[PATCH rtems-docs] user/bsps: Update ZynqMP for hardware BSPs
Gedare Bloom
gedare at rtems.org
Thu Jul 1 19:10:06 UTC 2021
On Thu, Jul 1, 2021 at 12:28 PM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> Update the ZynqMP documentation for the new hardware BSP variants
> including information about booting, boot image generation, and
> networking.
> user/bsps/aarch64/xilinx-zynqmp.rst | 56 ++++++++++++++++++++++++-----
> 1 file changed, 48 insertions(+), 8 deletions(-)
> diff --git a/user/bsps/aarch64/xilinx-zynqmp.rst b/user/bsps/aarch64/xilinx-zynqmp.rst
> index 7401e84..333ce8e 100644
> --- a/user/bsps/aarch64/xilinx-zynqmp.rst
> +++ b/user/bsps/aarch64/xilinx-zynqmp.rst
> @@ -4,19 +4,45 @@
> .. _BSP_aarch64_qemu_xilinx_zynqmp_ilp32_qemu:
> .. _BSP_aarch64_qemu_xilinx_zynqmp_lp64_qemu:
> +.. _BSP_aarch64_qemu_xilinx_zynqmp_ilp32_zu3eg:
> +.. _BSP_aarch64_qemu_xilinx_zynqmp_lp64_zu3eg:
> Qemu Xilinx ZynqMP
> -This BSP supports two variants, `xilinx-zynqmp-ilp32-qemu` and
> -`xilinx-zynqmp-lp64-qemu`. The basic hardware initialization is performed by the
> -BSP. These BSPs support the GICv2 interrupt controller present in all ZynqMP
> -systems.
> +This BSP supports four variants: `xilinx-zynqmp-ilp32-qemu`,
> +`xilinx-zynqmp-lp64-qemu`, `xilinx-zynqmp-ilp32-zu3eg`, and
> +`xilinx-zynqmp-lp64-zu3eg`. The basic hardware initialization is performed by
This is a little confusing because there needs to be some hw
initialization first (e.g., by u-boot or ATF). Maybe clarify that
point. Otherwise, thanks for the addition looks great.
> +the BSP. These BSPs support the GICv2 interrupt controller present in all ZynqMP
> +systems. The zu3eg BSPs have also been tested to be fully functional on zu2cg
> +boards and should also work on any other ZynqMP chip variant since the
> +Processing Subsystem (PS) does not vary among chip variants other than the
> +number of CPU cores available.
> -Boot via ELF
> +Boot on QEMU
> The executable image is booted by Qemu in ELF format.
> +Boot on ZynqMP Hardware
> +On ZynqMP hardware, RTEMS can be started at EL1, EL2, or EL3 by u-boot or
> +directly as part of BOOT.bin. Regardless of the exception level at boot, RTEMS
> +will drop to EL1 for execution. For quick turnaround during testing, it is
> +recommended to use the u-boot BOOT.bin that comes with the PetaLinux prebuilts
> +for the board in question.
> +Hardware Boot Image Generation
> +RTEMS expects basic hardware initialization to be performed by ARM Trusted
> +Firmware (ATF) as well as the services it provides, so this must be included
> +when generating a direct-boot RTEMS BOOT.bin.
> +When booting via u-boot, RTEMS must be packaged into a u-boot image or booted
> +as a raw binary since u-boot does not currently support ELF64 which is required
> +for AArch64 ELF binaries.
> Clock Driver
> @@ -25,10 +51,24 @@ The clock driver uses the `ARM Generic Timer`.
> Console Driver
> -The console driver supports the default Qemu emulated ARM PL011 PrimeCell UART.
> +The console driver supports the default Qemu emulated ARM PL011 PrimeCell UART
> +as well as the physical ARM PL011 PrimeCell UART in the ZynqMP hardware.
> +Network Configuration
> +When used with LibBSD, these BSP variants support networking via the four
> +Cadence GEM instances present on all ZynqMP hardware variants. These are enabled
> +using config.inc in LibBSD by setting any of the following constants to 1:
> +NET_CFG_ZYNQMP_USE_CGEM0 = 1
> +NET_CFG_ZYNQMP_USE_CGEM1 = 1
> +NET_CFG_ZYNQMP_USE_CGEM2 = 1
> +NET_CFG_ZYNQMP_USE_CGEM3 = 1
> +Most ZynqMP dev boards use CGEM3. None of the interfaces are enabled by default.
> -Running Executables
> +Running Executables on QEMU
> Executables generated by these BSPs can be run using the following command::
> 2.20.1
> devel mailing list
> devel at rtems.org
