[PATCH] eng: Add design group requirement item type
Fri Jan 15 05:13:26 UTC 2021
On 15/01/2021 04:31, Chris Johns wrote:
> On 14/1/21 4:04 pm, Sebastian Huber wrote:
>> On 14/01/2021 03:34, Chris Johns wrote:
>>> On 13/1/21 9:40 pm, Sebastian Huber wrote:
>>>> +Design Group Requirement Item Type
>>>> +This type refines the :ref:`SpecTypeNonFunctionalRequirementItemType` through
>>>> +the ``non-functional-type`` attribute if the value is ``design-group``. This
>>>> +set of attributes specifies a design group requirement.  Design group
>>>> +requirements have an explicit reference to the associated Doxygen group
>>>> +specified by the ``identifier`` attribute.  Design group requirements have an
>>>> +implicit validation by inspection method.  The qualification toolchain shall
>>>> +perform the inspection and check that the specified Doxygen group exists in the
>>>> +software source code. All explicit attributes shall be specified. The explicit
>>>> +attributes for this type are:
>>> Could you please explain the links between doxygen and the spec files? Are there
>>> other link for other reasons?
>> What do you mean with links? There are no URL references between Doxygen and the
>> specification if this is what you mean. The design group items are necessary to
>> place header files which only contain API elements into implementation groups.
>> An example is <rtems/rtems/part.h>. This header file should not be included by
>> the user directly, however, the header file itself contains only API elements.
>> It is in the RTEMSImplClassicPartition group:
>> https://git.rtems.org/rtems/tree/cpukit/include/rtems/rtems/part.h#n6
>> This group is specified by:
>> https://git.rtems.org/rtems-central/tree/spec/rtems/part/req/group.yml
> Oh, is this is use when generating the API header?
Yes, this is used to generate the API header. You need a specification
item for everything in the generated file.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
