[PATCH] Updated stm32h7 docs
Robin.Mueller robin.mueller.m at gmail.com
Wed Jan 6 16:08:28 UTC 2021
More informaion on where to find adaption points to different
board variations and also instructions on how to configure
the BSP build for a certain board variation
 user/bsps/arm/stm32h7.rst | 11 ++++++++++-
 1 file changed, 10 insertions(+), 1 deletion(-)
diff --git a/user/bsps/arm/stm32h7.rst b/user/bsps/arm/stm32h7.rst
index 3eee511..a373e70 100644
--- a/user/bsps/arm/stm32h7.rst
+++ b/user/bsps/arm/stm32h7.rst
@@ -11,16 +11,25 @@ This BSP supports the
 The BSP is known to run on these boards:
 * `STM32H743I-EVAL 2 <https://www.st.com/en/evaluation-tools/stm32h743i-eval.html>`_
+* `STM32H743ZI-Nucleo <https://www.st.com/en/evaluation-tools/nucleo-h743zi.html>`_
 Clock Driver
-The clock driver uses the `ARMv7-M Systick` module.
+The clock driver uses the `ARMv7-M Systick` module. The HSE (external oscillator) value can also be different for different evaluation or custom boards, so it is recommended to check the default values of the BSP.
 Console Driver
 The console driver supports the on-chip UART and USART modules.
+Different board variations use different GPIO pins and blocks for the default communication UART and it is recommended to check whetheer the default configuration provided is valid in the BSP.
+To specify that the BSP should be built for the STM32H743ZI-Nucleo board,
+users can supply ``STM32H743ZI_NUCLEO == True`` to ``config.ini`` when building the
+BSP.
+Alternatively, users can supply the configuration structs defined in ``hal.h``
+in the applicaton for other boards. For the console driver, the ``stm32h7_usartX_config`` structs are used to configure the GPIO pins and other parameters. The default implementations can be found in ``bsps/arm/stm32ht/console`` in the RTEMS sources.
 Network Interface Driver
2.25.1
