   .irq = USART3_IRQn,
   .device_index = 2
+#endif
   .uart = {
index d423e4f782..7dd73075ba 100644
@@ -21,6 +21,9 @@
+#ifdef __rtems__
 #ifdef __cplusplus
  extern "C" {
 #endif
@@ -103,7 +106,12 @@
+#else
+#endif
index 874ad047db..22422f2c38 100644
@@ -29,12 +29,17 @@
 #include "config.h"
 #endif
+#ifdef __rtems__
+#endif
@@ -54,7 +59,7 @@ const RCC_OscInitTypeDef stm32h7_config_oscillator = {
   .PLL.PLLFRACN = 0
@@ -69,7 +74,7 @@ const RCC_ClkInitTypeDef stm32h7_config_clocks = {
@@ -48,10 +48,16 @@
 #include <math.h>
 #ifdef __rtems__
+#else
+#endif
index 835247316c..cd3446d1d4 100644
@@ -244,6 +244,8 @@ links:
   uid: ../grp
--- /dev/null
@@ -0,0 +1,13 @@
+actions:
+build-type: option
+default: false
+enabled-by: true
+format: '{}'
+links: []
+description: |
+type: build
2.25.1
>From 4e2645f7586508b0f68e2fb19f888e92d4ac5530 Mon Sep 17 00:00:00 2001
Date: Mon, 4 Jan 2021 16:00:46 +0100
Subject: [PATCH 14/19] functions made public
 bsps/arm/stm32h7/console/console-usart3.c | 4 ++--
index c84f6eb417..555669436e 100644
@@ -36,7 +36,7 @@
-__attribute__((weak)) static const stm32h7_uart_config stm32h7_usart3_config = {
+__attribute__((weak)) const stm32h7_uart_config stm32h7_usart3_config = {
   .gpio = {
     .regs = GPIOD,
     .config = {
@@ -51,7 +51,7 @@ __attribute__((weak)) static const stm32h7_uart_config stm32h7_usart3_config = {
   .device_index = 2
 #else
   .gpio = {
     .regs = GPIOB,
     .config = {
2.25.1
>From 0cb2f4f4deb0015f96866bc00869095b2e637437 Mon Sep 17 00:00:00 2001
Date: Mon, 4 Jan 2021 16:04:03 +0100
Subject: [PATCH 15/19] better help output
 spec/build/bsps/arm/stm32h7/opth743nucleo.yml | 2 +-
index 3e68455893..2c4176bf00 100644
--- a/spec/build/bsps/arm/stm32h7/opth743nucleo.yml
@@ -9,5 +9,5 @@ format: '{}'
 links: []
 description: |
-  Nucleo board. Use 8 MHz HSE external clock.
+  Nucleo board. Use 8 MHz HSE external clock and different pins for the UART console.
 type: build
2.25.1
>From 6ac23279ddc8d8cf5b57c38f7c0e994f225f74af Mon Sep 17 00:00:00 2001
Date: Tue, 5 Jan 2021 12:09:31 +0100
Subject: [PATCH 16/19] merged changes from upstream
 bsps/arm/stm32h7/console/console-uart4-cfg.c  | 47 +++++++++++++
 bsps/arm/stm32h7/console/console-uart4.c      | 15 ----
 bsps/arm/stm32h7/console/console-uart5-cfg.c  | 47 +++++++++++++
 bsps/arm/stm32h7/console/console-uart5.c      | 15 ----
 bsps/arm/stm32h7/console/console-uart7-cfg.c  | 47 +++++++++++++
 bsps/arm/stm32h7/console/console-uart7.c      | 15 ----
 bsps/arm/stm32h7/console/console-uart8-cfg.c  | 47 +++++++++++++
 bsps/arm/stm32h7/console/console-uart8.c      | 15 ----
 bsps/arm/stm32h7/console/console-uart9-cfg.c  | 51 ++++++++++++++
 bsps/arm/stm32h7/console/console-uart9.c      | 15 ----
 bsps/arm/stm32h7/console/console-usart1-cfg.c | 47 +++++++++++++
 bsps/arm/stm32h7/console/console-usart1.c     | 15 ----
 .../arm/stm32h7/console/console-usart10-cfg.c | 51 ++++++++++++++
 bsps/arm/stm32h7/console/console-usart10.c    | 15 ----
 bsps/arm/stm32h7/console/console-usart2-cfg.c | 47 +++++++++++++
 bsps/arm/stm32h7/console/console-usart2.c     | 15 ----
 bsps/arm/stm32h7/console/console-usart3-cfg.c | 68 +++++++++++++++++++
 bsps/arm/stm32h7/console/console-usart3.c     | 36 ----------
 bsps/arm/stm32h7/console/console-usart6-cfg.c | 47 +++++++++++++
 bsps/arm/stm32h7/console/console-usart6.c     | 15 ----
 bsps/arm/stm32h7/include/stm32h7/hal.h        | 20 ++++++
 bsps/arm/stm32h7/start/stm32h7-config-clk.c   | 45 ++++++++++++
 bsps/arm/stm32h7/start/stm32h7-config-fls.c   | 34 ++++++++++
 bsps/arm/stm32h7/start/stm32h7-config-osc.c   | 52 ++++++++++++++
 bsps/arm/stm32h7/start/stm32h7-config-per.c   | 62 +++++++++++++++++
 bsps/arm/stm32h7/start/stm32h7-config-pwr.c   | 35 ++++++++++
 spec/build/bsps/arm/stm32h7/bspstm32h7.yml    | 16 ++++-
 27 files changed, 762 insertions(+), 172 deletions(-)
 create mode 100644 bsps/arm/stm32h7/console/console-uart4-cfg.c
 create mode 100644 bsps/arm/stm32h7/console/console-uart5-cfg.c
 create mode 100644 bsps/arm/stm32h7/console/console-uart7-cfg.c
 create mode 100644 bsps/arm/stm32h7/console/console-uart8-cfg.c
 create mode 100644 bsps/arm/stm32h7/console/console-uart9-cfg.c
 create mode 100644 bsps/arm/stm32h7/console/console-usart1-cfg.c
 create mode 100644 bsps/arm/stm32h7/console/console-usart10-cfg.c
 create mode 100644 bsps/arm/stm32h7/console/console-usart2-cfg.c
 create mode 100644 bsps/arm/stm32h7/console/console-usart3-cfg.c
 create mode 100644 bsps/arm/stm32h7/console/console-usart6-cfg.c
 create mode 100644 bsps/arm/stm32h7/start/stm32h7-config-clk.c
 create mode 100644 bsps/arm/stm32h7/start/stm32h7-config-fls.c
 create mode 100644 bsps/arm/stm32h7/start/stm32h7-config-osc.c
 create mode 100644 bsps/arm/stm32h7/start/stm32h7-config-per.c
 create mode 100644 bsps/arm/stm32h7/start/stm32h7-config-pwr.c
diff --git a/bsps/arm/stm32h7/console/console-uart4-cfg.c b/bsps/arm/stm32h7/console/console-uart4-cfg.c
index 0000000000..bef3bf0a4d
--- /dev/null
+++ b/bsps/arm/stm32h7/console/console-uart4-cfg.c
@@ -0,0 +1,47 @@
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <stm32h7/hal.h>
+const stm32h7_uart_config stm32h7_uart4_config = {
+  .gpio = {
+    .regs = GPIOH,
+    .config = {
+      .Pin = GPIO_PIN_13 | GPIO_PIN_14,
+      .Alternate = GPIO_AF6_UART4
+  .irq = UART4_IRQn,
+  .device_index = 3
diff --git a/bsps/arm/stm32h7/console/console-uart4.c b/bsps/arm/stm32h7/console/console-uart4.c
index 40536d61cf..ab751d86ce 100644
--- a/bsps/arm/stm32h7/console/console-uart4.c
+++ b/bsps/arm/stm32h7/console/console-uart4.c
@@ -31,21 +31,6 @@
-static const stm32h7_uart_config stm32h7_uart4_config = {
-  .gpio = {
-    .regs = GPIOH,
-    .config = {
-      .Pin = GPIO_PIN_13 | GPIO_PIN_14,
-      .Mode = GPIO_MODE_AF_PP,
-      .Pull = GPIO_NOPULL,
-      .Speed = GPIO_SPEED_FREQ_LOW,
-      .Alternate = GPIO_AF6_UART4
-  .irq = UART4_IRQn,
-  .device_index = 3
 stm32h7_uart_context stm32h7_uart4_instance = {
   .uart = {
     .Instance = UART4,
diff --git a/bsps/arm/stm32h7/console/console-uart5-cfg.c b/bsps/arm/stm32h7/console/console-uart5-cfg.c
index 0000000000..2723f918e7
--- /dev/null
+++ b/bsps/arm/stm32h7/console/console-uart5-cfg.c
@@ -0,0 +1,47 @@
+ * are met:
+#endif
+const stm32h7_uart_config stm32h7_uart5_config = {
+  .gpio = {
+    .regs = GPIOD,
+    .config = {
+      .Pin = GPIO_PIN_1 | GPIO_PIN_2,
+      .Alternate = GPIO_AF8_UART5
+  .irq = UART5_IRQn,
+  .device_index = 4
diff --git a/bsps/arm/stm32h7/console/console-uart5.c b/bsps/arm/stm32h7/console/console-uart5.c
index 45b1c04b7c..5c6417f22a 100644
--- a/bsps/arm/stm32h7/console/console-uart5.c
+++ b/bsps/arm/stm32h7/console/console-uart5.c
@@ -31,21 +31,6 @@
-static const stm32h7_uart_config stm32h7_uart5_config = {
-  .gpio = {
-    .regs = GPIOD,
-    .config = {
-      .Pin = GPIO_PIN_1 | GPIO_PIN_2,
-      .Alternate = GPIO_AF8_UART5
-  .irq = UART5_IRQn,
-  .device_index = 4
 stm32h7_uart_context stm32h7_uart5_instance = {
   .uart = {
     .Instance = UART5,
diff --git a/bsps/arm/stm32h7/console/console-uart7-cfg.c b/bsps/arm/stm32h7/console/console-uart7-cfg.c
index 0000000000..640fb358e3
--- /dev/null
+++ b/bsps/arm/stm32h7/console/console-uart7-cfg.c
@@ -0,0 +1,47 @@
+ * are met:
+#endif
+const stm32h7_uart_config stm32h7_uart7_config = {
+  .gpio = {
+    .regs = GPIOB,
+    .config = {
+      .Pin = GPIO_PIN_3 | GPIO_PIN_4,
+      .Alternate = GPIO_AF7_UART7
+  .irq = UART7_IRQn,
+  .device_index = 6
diff --git a/bsps/arm/stm32h7/console/console-uart7.c b/bsps/arm/stm32h7/console/console-uart7.c
index eadf7723c6..cc113340c3 100644
--- a/bsps/arm/stm32h7/console/console-uart7.c
+++ b/bsps/arm/stm32h7/console/console-uart7.c
@@ -31,21 +31,6 @@
-static const stm32h7_uart_config stm32h7_uart7_config = {
-  .gpio = {
-    .regs = GPIOB,
-    .config = {
-      .Pin = GPIO_PIN_3 | GPIO_PIN_4,
-      .Alternate = GPIO_AF7_UART7
-  .irq = UART7_IRQn,
-  .device_index = 6
 stm32h7_uart_context stm32h7_uart7_instance = {
   .uart = {
     .Instance = UART7,
diff --git a/bsps/arm/stm32h7/console/console-uart8-cfg.c b/bsps/arm/stm32h7/console/console-uart8-cfg.c
index 0000000000..080de49df4
--- /dev/null
+++ b/bsps/arm/stm32h7/console/console-uart8-cfg.c
@@ -0,0 +1,47 @@
+ * are met:
+#endif
+const stm32h7_uart_config stm32h7_uart8_config = {
+  .gpio = {
+    .regs = GPIOE,
+    .config = {
+      .Pin = GPIO_PIN_0 | GPIO_PIN_1,
+      .Alternate = GPIO_AF8_UART8
+  .irq = UART8_IRQn,
+  .device_index = 7
diff --git a/bsps/arm/stm32h7/console/console-uart8.c b/bsps/arm/stm32h7/console/console-uart8.c
index 5daa0e3635..e79d1e4d78 100644
--- a/bsps/arm/stm32h7/console/console-uart8.c
+++ b/bsps/arm/stm32h7/console/console-uart8.c
@@ -31,21 +31,6 @@
-static const stm32h7_uart_config stm32h7_uart8_config = {
-  .gpio = {
-    .regs = GPIOE,
-    .config = {
-      .Pin = GPIO_PIN_0 | GPIO_PIN_1,
-      .Alternate = GPIO_AF8_UART8
-  .irq = UART8_IRQn,
-  .device_index = 7
 stm32h7_uart_context stm32h7_uart8_instance = {
   .uart = {
     .Instance = UART8,
diff --git a/bsps/arm/stm32h7/console/console-uart9-cfg.c b/bsps/arm/stm32h7/console/console-uart9-cfg.c
index 0000000000..a382b869f1
--- /dev/null
+++ b/bsps/arm/stm32h7/console/console-uart9-cfg.c
@@ -0,0 +1,51 @@
+ * are met:
+#endif
+#ifdef UART9
+const stm32h7_uart_config stm32h7_uart9_config = {
+  .gpio = {
+    .regs = GPIOB,
+    .config = {
+      .Pin = GPIO_PIN_15 | GPIO_PIN_14,
+      .Alternate = GPIO_AF11_UART9
+  .irq = UART9_IRQn,
+  .device_index = 8
+#endif /* UART9 */
diff --git a/bsps/arm/stm32h7/console/console-uart9.c b/bsps/arm/stm32h7/console/console-uart9.c
index 821bc11bcc..b6bdcf61f2 100644
--- a/bsps/arm/stm32h7/console/console-uart9.c
+++ b/bsps/arm/stm32h7/console/console-uart9.c
@@ -33,21 +33,6 @@
 #ifdef UART9
-static const stm32h7_uart_config stm32h7_uart9_config = {
-  .gpio = {
-    .regs = GPIOB,
-    .config = {
-      .Pin = GPIO_PIN_15 | GPIO_PIN_14,
-      .Alternate = GPIO_AF11_UART9
-  .irq = UART9_IRQn,
-  .device_index = 8
 stm32h7_uart_context stm32h7_uart9_instance = {
   .uart = {
     .Instance = UART9,
diff --git a/bsps/arm/stm32h7/console/console-usart1-cfg.c b/bsps/arm/stm32h7/console/console-usart1-cfg.c
index 0000000000..47c13b2f54
--- /dev/null
+++ b/bsps/arm/stm32h7/console/console-usart1-cfg.c
@@ -0,0 +1,47 @@
+ * are met:
+#endif
+const stm32h7_uart_config stm32h7_usart1_config = {
+  .gpio = {
+    .regs = GPIOB,
+    .config = {
+      .Pin = GPIO_PIN_14 | GPIO_PIN_15,
+      .Alternate = GPIO_AF4_USART1
+  .irq = USART1_IRQn,
+  .device_index = 0
diff --git a/bsps/arm/stm32h7/console/console-usart1.c b/bsps/arm/stm32h7/console/console-usart1.c
index 6dec753d7d..fa83001c33 100644
--- a/bsps/arm/stm32h7/console/console-usart1.c
+++ b/bsps/arm/stm32h7/console/console-usart1.c
@@ -31,21 +31,6 @@
-static const stm32h7_uart_config stm32h7_usart1_config = {
-  .gpio = {
-    .regs = GPIOB,
-    .config = {
-      .Pin = GPIO_PIN_14 | GPIO_PIN_15,
-      .Alternate = GPIO_AF4_USART1
-  .irq = USART1_IRQn,
-  .device_index = 0
 stm32h7_uart_context stm32h7_usart1_instance = {
   .uart = {
     .Instance = USART1,
diff --git a/bsps/arm/stm32h7/console/console-usart10-cfg.c b/bsps/arm/stm32h7/console/console-usart10-cfg.c
index 0000000000..72fe2541f3
--- /dev/null
+++ b/bsps/arm/stm32h7/console/console-usart10-cfg.c
@@ -0,0 +1,51 @@
+ * are met:
+#endif
+#ifdef USART10
+const stm32h7_uart_config stm32h7_usart10_config = {
+  .gpio = {
+    .regs = GPIOB,
+    .config = {
+      .Alternate = GPIO_AF11_USART10
+  .irq = USART10_IRQn,
+  .device_index = 9
+#endif /* USART10 */
diff --git a/bsps/arm/stm32h7/console/console-usart10.c b/bsps/arm/stm32h7/console/console-usart10.c
index b73346e2cf..7ba2e45433 100644
--- a/bsps/arm/stm32h7/console/console-usart10.c
+++ b/bsps/arm/stm32h7/console/console-usart10.c
@@ -33,21 +33,6 @@
 #ifdef USART10
-static const stm32h7_uart_config stm32h7_usart10_config = {
-  .gpio = {
-    .regs = GPIOB,
-    .config = {
-      .Alternate = GPIO_AF11_USART10
-  .irq = USART10_IRQn,
-  .device_index = 9
 stm32h7_uart_context stm32h7_usart10_instance = {
   .uart = {
     .Instance = USART10,
diff --git a/bsps/arm/stm32h7/console/console-usart2-cfg.c b/bsps/arm/stm32h7/console/console-usart2-cfg.c
index 0000000000..b17561982b
--- /dev/null
+++ b/bsps/arm/stm32h7/console/console-usart2-cfg.c
@@ -0,0 +1,47 @@
+ * are met:
+#endif
+const stm32h7_uart_config stm32h7_usart2_config = {
+  .gpio = {
+    .regs = GPIOA,
+    .config = {
+      .Pin = GPIO_PIN_2 | GPIO_PIN_3,
+      .Alternate = GPIO_AF7_USART2
+  .irq = USART2_IRQn,
+  .device_index = 1
diff --git a/bsps/arm/stm32h7/console/console-usart2.c b/bsps/arm/stm32h7/console/console-usart2.c
index 291dbc044d..b14be49d08 100644
--- a/bsps/arm/stm32h7/console/console-usart2.c
+++ b/bsps/arm/stm32h7/console/console-usart2.c
@@ -31,21 +31,6 @@
-static const stm32h7_uart_config stm32h7_usart2_config = {
-  .gpio = {
-    .regs = GPIOA,
-    .config = {
-      .Pin = GPIO_PIN_2 | GPIO_PIN_3,
-      .Alternate = GPIO_AF7_USART2
-  .irq = USART2_IRQn,
-  .device_index = 1
 stm32h7_uart_context stm32h7_usart2_instance = {
   .uart = {
     .Instance = USART2,
diff --git a/bsps/arm/stm32h7/console/console-usart3-cfg.c b/bsps/arm/stm32h7/console/console-usart3-cfg.c
index 0000000000..dc552610e1
--- /dev/null
+++ b/bsps/arm/stm32h7/console/console-usart3-cfg.c
@@ -0,0 +1,68 @@
+ * are met:
+#ifdef __rtems__
+#endif
+#endif
+const stm32h7_uart_config stm32h7_usart3_config = {
+  .gpio = {
+    .regs = GPIOD,
+    .config = {
+  .device_index = 2
+#else
+  .gpio = {
+    .regs = GPIOB,
+    .config = {
+      .Pin = GPIO_PIN_9 | GPIO_PIN_10,
+  .device_index = 2
index 555669436e..4fb8c7de55 100644
@@ -25,48 +25,12 @@
-#ifdef __rtems__
-#include <bspopts.h>
-#endif
 #include "config.h"
 #endif
-__attribute__((weak)) const stm32h7_uart_config stm32h7_usart3_config = {
-  .gpio = {
-    .regs = GPIOD,
-    .config = {
-      .Pin = GPIO_PIN_8 | GPIO_PIN_9,
-      .Alternate = GPIO_AF7_USART3
-  .irq = USART3_IRQn,
-  .device_index = 2
-#else
-  .gpio = {
-    .regs = GPIOB,
-    .config = {
-      .Pin = GPIO_PIN_9 | GPIO_PIN_10,
-  .device_index = 2
-#endif
   .uart = {
     .Instance = USART3,
diff --git a/bsps/arm/stm32h7/console/console-usart6-cfg.c b/bsps/arm/stm32h7/console/console-usart6-cfg.c
index 0000000000..f41a2c737f
--- /dev/null
+++ b/bsps/arm/stm32h7/console/console-usart6-cfg.c
@@ -0,0 +1,47 @@
+ * are met:
+#endif
+const stm32h7_uart_config stm32h7_usart6_config = {
+  .gpio = {
+    .regs = GPIOC,
+    .config = {
+      .Pin = GPIO_PIN_6 | GPIO_PIN_7,
+      .Alternate = GPIO_AF7_USART6
+  .irq = USART6_IRQn,
+  .device_index = 5
diff --git a/bsps/arm/stm32h7/console/console-usart6.c b/bsps/arm/stm32h7/console/console-usart6.c
index d43d8dfbf5..91d9d0302f 100644
--- a/bsps/arm/stm32h7/console/console-usart6.c
+++ b/bsps/arm/stm32h7/console/console-usart6.c
@@ -31,21 +31,6 @@
-static const stm32h7_uart_config stm32h7_usart6_config = {
-  .gpio = {
-    .regs = GPIOC,
-    .config = {
-      .Pin = GPIO_PIN_6 | GPIO_PIN_7,
-      .Alternate = GPIO_AF7_USART6
-  .irq = USART6_IRQn,
-  .device_index = 5
 stm32h7_uart_context stm32h7_usart6_instance = {
   .uart = {
     .Instance = USART6,
diff --git a/bsps/arm/stm32h7/include/stm32h7/hal.h b/bsps/arm/stm32h7/include/stm32h7/hal.h
index fe37f03c04..de38f1a5e8 100644
--- a/bsps/arm/stm32h7/include/stm32h7/hal.h
+++ b/bsps/arm/stm32h7/include/stm32h7/hal.h
@@ -112,24 +112,44 @@ int stm32h7_uart_polled_read(rtems_termios_device_context *base);
 extern stm32h7_uart_context stm32h7_usart1_instance;
+extern const stm32h7_uart_config stm32h7_usart1_config;
 extern stm32h7_uart_context stm32h7_usart2_instance;
+extern const stm32h7_uart_config stm32h7_usart2_config;
 extern stm32h7_uart_context stm32h7_usart3_instance;
+extern const stm32h7_uart_config stm32h7_usart3_config;
 extern stm32h7_uart_context stm32h7_uart4_instance;
+extern const stm32h7_uart_config stm32h7_uart4_config;
 extern stm32h7_uart_context stm32h7_uart5_instance;
+extern const stm32h7_uart_config stm32h7_uart5_config;
 extern stm32h7_uart_context stm32h7_usart6_instance;
+extern const stm32h7_uart_config stm32h7_usart6_config;
 extern stm32h7_uart_context stm32h7_uart7_instance;
+extern const stm32h7_uart_config stm32h7_uart7_config;
 extern stm32h7_uart_context stm32h7_uart8_instance;
+extern const stm32h7_uart_config stm32h7_uart8_config;
 extern stm32h7_uart_context stm32h7_uart9_instance;
+extern const stm32h7_uart_config stm32h7_uart9_config;
 extern stm32h7_uart_context stm32h7_usart10_instance;
+extern const stm32h7_uart_config stm32h7_usart10_config;
 extern const uint32_t stm32h7_config_pwr_regulator_voltagescaling;
 extern const RCC_OscInitTypeDef stm32h7_config_oscillator;
diff --git a/bsps/arm/stm32h7/start/stm32h7-config-clk.c b/bsps/arm/stm32h7/start/stm32h7-config-clk.c
index 0000000000..3e7c930201
--- /dev/null
+++ b/bsps/arm/stm32h7/start/stm32h7-config-clk.c
@@ -0,0 +1,45 @@
+ * are met:
+#endif
+const RCC_ClkInitTypeDef stm32h7_config_clocks = {
+  .ClockType = RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_SYSCLK
+    | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2
+    | RCC_CLOCKTYPE_D3PCLK1 | RCC_CLOCKTYPE_D1PCLK1,
+  .SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK,
+  .SYSCLKDivider = RCC_SYSCLK_DIV1,
+  .AHBCLKDivider = RCC_HCLK_DIV2,
+  .APB3CLKDivider = RCC_APB3_DIV2,
+  .APB1CLKDivider = RCC_APB1_DIV2,
+  .APB2CLKDivider = RCC_APB2_DIV2,
+  .APB4CLKDivider = RCC_APB4_DIV2
diff --git a/bsps/arm/stm32h7/start/stm32h7-config-fls.c b/bsps/arm/stm32h7/start/stm32h7-config-fls.c
index 0000000000..f2d10d2410
--- /dev/null
+++ b/bsps/arm/stm32h7/start/stm32h7-config-fls.c
@@ -0,0 +1,34 @@
+ * are met:
+#endif
+const uint32_t stm32h7_config_flash_latency = FLASH_LATENCY_4;
diff --git a/bsps/arm/stm32h7/start/stm32h7-config-osc.c b/bsps/arm/stm32h7/start/stm32h7-config-osc.c
index 0000000000..b639c7ca36
--- /dev/null
+++ b/bsps/arm/stm32h7/start/stm32h7-config-osc.c
@@ -0,0 +1,52 @@
+ * are met:
+#endif
+  .OscillatorType = RCC_OSCILLATORTYPE_HSI | RCC_OSCILLATORTYPE_HSE
+    | RCC_OSCILLATORTYPE_LSE | RCC_OSCILLATORTYPE_HSI48,
+  .HSEState = RCC_HSE_ON,
+  .LSEState = RCC_LSE_ON,
+  .HSIState = RCC_HSI_DIV1,
+  .HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT,
+  .HSI48State = RCC_HSI48_ON,
+  .PLL.PLLM = 5,
+  .PLL.PLLN = 192,
+  .PLL.PLLP = 2,
+  .PLL.PLLQ = 12,
+  .PLL.PLLR = 2,
+  .PLL.PLLRGE = RCC_PLL1VCIRANGE_2,
+  .PLL.PLLFRACN = 0
diff --git a/bsps/arm/stm32h7/start/stm32h7-config-per.c b/bsps/arm/stm32h7/start/stm32h7-config-per.c
index 0000000000..79aa1494dd
--- /dev/null
+++ b/bsps/arm/stm32h7/start/stm32h7-config-per.c
@@ -0,0 +1,62 @@
+ * are met:
+#endif
+  .PLL2.PLL2M = 3,
+  .PLL2.PLL2N = 48,
+  .PLL2.PLL2P = 1,
+  .PLL2.PLL2Q = 2,
+  .PLL2.PLL2R = 2,
+  .PLL3.PLL3M = 25,
+  .PLL3.PLL3P = 2,
+  .PLL3.PLL3Q = 4,
+  .PLL3.PLL3R = 2,
diff --git a/bsps/arm/stm32h7/start/stm32h7-config-pwr.c b/bsps/arm/stm32h7/start/stm32h7-config-pwr.c
index 0000000000..3fcdeba2e8
--- /dev/null
+++ b/bsps/arm/stm32h7/start/stm32h7-config-pwr.c
@@ -0,0 +1,35 @@
+ * are met:
+#endif
+const uint32_t stm32h7_config_pwr_regulator_voltagescaling =
+  PWR_REGULATOR_VOLTAGE_SCALE0;
index cd3446d1d4..71a19cdbb9 100644
@@ -270,15 +270,25 @@ source:
 - bsps/arm/shared/start/bsp-start-memcpy.S
 - bsps/arm/stm32h7/console/console.c
 - bsps/arm/stm32h7/console/console-uart4.c
+- bsps/arm/stm32h7/console/console-uart4-cfg.c
 - bsps/arm/stm32h7/console/console-uart5.c
+- bsps/arm/stm32h7/console/console-uart5-cfg.c
 - bsps/arm/stm32h7/console/console-uart7.c
+- bsps/arm/stm32h7/console/console-uart7-cfg.c
 - bsps/arm/stm32h7/console/console-uart8.c
+- bsps/arm/stm32h7/console/console-uart8-cfg.c
 - bsps/arm/stm32h7/console/console-uart9.c
+- bsps/arm/stm32h7/console/console-uart9-cfg.c
 - bsps/arm/stm32h7/console/console-usart10.c
+- bsps/arm/stm32h7/console/console-usart10-cfg.c
 - bsps/arm/stm32h7/console/console-usart1.c
+- bsps/arm/stm32h7/console/console-usart1-cfg.c
 - bsps/arm/stm32h7/console/console-usart2.c
+- bsps/arm/stm32h7/console/console-usart2-cfg.c
 - bsps/arm/stm32h7/console/console-usart3.c
+- bsps/arm/stm32h7/console/console-usart3-cfg.c
 - bsps/arm/stm32h7/console/console-usart6.c
+- bsps/arm/stm32h7/console/console-usart6-cfg.c
 - bsps/arm/stm32h7/console/printk-support.c
 - bsps/arm/stm32h7/hal/stm32h7xx_hal_adc.c
 - bsps/arm/stm32h7/hal/stm32h7xx_hal_adc_ex.c
@@ -400,7 +410,11 @@ source:
 - bsps/arm/stm32h7/start/ext-mem-ctl.c
 - bsps/arm/stm32h7/start/getentropy-rng.c
 - bsps/arm/stm32h7/start/mpu-config.c
-- bsps/arm/stm32h7/start/stm32h7-config.c
+- bsps/arm/stm32h7/start/stm32h7-config-clk.c
+- bsps/arm/stm32h7/start/stm32h7-config-fls.c
+- bsps/arm/stm32h7/start/stm32h7-config-osc.c
+- bsps/arm/stm32h7/start/stm32h7-config-per.c
+- bsps/arm/stm32h7/start/stm32h7-config-pwr.c
 - bsps/arm/stm32h7/start/stm32h7-hal.c
 - bsps/arm/stm32h7/start/stm32h7-hal-eth.c
 - bsps/arm/stm32h7/start/stm32h7-hal-uart.c
2.25.1
>From d63a12b6fde4c6025be5e755bb4fde547f968979 Mon Sep 17 00:00:00 2001
Date: Tue, 5 Jan 2021 12:10:37 +0100
Subject: [PATCH 17/19] reverted gitignore change
 .gitignore | 1 -
 1 file changed, 1 deletion(-)
index ec719d4cf0..8b28b186e1 100644
--- a/.gitignore
+++ b/.gitignore
@@ -12,4 +12,3 @@ Makefile.in
 .waf*
-.project
2.25.1
>From 2da3db8799018e98d2237ee54b13f163690fbeb2 Mon Sep 17 00:00:00 2001
Date: Tue, 5 Jan 2021 12:13:03 +0100
Subject: [PATCH 18/19] removed some moved components
 bsps/arm/stm32h7/start/stm32h7-config.c | 67 -------------------------
 1 file changed, 67 deletions(-)
index 22422f2c38..7dda17cd60 100644
@@ -29,77 +29,10 @@
 #include "config.h"
 #endif
-#ifdef __rtems__
-#endif
-__attribute__((weak)) const RCC_OscInitTypeDef stm32h7_config_oscillator = {
-  .OscillatorType = RCC_OSCILLATORTYPE_HSI | RCC_OSCILLATORTYPE_HSE
-    | RCC_OSCILLATORTYPE_LSE | RCC_OSCILLATORTYPE_HSI48,
-  .HSEState = RCC_HSE_ON,
-  .LSEState = RCC_LSE_ON,
-  .HSIState = RCC_HSI_DIV1,
-  .HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT,
-  .HSI48State = RCC_HSI48_ON,
-  .PLL.PLLM = 5,
-  .PLL.PLLN = 192,
-  .PLL.PLLP = 2,
-  .PLL.PLLQ = 12,
-  .PLL.PLLR = 2,
-  .PLL.PLLRGE = RCC_PLL1VCIRANGE_2,
-  .PLL.PLLFRACN = 0
-__attribute__((weak)) const RCC_ClkInitTypeDef stm32h7_config_clocks = {
-  .ClockType = RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_SYSCLK
-    | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2
-    | RCC_CLOCKTYPE_D3PCLK1 | RCC_CLOCKTYPE_D1PCLK1,
-  .SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK,
-  .SYSCLKDivider = RCC_SYSCLK_DIV1,
-  .AHBCLKDivider = RCC_HCLK_DIV2,
-  .APB3CLKDivider = RCC_APB3_DIV2,
-  .APB1CLKDivider = RCC_APB1_DIV2,
-  .APB2CLKDivider = RCC_APB2_DIV2,
-  .APB4CLKDivider = RCC_APB4_DIV2
-__attribute__((weak)) const RCC_PeriphCLKInitTypeDef stm32h7_config_peripheral_clocks = {
-  .PLL2.PLL2M = 3,
-  .PLL2.PLL2N = 48,
-  .PLL2.PLL2P = 1,
-  .PLL2.PLL2Q = 2,
-  .PLL2.PLL2R = 2,
-  .PLL3.PLL3M = 25,
-  .PLL3.PLL3P = 2,
-  .PLL3.PLL3Q = 4,
-  .PLL3.PLL3R = 2,
2.25.1
>From 8bcd2c40ac28bf575d6e012c57e3546799eefb40 Mon Sep 17 00:00:00 2001
Date: Tue, 5 Jan 2021 12:16:19 +0100
Subject: [PATCH 19/19] deleted old cfg file
 bsps/arm/stm32h7/start/stm32h7-config.c | 38 -------------------------
 1 file changed, 38 deletions(-)
 delete mode 100644 bsps/arm/stm32h7/start/stm32h7-config.c
deleted file mode 100644
index 7dda17cd60..0000000000
+++ /dev/null
@@ -1,38 +0,0 @@
-/* SPDX-License-Identifier: BSD-2-Clause */
- * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- *    notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- *    notice, this list of conditions and the following disclaimer in the
- *    documentation and/or other materials provided with the distribution.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
- * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
- * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
- * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
- * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
- * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
- * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
- * POSSIBILITY OF SUCH DAMAGE.
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <stm32h7/hal.h>
-const uint32_t stm32h7_config_pwr_regulator_voltagescaling =
-  PWR_REGULATOR_VOLTAGE_SCALE0;
-const uint32_t stm32h7_config_flash_latency = FLASH_LATENCY_4;
2.25.1
