[PATCH] Add model file for Coverity
Joel Sherrill
joel at rtems.org
Thu Jan 28 19:15:18 UTC 2021
On Thu, Jan 28, 2021 at 1:11 PM Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Jan 28, 2021 at 12:44 PM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 28/01/2021 19:42, Sebastian Huber wrote:
>> > +#define _CPU_Fatal_halt( _source, _error ) \
>> > + do { \
>> > + (void) _source; \
>> > + (void) _error; \
>> > + __coverity_panic__(); \
>> > + } while( 0 )
>> I am not sure if #define works for the models. The documentation
>> mentions only real functions and types. I guess we have to try it out.
>> Which built-in defines are used by Coverity? For example, is __GNUC__
>> defined? What does it with __asm__ statements?
> No idea.
> They appear to do their best to hide the documentation from open source
> users as best I can tell. They send you to stackoverflow. They used to have
> a support email. I did manage to find this but it wasn't easy (thanks
> Google)
> https://scan.coverity.com/models
> I have found some examples and guidance from other open source projects.
> But not much.
> https://fossies.org/linux/xen/misc/coverity/model.c
> There is this old blog about some things commonly flagged in Linux and
> what they did.
> https://www.synopsys.com/blogs/software-security/gimme-a-break/
> Adding comments for intentional switch case fall throughs "nobreak" is
> properly
> a good idea without crossing into adding Coverity specific disables.
> Do you want Gedare or I to upload that and see what happens?
I added your model and it is automatically queued up to re-run the
analysis.
I guess we will see if it fixes things.
Feel free to push it.
> --joel
>> embedded brains GmbH
>> Herr Sebastian HUBER
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: sebastian.huber at embedded-brains.de
>> phone: +49-89-18 94 741 - 16
>> fax: +49-89-18 94 741 - 08
>> Registergericht: Amtsgericht München
>> Registernummer: HRB 157899
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210128/95df01fc/attachment.html>
