[PATCH] cpucounter: Increase conversion accuracy
Tue Jan 26 15:11:03 UTC 2021
The maximum frequency is UINT32_MAX.  Converted to a uint64_t variable
it can be shifted by 32.  The addition does not overflow since bin_per_s
- 1 is UINT32_MAX.
 cpukit/sapi/src/cpucounterconverter.c | 7 ++++---
 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/cpukit/sapi/src/cpucounterconverter.c b/cpukit/sapi/src/cpucounterconverter.c
index 08a745dfc6..88403987d2 100644
--- a/cpukit/sapi/src/cpucounterconverter.c
+++ b/cpukit/sapi/src/cpucounterconverter.c
@@ -42,19 +42,20 @@ int64_t rtems_counter_ticks_to_sbintime( rtems_counter_ticks ticks )
 rtems_counter_ticks rtems_counter_sbintime_to_ticks( int64_t sbt )
-  return (rtems_counter_ticks) (((uint64_t) sbt * from_sbt_scaler) >> 31);
+  return (rtems_counter_ticks) (((uint64_t) sbt * from_sbt_scaler) >> 32);
 void rtems_counter_initialize_converter( uint32_t frequency )
   uint64_t ns_per_s = UINT64_C(1000000000);
   uint64_t bin_per_s = UINT64_C(1) << 32;
+  uint64_t bin_freq = (uint64_t) frequency << 32;
   to_ns_scaler = ((ns_per_s << 32) + frequency - 1) / frequency;
-  from_ns_scaler = ((UINT64_C(1) << 32) * frequency + ns_per_s - 1) / ns_per_s;
+  from_ns_scaler = (bin_freq + ns_per_s - 1) / ns_per_s;
   to_sbt_scaler = ((bin_per_s << 31) + frequency - 1) / frequency;
-  from_sbt_scaler = ((UINT64_C(1) << 31) * frequency + bin_per_s - 1) / bin_per_s;
+  from_sbt_scaler = (bin_freq + bin_per_s - 1) / bin_per_s;
 static void rtems_counter_sysinit( void )
2.26.2
