[PATCH] bsp/imx: Fix system counter init for imx6
Mon Jan 18 21:45:54 UTC 2021
On 18/1/21 8:05 pm, Christian MAUDERER wrote:
> I want to backport that patch to RTEMS 5 too because this problem occurred
> multiple times on the mailing list. If that is OK I'll create a separate ticket
> for RTEMS 5 that describes that problem. For RTEMS 6 it should finally be the
> last step to closing the "add i.MX6UL" ticket.
This is OK for RTEMS 5. Please create the ticket and push the change when you
are ready.
Thanks
