[PATCH] Reports: Convert to C++
Ryan Long ryan.long at oarcorp.com
Tue Jul 6 15:53:20 UTC 2021
Made formatting consistent and converted C code to C++.
 tester/covoar/ReportsBase.cc |  525 +++++++++----------
 tester/covoar/ReportsBase.h  |  156 +++---
 tester/covoar/ReportsHtml.cc | 1183 +++++++++++++++++-------------------------
 tester/covoar/ReportsHtml.h  |  141 ++---
 tester/covoar/ReportsText.cc |  348 ++++++-------
 tester/covoar/ReportsText.h  |   75 ++-
 6 files changed, 1041 insertions(+), 1387 deletions(-)
diff --git a/tester/covoar/ReportsBase.cc b/tester/covoar/ReportsBase.cc
index 328980d..3041df2 100644
--- a/tester/covoar/ReportsBase.cc
+++ b/tester/covoar/ReportsBase.cc
@@ -4,6 +4,9 @@
 #include <sys/stat.h>
 #include <sys/types.h>
+#include <iomanip>
+#include <sstream>
 #include "ReportsBase.h"
 #include "app_common.h"
 #include "CoverageRanges.h"
@@ -20,10 +23,12 @@
 namespace Coverage {
-ReportsBase::ReportsBase( time_t timestamp, std::string symbolSetName ):
-  reportExtension_m(""),
-  symbolSetName_m(symbolSetName),
-  timestamp_m( timestamp )
+ReportsBase::ReportsBase(
+  time_t             timestamp,
+  const std::string& symbolSetName
+): reportExtension_m( "" ),
+   symbolSetName_m( symbolSetName ),
+   timestamp_m(  timestamp  )
@@ -31,14 +36,14 @@ ReportsBase::~ReportsBase()
-FILE* ReportsBase::OpenFile(
-  const char* const fileName,
-  const char* const symbolSetName
+std::ofstream* ReportsBase::OpenFile(
+  const std::string& fileName,
-  int          sc;
-  FILE        *aFile;
-  std::string  file;
+  int            sc;
+  std::ofstream* aFile = new std::ofstream;
+  std::string    file;
   std::string symbolSetOutputDirectory;
   rld::path::path_join(
@@ -51,136 +56,110 @@ FILE* ReportsBase::OpenFile(
 #ifdef _WIN32
   sc = _mkdir( symbolSetOutputDirectory );
 #else
-  sc = mkdir( symbolSetOutputDirectory.c_str(),0755 );
+  sc = mkdir( symbolSetOutputDirectory.c_str(), 0755 );
 #endif
-  if ( (sc == -1) && (errno != EEXIST) ) {
-    fprintf(
-      stderr,
-      "Unable to create output directory %s\n",
-      symbolSetOutputDirectory.c_str()
+  if ( ( sc == -1 ) && ( errno != EEXIST ) ) {
+    std::cerr << "Unable to create output directory "
+              << symbolSetOutputDirectory << "\n";
     return NULL;
   file = symbolSetOutputDirectory;
-  rld::path::path_join(file, fileName, file);
+  rld::path::path_join( file, fileName, file );
   // Open the file.
-  aFile = fopen( file.c_str(), "w" );
-  if ( !aFile ) {
-    fprintf( stderr, "Unable to open %s\n", file.c_str() );
+  aFile->open( file );
+  if ( !aFile->is_open() ) {
+    std::cerr << "Unable to open " << file << "\n";
   return aFile;
-void ReportsBase::WriteIndex(
+void ReportsBase::WriteIndex( const std::string& fileName )
-FILE* ReportsBase::OpenAnnotatedFile(
+std::ofstream* ReportsBase::OpenAnnotatedFile( const std::string& fileName )
-  return OpenFile(fileName, symbolSetName_m.c_str());
+  return OpenFile( fileName, symbolSetName_m );
-FILE* ReportsBase::OpenBranchFile(
-  bool              hasBranches
+std::ofstream* ReportsBase::OpenBranchFile(
+  bool               hasBranches
-FILE* ReportsBase::OpenCoverageFile(
+std::ofstream* ReportsBase::OpenCoverageFile( const std::string& fileName )
-FILE* ReportsBase::OpenNoRangeFile(
+std::ofstream* ReportsBase::OpenNoRangeFile( const std::string& fileName )
-FILE* ReportsBase::OpenSizeFile(
+std::ofstream* ReportsBase::OpenSizeFile( const std::string& fileName )
-FILE* ReportsBase::OpenSymbolSummaryFile(
+std::ofstream* ReportsBase::OpenSymbolSummaryFile(
-void ReportsBase::CloseFile(
-  FILE*  aFile
+void ReportsBase::CloseFile( std::ofstream* aFile )
-  fclose( aFile );
+  aFile->close();
-void ReportsBase::CloseAnnotatedFile(
-  FILE*  aFile
+void ReportsBase::CloseAnnotatedFile( std::ofstream* aFile )
   CloseFile( aFile );
-void ReportsBase::CloseBranchFile(
-  FILE*  aFile,
-  bool   hasBranches
+void ReportsBase::CloseBranchFile( std::ofstream* aFile, bool hasBranches )
   CloseFile( aFile );
-void  ReportsBase::CloseCoverageFile(
-  FILE*  aFile
+void  ReportsBase::CloseCoverageFile( std::ofstream* aFile )
   CloseFile( aFile );
-void  ReportsBase::CloseNoRangeFile(
-  FILE*  aFile
+void  ReportsBase::CloseNoRangeFile( std::ofstream* aFile )
   CloseFile( aFile );
-void  ReportsBase::CloseSizeFile(
-  FILE*  aFile
+void  ReportsBase::CloseSizeFile( std::ofstream* aFile )
   CloseFile( aFile );
-void  ReportsBase::CloseSymbolSummaryFile(
-  FILE*  aFile
+void  ReportsBase::CloseSymbolSummaryFile( std::ofstream* aFile )
   CloseFile( aFile );
-std::string expand_tabs(const std::string& in) {
+std::string  expand_tabs( const std::string& in )
   std::string expanded = "";
-  int i = 0;
+  int         i = 0;
-  for (char c : in) {
-    if (c == '\t') {
-      int num_tabs = 4 - (i % 4);
-      expanded.append(num_tabs, ' ');
+  for ( char c : in ) {
+    if ( c == '\t' ) {
+      int num_tabs = 4 - ( i % 4 );
+      expanded.append( num_tabs, ' ' );
       i += num_tabs;
     } else {
       expanded += c;
@@ -194,62 +173,69 @@ std::string expand_tabs(const std::string& in) {
  *  Write annotated report
-void ReportsBase::WriteAnnotatedReport(
-  FILE*                      aFile = NULL;
-  Coverage::CoverageRanges*  theBranches;
-  Coverage::CoverageRanges*  theRanges;
-  Coverage::CoverageMapBase* theCoverageMap = NULL;
-  uint32_t                   bAddress = 0;
-  AnnotatedLineState_t       state;
-  aFile = OpenAnnotatedFile(fileName);
-  if (!aFile)
+void ReportsBase::WriteAnnotatedReport( const std::string& fileName )
+  std::ofstream*              aFile = NULL;
+  Coverage::CoverageRanges*   theBranches;
+  Coverage::CoverageRanges*   theRanges;
+  Coverage::CoverageMapBase*  theCoverageMap = NULL;
+  uint32_t                    bAddress = 0;
+  AnnotatedLineState_t        state;
+  aFile = OpenAnnotatedFile( fileName );
     return;
   // Process uncovered branches for each symbol.
-  const std::vector<std::string>& symbols = SymbolsToAnalyze->getSymbolsForSet(symbolSetName_m);
+  const std::vector<std::string>& symbols =
+    SymbolsToAnalyze->getSymbolsForSet( symbolSetName_m );
-  for (const auto& symbol : symbols) {
-    const SymbolInformation& info = SymbolsToAnalyze->allSymbols().at(symbol);
+  for ( const auto& symbol : symbols ) {
+    const SymbolInformation& info =
+      SymbolsToAnalyze->allSymbols().at( symbol );
     // If uncoveredRanges and uncoveredBranches don't exist, then the
     // symbol was never referenced by any executable.  Just skip it.
-    if ((info.uncoveredRanges == NULL) &&
-        (info.uncoveredBranches == NULL))
+    if ( ( info.uncoveredRanges == NULL ) &&
+         ( info.uncoveredBranches == NULL ) )
       continue;
     // If uncoveredRanges and uncoveredBranches are empty, then everything
     // must have been covered for this symbol.  Just skip it.
-    if ((info.uncoveredRanges->set.empty()) &&
-        (info.uncoveredBranches->set.empty()))
+    if ( ( info.uncoveredRanges->set.empty() ) &&
+         ( info.uncoveredBranches->set.empty() ) )
       continue;
     theCoverageMap = info.unifiedCoverageMap;
-    bAddress = info.baseAddress;
-    theRanges = info.uncoveredRanges;
-    theBranches = info.uncoveredBranches;
+    bAddress       = info.baseAddress;
+    theRanges      = info.uncoveredRanges;
+    theBranches    = info.uncoveredBranches;
     // Add annotations to each line where necessary
     AnnotatedStart( aFile );
-    for (const auto& instruction : info.instructions) {
-      uint32_t           id = 0;
-      std::string        annotation = "";
-      std::string        line;
-      const std::size_t  LINE_LENGTH = 150;
-      char               textLine[LINE_LENGTH];
+    for ( const auto& instruction : info.instructions ) {
+      uint32_t          id = 0;
+      std::string       annotation = "";
+      std::string       line;
+      const std::size_t LINE_LENGTH = 150;
+      std::stringstream ss;
+      std::string       textLine = "";
       state = A_SOURCE;
       if ( instruction.isInstruction ) {
-        if (!theCoverageMap->wasExecuted( instruction.address - bAddress )){
+        if ( !theCoverageMap->wasExecuted( instruction.address - bAddress ) ) {
           annotation = "<== NOT EXECUTED";
           state = A_NEVER_EXECUTED;
           id = theRanges->getId( instruction.address );
-        } else if (theCoverageMap->isBranch( instruction.address - bAddress )) {
+        } else if (
+          theCoverageMap->isBranch( instruction.address - bAddress )
           id = theBranches->getId( instruction.address );
-          if (theCoverageMap->wasAlwaysTaken( instruction.address - bAddress )){
+          if (
+            theCoverageMap->wasAlwaysTaken( instruction.address - bAddress )
             annotation = "<== ALWAYS TAKEN";
             state = A_BRANCH_TAKEN;
           } else if (
@@ -263,11 +249,16 @@ void ReportsBase::WriteAnnotatedReport(
-      std::string textLineWithoutTabs = expand_tabs(instruction.line);
-      snprintf( textLine, LINE_LENGTH, "%-90s", textLineWithoutTabs.c_str() );
+      std::string textLineWithoutTabs = expand_tabs( instruction.line );
+      ss << std::left << std::setw( 90 )
+         << textLineWithoutTabs.c_str();
+      textLine = ss.str().substr( 0, LINE_LENGTH );
       line = textLine + annotation;
-      PutAnnotatedLine( aFile, state, line, id);
+      PutAnnotatedLine( aFile, state, line, id );
     AnnotatedEnd( aFile );
@@ -279,37 +270,39 @@ void ReportsBase::WriteAnnotatedReport(
  *  Write branch report
-void ReportsBase::WriteBranchReport(
-  FILE*                     report = NULL;
+void ReportsBase::WriteBranchReport( const std::string& fileName )
+  std::ofstream*            report = NULL;
   unsigned int              count;
   bool                      hasBranches = true;
-  if ((SymbolsToAnalyze->getNumberBranchesFound(symbolSetName_m) == 0) ||
-      (BranchInfoAvailable == false) )
+  if ( ( SymbolsToAnalyze->getNumberBranchesFound( symbolSetName_m ) == 0 ) ||
+       ( BranchInfoAvailable == false ) )
      hasBranches = false;
   // Open the branch report file
   report = OpenBranchFile( fileName, hasBranches );
-  if (!report)
+  if ( !report ) {
     return;
   // If no branches were found then branch coverage is not supported
-  if ((SymbolsToAnalyze->getNumberBranchesFound(symbolSetName_m) != 0) &&
-      (BranchInfoAvailable == true) ) {
+  if ( ( SymbolsToAnalyze->getNumberBranchesFound( symbolSetName_m ) != 0 ) &&
+       ( BranchInfoAvailable == true ) ) {
     // Process uncovered branches for each symbol in the set.
     count = 0;
-      if (theBranches && !theBranches->set.empty()) {
-        for (const auto& range : theBranches->set) {
+      if ( theBranches && !theBranches->set.empty() ) {
+        for ( const auto& range : theBranches->set ) {
           count++;
           PutBranchEntry( report, count, symbol, info, range );
@@ -323,21 +316,19 @@ void ReportsBase::WriteBranchReport(
  *  Write coverage report
-void ReportsBase::WriteCoverageReport(
+void ReportsBase::WriteCoverageReport( const std::string& fileName )
-  FILE*                     report;
-  unsigned int              count;
-  FILE*                     NoRangeFile;
-  std::string               NoRangeName;
+  std::ofstream*             report;
+  unsigned int               count;
+  std::ofstream*             NoRangeFile;
+  std::string                NoRangeName;
   // Open special file that captures NoRange informaiton
   NoRangeName = "no_range_";
   NoRangeName +=  fileName;
-  NoRangeFile = OpenNoRangeFile ( NoRangeName.c_str() );
-  if (!NoRangeFile) {
+  NoRangeFile = OpenNoRangeFile( NoRangeName.c_str() );
+  if ( !NoRangeFile ) {
     return;
@@ -348,11 +339,13 @@ void ReportsBase::WriteCoverageReport(
   // Process uncovered ranges for each symbol.
   count = 0;
@@ -360,11 +353,11 @@ void ReportsBase::WriteCoverageReport(
     // referenced by any executable.  There may be a problem with the
     // desired symbols list or with the executables so put something
     // in the report.
-    if (theRanges == NULL) {
+    if ( theRanges == NULL ) {
       putCoverageNoRange( report, NoRangeFile, count, symbol );
       count++;
-    }  else if (!theRanges->set.empty()) {
-      for (const auto& range : theRanges->set) {
+    }  else if ( !theRanges->set.empty() ) {
+      for ( const auto& range : theRanges->set ) {
         PutCoverageLine( report, count, symbol, info, range );
         count++;
@@ -373,17 +366,14 @@ void ReportsBase::WriteCoverageReport(
   CloseNoRangeFile( NoRangeFile );
   CloseCoverageFile( report );
  * Write size report
-void ReportsBase::WriteSizeReport(
+void ReportsBase::WriteSizeReport( const std::string& fileName )
-  FILE*                     report;
   unsigned int              count;
@@ -394,16 +384,18 @@ void ReportsBase::WriteSizeReport(
   count = 0;
-    if (theRanges && !theRanges->set.empty()) {
+    if ( theRanges && !theRanges->set.empty() ) {
         PutSizeLine( report, count, symbol, range );
         count++;
@@ -413,12 +405,10 @@ void ReportsBase::WriteSizeReport(
   CloseSizeFile( report );
-void ReportsBase::WriteSymbolSummaryReport(
+void ReportsBase::WriteSymbolSummaryReport( const std::string& fileName )
-  FILE*                                           report;
   // Open the report file.
   report = OpenSymbolSummaryFile( fileName );
@@ -427,11 +417,13 @@ void ReportsBase::WriteSymbolSummaryReport(
   // Process each symbol.
   count = 0;
     PutSymbolSummaryLine( report, count, symbol, info );
     count++;
@@ -441,42 +433,43 @@ void ReportsBase::WriteSymbolSummaryReport(
 void  ReportsBase::WriteSummaryReport(
     // Calculate coverage statistics and output results.
-  uint32_t                                        a;
-  uint32_t                                        endAddress;
-  uint32_t                                        notExecuted = 0;
-  double                                          percentage;
-  double                                          percentageBranches;
-  Coverage::CoverageMapBase*                      theCoverageMap;
-  uint32_t                                        totalBytes = 0;
-  FILE*                                           report;
+  uint32_t                   a;
+  uint32_t                   endAddress;
+  uint32_t                   notExecuted = 0;
+  double                     percentage;
+  double                     percentageBranches;
+  Coverage::CoverageMapBase* theCoverageMap;
+  uint32_t                   totalBytes = 0;
   report = OpenFile( fileName, symbolSetName );
-  if ( !report ) {
+  if ( !report->is_open() ) {
     return;
   // Look at each symbol.
-  const std::vector<std::string>& symbols = SymbolsToAnalyze->getSymbolsForSet(symbolSetName);
+    SymbolsToAnalyze->getSymbolsForSet( symbolSetName );
-    SymbolInformation info = SymbolsToAnalyze->allSymbols().at(symbol);
+    SymbolInformation info = SymbolsToAnalyze->allSymbols().at( symbol );
     // If the symbol's unified coverage map exists, scan through it
     // and count bytes.
-    if (theCoverageMap) {
+    if ( theCoverageMap ) {
       endAddress = info.stats.sizeInBytes - 1;
-      for (a = 0; a <= endAddress; a++) {
+      for ( a = 0; a <= endAddress; a++ ) {
         totalBytes++;
-        if (!theCoverageMap->wasExecuted( a ))
+        if ( !theCoverageMap->wasExecuted( a ) )
           notExecuted++;
@@ -489,75 +482,58 @@ void  ReportsBase::WriteSummaryReport(
   percentageBranches = (double) (
-    SymbolsToAnalyze->getNumberBranchesAlwaysTaken(symbolSetName) +
-      SymbolsToAnalyze->getNumberBranchesNeverTaken(symbolSetName) +
-      (SymbolsToAnalyze->getNumberBranchesNotExecuted(symbolSetName) * 2)
+    SymbolsToAnalyze->getNumberBranchesAlwaysTaken( symbolSetName ) +
+    SymbolsToAnalyze->getNumberBranchesNeverTaken( symbolSetName ) +
+  ( SymbolsToAnalyze->getNumberBranchesNotExecuted( symbolSetName ) * 2 )
   percentageBranches /=
-    (double) SymbolsToAnalyze->getNumberBranchesFound(symbolSetName) * 2;
+    (double) SymbolsToAnalyze->getNumberBranchesFound( symbolSetName ) * 2;
   percentageBranches *= 100.0;
-  fprintf( report, "Bytes Analyzed                   : %d\n", totalBytes );
-  fprintf( report, "Bytes Not Executed               : %d\n", notExecuted );
-  fprintf( report, "Percentage Executed              : %5.4g\n", 100.0 - percentage  );
-  fprintf( report, "Percentage Not Executed          : %5.4g\n", percentage  );
-  fprintf(
-    report,
-    "Unreferenced Symbols             : %d\n",
-    SymbolsToAnalyze->getNumberUnreferencedSymbols(symbolSetName)
-  fprintf(
-    report,
-    "Uncovered ranges found           : %d\n\n",
-    SymbolsToAnalyze->getNumberUncoveredRanges(symbolSetName)
-  if ((SymbolsToAnalyze->getNumberBranchesFound(symbolSetName) == 0) ||
-      (BranchInfoAvailable == false) ) {
-    fprintf( report, "No branch information available\n" );
+  (*report) << "Bytes Analyzed                   : " << totalBytes << "\n"
+            << "Bytes Not Executed               : " << notExecuted << "\n"
+            << "Percentage Executed              : "
+            << std::fixed << std::setprecision( 2 ) << std::setw( 5 )
+            << 100.0 - percentage << "\n"
+            << "Percentage Not Executed          : " << percentage << "\n"
+            << "Unreferenced Symbols             : "
+            << SymbolsToAnalyze->getNumberUnreferencedSymbols( symbolSetName )
+            << "\nUncovered ranges found           : "
+            << SymbolsToAnalyze->getNumberUncoveredRanges( symbolSetName )
+            << "\n\n";
+  if ( ( SymbolsToAnalyze->getNumberBranchesFound( symbolSetName ) == 0 ) ||
+       ( BranchInfoAvailable == false ) ) {
+    (*report) << "No branch information available\n";
   } else {
-    fprintf(
-      report,
-      "Total conditional branches found : %d\n",
-      SymbolsToAnalyze->getNumberBranchesFound(symbolSetName)
-    fprintf(
-      report,
-      "Total branch paths found         : %d\n",
-      SymbolsToAnalyze->getNumberBranchesFound(symbolSetName) * 2
-    fprintf(
-      report,
-      "Uncovered branch paths found     : %d\n",
-    fprintf(
-      report,
-      "   %d branches always taken\n",
-    fprintf(
-      report,
-      "   %d branches never taken\n",
-    fprintf(
-      report,
-      "   %d branch paths not executed\n",
-      SymbolsToAnalyze->getNumberBranchesNotExecuted(symbolSetName) * 2
-    fprintf(
-      report,
-      "Percentage branch paths covered  : %4.4g\n",
-      100.0 - percentageBranches
+    (*report) << "Total conditional branches found : "
+              << SymbolsToAnalyze->getNumberBranchesFound( symbolSetName )
+              << "\nTotal branch paths found         : "
+              << SymbolsToAnalyze->getNumberBranchesFound( symbolSetName ) * 2
+              << "\nUncovered branch paths found     : "
+              << SymbolsToAnalyze->getNumberBranchesAlwaysTaken( symbolSetName ) +
+              << "\n   "
+              << " branches always taken\n   "
+              << SymbolsToAnalyze->getNumberBranchesNeverTaken( symbolSetName )
+              << " branches never taken\n   "
+              << SymbolsToAnalyze->getNumberBranchesNotExecuted( symbolSetName ) * 2
+              << " branch paths not executed\n"
+              << "Percentage branch paths covered  : "
+              << std::fixed << std::setprecision( 2 ) << std::setw( 4 )
+              << 100.0 - percentageBranches << "\n";
-  fclose( report );
+  CloseFile( report );
-void GenerateReports(const std::string& symbolSetName)
+void GenerateReports( const std::string& symbolSetName )
   typedef std::list<ReportsBase *> reportList_t;
@@ -565,68 +541,69 @@ void GenerateReports(const std::string& symbolSetName)
   reportList_t::iterator ritr;
   std::string            reportName;
   ReportsBase*           reports;
+  time_t                 timestamp;
-  time_t timestamp;
+  timestamp = time( NULL ); /* get current cal time */
-  timestamp = time(NULL); /* get current cal time */
-  reports = new ReportsText(timestamp, symbolSetName);
-  reportList.push_back(reports);
-  reports = new ReportsHtml(timestamp, symbolSetName);
+  reports = new ReportsText( timestamp, symbolSetName );
+  reportList.push_back( reports );
-  for (ritr = reportList.begin(); ritr != reportList.end(); ritr++ ) {
+  reports = new ReportsHtml( timestamp, symbolSetName );
+  for ( ritr = reportList.begin(); ritr != reportList.end(); ritr++ ) {
     reports = *ritr;
     reportName = "index" + reports->ReportExtension();
-    if (Verbose)
-      fprintf(
-        stderr, "Generate %s\n", reportName.c_str()
-    reports->WriteIndex( reportName.c_str() );
+    if ( Verbose ) {
+      std::cerr << "Generate " << reportName << "\n";
+    reports->WriteIndex( reportName );
     reportName = "annotated" + reports->ReportExtension();
-    if (Verbose)
-      fprintf(
-    reports->WriteAnnotatedReport( reportName.c_str() );
+    if ( Verbose ) {
+    reports->WriteAnnotatedReport( reportName );
     reportName = "branch" + reports->ReportExtension();
-    if (Verbose)
-      fprintf(
-    reports->WriteBranchReport(reportName.c_str() );
+    if ( Verbose ) {
+    reports->WriteBranchReport( reportName );
     reportName = "uncovered" + reports->ReportExtension();
-    if (Verbose)
-      fprintf(
-    reports->WriteCoverageReport(reportName.c_str() );
+    if ( Verbose ) {
+    reports->WriteCoverageReport( reportName );
     reportName = "sizes" + reports->ReportExtension();
-    if (Verbose)
-      fprintf(
-    reports->WriteSizeReport(reportName.c_str() );
+    if ( Verbose ) {
+    reports->WriteSizeReport( reportName );
     reportName = "symbolSummary" + reports->ReportExtension();
-    if (Verbose)
-      fprintf(
-    reports->WriteSymbolSummaryReport(reportName.c_str() );
+    if ( Verbose ) {
+    reports->WriteSymbolSummaryReport( reportName );
     reports = *ritr;
     delete reports;
-  ReportsBase::WriteSummaryReport( "summary.txt", symbolSetName.c_str() );
+  ReportsBase::WriteSummaryReport( "summary.txt", symbolSetName );
diff --git a/tester/covoar/ReportsBase.h b/tester/covoar/ReportsBase.h
index ab8f8dd..9dfa080 100644
--- a/tester/covoar/ReportsBase.h
+++ b/tester/covoar/ReportsBase.h
@@ -11,6 +11,8 @@
 #include <stdint.h>
 #include <string>
+#include <iostream>
+#include <fstream>
 #include <time.h>
 #include "DesiredSymbols.h"
@@ -24,7 +26,8 @@ namespace Coverage {
 class ReportsBase {
   public:
-    ReportsBase( time_t timestamp, std::string symbolSetName );
+    ReportsBase( time_t timestamp, const std::string& symbolSetName );
     virtual ~ReportsBase();
@@ -32,9 +35,7 @@ class ReportsBase {
      *  @param[in] fileName identifies the report file name
-    virtual void WriteIndex(
+    virtual void WriteIndex( const std::string& fileName );
      *  This method produces an annotated assembly listing report containing
@@ -42,9 +43,7 @@ class ReportsBase {
      *  @param[in] fileName identifies the annotated report file name
-    void WriteAnnotatedReport(
+    void WriteAnnotatedReport( const std::string& fileName );
      *  This method produces a report that contains information about each
@@ -52,9 +51,7 @@ class ReportsBase {
      *  @param[in] fileName identifies the branch report file name
-    void WriteBranchReport(
+    void WriteBranchReport( const std::string& fileName );
@@ -62,9 +59,7 @@ class ReportsBase {
      *  @param[in] fileName identifies the coverage report file name
-    void WriteCoverageReport(
+    void WriteCoverageReport( const std::string& fileName );
      *  This method produces a summary report that lists each uncovered
@@ -72,9 +67,7 @@ class ReportsBase {
-    void WriteSizeReport(
+    void WriteSizeReport( const std::string& fileName );
      *  This method produces a summary report that lists information on
@@ -82,16 +75,14 @@ class ReportsBase {
-    void WriteSymbolSummaryReport(
+    void WriteSymbolSummaryReport( const std::string& fileName );
      *  This method produces a sumary report for the overall test run.
     static void  WriteSummaryReport(
@@ -136,9 +127,9 @@ class ReportsBase {
      *  @param[in] symbolSetName identifies the name of the report's symbol set
-     static FILE* OpenFile(
+    static std::ofstream* OpenFile(
@@ -147,9 +138,7 @@ class ReportsBase {
-    virtual FILE* OpenAnnotatedFile(
+    virtual std::ofstream* OpenAnnotatedFile( const std::string& fileName );
      *  This method opens a report file and verifies that it opened.
@@ -158,9 +147,9 @@ class ReportsBase {
      *  @param[in] hasBranches indicates if there are branches to report
-    virtual FILE* OpenBranchFile(
-      bool              hasBranches
+    virtual std::ofstream* OpenBranchFile(
+      bool               hasBranches
@@ -169,9 +158,7 @@ class ReportsBase {
-    virtual FILE* OpenCoverageFile(
+    virtual std::ofstream* OpenCoverageFile( const std::string& fileName );
@@ -179,9 +166,7 @@ class ReportsBase {
-    virtual FILE* OpenNoRangeFile(
+    virtual std::ofstream* OpenNoRangeFile( const std::string& fileName );
@@ -189,9 +174,7 @@ class ReportsBase {
-    virtual FILE* OpenSizeFile(
+    virtual std::ofstream* OpenSizeFile( const std::string& fileName );
@@ -199,8 +182,8 @@ class ReportsBase {
-    virtual FILE* OpenSymbolSummaryFile(
+    virtual std::ofstream* OpenSymbolSummaryFile(
@@ -208,9 +191,7 @@ class ReportsBase {
      *  @param[in] aFile identifies the report file name
-    static void CloseFile(
-      FILE*  aFile
+    static void CloseFile( std::ofstream* aFile );
      *  This method puts any necessary footer information into
@@ -218,9 +199,7 @@ class ReportsBase {
-    virtual void CloseAnnotatedFile(
-      FILE*  aFile
+    virtual void CloseAnnotatedFile( std::ofstream* aFile );
@@ -229,10 +208,7 @@ class ReportsBase {
-    virtual void CloseBranchFile(
-      FILE*  aFile,
-      bool   hasBranches
+    virtual void CloseBranchFile( std::ofstream* aFile, bool hasBranches );
@@ -240,9 +216,7 @@ class ReportsBase {
-    virtual void CloseCoverageFile(
-      FILE*  aFile
+    virtual void CloseCoverageFile( std::ofstream* aFile );
@@ -250,9 +224,7 @@ class ReportsBase {
-    void  CloseNoRangeFile(
-      FILE*  aFile
+    void  CloseNoRangeFile( std::ofstream* aFile );
@@ -260,9 +232,7 @@ class ReportsBase {
-    virtual void CloseSizeFile(
-      FILE*  aFile
+    virtual void CloseSizeFile( std::ofstream* aFile );
@@ -270,9 +240,7 @@ class ReportsBase {
-    virtual void CloseSymbolSummaryFile(
-      FILE*  aFile
+    virtual void CloseSymbolSummaryFile( std::ofstream* aFile );
      *  This method puts any necessary a line of annotated
@@ -284,9 +252,9 @@ class ReportsBase {
      *  @param[in] id identifies the branch or range id.
     virtual void PutAnnotatedLine(
-      FILE*                aFile,
+      std::ofstream*       aFile,
       AnnotatedLineState_t state,
-      std::string          line,
+      const std::string&   line,
       uint32_t             id
     )=0;
@@ -296,9 +264,7 @@ class ReportsBase {
-     virtual void AnnotatedStart(
-      FILE*                aFile
-    )=0;
+    virtual void AnnotatedStart( std::ofstream* aFile )=0;
@@ -306,9 +272,7 @@ class ReportsBase {
-     virtual void AnnotatedEnd(
-      FILE*                aFile
-    )=0;
+    virtual void AnnotatedEnd( std::ofstream* aFile )=0;
@@ -317,9 +281,7 @@ class ReportsBase {
      *  @param[in] report identifies the report file name
-    virtual bool PutNoBranchInfo(
-      FILE* report
-    ) = 0;
+    virtual bool PutNoBranchInfo( std::ofstream* report )=0;
      *  This method puts a branch entry into the branch report.
@@ -331,11 +293,11 @@ class ReportsBase {
      *  @param[in] range is the range information.
     virtual bool PutBranchEntry(
-      FILE*                                            report,
-      unsigned int                                     number,
-      const std::string&                               symbolName,
-      const SymbolInformation&                         symbolInfo,
-      const CoverageRanges::coverageRange_t&           range
+      std::ofstream*                         report,
+      unsigned int                           number,
+      const std::string&                     symbolName,
+      const SymbolInformation&               symbolInfo,
+      const CoverageRanges::coverageRange_t& range
     )=0;
@@ -347,10 +309,10 @@ class ReportsBase {
      *  @param[in] symbol is a pointer to the symbol information
     virtual void putCoverageNoRange(
-      FILE*        report,
-      FILE*        noRangeFile,
-      std::string  symbol
+      std::ofstream*     noRangeFile,
     )=0;
@@ -363,11 +325,11 @@ class ReportsBase {
     virtual bool PutCoverageLine(
-      FILE*                                           report,
     )=0;
@@ -379,10 +341,10 @@ class ReportsBase {
     virtual bool PutSizeLine(
-      FILE*                                           report,
     )=0;
@@ -394,10 +356,10 @@ class ReportsBase {
      *  @param[in] symbolInfo is the symbol's information.
     virtual bool PutSymbolSummaryLine(
-      FILE*                                           report,
     )=0;
@@ -407,7 +369,7 @@ class ReportsBase {
  *  @param[in] symbolSetName is the name of the symbol set to report on.
-void GenerateReports(const std::string& symbolSetName);
+void GenerateReports( const std::string& symbolSetName );
diff --git a/tester/covoar/ReportsHtml.cc b/tester/covoar/ReportsHtml.cc
index fe75cdd..6e4bc7e 100644
--- a/tester/covoar/ReportsHtml.cc
+++ b/tester/covoar/ReportsHtml.cc
@@ -2,6 +2,9 @@
+#include <sstream>
+#include <iomanip>
 #include <rld.h>
 #include "ReportsHtml.h"
@@ -25,14 +28,16 @@
    "</tr>\n" \
    "</tfoot>\n"
 #else
-#define TABLE_HEADER_CLASS
-#define TABLE_FOOTER
+#define TABLE_HEADER_CLASS ""
+#define TABLE_FOOTER ""
 #endif
-  ReportsHtml::ReportsHtml( time_t timestamp, std::string symbolSetName ):
-    ReportsBase( timestamp, symbolSetName )
+  ReportsHtml::ReportsHtml(
+    time_t             timestamp,
+  ): ReportsBase( timestamp, symbolSetName )
     reportExtension_m = ".html";
@@ -41,400 +46,309 @@ namespace Coverage {
-  void ReportsHtml::WriteIndex(
+  void ReportsHtml::WriteIndex( const std::string& fileName )
     #define PRINT_ITEM( _t, _n ) \
-       fprintf( \
-         aFile, \
-         "<li>%s (<a href=\"%s.html\">html</a> or "\
-         "<a href=\"%s.txt\">text</a>)</li>\n", \
-        _t, _n, _n );
+       (*aFile) << "<li>" \
+                << _t << " (<a href=\"" \
+                << _n << ".html\">html</a> or <a href=\"" \
+                << _n << ".txt\">text</a>)</li>\n";
     #define PRINT_TEXT_ITEM( _t, _n ) \
-       fprintf( \
-         aFile, \
-         "<li>%s (<a href=\"%s\">text</a>)</li>\n", \
-        _t, _n );
+                << _n << "\">text</a>)</li>\n";
-    FILE*  aFile;
+    std::ofstream*  aFile;
     // Open the file
     aFile = OpenFile( fileName );
-    fprintf(
-      aFile,
-      "<title>Index</title>\n"
-      "<div class=\"heading-title\">"
+    (*aFile) << "<title>Index</title>\n"
+             << "<div class=\"heading-title\">";
-    if (projectName)
-      fprintf(
-        aFile,
-         "%s<br>",
-         projectName
-    fprintf(
-      aFile,
-      "Coverage Analysis Reports</div>\n"
-      "<div class =\"datetime\">%s</div>\n",
-      asctime( localtime(&timestamp_m) )
+    if ( projectName ) {
+      (*aFile) << projectName << "<br>";
-    fprintf( aFile, "<ul>\n" );
+    (*aFile) << "Coverage Analysis Reports</div>\n"
+             << "<div class =\"datetime\">"
+             <<  asctime( localtime( &timestamp_m ) ) << "</div>\n";
-    PRINT_TEXT_ITEM( "Summary",         "summary.txt" );
-    PRINT_ITEM( "Coverage Report",      "uncovered" );
-    PRINT_ITEM( "Branch Report",        "branch" );
-    PRINT_ITEM( "Annotated Assembly",   "annotated" );
-    PRINT_ITEM( "Symbol Summary",       "symbolSummary" );
-    PRINT_ITEM( "Uncovered Range Size Report",          "sizes" );
+    (*aFile) << "<ul>\n";
-    PRINT_TEXT_ITEM( "Explanations Not Found", "ExplanationsNotFound.txt" );
+    PRINT_TEXT_ITEM( "Summary",                     "summary.txt" );
+    PRINT_ITEM(      "Coverage Report",             "uncovered" );
+    PRINT_ITEM(      "Branch Report",               "branch" );
+    PRINT_ITEM(      "Annotated Assembly",          "annotated" );
+    PRINT_ITEM(      "Symbol Summary",              "symbolSummary" );
+    PRINT_ITEM(      "Uncovered Range Size Report", "sizes" );
+    PRINT_TEXT_ITEM( "Explanations Not Found",      "ExplanationsNotFound.txt" );
-    fprintf(
-      aFile,
-      "</ul>\n"
-      "<!-- INSERT PROJECT SPECIFIC ITEMS HERE -->\n"
-      "</html>\n"
+    (*aFile) << "</ul>\n"
+             << "<!-- INSERT PROJECT SPECIFIC ITEMS HERE -->\n"
+             << "</html>\n";
     CloseFile( aFile );
+    delete aFile;
     #undef PRINT_ITEM
     #undef PRINT_TEXT_ITEM
-  FILE* ReportsHtml::OpenFile(
+  std::ofstream* ReportsHtml::OpenFile( const std::string& fileName )
-    FILE*  aFile;
     // Open the file
-    aFile = ReportsBase::OpenFile( fileName, symbolSetName_m.c_str() );
+    aFile = ReportsBase::OpenFile( fileName, symbolSetName_m );
     // Put Header information on the file
-    fprintf(
-      aFile,
-      "<html>\n"
-      "<meta http-equiv=\"Content-Language\" content=\"English\" >\n"
-      "<meta http-equiv=\"Content-Type\" content=\"text/html; charset=us-ascii\" >\n"
-      "<link rel=\"stylesheet\" type=\"text/css\" href=\"../covoar.css\" media=\"screen\" >\n"
-      "<script type=\"text/javascript\" src=\"../table.js\"></script>\n"
+    (*aFile) << "<html>\n"
+             << "<meta http-equiv=\"Content-Language\" content=\"English\" >\n"
+             << "<meta http-equiv=\"Content-Type\" content=\"text/html; charset=us-ascii\" >\n"
+             << "<link rel=\"stylesheet\" type=\"text/css\" href=\"../covoar.css\" media=\"screen\" >\n"
+             << "<script type=\"text/javascript\" src=\"../table.js\"></script>"
+             << "\n";
     return aFile;
-  FILE* ReportsHtml::OpenAnnotatedFile(
+  std::ofstream* ReportsHtml::OpenAnnotatedFile( const std::string& fileName )
-    FILE *aFile;
     // Open the file
-    aFile = OpenFile(fileName);
+    aFile = OpenFile( fileName );
-    fprintf(
-      aFile,
-      "<title>Annotated Report</title>\n"
+    (*aFile) << "<title>Annotated Report</title>\n"
-    if (projectName)
-      fprintf(
-        aFile,
-         "%s<br>",
-         projectName
-    fprintf(
-      aFile,
-      "Annotated Report</div>\n"
-      "<body>\n"
-      "<pre class=\"code\">\n",
+    (*aFile) << "Annotated Report</div>\n"
+             << "<body>\n"
+             << "<pre class=\"code\">\n";
     return aFile;
-  FILE* ReportsHtml::OpenBranchFile(
-    bool              hasBranches
+  std::ofstream* ReportsHtml::OpenBranchFile(
+    bool               hasBranches
-    FILE *aFile;
     // Open the file
     // Put header information into the file
-    fprintf(
-      aFile,
-      "<title>Branch Report</title>\n"
+    (*aFile) << "<title>Branch Report</title>\n"
-    if (projectName)
-      fprintf(
-        aFile,
-        "%s<br>",
-        projectName
-    fprintf(
-      aFile,
-      "Branch Report</div>\n"
-      "<body>\n"
-      "<table class=\"covoar table-autosort:0 table-autofilter table-stripeclass:covoar-tr-odd"
-          TABLE_HEADER_CLASS "\">\n"
-      "<thead>\n"
-      "<tr>\n"
-      "<th class=\"table-sortable:default\" align=\"left\">Symbol</th>\n"
-      "<th class=\"table-sortable:default\" align=\"left\">Line</th>\n"
-      "<th class=\"table-filterable table-sortable:default\" align=\"left\">File</th>\n"
-      "<th class=\"table-sortable:numeric\" align=\"left\">Size <br>Bytes</th>\n"
-      "<th class=\"table-sortable:default\" align=\"left\">Reason</th>\n"
-      "<th class=\"table-filterable table-sortable:default\" align=\"left\">Taken</th>\n"
-      "<th class=\"table-filterable table-sortable:default\" align=\"left\">Not Taken</th>\n"
-      "<th class=\"table-filterable table-sortable:default\" align=\"left\">Classification</th>\n"
-      "<th class=\"table-sortable:default\" align=\"left\">Explanation</th>\n"
-      "</tr>\n"
-      "</thead>\n"
-      "<tbody>\n",
+    (*aFile) << "Branch Report</div>\n"
+             << "<body>\n"
+             << "<table class=\"covoar table-autosort:0 table-autofilter table-stripeclass:covoar-tr-odd"
+             << TABLE_HEADER_CLASS << "\">\n"
+             << "<thead>\n"
+             << "<tr>\n"
+             << "<th class=\"table-sortable:default\" align=\"left\">Symbol</th>\n"
+             << "<th class=\"table-sortable:default\" align=\"left\">Line</th>\n"
+             << "<th class=\"table-filterable table-sortable:default\" align=\"left\">File</th>\n"
+             << "<th class=\"table-sortable:numeric\" align=\"left\">Size <br>Bytes</th>\n"
+             << "<th class=\"table-sortable:default\" align=\"left\">Reason</th>\n"
+             << "<th class=\"table-filterable table-sortable:default\" align=\"left\">Taken</th>\n"
+             << "<th class=\"table-filterable table-sortable:default\" align=\"left\">Not Taken</th>\n"
+             << "<th class=\"table-filterable table-sortable:default\" align=\"left\">Classification</th>\n"
+             << "<th class=\"table-sortable:default\" align=\"left\">Explanation</th>\n"
+             << "</tr>\n"
+             << "</thead>\n"
+             << "<tbody>\n";
     return aFile;
-  FILE*  ReportsHtml::OpenCoverageFile(
+  std::ofstream*  ReportsHtml::OpenCoverageFile( const std::string& fileName )
-    FILE *aFile;
     // Open the file
-    fprintf(
-      aFile,
-        "<title>Coverage Report</title>\n"
+    (*aFile) << "<title>Coverage Report</title>\n"
-    if (projectName)
-      fprintf(
-        aFile,
-        "%s<br>",
-        projectName
-    fprintf(
-      aFile,
-       "Coverage Report</div>\n"
-       "<body>\n"
-      "<thead>\n"
-      "<tr>\n"
-      "<th class=\"table-sortable:default\" align=\"left\">Range</th>\n"
-      "<th class=\"table-sortable:numeric\" align=\"left\">Size <br>Instructions</th>\n"
-      "</tr>\n"
-      "</thead>\n"
-      "<tbody>\n",
+    (*aFile) << "Coverage Report</div>\n"
+             << "<body>\n"
+             << "<thead>\n"
+             << "<tr>\n"
+             << "<th class=\"table-sortable:default\" align=\"left\">Range</th>\n"
+             << "<th class=\"table-sortable:numeric\" align=\"left\">Size <br>Instructions</th>\n"
+             << "</tr>\n"
+             << "</thead>\n"
+             << "<tbody>\n";
     return aFile;
-  FILE* ReportsHtml::OpenNoRangeFile(
+  std::ofstream* ReportsHtml::OpenNoRangeFile( const std::string& fileName )
-    FILE *aFile;
     // Open the file
-    fprintf(
-      aFile,
-        "<title> Report</title>\n"
+    (*aFile) << "<title> Report</title>\n"
-    if (projectName)
-      fprintf(
-        aFile,
-        "%s<br>",
-        projectName
-    fprintf(
-      aFile,
-       "No Range Report</div>\n"
-        "<body>\n"
-      "<thead>\n"
-      "<tr>\n"
-      "</tr>\n"
-      "</thead>\n"
-      "<tbody>\n",
+    (*aFile) << "No Range Report</div>\n"
+             << "<body>\n"
+             << "<thead>\n"
+             << "<tr>\n"
+             << "</tr>\n"
+             << "</thead>\n"
+             << "<tbody>\n";
     return aFile;
-  FILE*  ReportsHtml::OpenSizeFile(
+  std::ofstream* ReportsHtml::OpenSizeFile( const std::string& fileName )
-    FILE *aFile;
     // Open the file
-    fprintf(
-      aFile,
-      "<title>Uncovered Range Size Report</title>\n"
+    (*aFile) << "<title>Uncovered Range Size Report</title>\n"
-    if (projectName)
-      fprintf(
-        aFile,
-        "%s<br>",
-        projectName
-    fprintf(
-      aFile,
-      "Uncovered Range Size Report</div>\n"
-      "<body>\n"
-      "<thead>\n"
-      "<tr>\n"
-      "<th class=\"table-sortable:numeric\" align=\"left\">Size</th>\n"
-      "</tr>\n"
-      "</thead>\n"
-      "<tbody>\n",
+    (*aFile) << "Uncovered Range Size Report</div>\n"
+             << "<body>\n"
+             << "<thead>\n"
+             << "<tr>\n"
+             << "<th class=\"table-sortable:numeric\" align=\"left\">Size</th>\n"
+             << "</tr>\n"
+             << "</thead>\n"
+             << "<tbody>\n";
     return aFile;
-  FILE*  ReportsHtml::OpenSymbolSummaryFile(
+  std::ofstream* ReportsHtml::OpenSymbolSummaryFile(
-    FILE *aFile;
     // Open the file
-    fprintf(
-      aFile,
-      "<title>Symbol Summary Report</title>\n"
+    (*aFile) << "<title>Symbol Summary Report</title>\n"
-    if (projectName)
-      fprintf(
-        aFile,
-        "%s<br>",
-        projectName
-    fprintf(
-      aFile,
-      "Symbol Summary Report</div>\n"
-      "<body>\n"
-      "<thead>\n"
-      "<tr>\n"
-      "<th class=\"table-sortable:default\" align=\"center\">Symbol</th>\n"
-      "<th class=\"table-sortable:numeric\" align=\"center\">Total<br>Size<br>Bytes</th>\n"
-      "<th class=\"table-sortable:numeric\" align=\"center\">Total<br>Size<br>Instr</th>\n"
-      "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Ranges</th>\n"
-      "<th class=\"table-sortable:numeric\" align=\"center\">Uncovered<br>Size<br>Bytes</th>\n"
-      "<th class=\"table-sortable:numeric\" align=\"center\">Uncovered<br>Size<br>Instr</th>\n"
-      "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Branches</th>\n"
-      "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Always<br>Taken</th>\n"
-      "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Never<br>Taken</th>\n"
-      "<th class=\"table-sortable:numeric\" align=\"center\">Percent<br>Uncovered<br>Instructions</th>\n"
-      "<th class=\"table-sortable:numeric\" align=\"center\">Percent<br>Uncovered<br>Bytes</th>\n"
-      "</tr>\n"
-      "</thead>\n"
-      "<tbody>\n",
+    (*aFile) << "Symbol Summary Report</div>\n"
+             << "<body>\n"
+             << "<thead>\n"
+             << "<tr>\n"
+             << "<th class=\"table-sortable:default\" align=\"center\">Symbol</th>\n"
+             << "<th class=\"table-sortable:numeric\" align=\"center\">Total<br>Size<br>Bytes</th>\n"
+             << "<th class=\"table-sortable:numeric\" align=\"center\">Total<br>Size<br>Instr</th>\n"
+             << "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Ranges</th>\n"
+             << "<th class=\"table-sortable:numeric\" align=\"center\">Uncovered<br>Size<br>Bytes</th>\n"
+             << "<th class=\"table-sortable:numeric\" align=\"center\">Uncovered<br>Size<br>Instr</th>\n"
+             << "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Branches</th>\n"
+             << "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Always<br>Taken</th>\n"
+             << "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Never<br>Taken</th>\n"
+             << "<th class=\"table-sortable:numeric\" align=\"center\">Percent<br>Uncovered<br>Instructions</th>\n"
+             << "<th class=\"table-sortable:numeric\" align=\"center\">Percent<br>Uncovered<br>Bytes</th>\n"
+             << "</tr>\n"
+             << "</thead>\n"
+             << "<tbody>\n";
     return aFile;
-  void ReportsHtml::AnnotatedStart(
-    FILE*                aFile
+  void ReportsHtml::AnnotatedStart( std::ofstream* aFile )
-    fprintf(
-      aFile,
-      "<hr>\n"
+    (*aFile) << "<hr>\n";
-  void ReportsHtml::AnnotatedEnd(
-    FILE*                aFile
+  void ReportsHtml::AnnotatedEnd( std::ofstream* aFile )
   void ReportsHtml::PutAnnotatedLine(
-    FILE*                aFile,
-    std::string          line,
     uint32_t             id
     std::string stateText;
-    char        number[10];
+    std::string number;
-    sprintf(number,"%d", id);
+    number = std::to_string( id );
     // Set the stateText based upon the current state.
-    switch (state) {
+    switch ( state ) {
       case  A_SOURCE:
         stateText = "</pre>\n<pre class=\"code\">\n";
         break;
@@ -460,7 +374,7 @@ namespace Coverage {
         stateText += "\"></a><pre class=\"codeNeverTaken\">\n";
         break;
       default:
-        throw rld::error( "Unknown state", "ReportsHtml::PutAnnotatedLine");
+        throw rld::error( "Unknown state", "ReportsHtml::PutAnnotatedLine" );
         break;
@@ -468,40 +382,43 @@ namespace Coverage {
     // format.  If it has changed close out the old format and open up the
     // new format.
     if ( state != lastState_m ) {
-      fprintf( aFile, "%s", stateText.c_str() );
+      (*aFile) << stateText;
       lastState_m = state;
     // For all the characters in the line replace html reserved special
     // characters and output the line. Note that for a /pre block this
     // is only a '<' symbol.
-    for (unsigned int i=0; i<line.size(); i++ ) {
-      if ( line[i] == '<' )
-        fprintf( aFile, "<" );
-      else
-        fprintf( aFile, "%c", line[i] );
+    for ( unsigned int i = 0; i < line.size(); i++ ) {
+      if ( line[i] == '<' ) {
+        (*aFile) << "<";
+      } else {
+        (*aFile) << line[i];
-    fprintf( aFile, "\n");
+    (*aFile) << "\n";
-  bool ReportsHtml::PutNoBranchInfo(
-    FILE* report
+  bool ReportsHtml::PutNoBranchInfo( std::ofstream* report )
-    if (BranchInfoAvailable &&
-      SymbolsToAnalyze->getNumberBranchesFound(symbolSetName_m) != 0)
-      fprintf( report, "All branch paths taken.\n" );
-    else
-      fprintf( report, "No branch information found.\n" );
+    if ( BranchInfoAvailable &&
+         SymbolsToAnalyze->getNumberBranchesFound( symbolSetName_m ) != 0
+      (*report) << "All branch paths taken." << "\n";
+    } else {
+      (*report) << "No branch information found." << "\n";
     return true;
   bool ReportsHtml::PutBranchEntry(
-    FILE*                                            report,
-    unsigned int                                     count,
+    unsigned int                           count,
     const Coverage::Explanation* explanation;
@@ -512,125 +429,110 @@ namespace Coverage {
     // Mark the background color different for odd and even lines.
-    if ( ( count%2 ) != 0 )
-      fprintf( report, "<tr class=\"covoar-tr-odd\">\n");
-    else
-      fprintf( report, "<tr>\n");
+    if ( ( count % 2 ) != 0 ) {
+      (*report) << "<tr class=\"covoar-tr-odd\">\n";
+    } else {
+      (*report) << "<tr>\n";
     // symbol
-    fprintf(
-      report,
-      "<td class=\"covoar-td\" align=\"center\">%s</td>\n",
-      symbolName.c_str()
+    (*report) << "<td class=\"covoar-td\" align=\"center\">"
+              << symbolName << "</td>\n";
     // line
-    fprintf(
-      report,
-      "<td class=\"covoar-td\" align=\"center\"><a href =\"annotated.html#range%d\">%s</td>\n",
-      range.id,
-      range.lowSourceLine.c_str()
+    (*report) << "<td class=\"covoar-td\" align=\"center\"><a href =\"annotated.html#range"
+              << range.id << "\">"
+              << range.lowSourceLine << "</td>\n";
     // File
-    i = range.lowSourceLine.find(":");
-    temp =  range.lowSourceLine.substr (0, i);
-    fprintf(
-      report,
-      temp.c_str()
+    i = range.lowSourceLine.find( ":" );
+    temp =  range.lowSourceLine.substr( 0, i );
+              << temp << "</td>\n";
     // Size in bytes
-    fprintf(
-      report,
-      "<td class=\"covoar-td\" align=\"center\">%d</td>\n",
-      range.highAddress - range.lowAddress + 1
+              << range.highAddress - range.lowAddress + 1 << "</td>\n";
     // Reason Branch was uncovered
-    if (range.reason ==
-      Coverage::CoverageRanges::UNCOVERED_REASON_BRANCH_ALWAYS_TAKEN)
-      fprintf(
-        report,
-        "<td class=\"covoar-td\" align=\"center\">Always Taken</td>\n"
-    else if (range.reason ==
-      Coverage::CoverageRanges::UNCOVERED_REASON_BRANCH_NEVER_TAKEN)
-      fprintf(
-        report,
-        "<td class=\"covoar-td\" align=\"center\">Never Taken</td>\n"
+    if (
+      range.reason ==
+      Coverage::CoverageRanges::UNCOVERED_REASON_BRANCH_ALWAYS_TAKEN
+      (*report) << "<td class=\"covoar-td\" align=\"center\">Always Taken</td>"
+                << "\n";
+    } else if (
+      range.reason ==
+      Coverage::CoverageRanges::UNCOVERED_REASON_BRANCH_NEVER_TAKEN
+      (*report) << "<td class=\"covoar-td\" align=\"center\">Never Taken</td>"
+                << "\n";
     // Taken / Not taken counts
-    lowAddress = range.lowAddress;
-    bAddress = symbolInfo.baseAddress;
+    lowAddress     = range.lowAddress;
+    bAddress       = symbolInfo.baseAddress;
     theCoverageMap = symbolInfo.unifiedCoverageMap;
-    fprintf(
-      report,
-      theCoverageMap->getWasTaken( lowAddress - bAddress )
-        fprintf(
-      report,
-      theCoverageMap->getWasNotTaken( lowAddress - bAddress )
+              << theCoverageMap->getWasTaken( lowAddress - bAddress )
+              << "</td>\n"
+              << "<td class=\"covoar-td\" align=\"center\">"
+              << theCoverageMap->getWasNotTaken( lowAddress - bAddress )
+              << "</td>" << "\n";
     // See if an explanation is available and write the Classification and
     // the Explination Columns.
     explanation = AllExplanations->lookupExplanation( range.lowSourceLine );
     if ( !explanation ) {
       // Write Classificationditr->second.baseAddress
-      fprintf(
-        report,
-        "<td class=\"covoar-td\" align=\"center\">NONE</td>\n"
-        "<td class=\"covoar-td\" align=\"center\">No Explanation</td>\n"
+      (*report) << "<td class=\"covoar-td\" align=\"center\">NONE</td>\n"
+                << "<td class=\"covoar-td\" align=\"center\">No Explanation</td>"
+                << "\n";
     } else {
-      char explanationFile[48];
-      sprintf( explanationFile, "explanation%d.html", range.id );
-      fprintf(
-        report,
-        "<td class=\"covoar-td\" align=\"center\">"
-        "<a href=\"%s\">Explanation</a></td>\n",
-        explanation->classification.c_str(),
-        explanationFile
-      WriteExplationFile( explanationFile, explanation );
+      std::stringstream explanationFile( "explanation" );
+      explanationFile << range.id << ".html";
+                << explanation->classification << "</td>\n"
+                << "<a href=\"" << explanationFile.str()
+                << "\">Explanation</a></td>" << "\n";
+      WriteExplanationFile( explanationFile.str(), explanation );
-    fprintf( report, "</tr>\n");
+    (*report) << "</tr>\n";
     return true;
-  bool ReportsHtml::WriteExplationFile(
-    const char*                  fileName,
+  bool ReportsHtml::WriteExplanationFile(
-    FILE* report;
     report = OpenFile( fileName );
-    for ( unsigned int i=0 ; i < explanation->explanation.size(); i++) {
-      fprintf(
-        report,
-        "%s\n",
-        explanation->explanation[i].c_str()
+    for ( unsigned int i = 0; i < explanation->explanation.size(); i++ ) {
+      (*report) << explanation->explanation[i] << "\n";
+    delete report;
     return true;
   void ReportsHtml::putCoverageNoRange(
-    FILE*         report,
     Coverage::Explanation explanation;
@@ -645,425 +547,320 @@ namespace Coverage {
-    if ( ( count%2 ) != 0 ){
-      fprintf( noRangeFile,  "<tr class=\"covoar-tr-odd\">\n");
+      (*report) << "<tr class=\"covoar-tr-odd\">" << "\n";
+      (*noRangeFile) << "<tr class=\"covoar-tr-odd\">" << "\n";
     } else {
-      fprintf( noRangeFile,  "<tr>\n");
+      (*noRangeFile) << "<tr>\n";
     // symbol
-    fprintf(
-      report,
-      symbol.c_str()
-    fprintf(
-      noRangeFile,
-      symbol.c_str()
+              << symbol << "</td>\n";
+    (*noRangeFile) << "<td class=\"covoar-td\" align=\"center\">"
     // starting line
-    fprintf(
-      report,
-      "<td class=\"covoar-td\" align=\"center\">unknown</td>\n"
+    (*report) << "<td class=\"covoar-td\" align=\"center\">unknown</td>\n";
     // file
-    fprintf(
-      report,
      // Size in bytes
-    fprintf(
-      report,
     // Size in instructions
-    fprintf(
-      report,
-    fprintf(
-      report,
-      "<td class=\"covoar-td\" align=\"center\">Unknown</td>\n"
-      "<a href=\"NotReferenced.html\">No data</a></td>\n"
-    WriteExplationFile( "NotReferenced.html", &explanation );
+    (*report) << "<td class=\"covoar-td\" align=\"center\">Unknown</td>\n"
+              << "<a href=\"NotReferenced.html\">No data</a></td>\n";
-    fprintf( noRangeFile, "</tr>\n");
+    WriteExplanationFile( "NotReferenced.html", &explanation );
+    (*noRangeFile) << "</tr>\n";
   bool ReportsHtml::PutCoverageLine(
-    FILE*                                            report,
-    const Coverage::Explanation*   explanation;
-    std::string                    temp;
-    int                            i;
+    const Coverage::Explanation* explanation;
+    std::string                  temp;
+    int                          i;
-    else
+    } else {
     // symbol
-    fprintf(
-      report,
     // Range
-    fprintf(
-      report,
-      "<td class=\"covoar-td\" align=\"center\"><a href =\"annotated.html#range%d\">%s <br>%s</td>\n",
-      range.id,
-      range.lowSourceLine.c_str(),
-      range.highSourceLine.c_str()
+              << range.lowSourceLine << " <br>"
+              << range.highSourceLine << "</td>\n";
     // File
-    fprintf(
-      report,
-      temp.c_str()
     // Size in bytes
-    fprintf(
-      report,
-    fprintf(
-      report,
-      range.instructionCount
+              << range.instructionCount << "</td>\n";
-      fprintf(
-        report,
-      fprintf(
-        report,
+                << "\n";
     } else {
-      fprintf(
-        report,
-        explanationFile
+                << "<a href=\""
+                << explanationFile.str() << "\">Explanation</a></td>\n";
     return true;
   bool  ReportsHtml::PutSizeLine(
-    FILE*                                           report,
-    std::string  temp;
-    int          i;
+    std::string temp;
+    int         i;
-    else
+    } else {
     // size
-    fprintf(
-      report,
     // symbol
-    fprintf(
-      report,
     // line
-    fprintf(
-      report,
-      range.id,
     // File
-    fprintf(
-      report,
-      temp.c_str()
+              << "</tr>\n";
     return true;
   bool  ReportsHtml::PutSymbolSummaryLine(
-    FILE*                                           report,
-    else
+    } else {
     // symbol
-    fprintf(
-      report,
-    if (symbolInfo.stats.sizeInBytes == 0) {
+    if ( symbolInfo.stats.sizeInBytes == 0 ) {
       // The symbol has never been seen. Write "unknown" for all columns.
-      fprintf(
-        report,
+                << "<td class=\"covoar-td\" align=\"center\">unknown</td>\n"
+                << "<td class=\"covoar-td\" align=\"center\">unknown</td>\n";
     } else {
       // Total Size in Bytes
-      fprintf(
-        report,
-        symbolInfo.stats.sizeInBytes
+                << symbolInfo.stats.sizeInBytes << "</td>\n";
       // Total Size in Instructions
-      fprintf(
-        report,
-        symbolInfo.stats.sizeInInstructions
+                << symbolInfo.stats.sizeInInstructions << "</td>\n";
       // Total Uncovered Ranges
-      fprintf(
-        report,
-        symbolInfo.stats.uncoveredRanges
+                << symbolInfo.stats.uncoveredRanges << "</td>\n";
       // Uncovered Size in Bytes
-      fprintf(
-        report,
-        symbolInfo.stats.uncoveredBytes
+                << symbolInfo.stats.uncoveredBytes << "</td>\n";
       // Uncovered Size in Instructions
-      fprintf(
-        report,
-        symbolInfo.stats.uncoveredInstructions
+                << symbolInfo.stats.uncoveredInstructions << "</td>\n";
       // Total number of branches
-      fprintf(
-        report,
-        symbolInfo.stats.branchesNotExecuted + symbolInfo.stats.branchesExecuted
+                << symbolInfo.stats.branchesNotExecuted +
+                << "</td>\n";
       // Total Always Taken
-      fprintf(
-        report,
-        symbolInfo.stats.branchesAlwaysTaken
+                << symbolInfo.stats.branchesAlwaysTaken << "</td>\n";
       // Total Never Taken
-      fprintf(
-        report,
-        symbolInfo.stats.branchesNeverTaken
+                << symbolInfo.stats.branchesNeverTaken << "</td>\n";
       // % Uncovered Instructions
-      if ( symbolInfo.stats.sizeInInstructions == 0 )
-        fprintf(
-          report,
-          "<td class=\"covoar-td\" align=\"center\">100.00</td>\n"
-      else
-        fprintf(
-          report,
-          "<td class=\"covoar-td\" align=\"center\">%.2f</td>\n",
-          (symbolInfo.stats.uncoveredInstructions*100.0)/
+      if ( symbolInfo.stats.sizeInInstructions == 0 ) {
+        (*report) << "<td class=\"covoar-td\" align=\"center\">100.00</td>\n";
+      } else {
+                  << ( symbolInfo.stats.uncoveredInstructions * 100.0 ) /
+                       symbolInfo.stats.sizeInInstructions
+                  << "</td>\n";
       // % Uncovered Bytes
-      if ( symbolInfo.stats.sizeInBytes == 0 )
-        fprintf(
-          report,
-      else
-        fprintf(
-          report,
-          (symbolInfo.stats.uncoveredBytes*100.0)/
+      } else {
+                  << ( symbolInfo.stats.uncoveredBytes * 100.0 ) /
+                       symbolInfo.stats.sizeInBytes
+                  << "</td>\n";
     return true;
-  void ReportsHtml::CloseAnnotatedFile(
-    FILE*  aFile
+  void ReportsHtml::CloseAnnotatedFile( std::ofstream* aFile )
-    fprintf(
-      aFile,
-      "</pre>\n"
-      "</body>\n"
-      "</html>"
+    (*aFile) << "</pre>\n</body>\n</html>";
+    CloseFile( aFile );
-    CloseFile(aFile);
+    delete aFile;
-  void ReportsHtml::CloseBranchFile(
-    FILE*  aFile,
-    bool   hasBranches
+  void ReportsHtml::CloseBranchFile( std::ofstream* aFile, bool hasBranches )
-    fprintf(
-      aFile,
-      TABLE_FOOTER
-      "</tbody>\n"
-      "</table>\n"
+    (*aFile) << TABLE_FOOTER
+             << "</tbody>\n"
+             << "</table>\n";
-    CloseFile(aFile);
+    delete aFile;
-  void ReportsHtml::CloseCoverageFile(
-    FILE*  aFile
+  void ReportsHtml::CloseCoverageFile( std::ofstream* aFile )
-    fprintf(
-      aFile,
-      TABLE_FOOTER
-      "</tbody>\n"
-      "</table>\n"
-      "</pre>\n"
-      "</body>\n"
-      "</html>"
+             << "</tbody>\n"
+             << "</table>\n"
+             << "</pre>\n"
+             << "</body>\n"
+             << "</html>";
-    CloseFile(aFile);
+    delete aFile;
-  void ReportsHtml::CloseNoRangeFile(
-    FILE*  aFile
+  void ReportsHtml::CloseNoRangeFile( std::ofstream* aFile )
-    fprintf(
-      aFile,
-      TABLE_FOOTER
-      "</tbody>\n"
-      "</table>\n"
-      "</pre>\n"
-      "</body>\n"
-      "</html>"
+             << "</tbody>\n"
+             << "</table>\n"
+             << "</pre>\n"
+             << "</body>\n"
+             << "</html>";
-    CloseFile(aFile);
+    delete aFile;
-  void ReportsHtml::CloseSizeFile(
-    FILE*  aFile
+  void ReportsHtml::CloseSizeFile( std::ofstream* aFile )
-    fprintf(
-      aFile,
-      TABLE_FOOTER
-      "</tbody>\n"
-      "</table>\n"
-      "</pre>\n"
-      "</body>\n"
-      "</html>"
+             << "</tbody>\n"
+             << "</table>\n"
+             << "</pre>\n"
+             << "</body>\n"
+             << "</html>";
     CloseFile( aFile );
+    delete aFile;
-  void ReportsHtml::CloseSymbolSummaryFile(
-    FILE*  aFile
+  void ReportsHtml::CloseSymbolSummaryFile( std::ofstream* aFile )
-    fprintf(
-      aFile,
-      TABLE_FOOTER
-       "</tbody>\n"
-      "</table>\n"
-      "</pre>\n"
-      "</body>\n"
-      "</html>"
+             << "</tbody>\n"
+             << "</table>\n"
+             << "</pre>\n"
+             << "</body>\n"
+             << "</html>";
      CloseFile( aFile );
+     delete aFile;
diff --git a/tester/covoar/ReportsHtml.h b/tester/covoar/ReportsHtml.h
index 8d209ae..6144476 100644
--- a/tester/covoar/ReportsHtml.h
+++ b/tester/covoar/ReportsHtml.h
@@ -9,6 +9,9 @@
 #ifndef __REPORTSHTML_H__
 #define __REPORTSHTML_H__
+#include <string>
+#include <fstream>
 #include <stdint.h>
 #include "Explanations.h"
@@ -22,7 +25,8 @@ namespace Coverage {
 class ReportsHtml: public ReportsBase {
   public:
-    ReportsHtml( time_t timestamp, std::string symbolSetName );
+    ReportsHtml( time_t timestamp, const std::string& symbolSetName );
    ~ReportsHtml();
@@ -30,9 +34,7 @@ class ReportsHtml: public ReportsBase {
     *  @param[in] fileName identifies the file name.
-   void WriteIndex(
+   void WriteIndex( const std::string& fileName );
@@ -40,9 +42,7 @@ class ReportsHtml: public ReportsBase {
@@ -50,9 +50,7 @@ class ReportsHtml: public ReportsBase {
@@ -60,9 +58,7 @@ class ReportsHtml: public ReportsBase {
     *  @param[in] fileName identifies the size report file name
   protected:
@@ -75,140 +71,111 @@ class ReportsHtml: public ReportsBase {
     AnnotatedLineState_t lastState_m;
     /* Inherit documentation from base class. */
-      bool              hasBranches
+      bool                 hasBranches
-    FILE* OpenNoRangeFile(
+    std::ofstream* OpenNoRangeFile( const std::string& fileName );
-      FILE*  aFile
-      FILE*  aFile,
-      bool   hasBranches
-      FILE*  aFile
-      FILE*  aFile
-      FILE*  aFile
-      FILE*  aFile
-      FILE*                aFile,
-      std::string          line,
       uint32_t             id
-      FILE*                aFile
+     virtual void AnnotatedStart( std::ofstream* aFile );
-      FILE*                aFile
+     virtual void AnnotatedEnd( std::ofstream* aFile );
-      FILE* report
+    virtual bool PutNoBranchInfo( std::ofstream* report );
-      FILE*                                            report,
-      FILE*        report,
-      FILE*                                           report,
-      FILE*                                           report,
-      FILE*                                           report,
-    virtual FILE* OpenFile(
+    virtual std::ofstream* OpenFile( const std::string& fileName );
-    virtual bool WriteExplationFile(
+    virtual bool WriteExplanationFile(
diff --git a/tester/covoar/ReportsText.cc b/tester/covoar/ReportsText.cc
index 33be32f..1218ebc 100644
--- a/tester/covoar/ReportsText.cc
+++ b/tester/covoar/ReportsText.cc
@@ -1,6 +1,8 @@
+#include <iomanip>
 #include "ReportsText.h"
@@ -11,8 +13,10 @@
-ReportsText::ReportsText( time_t timestamp, std::string symbolSetName ):
+ReportsText::ReportsText(
+  time_t             timestamp,
+): ReportsBase( timestamp, symbolSetName )
   reportExtension_m = ".txt";
@@ -21,272 +25,230 @@ ReportsText::~ReportsText()
-void ReportsText::AnnotatedStart(
-  FILE*                aFile
+void ReportsText::AnnotatedStart( std::ofstream* aFile )
-  fprintf(
-    aFile,
-    "=======================================\n"
+  (*aFile) << "========================================"
+           << "=======================================\n";
-void ReportsText::AnnotatedEnd(
-  FILE*                aFile
+void ReportsText::AnnotatedEnd( std::ofstream* aFile )
 void ReportsText::PutAnnotatedLine(
-  FILE*                aFile,
-  std::string          line,
   uint32_t             id
-  fprintf( aFile, "%s\n", line.c_str());
+  (*aFile) << line << "\n";
-bool ReportsText::PutNoBranchInfo(
-  FILE*           report
+bool ReportsText::PutNoBranchInfo( std::ofstream* report )
-    SymbolsToAnalyze->getNumberBranchesFound(symbolSetName_m) != 0 )
-  else
+    (*report) << "All branch paths taken.\n";
+  } else {
+    (*report) << "No branch information found.\n";
   return true;
 bool ReportsText::PutBranchEntry(
-  FILE*                                            report,
   // Add an entry to the report
-  fprintf(
-    report,
-    "============================================\n"
-    "Symbol        : %s (0x%x)\n"
-    "Line          : %s (0x%x)\n"
-    "Size in Bytes : %d\n",
-    symbolName.c_str(),
-    symbolInfo.baseAddress,
-    range.lowAddress,
-    fprintf(
-      report, "Reason        : %s\n\n", "ALWAYS TAKEN"
-    fprintf( report, "Reason        : %s\n\n", "NEVER TAKEN" );
+  (*report) << "============================================\n"
+            << "Symbol        : " << symbolName
+            << std::hex << " (0x" << symbolInfo.baseAddress << ")\n"
+            << "Line          : " << range.lowSourceLine
+            << " (0x" << range.lowAddress << ")\n"
+            << "Size in Bytes : " << range.highAddress - range.lowAddress + 1
+            << std::dec << "\n";
+  if (
+    range.reason ==
+    (*report) << "Reason        : ALWAYS TAKEN\n\n";
+  } else if (
+      range.reason ==
+      (*report) << "Reason        : NEVER TAKEN\n\n";
-    fprintf(
-      report,
-      "Classification: NONE\n"
-      "\n"
-      "Explanation:\n"
-      "No Explanation\n"
+    (*report) << "Classification: NONE\n"
+              << "\n"
+              << "Explanation:\n"
+              << "No Explanation\n";
   } else {
-    fprintf(
-      report,
-      "Classification: %s\n"
-      "\n"
-      "Explanation:\n",
-          i < explanation->explanation.size();
-          i++) {
-      fprintf(
-        report,
-        "%s\n",
+    (*report) << "Classification: " << explanation->classification << "\n"
+              << "\n"
+              << "Explanation:\n";
-  fprintf(
-    report, "============================================\n"
+  (*report) << "============================================\n";
   return true;
 void ReportsText::putCoverageNoRange(
-  FILE*         report,
-      fprintf(
-        report,
-        "Symbol        : %s\n\n"
-        "          *** NEVER REFERENCED ***\n\n"
-        "This symbol was never referenced by an analyzed executable.\n"
-        "Therefore there is no size or disassembly for this symbol.\n"
-        "This could be due to symbol misspelling or lack of a test for\n"
-        "this symbol.\n"
-        "============================================\n",
-        symbol.c_str()
-      fprintf( noRangeFile, "%s\n", symbol.c_str() );
+            << "Symbol        : " << symbol << "\n\n"
+            << "          *** NEVER REFERENCED ***\n\n"
+            << "This symbol was never referenced by an analyzed executable.\n"
+            << "Therefore there is no size or disassembly for this symbol.\n"
+            << "This could be due to symbol misspelling or lack of a test for\n"
+            << "this symbol.\n"
+            << "============================================\n";
+  (*noRangeFile) << symbol << "\n";
 bool ReportsText::PutCoverageLine(
-  FILE*                                           report,
-  fprintf(
-    report,
-    "Index                : %d\n"
-    "Starting Line        : %s (0x%x)\n"
-    "Ending Line          : %s (0x%x)\n"
-    "Size in Instructions : %d\n\n",
-    range.id,
-    range.lowAddress,
-    range.highSourceLine.c_str(),
-    range.highAddress,
-    range.highAddress - range.lowAddress + 1,
+            << "Index                : " << range.id << "\n"
+            << "Starting Line        : " << range.lowSourceLine
+            << "Ending Line          : " << range.highSourceLine
+            << " (0x" << range.highAddress << ")\n"
+            << std::dec
+            << range.highAddress - range.lowAddress + 1 << "\n"
+            << "Size in Instructions : " << range.instructionCount << "\n\n";
-    fprintf(
-      report,
-      "\n"
-      "Explanation:\n"
+              << "\n"
   } else {
-    fprintf(
-      report,
-      "\n"
-      "Explanation:\n",
-    for ( unsigned int i=0; i < explanation->explanation.size(); i++) {
-      fprintf( report,"%s\n", explanation->explanation[i].c_str() );
+              << "\n"
-  fprintf(report, "============================================\n");
   return true;
 bool  ReportsText::PutSizeLine(
-  FILE*                                           report,
-  fprintf(
-    report,
-    "%d\t%s\t%s\n",
+  (*report) << range.highAddress - range.lowAddress + 1 << "\t"
+            << symbolName << "\t"
+            << range.lowSourceLine << "\n";
   return true;
 bool  ReportsText::PutSymbolSummaryLine(
-  FILE*                                           report,
   float uncoveredBytes;
   float uncoveredInstructions;
-    fprintf(
-      report,
-      "Symbol                            : %s\n"
-      "this symbol.\n",
+              << "Symbol                            : " << symbolName << "\n"
   } else {
       uncoveredInstructions = 0;
-    else
-      uncoveredInstructions = (symbolInfo.stats.uncoveredInstructions*100.0)/
-                              symbolInfo.stats.sizeInInstructions;
+    } else {
+      uncoveredInstructions = ( symbolInfo.stats.uncoveredInstructions*100.0 ) /
+                                symbolInfo.stats.sizeInInstructions;
       uncoveredBytes = 0;
-    else
-      uncoveredBytes = (symbolInfo.stats.uncoveredBytes*100.0)/
-                       symbolInfo.stats.sizeInBytes;
-    fprintf(
-      report,
-      "Symbol                            : %s\n"
-      "Total Size in Bytes               : %d\n"
-      "Total Size in Instructions        : %d\n"
-      "Total number Branches             : %d\n"
-      "Total Always Taken                : %d\n"
-      "Total Never Taken                 : %d\n"
-      "Percentage Uncovered Instructions : %.2f\n"
-      "Percentage Uncovered Bytes        : %.2f\n",
-      symbolInfo.stats.sizeInBytes,
-      symbolInfo.stats.sizeInInstructions,
-      symbolInfo.stats.branchesNotExecuted +  symbolInfo.stats.branchesExecuted,
-      symbolInfo.stats.branchesAlwaysTaken,
-      symbolInfo.stats.branchesNeverTaken,
-      uncoveredInstructions,
-      uncoveredBytes
+    } else {
+      uncoveredBytes = ( symbolInfo.stats.uncoveredBytes * 100.0 ) /
+                         symbolInfo.stats.sizeInBytes;
+              << "Symbol                            : "
+              << symbolName << "\n"
+              << "Total Size in Bytes               : "
+              << symbolInfo.stats.sizeInBytes << "\n"
+              << "Total Size in Instructions        : "
+              << symbolInfo.stats.sizeInInstructions << "\n"
+              << "Total number Branches             : "
+              << symbolInfo.stats.branchesNotExecuted +  symbolInfo.stats.branchesExecuted
+              << "\n"
+              << "Total Always Taken                : "
+              << symbolInfo.stats.branchesAlwaysTaken << "\n"
+              << "Total Never Taken                 : "
+              << symbolInfo.stats.branchesNeverTaken << "\n"
+              << "Percentage Uncovered Instructions : "
+              << uncoveredInstructions << "\n"
+              << "Percentage Uncovered Bytes        : "
+              << uncoveredBytes << "\n";
   return true;
diff --git a/tester/covoar/ReportsText.h b/tester/covoar/ReportsText.h
index 23a1003..d5ce272 100644
--- a/tester/covoar/ReportsText.h
+++ b/tester/covoar/ReportsText.h
@@ -21,7 +21,8 @@ namespace Coverage {
 class ReportsText: public ReportsBase {
   public:
-    ReportsText( time_t timestamp, std::string symbolSetName );
+    ReportsText( time_t timestamp, const std::string& symbolSetName );
     virtual ~ReportsText();
@@ -30,9 +31,7 @@ class ReportsText: public ReportsBase {
@@ -40,9 +39,7 @@ class ReportsText: public ReportsBase {
@@ -50,75 +47,67 @@ class ReportsText: public ReportsBase {
   protected:
-      FILE*                aFile,
-      std::string          line,
       uint32_t             id
-      FILE*                aFile
-      FILE*                aFile
-      FILE* report
-      FILE*                                            report,
-      FILE*        report,
-      FILE*                                           report,
-      FILE*                                           report,
-      FILE*                                           report,
1.8.3.1
