[PATCH v1 1/1] gpiolib/grgpio: Add support for newer grgpio features
Jan Sommer
jan.sommer at dlr.de
Thu Jul 1 15:44:16 UTC 2021
- Use proper typedef for isr (avoid warning in user application)
- Use set input enable register together with pin direction
- Support irqgen == 1 mode if present in capabilities register
bsps/include/grlib/gpiolib.h | 7 +++++--
bsps/include/grlib/grlib.h | 4 +++-
bsps/shared/grlib/drvmgr/ambapp_bus.c | 5 +----
bsps/shared/grlib/gpio/gpiolib.c | 2 +-
bsps/shared/grlib/gpio/grgpio.c | 22 ++++++++++++++++------
5 files changed, 26 insertions(+), 14 deletions(-)
diff --git a/bsps/include/grlib/gpiolib.h b/bsps/include/grlib/gpiolib.h
index f82d4fa2c2..37ac140862 100644
--- a/bsps/include/grlib/gpiolib.h
+++ b/bsps/include/grlib/gpiolib.h
@@ -28,6 +28,9 @@ struct gpiolib_config {
#define GPIOLIB_IRQ_POL_LOW 0
#define GPIOLIB_IRQ_POL_HIGH 1
+/* Interrupt Service Routine (ISR) */
+typedef void (*gpiolib_isr)(void *arg);
/* Libarary initialize function must be called befor any other */
extern int gpiolib_initialize(void);
@@ -54,7 +57,7 @@ extern int gpiolib_irq_disable(void *handle);
extern int gpiolib_irq_mask(void *handle);
extern int gpiolib_irq_unmask(void *handle);
extern int gpiolib_irq_force(void *handle);
-extern int gpiolib_irq_register(void *handle, void *func, void *arg);
+extern int gpiolib_irq_register(void *handle, gpiolib_isr func, void *arg);
/*** Driver Interface ***/
@@ -66,7 +69,7 @@ struct gpiolib_drv_ops {
int (*config)(void *handle, struct gpiolib_config *cfg);
int (*get)(void *handle, int *val);
int (*irq_opts)(void *handle, unsigned int options);
- int (*irq_register)(void *handle, void *func, void *arg);
+ int (*irq_register)(void *handle, gpiolib_isr func, void *arg);
int (*open)(void *handle);
int (*set)(void *handle, int dir, int outval);
int (*show)(void *handle);
diff --git a/bsps/include/grlib/grlib.h b/bsps/include/grlib/grlib.h
index 49d9999807..4aa3e9df4a 100644
--- a/bsps/include/grlib/grlib.h
+++ b/bsps/include/grlib/grlib.h
@@ -17,6 +17,7 @@
#define __GRLIB_H__
#include <stdbool.h>
+#include <bsp/utility.h>
#ifdef __cplusplus
extern "C" {
@@ -125,6 +126,7 @@ struct grgpio_regs {
volatile unsigned int iedge; /* 0x14 Interrupt edge register */
volatile unsigned int bypass; /* 0x18 Bypass register */
volatile unsigned int cap; /* 0x1C Capability register */
+#define GRGPIO_CAP_IRQGEN(reg) BSP_FLD32GET(reg, 8, 12)
volatile unsigned int irqmap[4]; /* 0x20 - 0x2C Interrupt map registers */
volatile unsigned int res_30; /* 0x30 Reserved */
volatile unsigned int res_34; /* 0x34 Reserved */
@@ -132,7 +134,7 @@ struct grgpio_regs {
volatile unsigned int res_3C; /* 0x3C Reserved */
volatile unsigned int iavail; /* 0x40 Interrupt available register */
volatile unsigned int iflag; /* 0x44 Interrupt flag register */
- volatile unsigned int res_48; /* 0x48 Reserved */
+ volatile unsigned int input_en; /* 0x48 Input enable (if present) */
volatile unsigned int pulse; /* 0x4C Pulse register */
volatile unsigned int res_50; /* 0x50 Reserved */
volatile unsigned int output_or; /* 0x54 I/O port output register, logical-OR */
diff --git a/bsps/shared/grlib/drvmgr/ambapp_bus.c b/bsps/shared/grlib/drvmgr/ambapp_bus.c
index 3c38fc16e0..0aed29224c 100644
--- a/bsps/shared/grlib/drvmgr/ambapp_bus.c
+++ b/bsps/shared/grlib/drvmgr/ambapp_bus.c
@@ -521,11 +521,8 @@ static int ambapp_dev_fixup(struct drvmgr_dev *dev, struct amba_dev_info *pnp)
for(core = 0; core < subcores; core++)
drvmgr_dev_register(devs_to_register[core]);
return 1;
- } else if ( (pnp->info.device == GAISLER_GPIO) &&
- (pnp->info.vendor == VENDOR_GAISLER) ) {
- /* PIO[N] is connected to IRQ[N]. */
- pnp->info.irq = 0;
return 0;
diff --git a/bsps/shared/grlib/gpio/gpiolib.c b/bsps/shared/grlib/gpio/gpiolib.c
index cf0038c5bb..0cb76402cc 100644
--- a/bsps/shared/grlib/gpio/gpiolib.c
+++ b/bsps/shared/grlib/gpio/gpiolib.c
@@ -201,7 +201,7 @@ int gpiolib_get(void *handle, int *inval)
/*** IRQ Functions ***/
-int gpiolib_irq_register(void *handle, void *func, void *arg)
+int gpiolib_irq_register(void *handle, gpiolib_isr func, void *arg)
struct gpiolib_port *port = handle;
diff --git a/bsps/shared/grlib/gpio/grgpio.c b/bsps/shared/grlib/gpio/grgpio.c
index 05504ef020..5bce5f530a 100644
--- a/bsps/shared/grlib/gpio/grgpio.c
+++ b/bsps/shared/grlib/gpio/grgpio.c
@@ -229,6 +229,7 @@ static int grgpio_grpiolib_irq_opts(void *handle, unsigned int options)
struct grgpio_priv *priv;
int portnr;
+ int irq;
drvmgr_isr isr;
void *arg;
@@ -244,33 +245,41 @@ static int grgpio_grpiolib_irq_opts(void *handle, unsigned int options)
isr = priv->isrs[portnr].isr;
arg = priv->isrs[portnr].arg;
+ /* For irqgen == 1, irq == pirq, i.e. no offset */
+ irq = 0;
+ if (GRGPIO_CAP_IRQGEN(priv->regs->cap) == 0) {
+ /* For irqgen == 0, irq == pirq + portnr */
+ irq += portnr;
+ /* FIXME: irqgen > 1 currently not supported */
if ( options & GPIOLIB_IRQ_DISABLE ) {
/* Disable interrupt at interrupt controller */
- if ( drvmgr_interrupt_unregister(priv->dev, portnr, isr, arg) ) {
+ if ( drvmgr_interrupt_unregister(priv->dev, irq, isr, arg) ) {
return -1;
if ( options & GPIOLIB_IRQ_CLEAR ) {
/* Clear interrupt at interrupt controller */
- if ( drvmgr_interrupt_clear(priv->dev, portnr) ) {
+ if ( drvmgr_interrupt_clear(priv->dev, irq) ) {
return -1;
if ( options & GPIOLIB_IRQ_ENABLE ) {
/* Enable interrupt at interrupt controller */
- if ( drvmgr_interrupt_register(priv->dev, portnr, "grgpio", isr, arg) ) {
+ if ( drvmgr_interrupt_register(priv->dev, irq, "grgpio", isr, arg) ) {
return -1;
if ( options & GPIOLIB_IRQ_MASK ) {
/* Mask (disable) interrupt at interrupt controller */
- if ( drvmgr_interrupt_mask(priv->dev, portnr) ) {
+ if ( drvmgr_interrupt_mask(priv->dev, irq) ) {
return -1;
if ( options & GPIOLIB_IRQ_UNMASK ) {
/* Unmask (enable) interrupt at interrupt controller */
- if ( drvmgr_interrupt_unmask(priv->dev, portnr) ) {
+ if ( drvmgr_interrupt_unmask(priv->dev, irq) ) {
return -1;
@@ -278,7 +287,7 @@ static int grgpio_grpiolib_irq_opts(void *handle, unsigned int options)
return 0;
-static int grgpio_grpiolib_irq_register(void *handle, void *func, void *arg)
+static int grgpio_grpiolib_irq_register(void *handle, gpiolib_isr func, void *arg)
int portnr;
@@ -313,6 +322,7 @@ static int grgpio_grpiolib_set(void *handle, int dir, int outval)
/* Set Direction and Output */
mask = 1<<portnr;
priv->regs->dir = (priv->regs->dir & ~mask) | (dir ? mask : 0);
+ priv->regs->input_en = (priv->regs->input_en & ~mask) | (dir ? 0 : mask);
priv->regs->output = (priv->regs->output & ~mask) | (outval ? mask : 0);
return 0;
2.17.1
