[PATCH v2] Fix compiler warnings for schedulerstrongapa.c
Richi Dubey
richidubey at gmail.com
Mon Jul 5 16:15:27 UTC 2021
cpukit/score/src/schedulerstrongapa.c | 24 ++++++++++++++++++++----
1 file changed, 20 insertions(+), 4 deletions(-)
diff --git a/cpukit/score/src/schedulerstrongapa.c b/cpukit/score/src/schedulerstrongapa.c
index 845d19d1a8..2d138bc7c3 100644
--- a/cpukit/score/src/schedulerstrongapa.c
+++ b/cpukit/score/src/schedulerstrongapa.c
@@ -187,7 +187,7 @@ static inline Scheduler_Node * _Scheduler_strong_APA_Find_highest_ready(
uint32_t rear
- Scheduler_Node *highest_ready;
+ Scheduler_Node *highest_ready = NULL;
Scheduler_strong_APA_CPU *CPU;
const Chain_Node *tail;
Chain_Node *next;
@@ -259,6 +259,12 @@ static inline Scheduler_Node * _Scheduler_strong_APA_Find_highest_ready(
+ * By definition, the system would always have a ready node,
+ * hence highest_ready would not be NULL.
+ _Assert( highest_ready != NULL );
return highest_ready;
@@ -494,7 +500,7 @@ static inline Scheduler_Node* _Scheduler_strong_APA_Get_lowest_reachable(
Per_CPU_Control **cpu_to_preempt
- Scheduler_Node *lowest_reachable;
+ Scheduler_Node *lowest_reachable = NULL;
Priority_Control max_priority_num;
uint32_t cpu_max;
uint32_t cpu_index;
@@ -546,6 +552,11 @@ static inline Scheduler_Node* _Scheduler_strong_APA_Get_lowest_reachable(
+ * Since it is not allowed for a task to have an empty affinity set,
+ * there would always be a lowest_reachable task, hence it would not be NULL
+ _Assert( lowest_reachable != NULL );
return lowest_reachable;
@@ -673,7 +684,7 @@ static inline bool _Scheduler_strong_APA_Enqueue(
uint32_t cpu_max;
uint32_t cpu_index;
- Per_CPU_Control *cpu_to_preempt;
+ Per_CPU_Control *cpu_to_preempt = NULL;
Scheduler_strong_APA_Node *strong_node;
@@ -711,7 +722,12 @@ static inline bool _Scheduler_strong_APA_Enqueue(
rear,
&cpu_to_preempt
+ * there would always be a lowest_reachable task, hence cpu_to_preempt
+ * would not be NULL.
+ _Assert( cpu_to_preempt != NULL );
return _Scheduler_strong_APA_Do_enqueue(
context,
lowest_reachable,
2.17.1
