[PATCH] score: Add _Thread_Demand_objects_information()
Wed Jan 27 18:37:52 UTC 2021
We do not need all the checks if we have a valid indentifier to a thread
class object.
Move _RTEMS_tasks_Free() to the only source file which calls this
function.
 cpukit/include/rtems/rtems/tasksimpl.h  | 16 ----------------
 cpukit/include/rtems/score/threadimpl.h | 25 +++++++++++++++++++++++++
 cpukit/rtems/src/taskconstruct.c        |  8 ++++++++
 cpukit/score/src/threadrestart.c        | 12 ++++++------
 4 files changed, 39 insertions(+), 22 deletions(-)
diff --git a/cpukit/include/rtems/rtems/tasksimpl.h b/cpukit/include/rtems/rtems/tasksimpl.h
index eac4647897..62a618b635 100644
--- a/cpukit/include/rtems/rtems/tasksimpl.h
+++ b/cpukit/include/rtems/rtems/tasksimpl.h
@@ -66,22 +66,6 @@ RTEMS_INLINE_ROUTINE Thread_Control *_RTEMS_tasks_Allocate(void)
     _Objects_Allocate_unprotected( &_RTEMS_tasks_Information.Objects );
- *  @brief Frees a task control block.
- *  This routine frees a task control block to the
- *  inactive chain of free task control blocks.
-RTEMS_INLINE_ROUTINE void _RTEMS_tasks_Free (
-  Thread_Control *the_task
-  _Objects_Free(
-    _Objects_Get_information_id( the_task->Object.id ),
-    &the_task->Object
  * @brief Converts the RTEMS API priority to the corresponding SuperCore
  * priority and validates it.
diff --git a/cpukit/include/rtems/score/threadimpl.h b/cpukit/include/rtems/score/threadimpl.h
index 52945b407c..eb2810db73 100644
--- a/cpukit/include/rtems/score/threadimpl.h
+++ b/cpukit/include/rtems/score/threadimpl.h
@@ -842,6 +842,31 @@ RTEMS_INLINE_ROUTINE Objects_Information *_Thread_Get_objects_information(
   return _Objects_Information_table[ the_api ][ 1 ];
+ * @brief Demands the thread object information associated with the object
+ *   identifier.
+ * @param id is a valid identifier to a thread class object.
+ * @return Returns the thread object information associated with the identifier.
+RTEMS_INLINE_ROUTINE Thread_Information *_Thread_Demand_objects_information(
+  Objects_Id id
+  size_t              the_api;
+  Thread_Information *information;
+  the_api = (size_t) _Objects_Get_API( id );
+  _Assert( _Objects_Is_api_valid( the_api ) );
+  information = (Thread_Information *)
+    _Objects_Information_table[ the_api ][ 1 ];
+  _Assert( information != NULL );
+  return information;
  * @brief Gets a thread by its identifier.
diff --git a/cpukit/rtems/src/taskconstruct.c b/cpukit/rtems/src/taskconstruct.c
index 6ff83a0b9c..656db7a674 100644
--- a/cpukit/rtems/src/taskconstruct.c
+++ b/cpukit/rtems/src/taskconstruct.c
@@ -79,6 +79,14 @@ rtems_status_code rtems_task_construct(
   return _RTEMS_tasks_Create( config, id, _RTEMS_tasks_Prepare_user_stack );
+static void _RTEMS_tasks_Free( Thread_Control *the_thread )
+  information = _Thread_Demand_objects_information( the_thread->Object.id );
+  _Objects_Free( &information->Objects, &the_thread->Object );
 rtems_status_code _RTEMS_tasks_Create(
   const rtems_task_config   *config,
   rtems_id                  *id,
diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
index b4204f7fbb..5670abdc26 100644
--- a/cpukit/score/src/threadrestart.c
+++ b/cpukit/score/src/threadrestart.c
@@ -130,16 +130,16 @@ static void _Thread_Add_to_zombie_chain( Thread_Control *the_thread )
 static void _Thread_Make_zombie( Thread_Control *the_thread )
 #if defined(RTEMS_SCORE_THREAD_ENABLE_RESOURCE_COUNT)
   if ( _Thread_Owns_resources( the_thread ) ) {
     _Internal_error( INTERNAL_ERROR_RESOURCE_IN_USE );
 #endif
-  _Objects_Close(
-    _Objects_Get_information_id( the_thread->Object.id ),
-    &the_thread->Object
+  _Objects_Close( &information->Objects, &the_thread->Object );
   _Thread_Set_state( the_thread, STATES_ZOMBIE );
   _Thread_queue_Extract_with_proxy( the_thread );
@@ -157,8 +157,7 @@ static void _Thread_Make_zombie( Thread_Control *the_thread )
 static void _Thread_Free( Thread_Control *the_thread )
-  Thread_Information *information = (Thread_Information *)
-    _Objects_Get_information_id( the_thread->Object.id );
   _User_extensions_Thread_delete( the_thread );
   _User_extensions_Destroy_iterators( the_thread );
@@ -179,6 +178,7 @@ static void _Thread_Free( Thread_Control *the_thread )
 #endif
 #endif
   _Freechain_Push(
     &information->Thread_queue_heads.Free,
     the_thread->Wait.spare_heads
2.26.2
