Is rtems/bsd/test/network-config.h supposed to be installed?
Kinsey Moore
kinsey.moore at oarcorp.com
Fri Jul 2 19:28:41 UTC 2021
That's an oversight on my part since the discussion around this was so
focused on tests and not application code. I'll post a patch to install
it properly.
Kinsey
On 7/2/2021 14:14, Peter Dufault wrote:
> I updated my libbsd today and an application is failing to build because it can't find the include file "rtems/bsd/test/network-config.h". It was added yesterday to "rtemsbsd/include/bsp/nexus-devices.h". "nexus-devices.h" the only file outside of the testsuite directory that includes "network-config.h", and that network-config.h file is in .gitignore. Or am I missing a build step?
> Build failure:
> Waf: Entering directory `XXX/build/arm-rtems6-imxrt1052'
> [6/9] Compiling demo/init.c
> In file included from /opt/flatland/opt/rtems-6/arm-rtems6/imxrt1052/lib/include/machine/rtems-bsd-config.h:230,
> from ../../demo/init.c:695:
> /opt/flatland/opt/rtems-6/arm-rtems6/imxrt1052/lib/include/bsp/nexus-devices.h:41:10: fatal error: rtems/bsd/test/network-config.h: No such file or directory
> 41 | #include <rtems/bsd/test/network-config.h>
> compilation terminated.
> "rtems/bsd/test/network-config.h" was added to "rtemsbsd/include/bsp/nexus-devices.h"
> Committed yesterday by Joel at 11:30:
> Module: rtems-libbsd
> Branch: 6-freebsd-12
> Commit: b0c8153d54f7b14ed305f0da23a3dc2e207a0968
> Changeset: http://git.rtems.org/rtems-libbsd/commit/?id=b0c8153d54f7b14ed305f0da23a3dc2e207a0968
> Author: Kinsey Moore <kinsey.moore at oarcorp.com>
> Date: Wed Jun 30 15:00:58 2021 -0500
> rtemsbsd: Use config.inc to control ZynqMP ethernet
> This alters the selection of the 4 Cadence GEM interfaces on the Zynq
> Ultrascale+ MPSoC BSP to be provided by config.inc instead of being
> provided by options in the RTEMS BSP itself since those options appear
> to be dead code when not used in conjunction with LibBSD.
> rtemsbsd/include/bsp/nexus-devices.h | 9 +++++----
> testsuite/include/rtems/bsd/test/network-config.h.in | 8 ++++++++
> waf_libbsd.py | 4 +++-
> 3 files changed, 16 insertions(+), 5 deletions(-)
> diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
> index 5c1bab4..cbb3f48 100644
> --- a/rtemsbsd/include/bsp/nexus-devices.h
> +++ b/rtemsbsd/include/bsp/nexus-devices.h
> @@ -38,6 +38,7 @@
> #include <rtems/bsd/bsd.h>
> #include <rtems/bsd/modules.h>
> +#include <rtems/bsd/test/network-config.h>
> #include <machine/rtems-bsd-nexus-bus.h>
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210702/59084b28/attachment.html>
