[PATCH 1/6] nios2: Fix ISR dispatch variants
Sebastian Huber
Wed Jan 27 09:13:30 UTC 2021
The thread dispatch disabled level moved to _Per_CPU_Information some
time ago.
cpukit/score/cpu/nios2/nios2-eic-il-low-level.S | 7 +++----
cpukit/score/cpu/nios2/nios2-eic-rsie-low-level.S | 9 ++++-----
2 files changed, 7 insertions(+), 9 deletions(-)
diff --git a/cpukit/score/cpu/nios2/nios2-eic-il-low-level.S b/cpukit/score/cpu/nios2/nios2-eic-il-low-level.S
index 61eaa8cde6..a8045d74df 100644
--- a/cpukit/score/cpu/nios2/nios2-eic-il-low-level.S
+++ b/cpukit/score/cpu/nios2/nios2-eic-il-low-level.S
@@ -41,7 +41,6 @@
.section .text
.extern _Per_CPU_Information
- .extern _Thread_Dispatch_disable_level
.extern _Nios2_Thread_dispatch_disabled
.extern _Nios2_ISR_Status_interrupts_disabled
@@ -50,7 +49,7 @@
_Nios2_ISR_Dispatch_with_shadow_non_preemptive:
/* Load thread dispatch disable level */
- ldw r16, %gprel(_Thread_Dispatch_disable_level)(gp)
+ ldw r16, %gprel(_Per_CPU_Information + PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL)(gp)
/* Load high level handler address and argument */
ldw r8, 4(et)
@@ -58,7 +57,7 @@ _Nios2_ISR_Dispatch_with_shadow_non_preemptive:
/* Increment and store thread dispatch disable level */
addi r9, r16, 1
- stw r9, %gprel(_Thread_Dispatch_disable_level)(gp)
+ stw r9, %gprel(_Per_CPU_Information + PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL)(gp)
/* Call high level handler with argument */
callr r8
@@ -81,7 +80,7 @@ _Nios2_ISR_Dispatch_with_shadow_non_preemptive:
* problems if someone deletes or restarts the interrupted thread while
* we are in the thread dispatch helper.
- stw r16, %gprel(_Thread_Dispatch_disable_level)(gp)
+ stw r16, %gprel(_Per_CPU_Information + PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL)(gp)
/* Is thread dispatch allowed? */
bne r16, zero, no_thread_dispatch
diff --git a/cpukit/score/cpu/nios2/nios2-eic-rsie-low-level.S b/cpukit/score/cpu/nios2/nios2-eic-rsie-low-level.S
index fc11d335eb..4dd3749c45 100644
--- a/cpukit/score/cpu/nios2/nios2-eic-rsie-low-level.S
+++ b/cpukit/score/cpu/nios2/nios2-eic-rsie-low-level.S
@@ -40,7 +40,6 @@
.section .text
.globl _Nios2_ISR_Dispatch_with_shadow_preemptive
@@ -81,11 +80,11 @@ _Nios2_ISR_Dispatch_with_shadow_preemptive:
/* Increment ISR nest level and thread dispatch disable level */
ldw r9, %gprel(_Per_CPU_Information + PER_CPU_ISR_NEST_LEVEL)(gp)
- ldw r10, %gprel(_Thread_Dispatch_disable_level)(gp)
+ ldw r10, %gprel(_Per_CPU_Information + PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL)(gp)
addi r11, r9, 1
addi r10, r10, 1
stw r11, %gprel(_Per_CPU_Information + PER_CPU_ISR_NEST_LEVEL)(gp)
- stw r10, %gprel(_Thread_Dispatch_disable_level)(gp)
+ stw r10, %gprel(_Per_CPU_Information + PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL)(gp)
/* Switch to interrupt stack if necessary */
bne r9, zero, switch_to_interrupt_stack_done
@@ -114,11 +113,11 @@ switch_to_interrupt_stack_done:
/* Decrement ISR nest level and thread dispatch disable level */
subi r9, r9, 1
subi r10, r10, 1
stw r9, %gprel(_Per_CPU_Information + PER_CPU_ISR_NEST_LEVEL)(gp)
* Restore stack pointer. If the ISR nest level is greater than one,
2.26.2
