devel Digest, Vol 110, Issue 38
Niteesh G. S. niteesh.gs at gmail.com
Wed Jan 27 17:25:55 UTC 2021
> Date: Fri, 22 Jan 2021 04:28:37 +1100
> From: Chris Johns <chrisj at rtems.org>
> To: devel at rtems.org
> Subject: Re: [patch libBSD] dev/ofw: Use RTEMS OFW FDT implementation
> Message-ID: <d2cca4d0-f1fc-b93f-c30e-0c95ce4b410b at rtems.org>
> Content-Type: text/plain; charset=utf-8
> On 20/1/21 7:31 pm, G S Niteesh Babu wrote:
> > This commit modifies the OFW interface to the RTEMS FDT
> > implementation instead of the default FreeBSD.
> Which branch?
Did you mean which commit? If not can you please rephrase your question?
RTEMS OFW API implemented in this commit:
https://git.rtems.org/rtems/commit/?id=9d2ed41fcb1dc635ce7d689c60cdf374f2394dbd
> Is this patch dependent on the changes to rtems.git?
Yes. This patch depends on the previously committed patch
https://lists.rtems.org/pipermail/devel/2020-December/063644.html
Are the kernel versions of the functions built for all bsps?
> Which BSPs have been built to test the changes?
I tested the changes with Beagle BSP and xilinx_zynq_a9_qemu.
My concnern is these calls are currently available to all BSPs in libbsd
> and may
> not be in rtems.git.
If I understand the question correctly, my previous answer should have
answered this.
But once again, An RTEMS OFW API is already available in the master branch.
This
patch removes the functions which have been implemented in RTEMS. We provide
FreeBSD compatibility using ofw_compat.h.
https://git.rtems.org/rtems/tree/bsps/include/ofw/ofw_compat.h
> >  freebsd/sys/dev/ofw/openfirm.c                |  2 ++
> >  freebsd/sys/dev/ofw/openfirm.h                |  9 ++++++++
> Why do we need to keep these files in libbsd?
Some functions cannot be implemented in RTEMS since they depend
on the FreeBSD driver infrastructure. So I have left them here. All
functions
which are independent of the FreeBSD stuff are moved into RTEMS from
FreeBSD.
> >  .../machine/rtems-bsd-kernel-namespace.h      | 22 -------------------
> >  3 files changed, 11 insertions(+), 22 deletions(-)
> > diff --git a/freebsd/sys/dev/ofw/openfirm.c
> b/freebsd/sys/dev/ofw/openfirm.c
> > index 9cc7dbdc..30513ab2 100644
> > --- a/freebsd/sys/dev/ofw/openfirm.c
> > +++ b/freebsd/sys/dev/ofw/openfirm.c
> > @@ -333,6 +333,7 @@ OF_interpret(const char *cmd, int nreturns, ...)
> >   * Device tree functions
> > +#ifndef __rtems__
> >  /* Return the next sibling of this node or 0. */
> >  phandle_t
> >  OF_peer(phandle_t node)
> > @@ -672,6 +673,7 @@ OF_xref_from_node(phandle_t node)
> >               return (node);
> >       return (xref);
> > +#endif /* __rtems__ */
> >  device_t
> >  OF_device_from_xref(phandle_t xref)
> > diff --git a/freebsd/sys/dev/ofw/openfirm.h
> b/freebsd/sys/dev/ofw/openfirm.h
> > index f043197a..5df07258 100644
> > --- a/freebsd/sys/dev/ofw/openfirm.h
> > +++ b/freebsd/sys/dev/ofw/openfirm.h
> > @@ -64,7 +64,11 @@
> >  #include <sys/types.h>
> >  #include <machine/_bus.h>
> > +#ifdef __rtems__
> > +#include <ofw/ofw_compat.h>
> > +#ifndef __rtems__
> >   * Prototypes for Open Firmware Interface Routines
> > @@ -72,6 +76,7 @@
> >  typedef uint32_t     ihandle_t;
> >  typedef uint32_t     phandle_t;
> >  typedef uint32_t     pcell_t;
> >  #ifdef _KERNEL
> >  #include <sys/malloc.h>
> > @@ -102,6 +107,7 @@ int               OF_test(const char *name);
> >  void         OF_printf(const char *fmt, ...);
> >  /* Device tree functions */
> > +#ifndef __rtems__
> >  phandle_t    OF_peer(phandle_t node);
> >  phandle_t    OF_child(phandle_t node);
> >  phandle_t    OF_parent(phandle_t node);
> > @@ -140,6 +146,7 @@ ssize_t           OF_package_to_path(phandle_t node,
> char *buf, size_t len);
> >  phandle_t    OF_node_from_xref(phandle_t xref);
> >  phandle_t    OF_xref_from_node(phandle_t node);
> >   * When properties contain references to other nodes using xref handles
> it is
> > @@ -159,8 +166,10 @@ ssize_t          OF_read(ihandle_t instance, void
> *buf, size_t len);
> >  ssize_t              OF_write(ihandle_t instance, const void *buf,
> size_t len);
> >  int          OF_seek(ihandle_t instance, uint64_t where);
> > +#ifndef __rtems__
> >  phandle_t    OF_instance_to_package(ihandle_t instance);
> >  ssize_t              OF_instance_to_path(ihandle_t instance, char *buf,
> size_t len);
> >  int          OF_call_method(const char *method, ihandle_t instance,
> >                   int nargs, int nreturns, ...);
> > diff --git a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> > index 75b744a4..53944393 100644
> > --- a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> > +++ b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> > @@ -3044,42 +3044,20 @@
> >  #define      null_filtops _bsd_null_filtops
> >  #define      nullop _bsd_nullop
> >  #define      OF_call_method _bsd_OF_call_method
> > -#define      OF_canon _bsd_OF_canon
> > -#define      OF_child _bsd_OF_child
> >  #define      OF_claim _bsd_OF_claim
> >  #define      OF_close _bsd_OF_close
> >  #define      OF_device_from_xref _bsd_OF_device_from_xref
> >  #define      OF_device_register_xref _bsd_OF_device_register_xref
> >  #define      OF_enter _bsd_OF_enter
> >  #define      OF_exit _bsd_OF_exit
> > -#define      OF_finddevice _bsd_OF_finddevice
> > -#define      OF_getencprop _bsd_OF_getencprop
> > -#define      OF_getencprop_alloc _bsd_OF_getencprop_alloc
> > -#define      OF_getencprop_alloc_multi _bsd_OF_getencprop_alloc_multi
> > -#define      OF_getprop _bsd_OF_getprop
> > -#define      OF_getprop_alloc _bsd_OF_getprop_alloc
> > -#define      OF_getprop_alloc_multi _bsd_OF_getprop_alloc_multi
> > -#define      OF_getproplen _bsd_OF_getproplen
> > -#define      OF_hasprop _bsd_OF_hasprop
> >  #define      OF_init _bsd_OF_init
> >  #define      OF_install _bsd_OF_install
> > -#define      OF_instance_to_package _bsd_OF_instance_to_package
> > -#define      OF_instance_to_path _bsd_OF_instance_to_path
> >  #define      OF_interpret _bsd_OF_interpret
> > -#define      OF_nextprop _bsd_OF_nextprop
> > -#define      OF_node_from_xref _bsd_OF_node_from_xref
> >  #define      OF_open _bsd_OF_open
> > -#define      OF_package_to_path _bsd_OF_package_to_path
> > -#define      OF_parent _bsd_OF_parent
> > -#define      OF_peer _bsd_OF_peer
> >  #define      OF_printf _bsd_OF_printf
> > -#define      OF_prop_free _bsd_OF_prop_free
> >  #define      OF_read _bsd_OF_read
> >  #define      OF_release _bsd_OF_release
> > -#define      OF_searchencprop _bsd_OF_searchencprop
> > -#define      OF_searchprop _bsd_OF_searchprop
> >  #define      OF_seek _bsd_OF_seek
> > -#define      OF_setprop _bsd_OF_setprop
> >  #define      OF_test _bsd_OF_test
> >  #define      ofw_bus_assigned_addresses_to_rl
> _bsd_ofw_bus_assigned_addresses_to_rl
> >  #define      ofwbus_driver _bsd_ofwbus_driver
> How did you create this changes?
In RTEMS, there is ofw_compat.h
to provide compatibility between FreeBSD OFW API and RTEMS OFW API.
Thanks,
Niteesh.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210127/c02fa860/attachment.html>
