[PATCH] score: Use defines for Thread_Life_state
Sebastian Huber
Fri Jan 29 20:08:09 UTC 2021
On 29/01/2021 20:58, dufault at hda.com wrote:
>> On Jan 29, 2021, at 13:59 , Gedare Bloom <gedare at rtems.org> wrote:
>> On Fri, Jan 29, 2021 at 11:38 AM Joel Sherrill <joel.sherrill at gmail.com> wrote:
>> On Fri, Jan 29, 2021, 12:28 PM Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> On 29/01/2021 18:33, Peter Dufault wrote:
>>>>> Do not use an enum as a bit field. Document the state flags.
>>>>> Is this a new style rule that needs to be documented?
>>>> Into which category would you put this? Language and Compiler?
>>>> https://docs.rtems.org/branches/master/eng/coding-conventions.html
>>>> Yes.
>>> I use enums as bit fields a lot. I use them in conjunction with objects that are the same enum.
>>> I avoid using #define. In most situations you can't print them in a debugger and they imply restricted usage.
>>> Is this an appropriate warning? Does it always mean that the enum should be replaced with a #define?
>>> If it doesn't always apply then the style should make it clear when it should apply.
>> We don't have to agree with Coverity. This is why I asked before the change:
>> https://lists.rtems.org/pipermail/devel/2021-January/064105.html
>> From my point of view enums are useful for bit fields and I don't think
>> this point of view is too exotic since debuggers such as GDB and
>> Lauterbach support it. For example:
>> enum a {
>> A,
>> B,
>> C
>> enum a f(enum a x, enum a y)
>> return x | y;
>> enum a v;
>> int main()
>> v = f(B, C);
>> return 0;
>> Breakpoint 1, main () at test.c:16
>> 16 v = f(B, C);
>> (gdb) n
>> 17 return 0;
>> (gdb) p v
>> $1 = (B | C)
>> If we want enums as bitfields, we can add that as a coding guideline as an option and mention that some static analysis tools do not like it.
>> Then mark these all as ignored with an explanation
>> My only concern is whether the behavior is always well-defined (by the C standards). I'm not an expert and don't know where to find an answer to that question.
>> What I seem to glean from a quick search is that the main requirement is that the type is guaranteed consistent with char, signed int, or unsigned int. So bit manipulations would seem to be well-defined. Does coverity offer any guidance why it complains?
> Gedare's concerns about well-defined behavior match mine.
> I don't know why Coverity calls this issue out. Maybe they are enforcing one of my "I wish C worked that way" checks: a particular enum should only be used in conjunction with other expressions of that enum. Yes, that might require casting, but I'd like it. I don't know about Coverity but I bet it doesn't support how I wish things worked.
> As Gedare points out: maybe this exposes ill-defined behavior.
The PW.MIXED_ENUM_TYPE could be a Portability Warning? In C++ this stuff
is an error:
test.c:9:11: error: invalid conversion from ‘int’ to ‘a’ [-fpermissive]
return x | y;
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
