[PATCH v2] Add model file for Coverity
Sebastian Huber
Fri Jan 29 06:07:32 UTC 2021
static-analysis/coverity/model.c | 53 ++++++++++++++++++++++++++++++++
1 file changed, 53 insertions(+)
create mode 100644 static-analysis/coverity/model.c
diff --git a/static-analysis/coverity/model.c b/static-analysis/coverity/model.c
new file mode 100644
index 0000000..874b1b3
--- /dev/null
+++ b/static-analysis/coverity/model.c
@@ -0,0 +1,53 @@
+ * @file
+ * @brief This file provides models for the Coverity static analyser.
+ * If you update this file, then ask a project administrator to update the
+ * analysis settings:
+ * https://scan.coverity.com/projects/rtems?tab=analysis_settings
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+typedef enum { } Internal_errors_Source;
+typedef unsigned long Internal_errors_t;
+void _Terminate( Internal_errors_Source the_source, Internal_errors_t the_error )
+ (void) the_source;
+ (void) the_error;
+ __coverity_panic__();
+void __builtin_unreachable( void )
2.26.2
