gdb on CentOS was Re: Fwd: [rtems-source-builder commit] 6/7: Update unstable RTEMS 6/7 tool chain
Joel Sherrill
joel at rtems.org
Thu Jan 21 14:29:39 UTC 2021
This is now supposed to be fixed on the gdb master. Does the RSB need to be
moved forward?
--joel
On Wed, Jan 20, 2021 at 5:32 PM Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Jan 20, 2021, 5:04 PM Chris Johns <chrisj at rtems.org> wrote:
>> On 21/1/21 3:40 am, Joel Sherrill wrote:
>> > On Sun, Jan 17, 2021 at 11:20 PM Sebastian Huber
>> > <sebastian.huber at embedded-brains.de <mailto:
>> sebastian.huber at embedded-brains.de>>
>> > wrote:
>> > On 17/01/2021 21:23, Joel Sherrill wrote:
>> > > Does this fix the build failure for what looks to be all 6
>> toolchains
>> > > over the weekend?
>> > No, there seems to be a CentOS 7.9 specific issue with the GDB
>> build:
>> https://sourceware.org/pipermail/gdb-patches/2021-January/175152.html
>> https://sourceware.org/pipermail/gdb-patches/2021-January/175152.html>
>> > https://sourceware.org/bugzilla/show_bug.cgi?id=27219
>> > <https://sourceware.org/bugzilla/show_bug.cgi?id=27219>
>> > I attached a patch to that.
>> Will there be a patch for the RSB to apply the patch?
> The RSB for 6 is using the gdb head. This just needs to be merged.
>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210121/ff8ec9f5/attachment.html>
