[PATCH] libcsupport: Add no_reg_make_node as a mount option to the mount table
chrisj at rtems.org
chrisj at rtems.org
Mon Jan 25 01:10:22 UTC 2021
- Add the bool flag no_reg_make_mode to the mount table so a file
system can indicate creating regular files is not done by
use the mknod handler. The file system will handle creating a
file node in the open handler.
- Note, the mount option is an enum which means there is only one
exclusive option supported. As a result no encapsulation is
provided and file systems need to set no_reg_make_node directly.
Closes #4222
cpukit/include/rtems/libio.h | 1 +
cpukit/libcsupport/src/open.c | 13 ++++++++-----
2 files changed, 9 insertions(+), 5 deletions(-)
diff --git a/cpukit/include/rtems/libio.h b/cpukit/include/rtems/libio.h
index 18141c3d3c..d4042691c8 100644
--- a/cpukit/include/rtems/libio.h
+++ b/cpukit/include/rtems/libio.h
@@ -1613,6 +1613,7 @@ struct rtems_filesystem_mount_table_entry_tt {
rtems_filesystem_global_location_t *mt_fs_root;
bool mounted;
bool writeable;
+ bool no_reg_make_node;
const rtems_filesystem_limits_and_options_t *pathconf_limits_and_options;
diff --git a/cpukit/libcsupport/src/open.c b/cpukit/libcsupport/src/open.c
index bdb50240b4..c238dce5f7 100644
--- a/cpukit/libcsupport/src/open.c
+++ b/cpukit/libcsupport/src/open.c
@@ -34,7 +34,7 @@ static void create_regular_file(
int rv = 0;
- const rtems_filesystem_location_info_t *currentloc =
+ const rtems_filesystem_location_info_t *currentloc =
rtems_filesystem_eval_path_get_currentloc( ctx );
const char *token = rtems_filesystem_eval_path_get_token( ctx );
size_t tokenlen = rtems_filesystem_eval_path_get_tokenlen( ctx );
@@ -85,10 +85,15 @@ static int do_open(
| (make ? RTEMS_FS_MAKE : 0)
| (exclusive ? RTEMS_FS_EXCLUSIVE : 0);
rtems_filesystem_eval_path_context_t ctx;
+ const rtems_filesystem_location_info_t *currentloc;
+ bool create_reg_file;
rtems_filesystem_eval_path_start( &ctx, path, eval_flags );
- if ( rtems_filesystem_eval_path_has_token( &ctx ) ) {
+ currentloc = rtems_filesystem_eval_path_get_currentloc( &ctx );
+ create_reg_file = !currentloc->mt_entry->no_reg_make_node;
+ if ( create_reg_file && rtems_filesystem_eval_path_has_token( &ctx ) ) {
create_regular_file( &ctx, mode );
@@ -99,11 +104,9 @@ static int do_open(
#endif
if ( write_access || open_dir ) {
- rtems_filesystem_eval_path_get_currentloc( &ctx );
mode_t type = rtems_filesystem_location_type( currentloc );
- if ( write_access && S_ISDIR( type ) ) {
+ if ( create_reg_file && write_access && S_ISDIR( type ) ) {
rtems_filesystem_eval_path_error( &ctx, EISDIR );
2.24.1
