RTEMS booting on PolarFire SoC FPGA
somesh deshmukh someshdeshmukh07 at gmail.com
Wed Jan 6 05:30:01 UTC 2021
After testing multiple times I observed that the failing instruction is not
consistent but I am getting mcause as 2 every time, which represents
Illegal instruction.
Is it compulsory to use the device tree to boot RTEMS? I am trying to boot
it using a simple bootloader application that will copy the executable at
0x8000 and point the processor to that location to start execution. As the
primary goal is to execute the default hello world application on PolarFire
SoC Hardware.
Is BSP_START_COPY_FDT_FROM_U_BOOT macro in the start.S enabled by default?
Thanks and Regards,
Somesh
On Tue, Jan 5, 2021 at 5:53 PM Hesham Almatary <hesham.almatary at cl.cam.ac.uk>
wrote:
> I don't see why the "auipc" would fail. Are you sure that's the
> faulting instruction? Can you read mcause/mepc from your debugger
> after it hangs?
> How/where do you prepare the FDT and pass it to RTEMS? bsp_fdt_copy
> expects the bootloader to pass the HARTID in a0, and the FDT pointer
> in a1.
> On Tue, 5 Jan 2021 at 13:16, somesh deshmukh <someshdeshmukh07 at gmail.com>
> wrote:
> > Hi All,
> > I am trying to boot RTEMS on PolarFire SoC FPGA using rv64imafdc_medany
> BSP.
> > I am using a simple bare-metal bootloader application to copy the
> hello.bin(I generated a hello.bin file from hello.exe from
> testsuits/samples directory) at the address 0x80000000.
> > Attached is the disassembly of the example that I am using to boot the
> RTEMS. I kept breakpoint at 0x80000032  and the breakpoint gets a hit.
> After this instruction, the processor just hangs in some unknown state, and
> the breakpoints after this don't get hit as the processor is in the unknown
> state, the register values cant be read.
> > Does anyone have any idea how to debug this issue? Any leads will be
> helpful.
> > Thanks and Regards,
> > Somesh
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210106/061ece89/attachment.html>
