[PATCH rtems-libbsd] rtemsbsd: Use a separate header for test devices
Kinsey Moore kinsey.moore at oarcorp.com
Wed Jul 7 01:05:25 UTC 2021
On 7/6/2021 18:55, Chris Johns wrote:
> On 7/7/21 5:46 am, Kinsey Moore wrote:
>> This is an alternate patch to solve the issue of test-related information being included in an installed application-targeted header.
> Why is the ZYNQMP different to the zync BSP? I have been running the tests on
> the zynq for years and the CGEM hard IP is also almost the same.
> As I said in the other thread I have lost the reason for needing this special
> case for the ZYNQMP.
The need for the difference on ZynqMP is that there are 4 different CGEM
interfaces of which dev boards primarily make use of CGEM3. I have a
custom board in hand that uses CGEM2 which I can't run the network tests
on without modifying nexus-devices.h manually. Zynq7000 boards that use
CGEM1 instead of CGEM0 could make use of the same mechanism for testing.
Kinsey
