[PATCH] Implement FreeBSD helper structures
Tue Jan 19 23:02:33 UTC 2021
Does this have a ticket?
I may have missed some email about this idea. It looks like a partial
compatibility for the freebsd busspace API?
On Tue, Jan 19, 2021 at 9:20 AM G S Niteesh Babu <niteesh.gs at gmail.com>
wrote:
> The following structures and functions have been implemented to
> make porting of driver from FreeBSD easier.
>  1) struct resource_spec
>  2) struct device
>  3) struct resource
>  4) device_get_softc
>  5) bus_alloc_resources
>  6) bus_alloc_resource
>  7) bus_alloc_resource_any
>  8) bus_space_read_1
>  9) bus_space_read_2
> 10) bus_space_read_4
> 11) bus_space_write_1
> 12) bus_space_write_2
> 13) bus_space_write_4
>  bsps/include/rtems/freebsd-compat/bus.h      | 122 +++++++++++++++++++
>  bsps/include/rtems/freebsd-compat/device.h   |  46 +++++++
>  bsps/include/rtems/freebsd-compat/resource.h |  46 +++++++
>  bsps/include/rtems/freebsd-compat/rman.h     |  65 ++++++++++
>  bsps/shared/rtems/freebsd-compat/bus.c       | 119 ++++++++++++++++++
>  spec/build/bsps/obj.yml                      |   1 +
>  6 files changed, 399 insertions(+)
>  create mode 100644 bsps/include/rtems/freebsd-compat/bus.h
>  create mode 100644 bsps/include/rtems/freebsd-compat/device.h
>  create mode 100644 bsps/include/rtems/freebsd-compat/resource.h
>  create mode 100644 bsps/include/rtems/freebsd-compat/rman.h
>  create mode 100644 bsps/shared/rtems/freebsd-compat/bus.c
> diff --git a/bsps/include/rtems/freebsd-compat/bus.h
> b/bsps/include/rtems/freebsd-compat/bus.h
> new file mode 100644
> index 0000000000..4bd3ab311a
> --- /dev/null
> +++ b/bsps/include/rtems/freebsd-compat/bus.h
> @@ -0,0 +1,122 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup FreeBSDCompat
> + * @brief
> + * Copyright (C) <2020> Niteesh Babu <niteesh.gs at gmail.com>
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifndef _FREEBSD_COMPAT_BUS_H
> +#define _FREEBSD_COMPAT_BUS_H
> +#include <sys/types.h>
> +#include "device.h"
> +#include "rman.h"
> +struct resource_spec {
> +  int type;
> +  int rid;
> +  int flags;
> +#define RESOURCE_SPEC_END {-1, 0, 0}
> + * Write a 1, 2, 4, or 8 byte quantity to bus space
> + * described by tag/handle/offset.
> +static inline void
> +bus_space_write_1(bus_space_tag_t bst, bus_space_handle_t bsh, bus_size_t
> ofs,
> +    uint8_t val)
> +  uint8_t volatile *bsp = (uint8_t volatile *)(bsh + ofs);
> +  *bsp = val;
> +static inline void
> +bus_space_write_2(bus_space_tag_t bst, bus_space_handle_t bsh, bus_size_t
> ofs,
> +    uint16_t val)
> +  uint16_t volatile *bsp = (uint16_t volatile *)(bsh + ofs);
> +  *bsp = val;
> +static inline void
> +bus_space_write_4(bus_space_tag_t bst, bus_space_handle_t bsh, bus_size_t
> ofs,
> +    uint32_t val)
> +  uint32_t volatile *bsp = (uint32_t volatile *)(bsh + ofs);
> +  *bsp = val;
> + * Read a 1, 2, 4, or 8 byte quantity from bus space
> +static inline uint8_t
> +bus_space_read_1(bus_space_tag_t tag, bus_space_handle_t handle,
> +     bus_size_t offset)
> +  return (*(volatile uint8_t *)(handle + offset));
> +static inline uint16_t
> +bus_space_read_2(bus_space_tag_t tag, bus_space_handle_t handle,
> +  return (*(volatile uint16_t *)(handle + offset));
> +static inline uint32_t
> +bus_space_read_4(bus_space_tag_t tag, bus_space_handle_t handle,
> +  return (*(volatile uint32_t *)(handle + offset));
> +bus_space_handle_t rman_get_bushandle(struct resource *);
> +bus_space_tag_t rman_get_bustag(struct resource *);
> +void   *device_get_softc(device_t dev);
> +int    bus_alloc_resources(device_t dev, struct resource_spec *rs,
> +          struct resource **res);
> +struct resource *bus_alloc_resource(device_t dev, int type, int *rid,
> +             rman_res_t start, rman_res_t end,
> +             rman_res_t count, u_int flags);
> +static __inline struct resource *
> +bus_alloc_resource_any(device_t dev, int type, int *rid, uint32_t flags)
> +  return (bus_alloc_resource(dev, type, rid, 0, ~0, 1, flags));
> +#endif /* _FREEBSD_COMPAT_BUS_H_ */
> diff --git a/bsps/include/rtems/freebsd-compat/device.h
> b/bsps/include/rtems/freebsd-compat/device.h
> index 0000000000..c646bb5986
> --- /dev/null
> +++ b/bsps/include/rtems/freebsd-compat/device.h
> @@ -0,0 +1,46 @@
> + * @file
> + * @brief
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#ifndef _FREEBSD_COMPAT_DEVICE_H
> +#define _FREEBSD_COMPAT_DEVICE_H
> +struct device {
> +    void *softc;
> +    unsigned int node;
> +typedef struct device *device_t;
> +#endif /* _FREEBSD_COMPAT_DEVICE_H */
> diff --git a/bsps/include/rtems/freebsd-compat/resource.h
> b/bsps/include/rtems/freebsd-compat/resource.h
> index 0000000000..f84fd60e21
> --- /dev/null
> +++ b/bsps/include/rtems/freebsd-compat/resource.h
> @@ -0,0 +1,46 @@
> + * @file
> + * @ingroup LIBFREEBSD
> + * @brief
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#ifndef _FREEBSD_COMPAT_RESOURCE_H
> +#define _FREEBSD_COMPAT_RESOURCE_H
> +#define SYS_RES_IRQ 1
> +#define SYS_RES_DRQ 2
> +#define SYS_RES_MEMORY 3
> +#define SYS_RES_IOPORT 4
> +#define SYS_RES_GPIO 5
> +#endif /* _FREEBSD_COMPAT_RESOURCE_H */
> diff --git a/bsps/include/rtems/freebsd-compat/rman.h
> b/bsps/include/rtems/freebsd-compat/rman.h
> index 0000000000..cf359789e6
> --- /dev/null
> +++ b/bsps/include/rtems/freebsd-compat/rman.h
> @@ -0,0 +1,65 @@
> + * @file
> + * @brief
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#ifndef _FREEBSD_COMPAT_RMAN_H
> +#define _FREEBSD_COMPAT_RMAN_H
> +#include <stdint.h>
> +typedef uint32_t bus_size_t;
> + * Access methods for bus resources and address space.
> +typedef int       bus_space_tag_t;
> +typedef uintptr_t bus_space_handle_t;
> +#define        RF_ALLOCATED    0x0001  /* resource has been reserved */
> +#define        RF_ACTIVE       0x0002  /* resource allocation has been
> activated */
> +#define        RF_SHAREABLE    0x0004  /* resource permits
> contemporaneous sharing */
> +#define        RF_SPARE1       0x0008
> +#define        RF_SPARE2       0x0010
> +#define        RF_FIRSTSHARE   0x0020  /* first in sharing list */
> +#define        RF_PREFETCHABLE 0x0040  /* resource is prefetchable */
> +#define        RF_OPTIONAL     0x0080  /* for bus_alloc_resources() */
> +#define        RF_UNMAPPED     0x0100  /* don't map resource when
> activating */
> +struct resource {
> +  bus_space_tag_t     r_bustag;
> +  bus_space_handle_t  r_bushandle;/* bus_space handle */
> +#endif /* _FREEBSD_COMPAT_RMAN_H */
> diff --git a/bsps/shared/rtems/freebsd-compat/bus.c
> b/bsps/shared/rtems/freebsd-compat/bus.c
> index 0000000000..7ce91b80e6
> --- /dev/null
> +++ b/bsps/shared/rtems/freebsd-compat/bus.c
> @@ -0,0 +1,119 @@
> + * @file
> + * @brief
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#include <rtems/bspIo.h>
> +#include <libfdt.h>
> +#include <stdlib.h>
> +#include <string.h>
> +#include <assert.h>
> +#include <errno.h>
> +#include <ofw/ofw.h>
> +#include <rtems/freebsd-compat/bus.h>
> +#include <rtems/freebsd-compat/resource.h>
> +typedef unsigned int u_int;
> + * @brief Return the device's softc field
> + * The softc is allocated and zeroed when a driver is attached, based
> + * on the size field of the driver.
> +void *
> +device_get_softc(device_t dev)
> +  return (dev->softc);
> +bus_space_handle_t
> +rman_get_bushandle(struct resource *r)
> +  return (r->r_bushandle);
> +bus_space_tag_t
> +rman_get_bustag(struct resource *r)
> +  return (r->r_bustag);
> +int
> +bus_alloc_resources(device_t dev, struct resource_spec *rs,
> +  int i;
> +  for (i = 0; rs[i].type != -1; i++) {
> +    res[i] = bus_alloc_resource_any(dev,
> +    rs[i].type, &rs[i].rid, rs[i].flags);
> +    if (res[i] == NULL) {
> +      return (-1);
> +  return (0);
> +struct resource *
> +bus_alloc_resource(device_t dev, int type, int *rid, rman_res_t start,
> +    rman_res_t end, rman_res_t count, u_int flags)
> +  int node;
> +  int rv;
> +  rtems_ofw_memory_area reg[*rid + 1];
> +  struct resource *res;
> +  node = dev->node;
> +   * We only support querying register values from FDT.
> +  assert(type == SYS_RES_MEMORY);
> +  res = (struct resource *)malloc(sizeof(struct resource));
> +  if (res != NULL) {
> +    rv = rtems_ofw_get_reg(node, &reg[0], sizeof(reg));
> +    if (rv == -1) {
> +      return NULL;
> +    res->r_bushandle = reg[*rid].start;
> +  return (res);
> diff --git a/spec/build/bsps/obj.yml b/spec/build/bsps/obj.yml
> index 0ea07fc83d..7cf12cd27a 100644
> --- a/spec/build/bsps/obj.yml
> +++ b/spec/build/bsps/obj.yml
> @@ -109,4 +109,5 @@ source:
>  - bsps/shared/start/bootcard.c
>  - bsps/shared/rtems-version.c
>  - bsps/shared/ofw/ofw.c
> +- bsps/shared/rtems/freebsd-compat/bus.c
>  type: build
> 2.17.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210119/1dc7f404/attachment-0001.html>
