[PATCH] score: Use defines for Thread_Life_state
Fri Jan 29 15:09:47 UTC 2021
On Fri, Jan 29, 2021 at 9:06 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Fri, Jan 29, 2021 at 12:24 AM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> Do not use an enum as a bit field.  Document the state flags.
Is this a new style rule that needs to be documented?
>> This fix relates to a Coverity issue (PW.MIXED_ENUM_TYPE).
>>  cpukit/include/rtems/score/thread.h | 57 ++++++++++++++++++++++++-----
>>  1 file changed, 47 insertions(+), 10 deletions(-)
>> diff --git a/cpukit/include/rtems/score/thread.h
>> b/cpukit/include/rtems/score/thread.h
>> index 8785879184..82d98f278a 100644
>> --- a/cpukit/include/rtems/score/thread.h
>> +++ b/cpukit/include/rtems/score/thread.h
>> @@ -659,22 +659,59 @@ typedef struct {
>>  } Thread_Action_control;
>> - * @brief Thread life states.
>> + * @brief This type represents the thread life state.
>> - * The thread life states are orthogonal to the thread states used for
>> + * The thread life state are orthogonal to the thread state used for
> s/are/is
> or s/life state/life states
>>   * synchronization primitives and blocking operations.  They reflect the
>> state
>   * changes triggered with thread restart and delete requests.
>> - * The individual state values must be a power of two to allow use of bit
>> + * The individual state flags must be a power of two to allow use of bit
>>   * operations to manipulate and evaluate the thread life state.
>> -typedef enum {
>> -  THREAD_LIFE_PROTECTED = 0x1,
>> -  THREAD_LIFE_RESTARTING = 0x2,
>> -  THREAD_LIFE_TERMINATING = 0x4,
>> -  THREAD_LIFE_CHANGE_DEFERRED = 0x8,
>> -  THREAD_LIFE_DETACHED = 0x10
>> -} Thread_Life_state;
>> +typedef int Thread_Life_state;
> Maybe unsigned is better? It can be safer sometimes for undefined
> behaviors. this shouldn't matter greatly. It just doesn't make sense to
> call a combination of flags as a signed value.
>> + * @brief Indicates that the thread life is protected.
>> + * If this flag is set, then the thread restart or delete requests are
>> deferred
>> + * until the protection and deferred change flags are cleared.  It is
>> used by
>> + * _Thread_Set_life_protection().
> thanks for improving the doxygen along the way.
>> +#define THREAD_LIFE_PROTECTED 0x1
>> + * @brief Indicates that thread is restarting.
>> + * If this flag is set, then a thread restart request is in pending. See
>> + * _Thread_Restart_self() and _Thread_Restart_other().
>> +#define THREAD_LIFE_RESTARTING 0x2
>> + * @brief Indicates that thread is terminating.
>> + * If this flag is set, then a thread termination request is in
>> pending.  See
>> + * _Thread_Exit() and _Thread_Cancel().
>> +#define THREAD_LIFE_TERMINATING 0x4
>> + * @brief Indicates that thread life changes are deferred.
>> deferred
>> used by
>> + * pthread_setcanceltype().
>> +#define THREAD_LIFE_CHANGE_DEFERRED 0x8
>> + * @brief Indicates that thread is detached.
>> + * If this flag is set, then the thread is detached.  Detached threads
>> do not
>> + * wait during termination for other threads to join.  See
>> rtems_task_delete(),
>> + * rtems_task_exit(), and pthread_detach().
>> +#define THREAD_LIFE_DETACHED 0x10
>>   * @brief Thread life control.
>> 2.26.2
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210129/79ed5d56/attachment.html>
