[rtems-docs commit] c-user: Generate Timer Manager documentation
Chris Johns
chrisj at rtems.org
Fri Jan 15 03:29:59 UTC 2021
On 15/1/21 6:20 am, Joel Sherrill wrote:
> On Wed, Jan 13, 2021 at 6:26 PM Sebastian Huber
> <sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de>>
> wrote:
> On 11/12/2020 01:35, Chris Johns wrote:
> > On 10/12/20 4:41 pm, Sebastian Huber wrote:
> >> On 10/12/2020 03:24, Chris Johns wrote:
> >>> On 9/12/20 7:20 pm, Sebastian Huber wrote:
> >>>> Module: rtems-docs
> >>>> Branch: master
> >>>> Commit: d716c79070901195912526c6e49d43defad00bdd
> >>>> Changeset:
> http://git.rtems.org/rtems-docs/commit/?id=d716c79070901195912526c6e49d43defad00bdd
> <http://git.rtems.org/rtems-docs/commit/?id=d716c79070901195912526c6e49d43defad00bdd>
> >>>> Author: Sebastian Huber<sebastian.huber at embedded-brains.de
> >>>> Date: Wed Dec 2 08:17:12 2020 +0100
> >>>> The documentation is a consolidation of the comments in Doxygen markup
> >>>> and the documentation sources in Sphinx markup. The documentation was
> >>>> transfered to interface specification items. The documentation source
> >>>> files were generated from the items by a script.
> >>>> Update #3993.
> >>>> c-user/timer/directives.rst | 992
> >>>> c-user/timer/introduction.rst | 57 ++-
> >>>> 2 files changed, 674 insertions(+), 375 deletions(-)
> >>>> diff --git a/c-user/timer/directives.rst b/c-user/timer/directives.rst
> >>>> index d9b9877..d65f263 100644
> >>>> --- a/c-user/timer/directives.rst
> >>>> +++ b/c-user/timer/directives.rst
> >>>> @@ -1,463 +1,729 @@
> >>>> .. SPDX-License-Identifier: CC-BY-SA-4.0
> >>>> +.. Copyright (C) 2020 embedded brains GmbH
> (http://www.embedded-brains.de <http://www.embedded-brains.de>)
> >>>> .. Copyright (C) 1988, 2008 On-Line Applications Research
> Corporation (OAR)
> >>>> +.. This file is part of the RTEMS quality process and was automatically
> >>>> +.. generated. If you find something that needs to be fixed or
> >>>> +.. worded better please post a report or patch to an RTEMS mailing list
> >>>> +.. or raise a bug report:
> >>>> +..https://docs.rtems.org/branches/master/user/support/bugs.html
> <https://docs.rtems.org/branches/master/user/support/bugs.html>
> >>>> +.. For information on updating and regenerating please refer to:
> >>>> +..https://docs.rtems.org/branches/master/eng/req/howto.html
> <https://docs.rtems.org/branches/master/eng/req/howto.html>
> >>> We need a solution. I would prefer we resolve this before we add any more
> >>> instances of these links.
> >> I understand that cross-document links are a problem, however, these two
> links
> >> are in comments and thus don't show up in the generated documents. A link
> to the
> >> bug reporting should always point to the latest information since there
> is only
> >> one bug reporting procedure in the project at a time. The link to the howto
> >> could be branch-specific.
> > Yes I agree. My concern is a change in how master is hosted breaks the links.
> >>> Suggestions?
> >> We could add a script which performs some post processing after creation
> the of
> >> the release branches.
> > What about ....
> > https://www.rtems.org/support/bugs.html
> <https://www.rtems.org/support/bugs.html>
> I can add a page in Drupal with a forced name but am not sure about the support/
> part
> and it looks like Drupal redirect pages are an optional feature which is not
> installed and
> the module may be unsupported.
> When we did this type of thing before, it was always with Apache itself. That's
> how we
> had rtems.org/PRnnnn <http://rtems.org/PRnnnn> redirect to a specific ticket
> like GCC has. AFAIK This feature
> was not deemed worthy of inclusion back when the hosting was moved.
> Anyway URL rewriting in Apache is simple with a regular expression in a configuraton
> file.
> https://httpd.apache.org/docs/2.4/rewrite/remapping.html
> <https://httpd.apache.org/docs/2.4/rewrite/remapping.html>
> All you need to do is convince the admin to add a rule.
> Something like rtems.org/bugs/[567] <http://rtems.org/bugs/[567]> might also be
> nice and shorter. Let bugs with
> no number go to https://devel.rtems.org/wiki/NewTicket
> <https://devel.rtems.org/wiki/NewTicket> which is where "Report a Bug"
> is directed on the right hand side of rtems.org <http://rtems.org>.
> Personally I like using the Apache rewrite engine to make shorter easier to
> remember URLs.
Good idea. I suggest you ping Amar and ask him to add a rewrite rule.
