[PATCH] Squashed commit of the following:
Tue Jan 5 16:01:10 UTC 2021
Hi Robin,
On Tue, Jan 5, 2021 at 5:20 AM Robin.Mueller <robin.mueller.m at gmail.com>
wrote:
> commit 8bcd2c40ac28bf575d6e012c57e3546799eefb40
> Author: Robin.Mueller <robin.mueller.m at gmail.com>
> Date:   Tue Jan 5 12:16:19 2021 +0100
>     deleted old cfg file
> commit 2da3db8799018e98d2237ee54b13f163690fbeb2
> Date:   Tue Jan 5 12:13:03 2021 +0100
>     removed some moved components
> commit d63a12b6fde4c6025be5e755bb4fde547f968979
> Date:   Tue Jan 5 12:10:37 2021 +0100
>     reverted gitignore change
> commit 6ac23279ddc8d8cf5b57c38f7c0e994f225f74af
> Date:   Tue Jan 5 12:09:31 2021 +0100
>     merged changes from upstream
> commit a51d8f3c977abb23871dea6926de75a26592db09
> Merge: d238213dd6 0cb2f4f4de
> Date:   Mon Jan 4 16:04:26 2021 +0100
>     Merge branch 'mueller/nucleo-patch' into mueller/nucleo_another_try
> commit 0cb2f4f4deb0015f96866bc00869095b2e637437
> Date:   Mon Jan 4 16:04:03 2021 +0100
>     better help output
> commit 4e2645f7586508b0f68e2fb19f888e92d4ac5530
> Date:   Mon Jan 4 16:00:46 2021 +0100
>     functions made public
> commit d238213dd657dcdd4825c8fa3db33422ecb37719
> Merge: 3a243aabc1 a6675d388e
> Date:   Mon Jan 4 15:52:35 2021 +0100
> commit a6675d388e174ad23ce6d61b3084742c056186be
> Date:   Mon Jan 4 15:51:39 2021 +0100
>     prepared patch
> commit 3a243aabc1cb933a1d1a0ed86eea0c9f54d97f90
> Merge: 50a549d493 f867e7b6f4
> Date:   Mon Jan 4 15:48:18 2021 +0100
>     Merge branch 'master' into mueller/nucleo_another_try
> commit 50a549d4938dc2681ec0cf18aa49bd1c74e1d13d
> Date:   Mon Jan 4 13:01:31 2021 +0100
>     small tweak
> commit d920a820d4ad442dfb10ff733cef43b65b4bdea7
> Date:   Mon Jan 4 12:59:25 2021 +0100
>     reverted stuff and made definitions weak
> commit ce36d0583959c146e48b3215b3b9000bd4a9ab66
> Date:   Mon Jan 4 11:24:03 2021 +0100
>     stm32h7 config
> commit 3f460f0073d67f75bdd8ded2c02c0391bef9a131
> Date:   Sat Jan 2 18:51:47 2021 +0100
>     correct uart chosen
> commit b6f27f08107450e832fa2dea30f8e7dae925fd31
> Date:   Sat Jan 2 16:39:25 2021 +0100
>     trying to load bspopts
> commit cb345ef21d4ef442290715ce1e5fce48db91119b
> Merge: 93c21c74f9 a299c4feef
> Author: Robin Mueller <robin.mueller.m at gmail.com>
> Date:   Thu Dec 17 23:10:56 2020 +0100
>     Merge remote-tracking branch 'upstream/master' into
> mueller/added-nucleo-yaml
> commit 93c21c74f928796cbc618c7c4aef492244973402
> Merge: 51104ac6a5 fe58f6ce4b
> Date:   Fri Nov 27 00:00:59 2020 +0100
> commit 51104ac6a5b700a65efb3ecca22b3c5df41a80f5
> Date:   Thu Nov 26 11:25:22 2020 +0100
>     value hardcoded again
> commit 2d96d82a84ca4f96a1b17406a0aefe07bb52510e
> Date:   Thu Nov 26 11:15:38 2020 +0100
>     define not propagated to header
> commit 706a4542c3bdc963497d6404602dcf24391dea01
> Date:   Wed Nov 25 23:48:36 2020 +0100
>     comment moved
> commit bd8359bbd7c3d154f401a1ffdf16d90a6e8b34dd
> Date:   Wed Nov 25 21:40:19 2020 +0100
>     moved config option
> commit ede140e783479c09fc82a0008651e07b612dc488
> Date:   Wed Nov 25 21:37:31 2020 +0100
>     added build dependency
> commit 4e5c1404ce9277eaadd1b7e697310fc97206000f
> Date:   Wed Nov 25 20:16:45 2020 +0100
>     trying to make it externally configurable
> commit 4fbd5f99683518c3442612c639b3894036de8b1e
> Date:   Wed Nov 25 19:53:11 2020 +0100
>     added nucleo adaption
> Squached version of the patch
Can you please reword your commit message to provide a useful single
message? https://devel.rtems.org/wiki/Developer/Git#GitCommits
We don't need all the intermediate commit messages/states of your code.
>  bsps/arm/stm32h7/console/console-usart3-cfg.c | 21 +++++++++++++++++++
>  bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h |  8 +++++++
>  bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h |  1 +
>  bsps/arm/stm32h7/start/system_stm32h7xx.c     |  6 ++++++
>  spec/build/bsps/arm/stm32h7/bspstm32h7.yml    |  2 ++
>  spec/build/bsps/arm/stm32h7/opth743nucleo.yml | 13 ++++++++++++
>  6 files changed, 51 insertions(+)
>  create mode 100644 spec/build/bsps/arm/stm32h7/opth743nucleo.yml
> diff --git a/bsps/arm/stm32h7/console/console-usart3-cfg.c
> b/bsps/arm/stm32h7/console/console-usart3-cfg.c
> index b40f6da5aa..dc552610e1 100644
> --- a/bsps/arm/stm32h7/console/console-usart3-cfg.c
> +++ b/bsps/arm/stm32h7/console/console-usart3-cfg.c
> @@ -25,12 +25,32 @@
>   * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef __rtems__
> +#include <bspopts.h>
> +#endif
>  #ifdef HAVE_CONFIG_H
>  #include "config.h"
>  #endif
>  #include <stm32h7/hal.h>
> +#if STM32H743ZI_NUCLEO == 1
> +const stm32h7_uart_config stm32h7_usart3_config = {
> +  .gpio = {
> +    .regs = GPIOD,
> +    .config = {
> +      .Pin = GPIO_PIN_8 | GPIO_PIN_9,
> +      .Mode = GPIO_MODE_AF_PP,
> +      .Pull = GPIO_NOPULL,
> +      .Speed = GPIO_SPEED_FREQ_LOW,
> +      .Alternate = GPIO_AF7_USART3
> +  .irq = USART3_IRQn,
> +  .device_index = 2
> +#else
>    .gpio = {
>      .regs = GPIOB,
> @@ -45,3 +65,4 @@ const stm32h7_uart_config stm32h7_usart3_config = {
>    .irq = USART3_IRQn,
>    .device_index = 2
> +#endif /*  STM32H743ZI_NUCLEO == 1 */
> diff --git a/bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h
> b/bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h
> index d423e4f782..7dd73075ba 100644
> --- a/bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h
> +++ b/bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h
> @@ -21,6 +21,9 @@
>  #ifndef __STM32H7xx_HAL_CONF_H
>  #define __STM32H7xx_HAL_CONF_H
> +#ifdef __rtems__
> +#endif /* __rtems__ */
>  #ifdef __cplusplus
>   extern "C" {
>  #endif
> @@ -103,7 +106,12 @@
>    *        (when HSE is used as system clock source, directly or through
> the PLL).
>  #if !defined  (HSE_VALUE)
Is this code copied from the upstream? Or did you write this adaptation? If
it is modified, probably it should be wrapped with the ifdef __rtems__ part?
> +// HSE for the STM32H743ZI Nucleo
prefer /* */ comments
> +#define HSE_VALUE    ((uint32_t)8000000)
> +#else
>  #define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External
> oscillator in Hz : FPGA case fixed to 60MHZ */
Keep line lengths below 80 characters. Can move the comment above the
define, or just keep the tail end (FPGA is 60 MHz).
Unless the code is copied from 3rd party, then keep its original formatting
for easier updates.
+#endif
>  #endif /* HSE_VALUE */
>  #if !defined  (HSE_STARTUP_TIMEOUT)
> diff --git a/bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h
> b/bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h
> index e9fecc4aa0..b171f7dac7 100644
> --- a/bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h
> +++ b/bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h
> @@ -27,6 +27,7 @@ extern "C" {
>  /* Includes
>  #include "stm32h7xx_hal_def.h"
> +#include "stm32h7xx_hal_dma.h"
>  /** @addtogroup STM32H7xx_HAL_Driver
> diff --git a/bsps/arm/stm32h7/start/system_stm32h7xx.c
> b/bsps/arm/stm32h7/start/system_stm32h7xx.c
> index 092d853720..65c5a65ef0 100644
> --- a/bsps/arm/stm32h7/start/system_stm32h7xx.c
> +++ b/bsps/arm/stm32h7/start/system_stm32h7xx.c
> @@ -48,10 +48,16 @@
>  #include "stm32h7xx.h"
>  #include <math.h>
>  #ifdef __rtems__
>  #include <bsp/linker-symbols.h>
Does this actually get picked up, now that you have the same check and
define in hal_conf?
use == 1 to be consistent?
> +#define HSE_VALUE    ((uint32_t)8000000) /*!< Value of the External
> oscillator in Hz */
> +#else
> oscillator in Hz */
> +#endif
>  #if !defined  (CSI_VALUE)
> diff --git a/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
> b/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
> index 1e54838c66..71a19cdbb9 100644
> --- a/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
> +++ b/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
> @@ -244,6 +244,8 @@ links:
>    uid: ../../optconsolebaud
>  - role: build-dependency
>    uid: ../../optconsoleirq
> +- role: build-dependency
> +  uid: opth743nucleo
>    uid: ../grp
> diff --git a/spec/build/bsps/arm/stm32h7/opth743nucleo.yml
> b/spec/build/bsps/arm/stm32h7/opth743nucleo.yml
> new file mode 100644
> index 0000000000..2c4176bf00
> --- /dev/null
> +++ b/spec/build/bsps/arm/stm32h7/opth743nucleo.yml
> @@ -0,0 +1,13 @@
> +actions:
> +- get-boolean: null
> +- define-condition: null
> +build-type: option
> +default: false
> +default-by-variant: []
> +enabled-by: true
> +format: '{}'
> +links: []
> +name: STM32H743ZI_NUCLEO
> +description: |
> +  Nucleo board. Use 8 MHz HSE external clock and different pins for the
> UART console.
> +type: build
> 2.25.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210105/7900d550/attachment-0001.html>
