[PATCH] This patch adds support for a STM32H7 variation
Fri Jan 8 20:49:54 UTC 2021
On 08/01/2021 15:30, Joel Sherrill wrote:
> On Fri, Jan 8, 2021 at 6:58 AM Robin Müller <robin.mueller.m at gmail.com
> <mailto:robin.mueller.m at gmail.com>> wrote:
>     Hi Sebastian,
>     That would also be a way. The question is whether all other board
>     variation should be included as well.
>     There are 12 boards listed in the STM32CubeH7 repository example
>     applications and I have not checked which pin and HSE values
>     these boards use or if there are any other important differences..
>     I would guess that it will not be necessary to add 12 BSPs for each
>     board variation because some board settings will be identical, but
>     maybe it would make sense to determine the board differences and
>     look where
>     it makes sense to add new BSPs..
> Are they really 12 BSPs or just build variants of this one BSP family?
> If just variants, I have come full circle on how I feel about having
> lots of BSP variants. I have seen multiple cases over the past few
> months where a new user only realized their board was supported
> because it shows up as a variant or it was explicitly mentioned in the
> user facing documentation by model. Either we explicitly have a
> variant with the model name or the list of models is in the guide with
> explicit instructions on how to build for them. We have the precedence
> on the Leon3 that we added variants to match specific hardware because
> it simplified the presentation to users. Little practical difference
> in the code but it makes a better user presentation.
> I know adding variants adds time to the full build sweep but I no
> longer care. It is just more time in the background on fast servers.
> None of us are killing time waiting for all the BSPs to do a test build.
> The important thing is that search engines find the board someone is
> searching for and find that RTEMS supports it. This is the only
> marketing/advertising we have as a project. I think we have to be
> conscious that Google indexes our manuals and that if we support
> something, putting it in the documentation both helps users and helps
> market RTEMS.
Good, I was about to write something similar. Adding a BSP variant is
simple.
>     In any case, I don't really know how to add BSPs (yet), my patch
>     was just the quickest way I could think of to make the Nucleo
>     board work
>     correctly (at least console and clock, what I've tested so far)
>     out of the box with the correct config.ini settings.
> I'm thrilled you got it to work. I'd be in favor of BSP variants so
> people do not have to edit the config.ini for these variations. It is
> obscure knowledge of what to change and easier if it is captured as a
> variant.
I will add a variant for this board in the next days. It would be nice
if you could test it.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
