[PATCH] Add model file for Coverity
Thu Jan 28 18:42:02 UTC 2021
 static-analysis/coverity/model.c | 63 ++++++++++++++++++++++++++++++++
 1 file changed, 63 insertions(+)
 create mode 100644 static-analysis/coverity/model.c
diff --git a/static-analysis/coverity/model.c b/static-analysis/coverity/model.c
new file mode 100644
index 0000000..cd25d2b
--- /dev/null
+++ b/static-analysis/coverity/model.c
@@ -0,0 +1,63 @@
+ * @file
+ * @brief This file provides models for the Coverity static analyser.
+ * If you update this file, then ask a project administrator to update the
+ * analysis settings:
+ * https://scan.coverity.com/projects/rtems?tab=analysis_settings
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#define _CPU_Fatal_halt( _source, _error ) \
+  do { \
+    (void) _source; \
+    (void) _error; \
+    __coverity_panic__(); \
+  } while( 0 )
+#define _CPU_ISR_Disable( _level ) \
+  do { \
+    _level = 0; \
+    __coverity_exclusive_lock_acquire__( &_level ); \
+  } while( 0 )
+#define _CPU_ISR_Enable( _level ) \
+  do { \
+    __coverity_exclusive_lock_release__( &_level ); \
+  } while( 0 )
+#define _Assert( _e ) \
+  ( ( _e ) ?  ( void ) 0 : __coverity_panic__() )
+void __builtin_unreachable( void )
2.26.2
