[PATCH] bsps/arm: Add start up support for ARMv6 RPi Models
pranav dangipranav at gmail.com
Tue Jul 6 15:53:12 UTC 2021
 bsps/arm/shared/start/start.S | 8 +++++++-
 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/bsps/arm/shared/start/start.S b/bsps/arm/shared/start/start.S
index bd623178ed..2ba6541405 100644
--- a/bsps/arm/shared/start/start.S
+++ b/bsps/arm/shared/start/start.S
@@ -482,16 +482,22 @@ bsp_start_hook_0_done:
 .Lvector_table_copy_done:
-#if (__ARM_ARCH >= 7 && __ARM_ARCH_PROFILE == 'A') || __ARM_ARCH >= 8
 	 * This code path is only executed by the primary processor.  Set the
 	 * VBAR to the normal vector table.  For secondary processors, this is
 	 * done by bsp_start_hook_0().
+#if (__ARM_ARCH >= 7 && __ARM_ARCH_PROFILE == 'A') || __ARM_ARCH >= 8
 	ldr	r0, =bsp_vector_table_begin
 	dsb
 	mcr	p15, 0, r0, c12, c0, 0
 	isb
+#elif defined __ARM_ARCH_6KZ__
+	mov     r1, #0
+	ldr     r0, =bsp_vector_table_begin
+	mcr     p15, 0, r1, c7, c10, 4      /* DataSync */
+	mcr     p15, 0, r0, c12, c0, 0      /* Load VBAR */
+	mcr     p15, 0, r1, c7, c5, 4       /* Flush Prefetch */
 #endif
 	SWITCH_FROM_ARM_TO_THUMB	r3
2.30.2
