Add "CONSTRAINTS" section do directive documentation?
Sebastian Huber
Wed Jan 20 10:48:51 UTC 2021
Hello,
I would like to add a "CONSTRAINTS" section to the directive
documentation (after or before the NOTES). For example in the NOTES of
rtems_timer_create()
https://docs.rtems.org/branches/master/c-user/timer/directives.html#rtems-timer-create
we have "This directive may cause the calling task to be preempted due
to an obtain and release of the object allocator mutex.".
I would like to move this to a CONSTRAINTS section and use a link in the
specification to indicate this. Other examples for constraints are:
* the allowed environment to call the directive (task context, interrupt
context, device driver initialization, etc.)
* dependency on a clock tick (directives with RTEMS_WAIT and a timeout)
Due to the links in the specification we can generate list like this
automatically:
https://docs.rtems.org/branches/master/c-user/interrupt/operations.html#directives-allowed-from-an-isr
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
