Question about Raspberry Pi bspstarthooks.c - potential patch
Alan Cudmore alan.cudmore at gmail.com
Thu Jul 1 13:43:37 UTC 2021
On Thu, Jul 1, 2021 at 8:20 AM Sebastian Huber
> On 29/06/2021 21:09, Alan Cudmore wrote:
> >> On 29/06/2021 20:56, Alan Cudmore wrote:
> >>> I understand the move in that commit now.
> >>> Maybe it's not working on the single core models because the code is
> >>> conditional for ARMV7 + A or ARMV8?
> >>> https://git.rtems.org/rtems/tree/bsps/arm/shared/start/start.S#n485
> >>> I think the single core RPIs are ARM1176JZF-S (ARMv6Z).
> >> Oh, yes, this is probably the problem. I wasn't aware that we have a BSP
> >> which uses Armv6. I will try to figure out the right options.
> > Thanks! As soon as you have something that would work, we can test it.
> > The CPU architecture is old, but it looks like these models will be in
> > production until at least 2026.
> I didn't find an Armv6 Reference Manual, so I have no idea if this works
> for all Armv6 systems (the only one in RTEMS is probably the Raspberry Pi)
> diff --git a/bsps/arm/shared/start/start.S b/bsps/arm/shared/start/start.S
> index 698495d32e..028bef6d2d 100644
> --- a/bsps/arm/shared/start/start.S
> +++ b/bsps/arm/shared/start/start.S
> @@ -482,7 +482,8 @@ bsp_start_hook_0_done:
>   .Lvector_table_copy_done:
> -#if (__ARM_ARCH >= 7 && __ARM_ARCH_PROFILE == 'A') || __ARM_ARCH >= 8
> +#if __ARM_ARCH == 6 || (__ARM_ARCH >= 7 && __ARM_ARCH_PROFILE == 'A') || \
> +  __ARM_ARCH >= 8
>           * This code path is only executed by the primary processor.
> Set the
>           * VBAR to the normal vector table.  For secondary processors,
> this is
The define works, but Armv6 does not implement dsb and isb.
I created a separate #if block for Armv6 without the dsb and isb
instructions and it seems to work on the Raspberry Pi Zero.
Do you think the equivalent synchronization operations are necessary
here? If so, I can research and test them. I found some references on
Raspberry Pi forums that I can follow (also had links to the ARM
manuals)
Also, for the #if blocks, would you prefer this style:
#if (7A or 8)
#else if (6)
#endif
or two separate #if blocks?
Thanks,
Alan
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
