[PATCH 1/3] score: Fix _Objects_Get_information() indentation
Thu Jan 28 10:31:01 UTC 2021
This fix relates to a Coverity issue (NESTING_INDENT_MISMATCH).
 cpukit/score/src/objectgetinfo.c | 15 ++++++++-------
 1 file changed, 8 insertions(+), 7 deletions(-)
diff --git a/cpukit/score/src/objectgetinfo.c b/cpukit/score/src/objectgetinfo.c
index 07b401faf0..a256d20d87 100644
--- a/cpukit/score/src/objectgetinfo.c
+++ b/cpukit/score/src/objectgetinfo.c
@@ -52,14 +52,15 @@ Objects_Information *_Objects_Get_information(
     return NULL;
-   *  In a multprocessing configuration, we may access remote objects.
-   *  Thus we may have 0 local instances and still have a valid object
-   *  pointer.
+   * In a multiprocessing configuration, we may access remote objects.
+   * Thus we may have 0 local instances and still have a valid object
+   * pointer.
-  #if !defined(RTEMS_MULTIPROCESSING)
-    if ( _Objects_Get_maximum_index( info ) == 0 )
-      return NULL;
-  #endif
+#if !defined(RTEMS_MULTIPROCESSING)
+  if ( _Objects_Get_maximum_index( info ) == 0 ) {
+    return NULL;
+#endif
   return info;
2.26.2
