[PATCH] tester: Swap Xilinx ZynqMP BSPs to secondary UART
Kinsey Moore
kinsey.moore at oarcorp.com
Thu Jan 14 15:23:59 UTC 2021
Qemu's machine definition uses the second UART in the memory map as the
primary UART. This follows from the hardware itself where the second
UART in the memory map is UART 0. This switches the tester to using the
correct UART.
tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini | 2 +-
tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini | 2 +-
2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini b/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini
index 5ff0e86..35869ed 100644
--- a/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini
+++ b/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini
@@ -35,4 +35,4 @@
bsp = xilinx_zynqmp_ilp32
arch = aarch64
tester = %{_rtscripts}/qemu.cfg
-bsp_qemu_opts = %{qemu_opts_base} -serial null -serial mon:stdio -machine xlnx-zcu102 -m 4096
+bsp_qemu_opts = %{qemu_opts_base} -serial mon:stdio -machine xlnx-zcu102 -m 4096
diff --git a/tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini
index 8db82b6..cd2d268 100644
--- a/tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini
+++ b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini
@@ -35,4 +35,4 @@
bsp = xilinx_zynqmp_lp64
arch = aarch64
2.20.1
