Report on failing tests with thread stack protection and their resolution.
Utkarsh Rai utkarsh.rai60 at gmail.com
Sun Jan 24 14:59:23 UTC 2021
On Sat, Jan 23, 2021 at 9:29 PM Joel Sherrill <joel at rtems.org> wrote:
> On Sat, Jan 23, 2021, 12:28 AM Utkarsh Rai <utkarsh.rai60 at gmail.com>
> wrote:
>> On Mon, Dec 7, 2020 at 8:00 AM Utkarsh Rai <utkarsh.rai60 at gmail.com>
>> wrote:
>>> On Thu, Dec 3, 2020 at 10:22 PM Gedare Bloom <gedare at rtems.org> wrote:
>>>> On Wed, Dec 2, 2020 at 5:53 PM Utkarsh Rai <utkarsh.rai60 at gmail.com>
>>>> wrote:
>>>>> Hello,
>>>>> As discussed in this
>>>>> <https://lists.rtems.org/pipermail/devel/2020-November/063341.html> thread,
>>>>> I have compiled a list of the tests that deal with inter stack
>>>>> communication and fail with the thread stack protection option. Most of
>>>>> these tests pass when, as Sebastian suggested and had provided a
>>>>> wonderful example, I disable memory protection at places where contents of
>>>>> different thread stacks are accessed by the current thread. There are a few
>>>>> tests that still fail due to inter-stack access in the application code
>>>>> itself.
>>>>> The changes I have made are -
>>>>> diff --git a/bsps/arm/realview-pbx-a9/mmu/bsp-set-mmu-attr.c
>>>>> b/bsps/arm/realview-pbx-a9/mmu/bsp-set-mmu-attr.c
>>>>> index c176d4b8c5..a45b175395 100644
>>>>> --- a/bsps/arm/realview-pbx-a9/mmu/bsp-set-mmu-attr.c
>>>>> +++ b/bsps/arm/realview-pbx-a9/mmu/bsp-set-mmu-attr.c
>>>>> @@ -1,15 +1,49 @@
>>>>>  #include <bsp/arm-cp15-start.h>
>>>>>  #include <rtems/score/memoryprotection.h>
>>>>> +#include <rtems/score/threadimpl.h>
>>>>>  #include <libcpu/arm-cp15.h>
>>>>> +bool set_memory_flags(Thread_Control* thread, void* arg)
>>>>> +  uintptr_t begin;
>>>>> +  uintptr_t end;
>>>>> +  uint32_t flags;
>>>>> +  rtems_interrupt_level irq_level;
>>>>> +  Thread_Control *executing;
>>>>> +  executing = _Thread_Executing;
>>>>> +  if(thread !=  executing) {
>>>> This is not concurrency-safe. By time the check happens, or following
>>>> code happens, the thread could become executing.
>>>>> +    flags = *( uint32_t *)( arg );
>>>>> +    begin = thread->Start.Initial_stack.area;
>>>>> +    end = begin + thread->Start.Initial_stack.size;
>>>>> +    rtems_interrupt_disable(irq_level);
>>>>> +    arm_cp15_set_translation_table_entries(begin, end, flags);
>>>>> +    rtems_interrupt_enable(irq_level);
>>>>> +  return false;
>>>> why -- what does the return value mean?
>>> While iterating over threads, if the visitor returns true the iteration
>>> stops.
>>>>> +rtems_status_code _Memory_protection_Enable( void )
>>>>> +  uint32_t access_flags;
>>>>> +  access_flags = translate_flags(  RTEMS_NO_ACCESS );
>>>>> +  _Thread_Iterate( set_memory_flags, &access_flags );
>>>>> +  return RTEMS_SUCCESSFUL; // check the return values for iterating
>>>>> function and current method.
>>>>> +rtems_status_code _Memory_protection_Disable( void )
>>>>> +  access_flags = translate_flags(  RTEMS_READ_WRITE );
>>>>> \ No newline at end of file
>>>>> diff --git a/cpukit/include/rtems/score/coremsgimpl.h
>>>>> b/cpukit/include/rtems/score/coremsgimpl.h
>>>>> index e598dce96a..3719a3d3c8 100644
>>>>> --- a/cpukit/include/rtems/score/coremsgimpl.h
>>>>> +++ b/cpukit/include/rtems/score/coremsgimpl.h
>>>>> @@ -27,6 +27,10 @@
>>>>>  #include <rtems/score/threaddispatch.h>
>>>>>  #include <rtems/score/threadqimpl.h>
>>>>> +#if defined RTEMS_THREAD_STACK_PROTECTION
>>>>> + #include <rtems/score/memoryprotection.h>
>>>>> +#endif
>>>>>  #include <limits.h>
>>>>>  #include <string.h>
>>>>> @@ -586,7 +590,9 @@ RTEMS_INLINE_ROUTINE Thread_Control
>>>>> *_CORE_message_queue_Dequeue_receiver(
>>>>>    if ( the_thread == NULL ) {
>>>>>      return NULL;
>>>>> +  _Memory_protection_Disable();
>>>> I wonder if it is necessary to disable all protection, or can you just
>>>> disable the protection applied to 'the_thread' (or maybe to 'executing')?
>>> No, it is not necessary. I will make the changes.
>>>>> +#endif
>>>>>     *(size_t *) the_thread->Wait.return_argument = size;
>>>>>     the_thread->Wait.count = (uint32_t) submit_type;
>>>>> @@ -595,6 +601,9 @@ RTEMS_INLINE_ROUTINE Thread_Control
>>>>>      the_thread->Wait.return_argument_second.mutable_object,
>>>>>      size
>>>>> +  _Memory_protection_Enable();
>>>>> +#endif
>>>>>    _Thread_queue_Extract_critical(
>>>>>      &the_message_queue->Wait_queue.Queue,
>>>>> diff --git a/cpukit/posix/src/psignalunblockthread.c
>>>>> b/cpukit/posix/src/psignalunblockthread.c
>>>>> index 80a0f33a09..e0f8468de6 100644
>>>>> --- a/cpukit/posix/src/psignalunblockthread.c
>>>>> +++ b/cpukit/posix/src/psignalunblockthread.c
>>>>> @@ -24,6 +24,9 @@
>>>>>  #include <signal.h>
>>>>>  #include <rtems/score/isr.h>
>>>>> +#include <rtems/score/memoryprotection.h>
>>>>> +#endif
>>>>>  #include <rtems/score/watchdogimpl.h>
>>>>> @@ -205,6 +208,10 @@ bool _POSIX_signals_Unblock_thread(
>>>>>        the_info = (siginfo_t *) the_thread->Wait.return_argument;
>>>>> +_Memory_protection_Disable();
>>>>> +#endif
>>>>>        if ( !info ) {
>>>>>          the_info->si_signo = signo;
>>>>>          the_info->si_code = SI_USER;
>>>>> @@ -212,6 +219,9 @@ bool _POSIX_signals_Unblock_thread(
>>>>>        } else {
>>>>>          *the_info = *info;
>>>>> +_Memory_protection_Enable();
>>>>> +#endif
>>>>>        _Thread_queue_Extract_with_proxy( the_thread );
>>>>>        return _POSIX_signals_Unblock_thread_done( the_thread, api,
>>>>> true );
>>>>> diff --git a/cpukit/rtems/src/eventsurrender.c
>>>>> b/cpukit/rtems/src/eventsurrender.c
>>>>> index 49f77d2663..5de62ec292 100644
>>>>> --- a/cpukit/rtems/src/eventsurrender.c
>>>>> +++ b/cpukit/rtems/src/eventsurrender.c
>>>>> @@ -23,6 +23,10 @@
>>>>> +#endif
>>>>>  static void _Event_Satisfy(
>>>>>    Thread_Control  *the_thread,
>>>>>    Event_Control   *event,
>>>>> @@ -31,7 +35,13 @@ static void _Event_Satisfy(
>>>>>    event->pending_events = _Event_sets_Clear( pending_events,
>>>>> seized_events );
>>>>> +#endif
>>>>>    *(rtems_event_set *) the_thread->Wait.return_argument =
>>>>> seized_events;
>>>>> +#endif
>>>>>  static bool _Event_Is_blocking_on_event(
>>>>> diff --git a/cpukit/rtems/src/regionprocessqueue.c
>>>>> b/cpukit/rtems/src/regionprocessqueue.c
>>>>> index 4adaf66674..29b078a38c 100644
>>>>> --- a/cpukit/rtems/src/regionprocessqueue.c
>>>>> +++ b/cpukit/rtems/src/regionprocessqueue.c
>>>>> @@ -22,6 +22,10 @@
>>>>>  #include <rtems/score/status.h>
>>>>> +#endif
>>>>>  void _Region_Process_queue(
>>>>>    Region_Control *the_region
>>>>> @@ -63,8 +67,13 @@ void _Region_Process_queue(
>>>>>      if ( the_segment == NULL )
>>>>>        break;
>>>>> +#endif
>>>>>      *(void **)the_thread->Wait.return_argument = the_segment;
>>>>> +#endif
>>>>>      _Thread_queue_Extract( the_thread );
>>>>>      the_thread->Wait.return_code = STATUS_SUCCESSFUL;
>>>>> _______________________________________________
>>>>> devel mailing list
>>>>> devel at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/devel
>> Hello,
>> Sorry for the long break but my university examinations had put me off
>> track. A quick review of work done till now -
>> The tests where inter-stack access takes place were identified (the test
>> report is attached in this thread) and the concerning mechanisms were made
>> thread-stack protection compatible. The current method of disabling memory
>> protection for these
>> regions uses _Thread_Iterate() which is bad in terms of performance, I
>> have modified it by disabling the memory protection solely for
>> 'the_thread'. The issue that remains is of User extension iterators, in
>> particular of nested iterators. My idea is to disable memory protection in
>> places during iteration where inter-stack access takes place.  The problem
>> is determining the region for which memory protection needs to be disabled.
>> One way to get around this would be by disabling memory protection for all
>> the stacks, in a blanket-based manner. The other possibility is to access
>> the last blocked thread and disable memory protection just for the stack of
>> this thread (as inter-stack access of the previously blocked thread takes
>> place during iteration). How to get access to the queue of blocked threads?
>> And is this method feasible?
> Is it possible to identify the reasons that threads fail this check? I'm
> suspicious there are a few places where disabling checks entirely for the
> scope of an RTEMS method is needed. Running the stack usage report would
> seem to be a case for that.
 Ok, this is an area that I have not looked into.
> But other cases might be writing method results like a message buffer on a
> stack would need to get access to a specific task just long enough to write
> the result.
I was able to identify these regions, Sebastian had provided me with a
nice patch
<https://lists.rtems.org/pipermail/devel/2020-November/063354.html>that
fixed cases like these.
Random cases in applications can't be generally solved but RTEMS itself is
> a finite set of code. Identifying the reasons RTEMS needs access and
> handling those might eliminate most of these. Fix one case and multiple
> tests may pass.
> Also important to know when these cases occur in RTEMS.
> Just a thought.
I believe the test report documents most of the important cases where
inter-stack access place 'inside' the RTEMS kernel code. The case that
remains to be addressed is of User extension iterators.
> --joel
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210124/3f6ebdf6/attachment-0001.html>
