[PATCH] waf: Ensure network-config.h gets installed
Kinsey Moore kinsey.moore at oarcorp.com
Sat Jul 3 01:16:50 UTC 2021
network-config.h is now required for application compilation when using
nexus-devices.h. This makes sure that it gets installed to resolve build
errors.
 waf_libbsd.py | 14 ++++++++++++--
 1 file changed, 12 insertions(+), 2 deletions(-)
diff --git a/waf_libbsd.py b/waf_libbsd.py
index bb4182e3..4d8788c6 100644
--- a/waf_libbsd.py
+++ b/waf_libbsd.py
@@ -198,6 +198,8 @@ class Builder(builder.ModuleManager):
         config = self.getConfiguration()
         module_header_path = "rtems/bsd"
         module_header_name = "modules.h"
+        network_config_header_path = "rtems/bsd/test"
+        network_config_header_name = "network-config.h"
@@ -312,8 +314,11 @@ class Builder(builder.ModuleManager):
                 for t in tags:
                     if lhs == t:
                         sed += "-e 's/@%s@/%s/' " % (t, rhs)
-        bld(target="testsuite/include/rtems/bsd/test/network-config.h",
-            source="testsuite/include/rtems/bsd/test/network-config.h.in",
+        network_config_h_file_path = os.path.join("testsuite/include",
+                                                  network_config_header_path,
+                                                  network_config_header_name)
+        bld(target=network_config_h_file_path,
+            source=network_config_h_file_path + ".in",
             rule=sed + " < ${SRC} > ${TGT}",
             update_outputs=True)
@@ -575,6 +580,11 @@ class Builder(builder.ModuleManager):
                           modules_h_file_with_path,
                           cwd=bld.path)
+        bld.install_files(os.path.join("${PREFIX}", arch_inc_path,
+                                       network_config_header_path),
+                          network_config_h_file_path,
+                          cwd=bld.path)
         # Tests
2.20.1
