Fwd: Build Linux: FAILED 7/rtems-moxie on x86_64-linux-gnu (dtc-1.6.0-x86_64-linux-gnu-1)
Joel Sherrill
joel at rtems.org
Thu Jan 14 23:27:28 UTC 2021
Why is dtc failing?
---------- Forwarded message ---------
Date: Thu, Jan 14, 2021, 5:15 PM
Subject: Build Linux: FAILED 7/rtems-moxie on x86_64-linux-gnu
To: <build at rtems.org>
RTEMS Source Builder - Set Builder, 6 (295f9e94b9f0)
warning: exe: absolute exe found in path: (__chown) /usr/sbin/chown
Host: Linux-5.3.18-lp152.50-default-x86_64-with-glibc2.3.4
Linux lupus 5.3.18-lp152.50-default #1 SMP Tue Nov 10 21:02:48 UTC
2020
(29ac38d) x86_64 x86_64
Build Time: 0:00:03.456161
Build FAILED: dtc-1.6.0-x86_64-linux-gnu-1
-rw-rw-r-- root/root 219 2020-03-04 07:14
dtc-1.6.0/tests/appendprop.dts
-rw-rw-r-- root/root 1243 2020-03-04 07:14
dtc-1.6.0/tests/appendprop1.c
-rw-rw-r-- root/root 1063 2020-03-04 07:14
dtc-1.6.0/tests/appendprop2.c
-rw-rw-r-- root/root 2239 2020-03-04 07:14
dtc-1.6.0/tests/appendprop_addrrange.c
-rw-rw-r-- root/root 954 2020-03-04 07:14
dtc-1.6.0/tests/asm_tree_dump.c
-rw-rw-r-- root/root 97 2020-03-04 07:14
dtc-1.6.0/tests/bad-chosen.dts
-rw-rw-r-- root/root 156 2020-03-04 07:14
dtc-1.6.0/tests/bad-dma-ranges.dts
-rw-rw-r-- root/root 128 2020-03-04 07:14
dtc-1.6.0/tests/bad-empty-ranges.dts
-rw-rw-r-- root/root 150 2020-03-04 07:14 dtc-1.6.0/tests/bad-gpio.dts
-rw-rw-r-- root/root 277 2020-03-04 07:14
dtc-1.6.0/tests/bad-graph.dts
-rw-rw-r-- root/root 140 2020-03-04 07:14
dtc-1.6.0/tests/bad-interrupt-cells.dts
-rw-rw-r-- root/root 53 2020-03-04 07:14
dtc-1.6.0/tests/bad-name-property.dts
-rw-rw-r-- root/root 107 2020-03-04 07:14
dtc-1.6.0/tests/bad-ncells.dts
-rw-rw-r-- root/root 29 2020-03-04 07:14
dtc-1.6.0/tests/bad-octal-literal.dts
-rw-rw-r-- root/root 124 2020-03-04 07:14
dtc-1.6.0/tests/bad-phandle-cells.dts
-rw-rw-r-- root/root 153 2020-03-04 07:14
dtc-1.6.0/tests/bad-reg-ranges.dts
-rw-rw-r-- root/root 142 2020-03-04 07:14
dtc-1.6.0/tests/bad-size-cells.dts
-rw-rw-r-- root/root 196 2020-03-04 07:14
dtc-1.6.0/tests/bad-string-props.dts
-rw-rw-r-- root/root 2967 2020-03-04 07:14 dtc-1.6.0/tests/base01.asm
-rw-rw-r-- root/root 32 2020-03-04 07:14 dtc-1.6.0/tests/base01.cmd
-rw-rw-r-- root/root 653 2020-03-04 07:14 dtc-1.6.0/tests/base01.dts
-rw-rw-r-- root/root 250 2020-03-04 07:14
dtc-1.6.0/tests/base01.stderr
-rw-rw-r-- root/root 624 2020-03-04 07:14 dtc-1.6.0/tests/boot-cpuid.c
-rw-rw-r-- root/root 200 2020-03-04 07:14
dtc-1.6.0/tests/boot-cpuid.dts
-rw-rw-r-- root/root 950 2020-03-04 07:14
dtc-1.6.0/tests/char_literal.c
-rw-rw-r-- root/root 69 2020-03-04 07:14
dtc-1.6.0/tests/char_literal.dts
-rw-rw-r-- root/root 1078 2020-03-04 07:14 dtc-1.6.0/tests/check_full.c
-rw-rw-r-- root/root 2961 2020-03-04 07:14
dtc-1.6.0/tests/check_header.c
-rw-rw-r-- root/root 1232 2020-03-04 07:14 dtc-1.6.0/tests/check_path.c
-rw-rw-r-- root/root 112 2020-03-04 07:14
dtc-1.6.0/tests/comments-cmp.dts
-rw-rw-r-- root/root 456 2020-03-04 07:14 dtc-1.6.0/tests/comments.dts
-rw-rw-r-- root/root 109 2020-03-04 07:14 dtc-1.6.0/tests/data.S
-rw-rw-r-- root/root 47 2020-03-04 07:14
dtc-1.6.0/tests/default-addr-size.dts
-rw-rw-r-- root/root 3406 2020-03-04 07:14 dtc-1.6.0/tests/del_node.c
-rw-rw-r-- root/root 1863 2020-03-04 07:14
dtc-1.6.0/tests/del_property.c
-rw-rw-r-- root/root 823 2020-03-04 07:14
dtc-1.6.0/tests/delete_reinstate_multilabel.dts
-rw-rw-r-- root/root 66 2020-03-04 07:14
dtc-1.6.0/tests/delete_reinstate_multilabel_ref.dts
-rw-rw-r-- root/root 70 2020-03-04 07:14
dtc-1.6.0/tests/dependencies.cmp
-rw-rw-r-- root/root 46 2020-03-04 07:14
dtc-1.6.0/tests/dependencies.dts
-rw-rw-r-- root/root 27 2020-03-04 07:14
dtc-1.6.0/tests/deps_inc1.dtsi
-rw-rw-r-- root/root 12 2020-03-04 07:14
dtc-1.6.0/tests/deps_inc2.dtsi
-rw-rw-r-- root/root 64 2020-03-04 07:14
dtc-1.6.0/tests/division-by-zero.dts
-rw-rw-r-- root/root 3463 2020-03-04 07:14
dtc-1.6.0/tests/dtb_reverse.c
-rw-rw-r-- root/root 3959 2020-03-04 07:14
dtc-1.6.0/tests/dtbs_equal_ordered.c
-rw-rw-r-- root/root 5679 2020-03-04 07:14
dtc-1.6.0/tests/dtbs_equal_unordered.c
-rwxrwxr-x root/root 734 2020-03-04 07:14
dtc-1.6.0/tests/dtc-checkfails.sh
-rwxrwxr-x root/root 402 2020-03-04 07:14 dtc-1.6.0/tests/dtc-fails.sh
-rwxrwxr-x root/root 284 2020-03-04 07:14 dtc-1.6.0/tests/dtc-fatal.sh
-rw-rw-r-- root/root 1303 2020-03-04 07:14 dtc-1.6.0/tests/dumptrees.c
-rw-rw-r-- root/root 42 2020-03-04 07:14
dtc-1.6.0/tests/dup-nodename.dts
-rw-rw-r-- root/root 90 2020-03-04 07:14
dtc-1.6.0/tests/dup-phandle.dts
dtc-1.6.0/tests/dup-propname.dts
-rw-rw-r-- root/root 152 2020-03-04 07:14
dtc-1.6.0/tests/embedded_nul.dts
-rw-rw-r-- root/root 154 2020-03-04 07:14
dtc-1.6.0/tests/embedded_nul_equiv.dts
-rw-rw-r-- root/root 18 2020-03-04 07:14 dtc-1.6.0/tests/empty.dts
-rw-rw-r-- root/root 140 2020-03-04 07:14 dtc-1.6.0/tests/escapes.dts
-rw-rw-r-- root/root 1153 2020-03-04 07:14
dtc-1.6.0/tests/extra-terminating-null.c
-rw-rw-r-- root/root 263 2020-03-04 07:14
dtc-1.6.0/tests/extra-terminating-null.dts
-rwxrwxr-x root/root 562 2020-03-04 07:14
dtc-1.6.0/tests/fdtdump-runtest.sh
-rw-rw-r-- root/root 724 2020-03-04 07:14 dtc-1.6.0/tests/fdtdump.dts
-rwxrwxr-x root/root 417 2020-03-04 07:14
dtc-1.6.0/tests/fdtget-runtest.sh
-rwxrwxr-x root/root 864 2020-03-04 07:14
dtc-1.6.0/tests/fdtoverlay-runtest.sh
-rwxrwxr-x root/root 809 2020-03-04 07:14
dtc-1.6.0/tests/fdtput-runtest.sh
-rw-rw-r-- root/root 581 2020-03-04 07:14
dtc-1.6.0/tests/find_property.c
-rw-rw-r-- root/root 2907 2020-03-04 07:14 dtc-1.6.0/tests/fs_tree1.c
-rw-rw-r-- root/root 936 2020-03-04 07:14 dtc-1.6.0/tests/get_alias.c
-rw-rw-r-- root/root 740 2020-03-04 07:14
dtc-1.6.0/tests/get_mem_rsv.c
-rw-rw-r-- root/root 1691 2020-03-04 07:14 dtc-1.6.0/tests/get_name.c
-rw-rw-r-- root/root 1991 2020-03-04 07:14 dtc-1.6.0/tests/get_path.c
-rw-rw-r-- root/root 1943 2020-03-04 07:14
dtc-1.6.0/tests/get_phandle.c
-rw-rw-r-- root/root 952 2020-03-04 07:14
dtc-1.6.0/tests/get_prop_offset.c
-rw-rw-r-- root/root 572 2020-03-04 07:14 dtc-1.6.0/tests/getprop.c
-rw-rw-r-- root/root 52 2020-03-04 07:14 dtc-1.6.0/tests/incbin.bin
-rw-rw-r-- root/root 1222 2020-03-04 07:14 dtc-1.6.0/tests/incbin.c
-rw-rw-r-- root/root 102 2020-03-04 07:14 dtc-1.6.0/tests/incbin.dts
-rw-rw-r-- root/root 25 2020-03-04 07:14 dtc-1.6.0/tests/include0.dts
-rw-rw-r-- root/root 571 2020-03-04 07:14 dtc-1.6.0/tests/include1.dts
-rw-rw-r-- root/root 42 2020-03-04 07:14 dtc-1.6.0/tests/include2.dts
-rw-rw-r-- root/root 17 2020-03-04 07:14 dtc-1.6.0/tests/include3.dts
-rw-rw-r-- root/root 28 2020-03-04 07:14 dtc-1.6.0/tests/include4.dts
-rw-rw-r-- root/root 9 2020-03-04 07:14 dtc-1.6.0/tests/include5.dts
dtc-1.6.0/tests/include5a.dts
-rw-rw-r-- root/root 14 2020-03-04 07:14 dtc-1.6.0/tests/include6.dts
-rw-rw-r-- root/root 250 2020-03-04 07:14 dtc-1.6.0/tests/include7.dts
-rw-rw-r-- root/root 27 2020-03-04 07:14 dtc-1.6.0/tests/include8.dts
-rw-rw-r-- root/root 2453 2020-03-04 07:14
dtc-1.6.0/tests/integer-expressions.c
-rw-rw-r-- root/root 1482 2020-03-04 07:14 dtc-1.6.0/tests/label01.dts
-rw-rw-r-- root/root 98 2020-03-04 07:14
dtc-1.6.0/tests/label_repeated.dts
-rw-rw-r-- root/root 554 2020-03-04 07:14
dtc-1.6.0/tests/line_directives.dts
-rw-rw-r-- root/root 2055 2020-03-04 07:14 dtc-1.6.0/tests/lorem.txt
-rw-rw-r-- root/root 3104 2020-03-04 07:14
dtc-1.6.0/tests/mangle-layout.c
-rw-rw-r-- root/root 62 2020-03-04 07:14
dtc-1.6.0/tests/minusone-phandle.dts
-rw-rw-r-- root/root 1392 2020-03-04 07:14
dtc-1.6.0/tests/move_and_save.c
-rw-rw-r-- root/root 989 2020-03-04 07:14
dtc-1.6.0/tests/multilabel.dts
-rw-rw-r-- root/root 1357 2020-03-04 07:14
dtc-1.6.0/tests/multilabel_merge.dts
-rw-rw-r-- root/root 1805 2020-03-04 07:14
dtc-1.6.0/tests/node_check_compatible.c
-rw-rw-r-- root/root 2139 2020-03-04 07:14
dtc-1.6.0/tests/node_offset_by_compatible.c
-rw-rw-r-- root/root 1242 2020-03-04 07:14
dtc-1.6.0/tests/node_offset_by_phandle.c
-rw-rw-r-- root/root 2606 2020-03-04 07:14
dtc-1.6.0/tests/node_offset_by_prop_value.c
-rw-rw-r-- root/root 80 2020-03-04 07:14
dtc-1.6.0/tests/nonexist-label-ref.dts
-rw-rw-r-- root/root 88 2020-03-04 07:14
dtc-1.6.0/tests/nonexist-node-ref.dts
-rw-rw-r-- root/root 111 2020-03-04 07:14
dtc-1.6.0/tests/nonexist-node-ref2.dts
-rw-rw-r-- root/root 2996 2020-03-04 07:14 dtc-1.6.0/tests/nop_node.c
-rw-rw-r-- root/root 1445 2020-03-04 07:14
dtc-1.6.0/tests/nop_property.c
-rw-rw-r-- root/root 2184 2020-03-04 07:14 dtc-1.6.0/tests/nopulate.c
-rw-rw-r-- root/root 1572 2020-03-04 07:14 dtc-1.6.0/tests/notfound.c
-rw-rw-r-- root/root 36 2020-03-04 07:14
dtc-1.6.0/tests/nul-in-escape.dts
-rw-rw-r-- root/root 8 2020-03-04 07:14
dtc-1.6.0/tests/nul-in-line-info1.dts
dtc-1.6.0/tests/nul-in-line-info2.dts
-rw-rw-r-- root/root 170 2020-03-04 07:14
dtc-1.6.0/tests/obsolete-chosen-interrupt-controller.dts
-rw-rw-r-- root/root 305 2020-03-04 07:14
dtc-1.6.0/tests/omit-no-ref.dts
-rw-rw-r-- root/root 1226 2020-03-04 07:14 dtc-1.6.0/tests/open_pack.c
-rw-rw-r-- root/root 4733 2020-03-04 07:14 dtc-1.6.0/tests/overlay.c
-rw-rw-r-- root/root 1084 2020-03-04 07:14
dtc-1.6.0/tests/overlay_bad_fixup.c
-rw-rw-r-- root/root 220 2020-03-04 07:14
dtc-1.6.0/tests/overlay_bad_fixup_bad_index.dts
-rw-rw-r-- root/root 221 2020-03-04 07:14
dtc-1.6.0/tests/overlay_bad_fixup_base.dtsi
-rw-rw-r-- root/root 199 2020-03-04 07:14
dtc-1.6.0/tests/overlay_bad_fixup_empty.dts
-rw-rw-r-- root/root 218 2020-03-04 07:14
dtc-1.6.0/tests/overlay_bad_fixup_empty_index.dts
dtc-1.6.0/tests/overlay_bad_fixup_index_trailing.dts
-rw-rw-r-- root/root 212 2020-03-04 07:14
dtc-1.6.0/tests/overlay_bad_fixup_path_empty_prop.dts
-rw-rw-r-- root/root 210 2020-03-04 07:14
dtc-1.6.0/tests/overlay_bad_fixup_path_only.dts
-rw-rw-r-- root/root 211 2020-03-04 07:14
dtc-1.6.0/tests/overlay_bad_fixup_path_only_sep.dts
-rw-rw-r-- root/root 217 2020-03-04 07:14
dtc-1.6.0/tests/overlay_bad_fixup_path_prop.dts
-rw-rw-r-- root/root 381 2020-03-04 07:14
dtc-1.6.0/tests/overlay_base.dts
-rw-rw-r-- root/root 362 2020-03-04 07:14
dtc-1.6.0/tests/overlay_base_manual_symbols.dts
-rw-rw-r-- root/root 755 2020-03-04 07:14
dtc-1.6.0/tests/overlay_overlay.dts
-rw-rw-r-- root/root 746 2020-03-04 07:14
dtc-1.6.0/tests/overlay_overlay_bypath.dts
-rw-rw-r-- root/root 364 2020-03-04 07:14
dtc-1.6.0/tests/overlay_overlay_local_merge.dts
-rw-rw-r-- root/root 343 2020-03-04 07:14
dtc-1.6.0/tests/overlay_overlay_long_path.dts
-rw-rw-r-- root/root 1906 2020-03-04 07:14
dtc-1.6.0/tests/overlay_overlay_manual_fixups.dts
-rw-rw-r-- root/root 1099 2020-03-04 07:14
dtc-1.6.0/tests/overlay_overlay_no_fixups.dts
-rw-rw-r-- root/root 1186 2020-03-04 07:14
dtc-1.6.0/tests/overlay_overlay_nosugar.dts
-rw-rw-r-- root/root 143 2020-03-04 07:14
dtc-1.6.0/tests/overlay_overlay_simple.dts
-rw-rw-r-- root/root 1880 2020-03-04 07:14
dtc-1.6.0/tests/parent_offset.c
-rw-rw-r-- root/root 2467 2020-03-04 07:14
dtc-1.6.0/tests/path-references.c
-rw-rw-r-- root/root 461 2020-03-04 07:14
dtc-1.6.0/tests/path-references.dts
-rw-rw-r-- root/root 4111 2020-03-04 07:14
dtc-1.6.0/tests/path_offset.c
-rw-rw-r-- root/root 1241 2020-03-04 07:14
dtc-1.6.0/tests/path_offset_aliases.c
-rw-rw-r-- root/root 313 2020-03-04 07:14
dtc-1.6.0/tests/pci-bridge-bad1.dts
-rw-rw-r-- root/root 306 2020-03-04 07:14
dtc-1.6.0/tests/pci-bridge-bad2.dts
-rw-rw-r-- root/root 536 2020-03-04 07:14
dtc-1.6.0/tests/pci-bridge-ok.dts
-rw-rw-r-- root/root 1539 2020-03-04 07:14
dtc-1.6.0/tests/phandle_format.c
-rw-rw-r-- root/root 51 2020-03-04 07:14
dtc-1.6.0/tests/prop-after-subnode.dts
-rw-rw-r-- root/root 1686 2020-03-04 07:14
dtc-1.6.0/tests/property_iterate.c
-rw-rw-r-- root/root 242 2020-03-04 07:14
dtc-1.6.0/tests/property_iterate.dts
-rw-rw-r-- root/root 579 2020-03-04 07:14
dtc-1.6.0/tests/propname_escapes.c
dtc-1.6.0/tests/propname_escapes.dts
-rw-rw-r-- root/root 23620 2020-03-04 07:14
dtc-1.6.0/tests/pylibfdt_tests.py
-rw-rw-r-- root/root 3518 2020-03-04 07:14 dtc-1.6.0/tests/references.c
-rw-rw-r-- root/root 853 2020-03-04 07:14
dtc-1.6.0/tests/references.dts
-rw-rw-r-- root/root 117 2020-03-04 07:14
dtc-1.6.0/tests/reg-ranges-root.dts
-rw-rw-r-- root/root 89 2020-03-04 07:14
dtc-1.6.0/tests/reg-without-unit-addr.dts
-rw-rw-r-- root/root 163 2020-03-04 07:14
dtc-1.6.0/tests/reuse-label.dts
dtc-1.6.0/tests/reuse-label1.dts
-rw-rw-r-- root/root 72 2020-03-04 07:14
dtc-1.6.0/tests/reuse-label2.dts
-rw-rw-r-- root/root 84 2020-03-04 07:14
dtc-1.6.0/tests/reuse-label3.dts
dtc-1.6.0/tests/reuse-label4.dts
dtc-1.6.0/tests/reuse-label5.dts
dtc-1.6.0/tests/reuse-label6.dts
-rw-rw-r-- root/root 765 2020-03-04 07:14 dtc-1.6.0/tests/root_node.c
-rwxrwxr-x root/root 42763 2020-03-04 07:14 dtc-1.6.0/tests/run_tests.sh
-rw-rw-r-- root/root 2022 2020-03-04 07:14 dtc-1.6.0/tests/rw_oom.c
-rw-rw-r-- root/root 2225 2020-03-04 07:14 dtc-1.6.0/tests/rw_tree1.c
drwxrwxr-x root/root 0 2020-03-04 07:14 dtc-1.6.0/tests/search_dir/
-rw-rw-r-- root/root 38 2020-03-04 07:14
dtc-1.6.0/tests/search_dir/search_test.dtsi
dtc-1.6.0/tests/search_dir/search_test2.dtsi
dtc-1.6.0/tests/search_dir_b/
-rw-rw-r-- root/root 50 2020-03-04 07:14
dtc-1.6.0/tests/search_dir_b/search_paths_subdir.dts
-rw-rw-r-- root/root 40 2020-03-04 07:14
dtc-1.6.0/tests/search_dir_b/search_test_b.dtsi
dtc-1.6.0/tests/search_dir_b/search_test_b2.dtsi
-rw-rw-r-- root/root 7 2020-03-04 07:14
dtc-1.6.0/tests/search_dir_b/search_test_c.dtsi
-rw-rw-r-- root/root 48 2020-03-04 07:14
dtc-1.6.0/tests/search_paths.dts
dtc-1.6.0/tests/search_paths_b.dts
-rw-rw-r-- root/root 1930 2020-03-04 07:14 dtc-1.6.0/tests/set_name.c
-rw-rw-r-- root/root 2121 2020-03-04 07:14 dtc-1.6.0/tests/setprop.c
-rw-rw-r-- root/root 2410 2020-03-04 07:14
dtc-1.6.0/tests/setprop_inplace.c
-rw-rw-r-- root/root 1756 2020-03-04 07:14
dtc-1.6.0/tests/sized_cells.c
dtc-1.6.0/tests/sized_cells.dts
-rw-rw-r-- root/root 405 2020-03-04 07:14
dtc-1.6.0/tests/sourceoutput.dts
-rw-rw-r-- root/root 205 2020-03-04 07:14
dtc-1.6.0/tests/stacked_overlay_addlabel.dts
-rw-rw-r-- root/root 158 2020-03-04 07:14
dtc-1.6.0/tests/stacked_overlay_bar.dts
-rw-rw-r-- root/root 61 2020-03-04 07:14
dtc-1.6.0/tests/stacked_overlay_base.dts
-rw-rw-r-- root/root 56 2020-03-04 07:14
dtc-1.6.0/tests/stacked_overlay_base_nolabel.dts
dtc-1.6.0/tests/stacked_overlay_baz.dts
-rw-rw-r-- root/root 622 2020-03-04 07:14
dtc-1.6.0/tests/string_escapes.c
-rw-rw-r-- root/root 4087 2020-03-04 07:14 dtc-1.6.0/tests/stringlist.c
-rw-rw-r-- root/root 149 2020-03-04 07:14
dtc-1.6.0/tests/stringlist.dts
-rw-rw-r-- root/root 1522 2020-03-04 07:14
dtc-1.6.0/tests/subnode_iterate.c
-rw-rw-r-- root/root 761 2020-03-04 07:14
dtc-1.6.0/tests/subnode_iterate.dts
-rw-rw-r-- root/root 2636 2020-03-04 07:14
dtc-1.6.0/tests/subnode_offset.c
-rw-rw-r-- root/root 3145 2020-03-04 07:14
dtc-1.6.0/tests/supernode_atdepth_offset.c
-rw-rw-r-- root/root 3850 2020-03-04 07:14 dtc-1.6.0/tests/sw_states.c
-rw-rw-r-- root/root 5369 2020-03-04 07:14 dtc-1.6.0/tests/sw_tree1.c
-rw-rw-r-- root/root 4884 2020-03-04 07:14 dtc-1.6.0/tests/test01.asm
-rw-rw-r-- root/root 1184 2020-03-04 07:14 dtc-1.6.0/tests/test01.dts
dtc-1.6.0/tests/test01.stderr
-rwxrwxr-x root/root 2056 2020-03-04 07:14
dtc-1.6.0/tests/test_kernel_dts
-rw-rw-r-- root/root 41 2020-03-04 07:14
dtc-1.6.0/tests/test_label_ref.dts
-rw-rw-r-- root/root 264 2020-03-04 07:14
dtc-1.6.0/tests/test_props.dts
-rw-rw-r-- root/root 796 2020-03-04 07:14
dtc-1.6.0/tests/test_tree1.dts
-rw-rw-r-- root/root 732 2020-03-04 07:14
dtc-1.6.0/tests/test_tree1_delete.dts
-rw-rw-r-- root/root 933 2020-03-04 07:14
dtc-1.6.0/tests/test_tree1_label_noderef.dts
-rw-rw-r-- root/root 798 2020-03-04 07:14
dtc-1.6.0/tests/test_tree1_merge.dts
-rw-rw-r-- root/root 767 2020-03-04 07:14
dtc-1.6.0/tests/test_tree1_merge_labelled.dts
-rw-rw-r-- root/root 788 2020-03-04 07:14
dtc-1.6.0/tests/test_tree1_merge_path.dts
-rw-rw-r-- root/root 642 2020-03-04 07:14
dtc-1.6.0/tests/test_tree1_wrong1.dts
-rw-rw-r-- root/root 658 2020-03-04 07:14
dtc-1.6.0/tests/test_tree1_wrong2.dts
-rw-rw-r-- root/root 659 2020-03-04 07:14
dtc-1.6.0/tests/test_tree1_wrong3.dts
-rw-rw-r-- root/root 670 2020-03-04 07:14
dtc-1.6.0/tests/test_tree1_wrong4.dts
-rw-rw-r-- root/root 684 2020-03-04 07:14
dtc-1.6.0/tests/test_tree1_wrong5.dts
-rw-rw-r-- root/root 699 2020-03-04 07:14
dtc-1.6.0/tests/test_tree1_wrong6.dts
-rw-rw-r-- root/root 705 2020-03-04 07:14
dtc-1.6.0/tests/test_tree1_wrong7.dts
dtc-1.6.0/tests/test_tree1_wrong8.dts
+ tar_exit=0
-rw-rw-r-- root/root 702 2020-03-04 07:14
dtc-1.6.0/tests/test_tree1_wrong9.dts
+ cd dtc-1.6.0
-rw-rw-r-- root/root 1890 2020-03-04 07:14 dtc-1.6.0/tests/testdata.h
+ /bin/chmod -R a+rX,g-w,o-w .
-rw-rw-r-- root/root 3430 2020-03-04 07:14 dtc-1.6.0/tests/tests.h
-rw-rw-r-- root/root 8645 2020-03-04 07:14 dtc-1.6.0/tests/testutils.c
-rw-rw-r-- root/root 1038 2020-03-04 07:14 dtc-1.6.0/tests/testutils.sh
-rw-rw-r-- root/root 6409 2020-03-04 07:14 dtc-1.6.0/tests/trees.S
-rw-rw-r-- root/root 1235 2020-03-04 07:14
dtc-1.6.0/tests/truncated_memrsv.c
-rw-rw-r-- root/root 801 2020-03-04 07:14
dtc-1.6.0/tests/truncated_property.c
-rw-rw-r-- root/root 2007 2020-03-04 07:14
dtc-1.6.0/tests/truncated_string.c
-rw-rw-r-- root/root 644 2020-03-04 07:14
dtc-1.6.0/tests/type-preservation.dt.yaml
-rw-rw-r-- root/root 754 2020-03-04 07:14
dtc-1.6.0/tests/type-preservation.dts
dtc-1.6.0/tests/unit-addr-leading-0s.dts
dtc-1.6.0/tests/unit-addr-leading-0x.dts
-rw-rw-r-- root/root 245 2020-03-04 07:14
dtc-1.6.0/tests/unit-addr-simple-bus-compatible.dts
-rw-rw-r-- root/root 234 2020-03-04 07:14
dtc-1.6.0/tests/unit-addr-simple-bus-reg-mismatch.dts
-rw-rw-r-- root/root 115 2020-03-04 07:14
dtc-1.6.0/tests/unit-addr-unique.dts
-rw-rw-r-- root/root 76 2020-03-04 07:14
dtc-1.6.0/tests/unit-addr-without-reg.dts
-rw-rw-r-- root/root 2461 2020-03-04 07:14
dtc-1.6.0/tests/utilfdt_test.c
-rw-rw-r-- root/root 2417 2020-03-04 07:14
dtc-1.6.0/tests/value-labels.c
-rw-rw-r-- root/root 233 2020-03-04 07:14
dtc-1.6.0/tests/value-labels.dts
dtc-1.6.0/tests/zero-phandle.dts
-rw-rw-r-- root/root 7054 2020-03-04 07:14 dtc-1.6.0/treesource.c
-rw-rw-r-- root/root 8701 2020-03-04 07:14 dtc-1.6.0/util.c
-rw-rw-r-- root/root 7112 2020-03-04 07:14 dtc-1.6.0/util.h
-rw-rw-r-- root/root 6380 2020-03-04 07:14 dtc-1.6.0/yamltree.c
+ cd /tmp/sh/src/rsb/rtems/build/dtc-1.6.0-x86_64-linux-gnu-1
+ SB_CXC=no
+ echo '==> clean %{buildroot}:
/tmp/sh/src/rsb/rtems/build/tmp/dtc-1.6.0-x86_64-linux-gnu-1-21112'
+ /bin/rm -rf
+ /bin/mkdir -p
+ echo '==> %build:'
==> %build:
++ pwd
+ build_top=/tmp/sh/src/rsb/rtems/build/dtc-1.6.0-x86_64-linux-gnu-1
+ cd dtc-1.6.0
+ LDFLAGS='
-L/tmp/sh/src/rsb/rtems/build/tmp/sb-21112/7/rtems-moxie/opt/rtems/7/lib'
+ LIBS=
++ echo 'gcc -O2 -g -pipe
-I/tmp/sh/src/rsb/rtems/build/tmp/sb-21112/7/rtems-moxie/opt/rtems/7/include
++ sed -e 's,-std=gnu99 ,,'
+ CC='gcc -O2 -g -pipe
++ echo 'g++ -O2 -g -pipe
+ CXX='g++ -O2 -g -pipe
+ CC_FOR_BUILD='gcc -O2 -g -pipe
+ CXX_FOR_BUILD='g++ -O2 -g -pipe
+ export CC CXX CC_FOR_BUILD CXX_FOR_BUILD CFLAGS LDFLAGS LIBS
+ make PREFIX=/opt/rtems/7
DEP tests/dumptrees.c
DEP tests/trees.S
DEP tests/testutils.c
DEP tests/value-labels.c
DEP tests/asm_tree_dump.c
DEP tests/truncated_memrsv.c
DEP tests/truncated_string.c
DEP tests/truncated_property.c
DEP tests/fs_tree1.c
DEP tests/check_full.c
DEP tests/check_header.c
DEP tests/check_path.c
DEP tests/overlay_bad_fixup.c
DEP tests/overlay.c
DEP tests/subnode_iterate.c
DEP tests/property_iterate.c
DEP tests/integer-expressions.c
DEP tests/utilfdt_test.c
DEP tests/path_offset_aliases.c
DEP tests/add_subnode_with_nops.c
DEP tests/dtbs_equal_unordered.c
DEP tests/dtb_reverse.c
DEP tests/dtbs_equal_ordered.c
DEP tests/extra-terminating-null.c
DEP tests/incbin.c
DEP tests/boot-cpuid.c
DEP tests/phandle_format.c
DEP tests/path-references.c
DEP tests/references.c
DEP tests/string_escapes.c
DEP tests/propname_escapes.c
DEP tests/appendprop2.c
DEP tests/appendprop1.c
DEP tests/del_node.c
DEP tests/del_property.c
DEP tests/setprop.c
DEP tests/set_name.c
DEP tests/rw_oom.c
DEP tests/rw_tree1.c
DEP tests/open_pack.c
DEP tests/nopulate.c
DEP tests/mangle-layout.c
DEP tests/move_and_save.c
DEP tests/sw_states.c
DEP tests/sw_tree1.c
DEP tests/nop_node.c
DEP tests/nop_property.c
DEP tests/setprop_inplace.c
DEP tests/stringlist.c
DEP tests/appendprop_addrrange.c
DEP tests/addr_size_cells2.c
DEP tests/addr_size_cells.c
DEP tests/notfound.c
DEP tests/sized_cells.c
DEP tests/char_literal.c
DEP tests/get_alias.c
DEP tests/node_offset_by_compatible.c
DEP tests/node_check_compatible.c
DEP tests/node_offset_by_phandle.c
DEP tests/node_offset_by_prop_value.c
DEP tests/parent_offset.c
DEP tests/supernode_atdepth_offset.c
DEP tests/get_path.c
DEP tests/get_phandle.c
DEP tests/get_prop_offset.c
DEP tests/getprop.c
DEP tests/get_name.c
DEP tests/path_offset.c
DEP tests/subnode_offset.c
DEP tests/find_property.c
DEP tests/root_node.c
DEP tests/get_mem_rsv.c
DEP libfdt/fdt_check.c
DEP libfdt/fdt_overlay.c
DEP libfdt/fdt_addresses.c
DEP libfdt/fdt_empty_tree.c
DEP libfdt/fdt_strerror.c
DEP libfdt/fdt_rw.c
DEP libfdt/fdt_sw.c
DEP libfdt/fdt_wip.c
DEP libfdt/fdt_ro.c
DEP libfdt/fdt.c
DEP util.c
DEP fdtoverlay.c
DEP fdtput.c
DEP fdtget.c
DEP fdtdump.c
LEX convert-dtsv0-lexer.lex.c
DEP convert-dtsv0-lexer.lex.c
DEP srcpos.c
BISON dtc-parser.tab.c
DEP dtc-parser.tab.c
LEX dtc-lexer.lex.c
DEP dtc-lexer.lex.c
DEP treesource.c
DEP livetree.c
DEP fstree.c
DEP flattree.c
DEP dtc.c
DEP data.c
DEP checks.c
CHK version_gen.h
UPD version_gen.h
DEP util.c
CHK version_gen.h
CC srcpos.o
CC util.o
CC convert-dtsv0-lexer.lex.o
LD convert-dtsv0
CC dtc.o
CC checks.o
CC data.o
CC flattree.o
CC fstree.o
CC livetree.o
CC treesource.o
CC dtc-lexer.lex.o
CC dtc-parser.tab.o
LD dtc
CC fdtdump.o
In file included from fdtdump.c:14:
fdtdump.c: In function 'main':
libfdt/libfdt.h:251:28: error: array subscript 'struct fdt_header[0]' is
partly outside array bounds of 'unsigned char[4]' [-Werror=array-bounds]
251 | fdth->name = cpu_to_fdt32(val); \
libfdt/libfdt.h:253:1: note: in expansion of macro 'fdt_set_hdr_'
253 | fdt_set_hdr_(magic);
fdtdump.c:216:31: note: while referencing 'smagic'
216 | unsigned char smagic[FDT_MAGIC_SIZE];
cc1: all warnings being treated as errors
make: *** [Makefile:345: fdtdump.o] Error 1
shell cmd failed: /bin/sh -ex
/tmp/sh/src/rsb/rtems/build/dtc-1.6.0-x86_64-linux-gnu-1/do-build
error: building dtc-1.6.0-x86_64-linux-gnu-1
See error report: rsb-report-dtc-1.6.0-x86_64-linux-gnu-1.txt
Output
Build Set: 7/rtems-moxie
config: devel/dtc-1.6.0-1.cfg
package: dtc-1.6.0-x86_64-linux-gnu-1
building: dtc-1.6.0-x86_64-linux-gnu-1
Build FAILED
Mailing report: build at rtems.org
Report
build mailing list
build at rtems.org
http://lists.rtems.org/mailman/listinfo/build
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210114/236dcee9/attachment-0001.html>
