[PATCH] Improve file header comment in generated files
Sebastian Huber
Tue Jan 19 06:01:00 UTC 2021
c-user/config/bdbuf.rst | 10 +++++++---
c-user/config/bsp-related.rst | 10 +++++++---
c-user/config/classic-api.rst | 10 +++++++---
c-user/config/classic-init-task.rst | 10 +++++++---
c-user/config/device-driver.rst | 10 +++++++---
c-user/config/event-record.rst | 10 +++++++---
c-user/config/filesystem.rst | 10 +++++++---
c-user/config/general.rst | 10 +++++++---
c-user/config/idle-task.rst | 10 +++++++---
c-user/config/mpci.rst | 10 +++++++---
c-user/config/posix-api.rst | 10 +++++++---
c-user/config/posix-init-thread.rst | 10 +++++++---
c-user/config/scheduler-general.rst | 10 +++++++---
c-user/config/task-stack-alloc.rst | 10 +++++++---
c-user/event/directives.rst | 10 +++++++---
c-user/event/introduction.rst | 10 +++++++---
c-user/io/directives.rst | 10 +++++++---
c-user/io/introduction.rst | 10 +++++++---
c-user/object-services/directives.rst | 10 +++++++---
c-user/object-services/introduction.rst | 10 +++++++---
c-user/partition/directives.rst | 10 +++++++---
c-user/partition/introduction.rst | 10 +++++++---
c-user/timer/directives.rst | 10 +++++++---
c-user/timer/introduction.rst | 10 +++++++---
eng/req/items.rst | 10 +++++++---
25 files changed, 175 insertions(+), 75 deletions(-)
diff --git a/c-user/config/bdbuf.rst b/c-user/config/bdbuf.rst
index 06399e0..5a3360f 100644
--- a/c-user/config/bdbuf.rst
+++ b/c-user/config/bdbuf.rst
@@ -8,11 +8,15 @@
.. worded better please post a report or patch to an RTEMS mailing list
.. or raise a bug report:
-.. https://docs.rtems.org/branches/master/user/support/bugs.html
+.. https://www.rtems.org/support/bugs.html
-.. For information on updating and regenerating please refer to:
+.. For information on updating and regenerating please refer to the How-To
+.. section in the Software Requirements Engineering chapter of the
+.. RTEMS Software Engineering manual. The manual is provided as a part of
+.. a release. For development sources please refer to the online
+.. documentation at:
-.. https://docs.rtems.org/branches/master/eng/req/howto.html
+.. https://docs.rtems.org
.. Generated from spec:/acfg/if/group-bdbuf
diff --git a/c-user/config/bsp-related.rst b/c-user/config/bsp-related.rst
index 3d0a3ca..f9052ee 100644
--- a/c-user/config/bsp-related.rst
+++ b/c-user/config/bsp-related.rst
@@ -8,11 +8,15 @@
.. Generated from spec:/acfg/if/group-bsp
diff --git a/c-user/config/classic-api.rst b/c-user/config/classic-api.rst
index e44716a..5976927 100644
--- a/c-user/config/classic-api.rst
+++ b/c-user/config/classic-api.rst
@@ -8,11 +8,15 @@
.. Generated from spec:/acfg/if/group-classic
diff --git a/c-user/config/classic-init-task.rst b/c-user/config/classic-init-task.rst
index b331e40..81ecfda 100644
--- a/c-user/config/classic-init-task.rst
+++ b/c-user/config/classic-init-task.rst
@@ -8,11 +8,15 @@
.. Generated from spec:/acfg/if/group-classicinit
diff --git a/c-user/config/device-driver.rst b/c-user/config/device-driver.rst
index 4fd8c71..b7c090b 100644
--- a/c-user/config/device-driver.rst
+++ b/c-user/config/device-driver.rst
@@ -8,11 +8,15 @@
.. Generated from spec:/acfg/if/group-devdrv
diff --git a/c-user/config/event-record.rst b/c-user/config/event-record.rst
index 48de243..f05b3a5 100644
--- a/c-user/config/event-record.rst
+++ b/c-user/config/event-record.rst
@@ -7,11 +7,15 @@
.. Generated from spec:/acfg/if/group-eventrecord
diff --git a/c-user/config/filesystem.rst b/c-user/config/filesystem.rst
index 1daea01..4d22668 100644
--- a/c-user/config/filesystem.rst
+++ b/c-user/config/filesystem.rst
@@ -8,11 +8,15 @@
.. Generated from spec:/acfg/if/group-filesystem
diff --git a/c-user/config/general.rst b/c-user/config/general.rst
index c2cb349..a58b1f4 100644
--- a/c-user/config/general.rst
+++ b/c-user/config/general.rst
@@ -8,11 +8,15 @@
.. Generated from spec:/acfg/if/group-general
diff --git a/c-user/config/idle-task.rst b/c-user/config/idle-task.rst
index f115dae..5bc2d3a 100644
--- a/c-user/config/idle-task.rst
+++ b/c-user/config/idle-task.rst
@@ -8,11 +8,15 @@
.. Generated from spec:/acfg/if/group-idle
diff --git a/c-user/config/mpci.rst b/c-user/config/mpci.rst
index e0fbe1d..8b394af 100644
--- a/c-user/config/mpci.rst
+++ b/c-user/config/mpci.rst
@@ -8,11 +8,15 @@
.. Generated from spec:/acfg/if/group-mpci
diff --git a/c-user/config/posix-api.rst b/c-user/config/posix-api.rst
index aa44467..04ee2f3 100644
--- a/c-user/config/posix-api.rst
+++ b/c-user/config/posix-api.rst
@@ -8,11 +8,15 @@
.. Generated from spec:/acfg/if/group-posix
diff --git a/c-user/config/posix-init-thread.rst b/c-user/config/posix-init-thread.rst
index 4c49bdd..dd9e692 100644
--- a/c-user/config/posix-init-thread.rst
+++ b/c-user/config/posix-init-thread.rst
@@ -8,11 +8,15 @@
.. Generated from spec:/acfg/if/group-posixinit
diff --git a/c-user/config/scheduler-general.rst b/c-user/config/scheduler-general.rst
index 5478e84..edabad1 100644
--- a/c-user/config/scheduler-general.rst
+++ b/c-user/config/scheduler-general.rst
@@ -9,11 +9,15 @@
.. Generated from spec:/acfg/if/group-schedgeneral
diff --git a/c-user/config/task-stack-alloc.rst b/c-user/config/task-stack-alloc.rst
index 733ffd3..fadac68 100644
--- a/c-user/config/task-stack-alloc.rst
+++ b/c-user/config/task-stack-alloc.rst
@@ -8,11 +8,15 @@
.. Generated from spec:/acfg/if/group-stackalloc
diff --git a/c-user/event/directives.rst b/c-user/event/directives.rst
index ee43e0b..a0153d9 100644
--- a/c-user/event/directives.rst
+++ b/c-user/event/directives.rst
@@ -8,11 +8,15 @@
.. _EventManagerDirectives:
diff --git a/c-user/event/introduction.rst b/c-user/event/introduction.rst
index a153cf3..3d87d23 100644
--- a/c-user/event/introduction.rst
+++ b/c-user/event/introduction.rst
@@ -8,11 +8,15 @@
.. Generated from spec:/rtems/event/if/group
diff --git a/c-user/io/directives.rst b/c-user/io/directives.rst
index c0a50d4..89bf078 100644
--- a/c-user/io/directives.rst
+++ b/c-user/io/directives.rst
@@ -8,11 +8,15 @@
.. _IOManagerDirectives:
diff --git a/c-user/io/introduction.rst b/c-user/io/introduction.rst
index 706c711..897ef41 100644
--- a/c-user/io/introduction.rst
+++ b/c-user/io/introduction.rst
@@ -8,11 +8,15 @@
.. Generated from spec:/rtems/io/if/group
diff --git a/c-user/object-services/directives.rst b/c-user/object-services/directives.rst
index ce7a894..a6701fa 100644
--- a/c-user/object-services/directives.rst
+++ b/c-user/object-services/directives.rst
@@ -8,11 +8,15 @@
.. _ObjectServicesDirectives:
diff --git a/c-user/object-services/introduction.rst b/c-user/object-services/introduction.rst
index 6e7f4af..963fc7b 100644
--- a/c-user/object-services/introduction.rst
+++ b/c-user/object-services/introduction.rst
@@ -8,11 +8,15 @@
.. Generated from spec:/rtems/object/if/group
diff --git a/c-user/partition/directives.rst b/c-user/partition/directives.rst
index e28ef2e..5940ecc 100644
--- a/c-user/partition/directives.rst
+++ b/c-user/partition/directives.rst
@@ -8,11 +8,15 @@
.. _PartitionManagerDirectives:
diff --git a/c-user/partition/introduction.rst b/c-user/partition/introduction.rst
index 02ccf28..33b6a10 100644
--- a/c-user/partition/introduction.rst
+++ b/c-user/partition/introduction.rst
@@ -8,11 +8,15 @@
.. Generated from spec:/rtems/part/if/group
diff --git a/c-user/timer/directives.rst b/c-user/timer/directives.rst
index d65f263..4076839 100644
--- a/c-user/timer/directives.rst
+++ b/c-user/timer/directives.rst
@@ -8,11 +8,15 @@
.. _TimerManagerDirectives:
diff --git a/c-user/timer/introduction.rst b/c-user/timer/introduction.rst
index 78f6c67..3f0e2cf 100644
--- a/c-user/timer/introduction.rst
+++ b/c-user/timer/introduction.rst
@@ -8,11 +8,15 @@
.. Generated from spec:/rtems/timer/if/group
diff --git a/eng/req/items.rst b/eng/req/items.rst
index c160ee7..03bb691 100644
--- a/eng/req/items.rst
+++ b/eng/req/items.rst
@@ -7,11 +7,15 @@
.. _ReqEngSpecificationItems:
2.26.2
