[PATCH] Improve file header comment in generated files
    Sebastian Huber
    Fri Jan 22 15:06:01 UTC 2021
 cpukit/doxygen/appl-config.h                        | 10 +++++++---
 cpukit/include/rtems.h                              | 10 +++++++---
 cpukit/include/rtems/config.h                       | 10 +++++++---
 cpukit/include/rtems/io.h                           | 10 +++++++---
 cpukit/include/rtems/rtems/attr.h                   | 10 +++++++---
 cpukit/include/rtems/rtems/config.h                 | 10 +++++++---
 cpukit/include/rtems/rtems/event.h                  | 10 +++++++---
 cpukit/include/rtems/rtems/modes.h                  | 10 +++++++---
 cpukit/include/rtems/rtems/object.h                 | 10 +++++++---
 cpukit/include/rtems/rtems/options.h                | 10 +++++++---
 cpukit/include/rtems/rtems/part.h                   | 10 +++++++---
 cpukit/include/rtems/rtems/status.h                 | 10 +++++++---
 cpukit/include/rtems/rtems/timer.h                  | 10 +++++++---
 cpukit/include/rtems/rtems/types.h                  | 10 +++++++---
 cpukit/include/rtems/score/basedefs.h               | 10 +++++++---
 testsuites/validation/tc-message-construct-errors.c | 10 +++++++---
 testsuites/validation/tc-part-performance.c         | 10 +++++++---
 testsuites/validation/tc-task-construct-errors.c    | 10 +++++++---
 testsuites/validation/ts-performance-0.c            | 10 +++++++---
 testsuites/validation/ts-validation-0.c             | 10 +++++++---
 20 files changed, 140 insertions(+), 60 deletions(-)
diff --git a/cpukit/doxygen/appl-config.h b/cpukit/doxygen/appl-config.h
index 4774972600..092e02ccca 100644
--- a/cpukit/doxygen/appl-config.h
+++ b/cpukit/doxygen/appl-config.h
@@ -33,11 +33,15 @@
  * worded better please post a report or patch to an RTEMS mailing list
  * or raise a bug report:
- * https://docs.rtems.org/branches/master/user/support/bugs.html
+ * https://www.rtems.org/bugs.html
- * For information on updating and regenerating please refer to:
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual.  The manual is provided as a part of
+ * a release.  For development sources please refer to the online
+ * documentation at:
- * https://docs.rtems.org/branches/master/eng/req/howto.html
+ * https://docs.rtems.org
diff --git a/cpukit/include/rtems.h b/cpukit/include/rtems.h
index d1b1452000..29716e9eaf 100644
--- a/cpukit/include/rtems.h
+++ b/cpukit/include/rtems.h
@@ -40,11 +40,15 @@
 /* Generated from spec:/rtems/if/header */
diff --git a/cpukit/include/rtems/config.h b/cpukit/include/rtems/config.h
index 3fda60289f..cc54a25d9e 100644
--- a/cpukit/include/rtems/config.h
+++ b/cpukit/include/rtems/config.h
@@ -40,11 +40,15 @@
 /* Generated from spec:/rtems/config/if/header */
diff --git a/cpukit/include/rtems/io.h b/cpukit/include/rtems/io.h
index 92ffb6d51b..445f24cb78 100644
--- a/cpukit/include/rtems/io.h
+++ b/cpukit/include/rtems/io.h
@@ -40,11 +40,15 @@
 /* Generated from spec:/rtems/io/if/header */
diff --git a/cpukit/include/rtems/rtems/attr.h b/cpukit/include/rtems/rtems/attr.h
index bf35a2c4af..baea36aa9f 100644
--- a/cpukit/include/rtems/rtems/attr.h
+++ b/cpukit/include/rtems/rtems/attr.h
@@ -38,11 +38,15 @@
 /* Generated from spec:/rtems/attr/if/header */
diff --git a/cpukit/include/rtems/rtems/config.h b/cpukit/include/rtems/rtems/config.h
index cd1791ebae..76a4a758b9 100644
--- a/cpukit/include/rtems/rtems/config.h
+++ b/cpukit/include/rtems/rtems/config.h
@@ -39,11 +39,15 @@
 /* Generated from spec:/rtems/config/if/header-2 */
diff --git a/cpukit/include/rtems/rtems/event.h b/cpukit/include/rtems/rtems/event.h
index 78d84213f7..8aa115762d 100644
--- a/cpukit/include/rtems/rtems/event.h
+++ b/cpukit/include/rtems/rtems/event.h
@@ -40,11 +40,15 @@
 /* Generated from spec:/rtems/event/if/header */
diff --git a/cpukit/include/rtems/rtems/modes.h b/cpukit/include/rtems/rtems/modes.h
index 8c3379d909..b711b119b6 100644
--- a/cpukit/include/rtems/rtems/modes.h
+++ b/cpukit/include/rtems/rtems/modes.h
@@ -38,11 +38,15 @@
 /* Generated from spec:/rtems/mode/if/header */
diff --git a/cpukit/include/rtems/rtems/object.h b/cpukit/include/rtems/rtems/object.h
index 3f879a169b..aee6d5c3ed 100644
--- a/cpukit/include/rtems/rtems/object.h
+++ b/cpukit/include/rtems/rtems/object.h
@@ -38,11 +38,15 @@
 /* Generated from spec:/rtems/object/if/header */
diff --git a/cpukit/include/rtems/rtems/options.h b/cpukit/include/rtems/rtems/options.h
index d8431c151d..60d90f997e 100644
--- a/cpukit/include/rtems/rtems/options.h
+++ b/cpukit/include/rtems/rtems/options.h
@@ -38,11 +38,15 @@
 /* Generated from spec:/rtems/option/if/header */
diff --git a/cpukit/include/rtems/rtems/part.h b/cpukit/include/rtems/rtems/part.h
index aeb4de64c5..5a747f428b 100644
--- a/cpukit/include/rtems/rtems/part.h
+++ b/cpukit/include/rtems/rtems/part.h
@@ -40,11 +40,15 @@
 /* Generated from spec:/rtems/part/if/header */
diff --git a/cpukit/include/rtems/rtems/status.h b/cpukit/include/rtems/rtems/status.h
index 9b32a85205..35752442d9 100644
--- a/cpukit/include/rtems/rtems/status.h
+++ b/cpukit/include/rtems/rtems/status.h
@@ -39,11 +39,15 @@
 /* Generated from spec:/rtems/status/if/header */
diff --git a/cpukit/include/rtems/rtems/timer.h b/cpukit/include/rtems/rtems/timer.h
index 3d454e39ec..fe22eef39d 100644
--- a/cpukit/include/rtems/rtems/timer.h
+++ b/cpukit/include/rtems/rtems/timer.h
@@ -40,11 +40,15 @@
 /* Generated from spec:/rtems/timer/if/header */
diff --git a/cpukit/include/rtems/rtems/types.h b/cpukit/include/rtems/rtems/types.h
index 32b45113c8..a058eedea1 100644
--- a/cpukit/include/rtems/rtems/types.h
+++ b/cpukit/include/rtems/rtems/types.h
@@ -38,11 +38,15 @@
 /* Generated from spec:/rtems/type/if/header */
diff --git a/cpukit/include/rtems/score/basedefs.h b/cpukit/include/rtems/score/basedefs.h
index 0081dbfbe4..d017ffa96a 100644
--- a/cpukit/include/rtems/score/basedefs.h
+++ b/cpukit/include/rtems/score/basedefs.h
@@ -40,11 +40,15 @@
 /* Generated from spec:/rtems/basedefs/if/header */
diff --git a/testsuites/validation/tc-message-construct-errors.c b/testsuites/validation/tc-message-construct-errors.c
index d71e427b63..f2fa30638b 100644
--- a/testsuites/validation/tc-message-construct-errors.c
+++ b/testsuites/validation/tc-message-construct-errors.c
@@ -37,11 +37,15 @@
 #ifdef HAVE_CONFIG_H
diff --git a/testsuites/validation/tc-part-performance.c b/testsuites/validation/tc-part-performance.c
index 46f48c7bf5..5c3148edcc 100644
--- a/testsuites/validation/tc-part-performance.c
+++ b/testsuites/validation/tc-part-performance.c
@@ -37,11 +37,15 @@
diff --git a/testsuites/validation/tc-task-construct-errors.c b/testsuites/validation/tc-task-construct-errors.c
index 4dfd12dbb8..bbaaf04ba2 100644
--- a/testsuites/validation/tc-task-construct-errors.c
+++ b/testsuites/validation/tc-task-construct-errors.c
@@ -37,11 +37,15 @@
diff --git a/testsuites/validation/ts-performance-0.c b/testsuites/validation/ts-performance-0.c
index cc61547ef9..1fb15ecfce 100644
--- a/testsuites/validation/ts-performance-0.c
+++ b/testsuites/validation/ts-performance-0.c
@@ -37,11 +37,15 @@
diff --git a/testsuites/validation/ts-validation-0.c b/testsuites/validation/ts-validation-0.c
index 1b5ea795cd..c56bd5ea81 100644
--- a/testsuites/validation/ts-validation-0.c
+++ b/testsuites/validation/ts-validation-0.c
@@ -37,11 +37,15 @@
2.26.2
