[PATCH] Reports: Convert to C++
Ryan Long ryan.long at oarcorp.com
Wed Jul 7 13:37:33 UTC 2021
I'll get those pointers changed to references, and remove the whitespace changes. Is there a particular reason to not use '\n' instead of std::endl? I read that std::endl is slower since it's flushing the buffer each time that it is used.
-----Original Message-----
Sent: Tuesday, July 6, 2021 7:13 PM
To: Ryan Long <ryan.long at oarcorp.com>; devel at rtems.org
Subject: Re: [PATCH] Reports: Convert to C++
On 7/7/21 1:53 am, Ryan Long wrote:
> Made formatting consistent and converted C code to C++.
>  tester/covoar/ReportsBase.cc |  525 +++++++++----------
>  tester/covoar/ReportsBase.h  |  156 +++---
>  tester/covoar/ReportsHtml.cc | 1183 +++++++++++++++++-------------------------
>  tester/covoar/ReportsHtml.h  |  141 ++---
>  tester/covoar/ReportsText.cc |  348 ++++++-------
>  tester/covoar/ReportsText.h  |   75 ++-
>  6 files changed, 1041 insertions(+), 1387 deletions(-)
> diff --git a/tester/covoar/ReportsBase.cc b/tester/covoar/ReportsBase.cc
> index 328980d..3041df2 100644
> --- a/tester/covoar/ReportsBase.cc
> +++ b/tester/covoar/ReportsBase.cc
> @@ -4,6 +4,9 @@
>  #include <sys/stat.h>
>  #include <sys/types.h>
> +#include <iomanip>
> +#include <sstream>
>  #include "ReportsBase.h"
>  #include "app_common.h"
>  #include "CoverageRanges.h"
> @@ -20,10 +23,12 @@
>  namespace Coverage {
> -ReportsBase::ReportsBase( time_t timestamp, std::string symbolSetName ):
> -  reportExtension_m(""),
> -  symbolSetName_m(symbolSetName),
> -  timestamp_m( timestamp )
> +ReportsBase::ReportsBase(
> +  time_t             timestamp,
> +  const std::string& symbolSetName
> +): reportExtension_m( "" ),
> +   symbolSetName_m( symbolSetName ),
> +   timestamp_m(  timestamp  )
> @@ -31,14 +36,14 @@ ReportsBase::~ReportsBase()
> -FILE* ReportsBase::OpenFile(
> -  const char* const fileName,
> -  const char* const symbolSetName
> +std::ofstream* ReportsBase::OpenFile(
A raw pointer anywhere is a possible source of a leak and with exceptions it is
hard to track all possible paths.
> +  const std::string& fileName,
Would having ...
     std::ostream& aFile
as a referenced arguement work?
> -  int          sc;
> -  FILE        *aFile;
> -  std::string  file;
> +  int            sc;
> +  std::ofstream* aFile = new std::ofstream;
Please consider std::shared_ptr<> or std::unique_ptr<> for pointers or just
avoid using them which I find simpler.
> +  std::string    file;
>    std::string symbolSetOutputDirectory;
>    rld::path::path_join(
> @@ -51,136 +56,110 @@ FILE* ReportsBase::OpenFile(
>  #ifdef _WIN32
>    sc = _mkdir( symbolSetOutputDirectory );
>  #else
> -  sc = mkdir( symbolSetOutputDirectory.c_str(),0755 );
> +  sc = mkdir( symbolSetOutputDirectory.c_str(), 0755 );
>  #endif
> -  if ( (sc == -1) && (errno != EEXIST) ) {
> -    fprintf(
> -      stderr,
> -      "Unable to create output directory %s\n",
> -      symbolSetOutputDirectory.c_str()
> +  if ( ( sc == -1 ) && ( errno != EEXIST ) ) {
> +    std::cerr << "Unable to create output directory "
> +              << symbolSetOutputDirectory << "\n";
Please do not use "\n", please use std::endl.
Why not throw an exception?
>      return NULL;
NULL should be nullptr in C++ but if this becomes 'void' it can be removed.
>    file = symbolSetOutputDirectory;
> -  rld::path::path_join(file, fileName, file);
> +  rld::path::path_join( file, fileName, file );
>    // Open the file.
> -  aFile = fopen( file.c_str(), "w" );
> -  if ( !aFile ) {
> -    fprintf( stderr, "Unable to open %s\n", file.c_str() );
> +  aFile->open( file );
> +  if ( !aFile->is_open() ) {
> +    std::cerr << "Unable to open " << file << "\n";
>    return aFile;
> -void ReportsBase::WriteIndex(
> +void ReportsBase::WriteIndex( const std::string& fileName )
> -FILE* ReportsBase::OpenAnnotatedFile(
> +std::ofstream* ReportsBase::OpenAnnotatedFile( const std::string& fileName )
.. and here ..
> -  return OpenFile(fileName, symbolSetName_m.c_str());
> +  return OpenFile( fileName, symbolSetName_m );
> -FILE* ReportsBase::OpenBranchFile(
> -  bool              hasBranches
> +std::ofstream* ReportsBase::OpenBranchFile(
... and here ...
> +  bool               hasBranches
> -FILE* ReportsBase::OpenCoverageFile(
> +std::ofstream* ReportsBase::OpenCoverageFile( const std::string& fileName )
> -FILE* ReportsBase::OpenNoRangeFile(
> +std::ofstream* ReportsBase::OpenNoRangeFile( const std::string& fileName )
> -FILE* ReportsBase::OpenSizeFile(
> +std::ofstream* ReportsBase::OpenSizeFile( const std::string& fileName )
> -FILE* ReportsBase::OpenSymbolSummaryFile(
> +std::ofstream* ReportsBase::OpenSymbolSummaryFile(
> -void ReportsBase::CloseFile(
> -  FILE*  aFile
> +void ReportsBase::CloseFile( std::ofstream* aFile )
> -  fclose( aFile );
> +  aFile->close();
> -void ReportsBase::CloseAnnotatedFile(
> -  FILE*  aFile
> +void ReportsBase::CloseAnnotatedFile( std::ofstream* aFile )
>    CloseFile( aFile );
> -void ReportsBase::CloseBranchFile(
> -  FILE*  aFile,
> -  bool   hasBranches
> +void ReportsBase::CloseBranchFile( std::ofstream* aFile, bool hasBranches )
>    CloseFile( aFile );
> -void  ReportsBase::CloseCoverageFile(
> -  FILE*  aFile
> +void  ReportsBase::CloseCoverageFile( std::ofstream* aFile )
>    CloseFile( aFile );
> -void  ReportsBase::CloseNoRangeFile(
> -  FILE*  aFile
> +void  ReportsBase::CloseNoRangeFile( std::ofstream* aFile )
>    CloseFile( aFile );
> -void  ReportsBase::CloseSizeFile(
> -  FILE*  aFile
> +void  ReportsBase::CloseSizeFile( std::ofstream* aFile )
>    CloseFile( aFile );
> -void  ReportsBase::CloseSymbolSummaryFile(
> -  FILE*  aFile
> +void  ReportsBase::CloseSymbolSummaryFile( std::ofstream* aFile )
>    CloseFile( aFile );
> -std::string expand_tabs(const std::string& in) {
> +std::string  expand_tabs( const std::string& in )
>    std::string expanded = "";
> -  int i = 0;
> +  int         i = 0;
> -  for (char c : in) {
> -    if (c == '\t') {
> -      int num_tabs = 4 - (i % 4);
> -      expanded.append(num_tabs, ' ');
> +  for ( char c : in ) {
> +    if ( c == '\t' ) {
> +      int num_tabs = 4 - ( i % 4 );
> +      expanded.append( num_tabs, ' ' );
>        i += num_tabs;
>      } else {
>        expanded += c;
> @@ -194,62 +173,69 @@ std::string expand_tabs(const std::string& in) {
>   *  Write annotated report
> -void ReportsBase::WriteAnnotatedReport(
> -  FILE*                      aFile = NULL;
> -  Coverage::CoverageRanges*  theBranches;
> -  Coverage::CoverageRanges*  theRanges;
> -  Coverage::CoverageMapBase* theCoverageMap = NULL;
> -  uint32_t                   bAddress = 0;
> -  AnnotatedLineState_t       state;
> -  aFile = OpenAnnotatedFile(fileName);
> -  if (!aFile)
> +void ReportsBase::WriteAnnotatedReport( const std::string& fileName )
> +  std::ofstream*              aFile = NULL;
> +  Coverage::CoverageRanges*   theBranches;
> +  Coverage::CoverageRanges*   theRanges;
> +  Coverage::CoverageMapBase*  theCoverageMap = NULL;
> +  uint32_t                    bAddress = 0;
> +  AnnotatedLineState_t        state;
> +  aFile = OpenAnnotatedFile( fileName );
Any exceptions possible in the code below? Using an instance and a reference to
Open works.
Ouch ... if the open fails nullptr is returned and anyway throwing an exception
would be better.
>      return;
>    // Process uncovered branches for each symbol.
> -  const std::vector<std::string>& symbols = SymbolsToAnalyze->getSymbolsForSet(symbolSetName_m);
> +  const std::vector<std::string>& symbols =
> +    SymbolsToAnalyze->getSymbolsForSet( symbolSetName_m );
> -  for (const auto& symbol : symbols) {
> -    const SymbolInformation& info = SymbolsToAnalyze->allSymbols().at(symbol);
> +  for ( const auto& symbol : symbols ) {
> +    const SymbolInformation& info =
> +      SymbolsToAnalyze->allSymbols().at( symbol );
>      // If uncoveredRanges and uncoveredBranches don't exist, then the
>      // symbol was never referenced by any executable.  Just skip it.
> -    if ((info.uncoveredRanges == NULL) &&
> -        (info.uncoveredBranches == NULL))
> +    if ( ( info.uncoveredRanges == NULL ) &&
> +         ( info.uncoveredBranches == NULL ) )
>        continue;
>      // If uncoveredRanges and uncoveredBranches are empty, then everything
>      // must have been covered for this symbol.  Just skip it.
> -    if ((info.uncoveredRanges->set.empty()) &&
> -        (info.uncoveredBranches->set.empty()))
> +    if ( ( info.uncoveredRanges->set.empty() ) &&
> +         ( info.uncoveredBranches->set.empty() ) )
>        continue;
>      theCoverageMap = info.unifiedCoverageMap;
> -    bAddress = info.baseAddress;
> -    theRanges = info.uncoveredRanges;
> -    theBranches = info.uncoveredBranches;
> +    bAddress       = info.baseAddress;
> +    theRanges      = info.uncoveredRanges;
> +    theBranches    = info.uncoveredBranches;
>      // Add annotations to each line where necessary
>      AnnotatedStart( aFile );
> -    for (const auto& instruction : info.instructions) {
> -      uint32_t           id = 0;
> -      std::string        annotation = "";
> -      std::string        line;
> -      const std::size_t  LINE_LENGTH = 150;
> -      char               textLine[LINE_LENGTH];
> +    for ( const auto& instruction : info.instructions ) {
> +      uint32_t          id = 0;
> +      std::string       annotation = "";
> +      std::string       line;
> +      const std::size_t LINE_LENGTH = 150;
> +      std::stringstream ss;
> +      std::string       textLine = "";
>        state = A_SOURCE;
>        if ( instruction.isInstruction ) {
> -        if (!theCoverageMap->wasExecuted( instruction.address - bAddress )){
> +        if ( !theCoverageMap->wasExecuted( instruction.address - bAddress ) ) {
>            annotation = "<== NOT EXECUTED";
>            state = A_NEVER_EXECUTED;
>            id = theRanges->getId( instruction.address );
> -        } else if (theCoverageMap->isBranch( instruction.address - bAddress )) {
> +        } else if (
> +          theCoverageMap->isBranch( instruction.address - bAddress )
>            id = theBranches->getId( instruction.address );
> -          if (theCoverageMap->wasAlwaysTaken( instruction.address - bAddress )){
> +          if (
> +            theCoverageMap->wasAlwaysTaken( instruction.address - bAddress )
>              annotation = "<== ALWAYS TAKEN";
>              state = A_BRANCH_TAKEN;
>            } else if (
> @@ -263,11 +249,16 @@ void ReportsBase::WriteAnnotatedReport(
> -      std::string textLineWithoutTabs = expand_tabs(instruction.line);
> -      snprintf( textLine, LINE_LENGTH, "%-90s", textLineWithoutTabs.c_str() );
> +      std::string textLineWithoutTabs = expand_tabs( instruction.line );
> +      ss << std::left << std::setw( 90 )
> +         << textLineWithoutTabs.c_str();
> +      textLine = ss.str().substr( 0, LINE_LENGTH );
>        line = textLine + annotation;
> -      PutAnnotatedLine( aFile, state, line, id);
> +      PutAnnotatedLine( aFile, state, line, id );
>      AnnotatedEnd( aFile );
Delete of aFile?
> @@ -279,37 +270,39 @@ void ReportsBase::WriteAnnotatedReport(
>   *  Write branch report
> -void ReportsBase::WriteBranchReport(
> -  FILE*                     report = NULL;
> +void ReportsBase::WriteBranchReport( const std::string& fileName )
> +  std::ofstream*            report = NULL;
same again
>    unsigned int              count;
>    bool                      hasBranches = true;
> -  if ((SymbolsToAnalyze->getNumberBranchesFound(symbolSetName_m) == 0) ||
> -      (BranchInfoAvailable == false) )
> +  if ( ( SymbolsToAnalyze->getNumberBranchesFound( symbolSetName_m ) == 0 ) ||
> +       ( BranchInfoAvailable == false ) )
>       hasBranches = false;
>    // Open the branch report file
>    report = OpenBranchFile( fileName, hasBranches );
> -  if (!report)
> +  if ( !report ) {
>      return;
>    // If no branches were found then branch coverage is not supported
> -  if ((SymbolsToAnalyze->getNumberBranchesFound(symbolSetName_m) != 0) &&
> -      (BranchInfoAvailable == true) ) {
> +  if ( ( SymbolsToAnalyze->getNumberBranchesFound( symbolSetName_m ) != 0 ) &&
> +       ( BranchInfoAvailable == true ) ) {
>      // Process uncovered branches for each symbol in the set.
>      count = 0;
> -      if (theBranches && !theBranches->set.empty()) {
> -        for (const auto& range : theBranches->set) {
> +      if ( theBranches && !theBranches->set.empty() ) {
> +        for ( const auto& range : theBranches->set ) {
>            count++;
>            PutBranchEntry( report, count, symbol, info, range );
> @@ -323,21 +316,19 @@ void ReportsBase::WriteBranchReport(
>   *  Write coverage report
> -void ReportsBase::WriteCoverageReport(
> +void ReportsBase::WriteCoverageReport( const std::string& fileName )
> -  FILE*                     report;
> -  unsigned int              count;
> -  FILE*                     NoRangeFile;
> -  std::string               NoRangeName;
> +  std::ofstream*             report;
> +  unsigned int               count;
> +  std::ofstream*             NoRangeFile;
> +  std::string                NoRangeName;
>    // Open special file that captures NoRange informaiton
>    NoRangeName = "no_range_";
>    NoRangeName +=  fileName;
> -  NoRangeFile = OpenNoRangeFile ( NoRangeName.c_str() );
> -  if (!NoRangeFile) {
> +  NoRangeFile = OpenNoRangeFile( NoRangeName.c_str() );
> +  if ( !NoRangeFile ) {
>      return;
> @@ -348,11 +339,13 @@ void ReportsBase::WriteCoverageReport(
>    // Process uncovered ranges for each symbol.
>    count = 0;
> @@ -360,11 +353,11 @@ void ReportsBase::WriteCoverageReport(
>      // referenced by any executable.  There may be a problem with the
>      // desired symbols list or with the executables so put something
>      // in the report.
> -    if (theRanges == NULL) {
> +    if ( theRanges == NULL ) {
>        putCoverageNoRange( report, NoRangeFile, count, symbol );
>        count++;
> -    }  else if (!theRanges->set.empty()) {
> -      for (const auto& range : theRanges->set) {
> +    }  else if ( !theRanges->set.empty() ) {
> +      for ( const auto& range : theRanges->set ) {
>          PutCoverageLine( report, count, symbol, info, range );
>          count++;
> @@ -373,17 +366,14 @@ void ReportsBase::WriteCoverageReport(
>    CloseNoRangeFile( NoRangeFile );
>    CloseCoverageFile( report );
>   * Write size report
> -void ReportsBase::WriteSizeReport(
> +void ReportsBase::WriteSizeReport( const std::string& fileName )
> -  FILE*                     report;
same again
>    unsigned int              count;
> @@ -394,16 +384,18 @@ void ReportsBase::WriteSizeReport(
>    count = 0;
> -    if (theRanges && !theRanges->set.empty()) {
> +    if ( theRanges && !theRanges->set.empty() ) {
>          PutSizeLine( report, count, symbol, range );
>          count++;
> @@ -413,12 +405,10 @@ void ReportsBase::WriteSizeReport(
>    CloseSizeFile( report );
> -void ReportsBase::WriteSymbolSummaryReport(
> +void ReportsBase::WriteSymbolSummaryReport( const std::string& fileName )
> -  FILE*                                           report;
and again
>    // Open the report file.
>    report = OpenSymbolSummaryFile( fileName );
> @@ -427,11 +417,13 @@ void ReportsBase::WriteSymbolSummaryReport(
>    // Process each symbol.
>    count = 0;
>      PutSymbolSummaryLine( report, count, symbol, info );
>      count++;
> @@ -441,42 +433,43 @@ void ReportsBase::WriteSymbolSummaryReport(
>  void  ReportsBase::WriteSummaryReport(
>      // Calculate coverage statistics and output results.
> -  uint32_t                                        a;
> -  uint32_t                                        endAddress;
> -  uint32_t                                        notExecuted = 0;
> -  double                                          percentage;
> -  double                                          percentageBranches;
> -  Coverage::CoverageMapBase*                      theCoverageMap;
> -  uint32_t                                        totalBytes = 0;
> -  FILE*                                           report;
> +  uint32_t                   a;
> +  uint32_t                   endAddress;
> +  uint32_t                   notExecuted = 0;
> +  double                     percentage;
> +  double                     percentageBranches;
> +  Coverage::CoverageMapBase* theCoverageMap;
> +  uint32_t                   totalBytes = 0;
here as well
>    report = OpenFile( fileName, symbolSetName );
> -  if ( !report ) {
> +  if ( !report->is_open() ) {
>      return;
>    // Look at each symbol.
> -  const std::vector<std::string>& symbols = SymbolsToAnalyze->getSymbolsForSet(symbolSetName);
> +    SymbolsToAnalyze->getSymbolsForSet( symbolSetName );
> -    SymbolInformation info = SymbolsToAnalyze->allSymbols().at(symbol);
> +    SymbolInformation info = SymbolsToAnalyze->allSymbols().at( symbol );
A change like this means I need to carefully check each piece to see if it is
just white space. It would be helpful if you could please avoid white space
changes when making code changes that would be a big help when reviewing. Thanks.
I will wait for a V2 patch before I checking remainder in detail.
>      // If the symbol's unified coverage map exists, scan through it
>      // and count bytes.
> -    if (theCoverageMap) {
> +    if ( theCoverageMap ) {
>        endAddress = info.stats.sizeInBytes - 1;
> -      for (a = 0; a <= endAddress; a++) {
> +      for ( a = 0; a <= endAddress; a++ ) {
>          totalBytes++;
> -        if (!theCoverageMap->wasExecuted( a ))
> +        if ( !theCoverageMap->wasExecuted( a ) )
>            notExecuted++;
> @@ -489,75 +482,58 @@ void  ReportsBase::WriteSummaryReport(
>    percentageBranches = (double) (
> -    SymbolsToAnalyze->getNumberBranchesAlwaysTaken(symbolSetName) +
> -      SymbolsToAnalyze->getNumberBranchesNeverTaken(symbolSetName) +
> -      (SymbolsToAnalyze->getNumberBranchesNotExecuted(symbolSetName) * 2)
> +    SymbolsToAnalyze->getNumberBranchesAlwaysTaken( symbolSetName ) +
> +    SymbolsToAnalyze->getNumberBranchesNeverTaken( symbolSetName ) +
> +  ( SymbolsToAnalyze->getNumberBranchesNotExecuted( symbolSetName ) * 2 )
>    percentageBranches /=
> -    (double) SymbolsToAnalyze->getNumberBranchesFound(symbolSetName) * 2;
> +    (double) SymbolsToAnalyze->getNumberBranchesFound( symbolSetName ) * 2;
>    percentageBranches *= 100.0;
> -  fprintf( report, "Bytes Analyzed                   : %d\n", totalBytes );
> -  fprintf( report, "Bytes Not Executed               : %d\n", notExecuted );
> -  fprintf( report, "Percentage Executed              : %5.4g\n", 100.0 - percentage  );
> -  fprintf( report, "Percentage Not Executed          : %5.4g\n", percentage  );
> -  fprintf(
> -    report,
> -    "Unreferenced Symbols             : %d\n",
> -    SymbolsToAnalyze->getNumberUnreferencedSymbols(symbolSetName)
> -  fprintf(
> -    report,
> -    "Uncovered ranges found           : %d\n\n",
> -    SymbolsToAnalyze->getNumberUncoveredRanges(symbolSetName)
> -  if ((SymbolsToAnalyze->getNumberBranchesFound(symbolSetName) == 0) ||
> -      (BranchInfoAvailable == false) ) {
> -    fprintf( report, "No branch information available\n" );
> +  (*report) << "Bytes Analyzed                   : " << totalBytes << "\n"
> +            << "Bytes Not Executed               : " << notExecuted << "\n"
> +            << "Percentage Executed              : "
> +            << std::fixed << std::setprecision( 2 ) << std::setw( 5 )
> +            << 100.0 - percentage << "\n"
> +            << "Percentage Not Executed          : " << percentage << "\n"
> +            << "Unreferenced Symbols             : "
> +            << SymbolsToAnalyze->getNumberUnreferencedSymbols( symbolSetName )
> +            << "\nUncovered ranges found           : "
> +            << SymbolsToAnalyze->getNumberUncoveredRanges( symbolSetName )
> +            << "\n\n";
> +  if ( ( SymbolsToAnalyze->getNumberBranchesFound( symbolSetName ) == 0 ) ||
> +       ( BranchInfoAvailable == false ) ) {
> +    (*report) << "No branch information available\n";
>    } else {
> -    fprintf(
> -      report,
> -      "Total conditional branches found : %d\n",
> -      SymbolsToAnalyze->getNumberBranchesFound(symbolSetName)
> -    fprintf(
> -      report,
> -      "Total branch paths found         : %d\n",
> -      SymbolsToAnalyze->getNumberBranchesFound(symbolSetName) * 2
> -    fprintf(
> -      report,
> -      "Uncovered branch paths found     : %d\n",
> -    fprintf(
> -      report,
> -      "   %d branches always taken\n",
> -    fprintf(
> -      report,
> -      "   %d branches never taken\n",
> -    fprintf(
> -      report,
> -      "   %d branch paths not executed\n",
> -      SymbolsToAnalyze->getNumberBranchesNotExecuted(symbolSetName) * 2
> -    fprintf(
> -      report,
> -      "Percentage branch paths covered  : %4.4g\n",
> -      100.0 - percentageBranches
> +    (*report) << "Total conditional branches found : "
> +              << SymbolsToAnalyze->getNumberBranchesFound( symbolSetName )
> +              << "\nTotal branch paths found         : "
> +              << SymbolsToAnalyze->getNumberBranchesFound( symbolSetName ) * 2
> +              << "\nUncovered branch paths found     : "
> +              << SymbolsToAnalyze->getNumberBranchesAlwaysTaken( symbolSetName ) +
> +              << "\n   "
> +              << " branches always taken\n   "
> +              << SymbolsToAnalyze->getNumberBranchesNeverTaken( symbolSetName )
> +              << " branches never taken\n   "
> +              << SymbolsToAnalyze->getNumberBranchesNotExecuted( symbolSetName ) * 2
> +              << " branch paths not executed\n"
> +              << "Percentage branch paths covered  : "
> +              << std::fixed << std::setprecision( 2 ) << std::setw( 4 )
> +              << 100.0 - percentageBranches << "\n";
> -  fclose( report );
> +  CloseFile( report );
> -void GenerateReports(const std::string& symbolSetName)
> +void GenerateReports( const std::string& symbolSetName )
>    typedef std::list<ReportsBase *> reportList_t;
> @@ -565,68 +541,69 @@ void GenerateReports(const std::string& symbolSetName)
>    reportList_t::iterator ritr;
>    std::string            reportName;
>    ReportsBase*           reports;
> +  time_t                 timestamp;
> -  time_t timestamp;
> +  timestamp = time( NULL ); /* get current cal time */
> -  timestamp = time(NULL); /* get current cal time */
> -  reports = new ReportsText(timestamp, symbolSetName);
> -  reportList.push_back(reports);
> -  reports = new ReportsHtml(timestamp, symbolSetName);
> +  reports = new ReportsText( timestamp, symbolSetName );
> +  reportList.push_back( reports );
> -  for (ritr = reportList.begin(); ritr != reportList.end(); ritr++ ) {
> +  reports = new ReportsHtml( timestamp, symbolSetName );
> +  for ( ritr = reportList.begin(); ritr != reportList.end(); ritr++ ) {
>      reports = *ritr;
>      reportName = "index" + reports->ReportExtension();
> -    if (Verbose)
> -      fprintf(
> -        stderr, "Generate %s\n", reportName.c_str()
> -    reports->WriteIndex( reportName.c_str() );
> +    if ( Verbose ) {
> +      std::cerr << "Generate " << reportName << "\n";
> +    reports->WriteIndex( reportName );
>      reportName = "annotated" + reports->ReportExtension();
> -    if (Verbose)
> -      fprintf(
> -    reports->WriteAnnotatedReport( reportName.c_str() );
> +    if ( Verbose ) {
> +    reports->WriteAnnotatedReport( reportName );
>      reportName = "branch" + reports->ReportExtension();
> -    if (Verbose)
> -      fprintf(
> -    reports->WriteBranchReport(reportName.c_str() );
> +    if ( Verbose ) {
> +    reports->WriteBranchReport( reportName );
>      reportName = "uncovered" + reports->ReportExtension();
> -    if (Verbose)
> -      fprintf(
> -    reports->WriteCoverageReport(reportName.c_str() );
> +    if ( Verbose ) {
> +    reports->WriteCoverageReport( reportName );
>      reportName = "sizes" + reports->ReportExtension();
> -    if (Verbose)
> -      fprintf(
> -    reports->WriteSizeReport(reportName.c_str() );
> +    if ( Verbose ) {
> +    reports->WriteSizeReport( reportName );
>      reportName = "symbolSummary" + reports->ReportExtension();
> -    if (Verbose)
> -      fprintf(
> -    reports->WriteSymbolSummaryReport(reportName.c_str() );
> +    if ( Verbose ) {
> +    reports->WriteSymbolSummaryReport( reportName );
>      reports = *ritr;
>      delete reports;
> -  ReportsBase::WriteSummaryReport( "summary.txt", symbolSetName.c_str() );
> +  ReportsBase::WriteSummaryReport( "summary.txt", symbolSetName );
> diff --git a/tester/covoar/ReportsBase.h b/tester/covoar/ReportsBase.h
> index ab8f8dd..9dfa080 100644
> --- a/tester/covoar/ReportsBase.h
> +++ b/tester/covoar/ReportsBase.h
> @@ -11,6 +11,8 @@
>  #include <stdint.h>
>  #include <string>
> +#include <iostream>
> +#include <fstream>
>  #include <time.h>
>  #include "DesiredSymbols.h"
> @@ -24,7 +26,8 @@ namespace Coverage {
>  class ReportsBase {
>    public:
> -    ReportsBase( time_t timestamp, std::string symbolSetName );
> +    ReportsBase( time_t timestamp, const std::string& symbolSetName );
>      virtual ~ReportsBase();
> @@ -32,9 +35,7 @@ class ReportsBase {
>       *  @param[in] fileName identifies the report file name
> -    virtual void WriteIndex(
> +    virtual void WriteIndex( const std::string& fileName );
>       *  This method produces an annotated assembly listing report containing
> @@ -42,9 +43,7 @@ class ReportsBase {
>       *  @param[in] fileName identifies the annotated report file name
> -    void WriteAnnotatedReport(
> +    void WriteAnnotatedReport( const std::string& fileName );
>       *  This method produces a report that contains information about each
> @@ -52,9 +51,7 @@ class ReportsBase {
>       *  @param[in] fileName identifies the branch report file name
> -    void WriteBranchReport(
> +    void WriteBranchReport( const std::string& fileName );
> @@ -62,9 +59,7 @@ class ReportsBase {
>       *  @param[in] fileName identifies the coverage report file name
> -    void WriteCoverageReport(
> +    void WriteCoverageReport( const std::string& fileName );
>       *  This method produces a summary report that lists each uncovered
> @@ -72,9 +67,7 @@ class ReportsBase {
> -    void WriteSizeReport(
> +    void WriteSizeReport( const std::string& fileName );
>       *  This method produces a summary report that lists information on
> @@ -82,16 +75,14 @@ class ReportsBase {
> -    void WriteSymbolSummaryReport(
> +    void WriteSymbolSummaryReport( const std::string& fileName );
>       *  This method produces a sumary report for the overall test run.
>      static void  WriteSummaryReport(
> @@ -136,9 +127,9 @@ class ReportsBase {
>       *  @param[in] symbolSetName identifies the name of the report's symbol set
> -     static FILE* OpenFile(
> +    static std::ofstream* OpenFile(
> @@ -147,9 +138,7 @@ class ReportsBase {
> -    virtual FILE* OpenAnnotatedFile(
> +    virtual std::ofstream* OpenAnnotatedFile( const std::string& fileName );
>       *  This method opens a report file and verifies that it opened.
> @@ -158,9 +147,9 @@ class ReportsBase {
>       *  @param[in] hasBranches indicates if there are branches to report
> -    virtual FILE* OpenBranchFile(
> -      bool              hasBranches
> +    virtual std::ofstream* OpenBranchFile(
> +      bool               hasBranches
> @@ -169,9 +158,7 @@ class ReportsBase {
> -    virtual FILE* OpenCoverageFile(
> +    virtual std::ofstream* OpenCoverageFile( const std::string& fileName );
> @@ -179,9 +166,7 @@ class ReportsBase {
> -    virtual FILE* OpenNoRangeFile(
> +    virtual std::ofstream* OpenNoRangeFile( const std::string& fileName );
> @@ -189,9 +174,7 @@ class ReportsBase {
> -    virtual FILE* OpenSizeFile(
> +    virtual std::ofstream* OpenSizeFile( const std::string& fileName );
> @@ -199,8 +182,8 @@ class ReportsBase {
> -    virtual FILE* OpenSymbolSummaryFile(
> +    virtual std::ofstream* OpenSymbolSummaryFile(
> @@ -208,9 +191,7 @@ class ReportsBase {
>       *  @param[in] aFile identifies the report file name
> -    static void CloseFile(
> -      FILE*  aFile
> +    static void CloseFile( std::ofstream* aFile );
>       *  This method puts any necessary footer information into
> @@ -218,9 +199,7 @@ class ReportsBase {
> -    virtual void CloseAnnotatedFile(
> -      FILE*  aFile
> +    virtual void CloseAnnotatedFile( std::ofstream* aFile );
> @@ -229,10 +208,7 @@ class ReportsBase {
> -    virtual void CloseBranchFile(
> -      FILE*  aFile,
> -      bool   hasBranches
> +    virtual void CloseBranchFile( std::ofstream* aFile, bool hasBranches );
> @@ -240,9 +216,7 @@ class ReportsBase {
> -    virtual void CloseCoverageFile(
> -      FILE*  aFile
> +    virtual void CloseCoverageFile( std::ofstream* aFile );
> @@ -250,9 +224,7 @@ class ReportsBase {
> -    void  CloseNoRangeFile(
> -      FILE*  aFile
> +    void  CloseNoRangeFile( std::ofstream* aFile );
> @@ -260,9 +232,7 @@ class ReportsBase {
> -    virtual void CloseSizeFile(
> -      FILE*  aFile
> +    virtual void CloseSizeFile( std::ofstream* aFile );
> @@ -270,9 +240,7 @@ class ReportsBase {
> -    virtual void CloseSymbolSummaryFile(
> -      FILE*  aFile
> +    virtual void CloseSymbolSummaryFile( std::ofstream* aFile );
>       *  This method puts any necessary a line of annotated
> @@ -284,9 +252,9 @@ class ReportsBase {
>       *  @param[in] id identifies the branch or range id.
>      virtual void PutAnnotatedLine(
> -      FILE*                aFile,
> +      std::ofstream*       aFile,
>        AnnotatedLineState_t state,
> -      std::string          line,
> +      const std::string&   line,
>        uint32_t             id
>      )=0;
> @@ -296,9 +264,7 @@ class ReportsBase {
> -     virtual void AnnotatedStart(
> -      FILE*                aFile
> -    )=0;
> +    virtual void AnnotatedStart( std::ofstream* aFile )=0;
> @@ -306,9 +272,7 @@ class ReportsBase {
> -     virtual void AnnotatedEnd(
> -      FILE*                aFile
> -    )=0;
> +    virtual void AnnotatedEnd( std::ofstream* aFile )=0;
> @@ -317,9 +281,7 @@ class ReportsBase {
>       *  @param[in] report identifies the report file name
> -    virtual bool PutNoBranchInfo(
> -      FILE* report
> -    ) = 0;
> +    virtual bool PutNoBranchInfo( std::ofstream* report )=0;
>       *  This method puts a branch entry into the branch report.
> @@ -331,11 +293,11 @@ class ReportsBase {
>       *  @param[in] range is the range information.
>      virtual bool PutBranchEntry(
> -      FILE*                                            report,
> -      unsigned int                                     number,
> -      const std::string&                               symbolName,
> -      const SymbolInformation&                         symbolInfo,
> -      const CoverageRanges::coverageRange_t&           range
> +      std::ofstream*                         report,
> +      unsigned int                           number,
> +      const std::string&                     symbolName,
> +      const SymbolInformation&               symbolInfo,
> +      const CoverageRanges::coverageRange_t& range
>      )=0;
> @@ -347,10 +309,10 @@ class ReportsBase {
>       *  @param[in] symbol is a pointer to the symbol information
>      virtual void putCoverageNoRange(
> -      FILE*        report,
> -      FILE*        noRangeFile,
> -      std::string  symbol
> +      std::ofstream*     noRangeFile,
>      )=0;
> @@ -363,11 +325,11 @@ class ReportsBase {
>      virtual bool PutCoverageLine(
> -      FILE*                                           report,
>      )=0;
> @@ -379,10 +341,10 @@ class ReportsBase {
>      virtual bool PutSizeLine(
> -      FILE*                                           report,
>      )=0;
> @@ -394,10 +356,10 @@ class ReportsBase {
>       *  @param[in] symbolInfo is the symbol's information.
>      virtual bool PutSymbolSummaryLine(
> -      FILE*                                           report,
>      )=0;
> @@ -407,7 +369,7 @@ class ReportsBase {
>   *  @param[in] symbolSetName is the name of the symbol set to report on.
> -void GenerateReports(const std::string& symbolSetName);
> +void GenerateReports( const std::string& symbolSetName );
> diff --git a/tester/covoar/ReportsHtml.cc b/tester/covoar/ReportsHtml.cc
> index fe75cdd..6e4bc7e 100644
> --- a/tester/covoar/ReportsHtml.cc
> +++ b/tester/covoar/ReportsHtml.cc
> @@ -2,6 +2,9 @@
>  #include <stdlib.h>
>  #include <string.h>
> +#include <sstream>
> +#include <iomanip>
>  #include <rld.h>
>  #include "ReportsHtml.h"
> @@ -25,14 +28,16 @@
>     "</tr>\n" \
>     "</tfoot>\n"
>  #else
> -#define TABLE_HEADER_CLASS
> -#define TABLE_FOOTER
> +#define TABLE_HEADER_CLASS ""
> +#define TABLE_FOOTER ""
>  #endif
> -  ReportsHtml::ReportsHtml( time_t timestamp, std::string symbolSetName ):
> -    ReportsBase( timestamp, symbolSetName )
> +  ReportsHtml::ReportsHtml(
> +    time_t             timestamp,
> +  ): ReportsBase( timestamp, symbolSetName )
>      reportExtension_m = ".html";
> @@ -41,400 +46,309 @@ namespace Coverage {
> -  void ReportsHtml::WriteIndex(
> +  void ReportsHtml::WriteIndex( const std::string& fileName )
>      #define PRINT_ITEM( _t, _n ) \
> -       fprintf( \
> -         aFile, \
> -         "<li>%s (<a href=\"%s.html\">html</a> or "\
> -         "<a href=\"%s.txt\">text</a>)</li>\n", \
> -        _t, _n, _n );
> +       (*aFile) << "<li>" \
> +                << _t << " (<a href=\"" \
> +                << _n << ".html\">html</a> or <a href=\"" \
> +                << _n << ".txt\">text</a>)</li>\n";
>      #define PRINT_TEXT_ITEM( _t, _n ) \
> -       fprintf( \
> -         aFile, \
> -         "<li>%s (<a href=\"%s\">text</a>)</li>\n", \
> -        _t, _n );
> +                << _n << "\">text</a>)</li>\n";
> -    FILE*  aFile;
> +    std::ofstream*  aFile;
>      // Open the file
>      aFile = OpenFile( fileName );
> -    fprintf(
> -      aFile,
> -      "<title>Index</title>\n"
> -      "<div class=\"heading-title\">"
> +    (*aFile) << "<title>Index</title>\n"
> +             << "<div class=\"heading-title\">";
> -    if (projectName)
> -      fprintf(
> -        aFile,
> -         "%s<br>",
> -         projectName
> -    fprintf(
> -      aFile,
> -      "Coverage Analysis Reports</div>\n"
> -      "<div class =\"datetime\">%s</div>\n",
> -      asctime( localtime(&timestamp_m) )
> +    if ( projectName ) {
> +      (*aFile) << projectName << "<br>";
> -    fprintf( aFile, "<ul>\n" );
> +    (*aFile) << "Coverage Analysis Reports</div>\n"
> +             << "<div class =\"datetime\">"
> +             <<  asctime( localtime( &timestamp_m ) ) << "</div>\n";
> -    PRINT_TEXT_ITEM( "Summary",         "summary.txt" );
> -    PRINT_ITEM( "Coverage Report",      "uncovered" );
> -    PRINT_ITEM( "Branch Report",        "branch" );
> -    PRINT_ITEM( "Annotated Assembly",   "annotated" );
> -    PRINT_ITEM( "Symbol Summary",       "symbolSummary" );
> -    PRINT_ITEM( "Uncovered Range Size Report",          "sizes" );
> +    (*aFile) << "<ul>\n";
> -    PRINT_TEXT_ITEM( "Explanations Not Found", "ExplanationsNotFound.txt" );
> +    PRINT_TEXT_ITEM( "Summary",                     "summary.txt" );
> +    PRINT_ITEM(      "Coverage Report",             "uncovered" );
> +    PRINT_ITEM(      "Branch Report",               "branch" );
> +    PRINT_ITEM(      "Annotated Assembly",          "annotated" );
> +    PRINT_ITEM(      "Symbol Summary",              "symbolSummary" );
> +    PRINT_ITEM(      "Uncovered Range Size Report", "sizes" );
> +    PRINT_TEXT_ITEM( "Explanations Not Found",      "ExplanationsNotFound.txt" );
> -    fprintf(
> -      aFile,
> -      "</ul>\n"
> -      "<!-- INSERT PROJECT SPECIFIC ITEMS HERE -->\n"
> -      "</html>\n"
> +    (*aFile) << "</ul>\n"
> +             << "<!-- INSERT PROJECT SPECIFIC ITEMS HERE -->\n"
> +             << "</html>\n";
>      CloseFile( aFile );
> +    delete aFile;
>      #undef PRINT_ITEM
>      #undef PRINT_TEXT_ITEM
> -  FILE* ReportsHtml::OpenFile(
> +  std::ofstream* ReportsHtml::OpenFile( const std::string& fileName )
> -    FILE*  aFile;
>      // Open the file
> -    aFile = ReportsBase::OpenFile( fileName, symbolSetName_m.c_str() );
> +    aFile = ReportsBase::OpenFile( fileName, symbolSetName_m );
>      // Put Header information on the file
> -    fprintf(
> -      aFile,
> -      "<html>\n"
> -      "<meta http-equiv=\"Content-Language\" content=\"English\" >\n"
> -      "<meta http-equiv=\"Content-Type\" content=\"text/html; charset=us-ascii\" >\n"
> -      "<link rel=\"stylesheet\" type=\"text/css\" href=\"../covoar.css\" media=\"screen\" >\n"
> -      "<script type=\"text/javascript\" src=\"../table.js\"></script>\n"
> +    (*aFile) << "<html>\n"
> +             << "<meta http-equiv=\"Content-Language\" content=\"English\" >\n"
> +             << "<meta http-equiv=\"Content-Type\" content=\"text/html; charset=us-ascii\" >\n"
> +             << "<link rel=\"stylesheet\" type=\"text/css\" href=\"../covoar.css\" media=\"screen\" >\n"
> +             << "<script type=\"text/javascript\" src=\"../table.js\"></script>"
> +             << "\n";
>      return aFile;
> -  FILE* ReportsHtml::OpenAnnotatedFile(
> +  std::ofstream* ReportsHtml::OpenAnnotatedFile( const std::string& fileName )
> -    FILE *aFile;
>      // Open the file
> -    aFile = OpenFile(fileName);
> +    aFile = OpenFile( fileName );
> -    fprintf(
> -      aFile,
> -      "<title>Annotated Report</title>\n"
> +    (*aFile) << "<title>Annotated Report</title>\n"
> -    if (projectName)
> -      fprintf(
> -        aFile,
> -         "%s<br>",
> -         projectName
> -    fprintf(
> -      aFile,
> -      "Annotated Report</div>\n"
> -      "<body>\n"
> -      "<pre class=\"code\">\n",
> +    (*aFile) << "Annotated Report</div>\n"
> +             << "<body>\n"
> +             << "<pre class=\"code\">\n";
>      return aFile;
> -  FILE* ReportsHtml::OpenBranchFile(
> -    bool              hasBranches
> +  std::ofstream* ReportsHtml::OpenBranchFile(
> +    bool               hasBranches
> -    FILE *aFile;
>      // Open the file
>      // Put header information into the file
> -    fprintf(
> -      aFile,
> -      "<title>Branch Report</title>\n"
> +    (*aFile) << "<title>Branch Report</title>\n"
> -    if (projectName)
> -      fprintf(
> -        aFile,
> -        "%s<br>",
> -        projectName
> -    fprintf(
> -      aFile,
> -      "Branch Report</div>\n"
> -      "<body>\n"
> -      "<table class=\"covoar table-autosort:0 table-autofilter table-stripeclass:covoar-tr-odd"
> -          TABLE_HEADER_CLASS "\">\n"
> -      "<thead>\n"
> -      "<tr>\n"
> -      "<th class=\"table-sortable:default\" align=\"left\">Symbol</th>\n"
> -      "<th class=\"table-sortable:default\" align=\"left\">Line</th>\n"
> -      "<th class=\"table-filterable table-sortable:default\" align=\"left\">File</th>\n"
> -      "<th class=\"table-sortable:numeric\" align=\"left\">Size <br>Bytes</th>\n"
> -      "<th class=\"table-sortable:default\" align=\"left\">Reason</th>\n"
> -      "<th class=\"table-filterable table-sortable:default\" align=\"left\">Taken</th>\n"
> -      "<th class=\"table-filterable table-sortable:default\" align=\"left\">Not Taken</th>\n"
> -      "<th class=\"table-filterable table-sortable:default\" align=\"left\">Classification</th>\n"
> -      "<th class=\"table-sortable:default\" align=\"left\">Explanation</th>\n"
> -      "</tr>\n"
> -      "</thead>\n"
> -      "<tbody>\n",
> +    (*aFile) << "Branch Report</div>\n"
> +             << "<body>\n"
> +             << "<table class=\"covoar table-autosort:0 table-autofilter table-stripeclass:covoar-tr-odd"
> +             << TABLE_HEADER_CLASS << "\">\n"
> +             << "<thead>\n"
> +             << "<tr>\n"
> +             << "<th class=\"table-sortable:default\" align=\"left\">Symbol</th>\n"
> +             << "<th class=\"table-sortable:default\" align=\"left\">Line</th>\n"
> +             << "<th class=\"table-filterable table-sortable:default\" align=\"left\">File</th>\n"
> +             << "<th class=\"table-sortable:numeric\" align=\"left\">Size <br>Bytes</th>\n"
> +             << "<th class=\"table-sortable:default\" align=\"left\">Reason</th>\n"
> +             << "<th class=\"table-filterable table-sortable:default\" align=\"left\">Taken</th>\n"
> +             << "<th class=\"table-filterable table-sortable:default\" align=\"left\">Not Taken</th>\n"
> +             << "<th class=\"table-filterable table-sortable:default\" align=\"left\">Classification</th>\n"
> +             << "<th class=\"table-sortable:default\" align=\"left\">Explanation</th>\n"
> +             << "</tr>\n"
> +             << "</thead>\n"
> +             << "<tbody>\n";
>      return aFile;
> -  FILE*  ReportsHtml::OpenCoverageFile(
> +  std::ofstream*  ReportsHtml::OpenCoverageFile( const std::string& fileName )
> -    FILE *aFile;
>      // Open the file
> -    fprintf(
> -      aFile,
> -        "<title>Coverage Report</title>\n"
> +    (*aFile) << "<title>Coverage Report</title>\n"
> -    if (projectName)
> -      fprintf(
> -        aFile,
> -        "%s<br>",
> -        projectName
> -    fprintf(
> -      aFile,
> -       "Coverage Report</div>\n"
> -       "<body>\n"
> -      "<thead>\n"
> -      "<tr>\n"
> -      "<th class=\"table-sortable:default\" align=\"left\">Range</th>\n"
> -      "<th class=\"table-sortable:numeric\" align=\"left\">Size <br>Instructions</th>\n"
> -      "</tr>\n"
> -      "</thead>\n"
> -      "<tbody>\n",
> +    (*aFile) << "Coverage Report</div>\n"
> +             << "<body>\n"
> +             << "<thead>\n"
> +             << "<tr>\n"
> +             << "<th class=\"table-sortable:default\" align=\"left\">Range</th>\n"
> +             << "<th class=\"table-sortable:numeric\" align=\"left\">Size <br>Instructions</th>\n"
> +             << "</tr>\n"
> +             << "</thead>\n"
> +             << "<tbody>\n";
>      return aFile;
> -  FILE* ReportsHtml::OpenNoRangeFile(
> +  std::ofstream* ReportsHtml::OpenNoRangeFile( const std::string& fileName )
> -    FILE *aFile;
>      // Open the file
> -    fprintf(
> -      aFile,
> -        "<title> Report</title>\n"
> +    (*aFile) << "<title> Report</title>\n"
> -    if (projectName)
> -      fprintf(
> -        aFile,
> -        "%s<br>",
> -        projectName
> -    fprintf(
> -      aFile,
> -       "No Range Report</div>\n"
> -        "<body>\n"
> -      "<thead>\n"
> -      "<tr>\n"
> -      "</tr>\n"
> -      "</thead>\n"
> -      "<tbody>\n",
> +    (*aFile) << "No Range Report</div>\n"
> +             << "<body>\n"
> +             << "<thead>\n"
> +             << "<tr>\n"
> +             << "</tr>\n"
> +             << "</thead>\n"
> +             << "<tbody>\n";
>      return aFile;
> -  FILE*  ReportsHtml::OpenSizeFile(
> +  std::ofstream* ReportsHtml::OpenSizeFile( const std::string& fileName )
> -    FILE *aFile;
>      // Open the file
> -    fprintf(
> -      aFile,
> -      "<title>Uncovered Range Size Report</title>\n"
> +    (*aFile) << "<title>Uncovered Range Size Report</title>\n"
> -    if (projectName)
> -      fprintf(
> -        aFile,
> -        "%s<br>",
> -        projectName
> -    fprintf(
> -      aFile,
> -      "Uncovered Range Size Report</div>\n"
> -      "<body>\n"
> -      "<thead>\n"
> -      "<tr>\n"
> -      "<th class=\"table-sortable:numeric\" align=\"left\">Size</th>\n"
> -      "</tr>\n"
> -      "</thead>\n"
> -      "<tbody>\n",
> +    (*aFile) << "Uncovered Range Size Report</div>\n"
> +             << "<body>\n"
> +             << "<thead>\n"
> +             << "<tr>\n"
> +             << "<th class=\"table-sortable:numeric\" align=\"left\">Size</th>\n"
> +             << "</tr>\n"
> +             << "</thead>\n"
> +             << "<tbody>\n";
>      return aFile;
> -  FILE*  ReportsHtml::OpenSymbolSummaryFile(
> +  std::ofstream* ReportsHtml::OpenSymbolSummaryFile(
> -    FILE *aFile;
>      // Open the file
> -    fprintf(
> -      aFile,
> -      "<title>Symbol Summary Report</title>\n"
> +    (*aFile) << "<title>Symbol Summary Report</title>\n"
> -    if (projectName)
> -      fprintf(
> -        aFile,
> -        "%s<br>",
> -        projectName
> -    fprintf(
> -      aFile,
> -      "Symbol Summary Report</div>\n"
> -      "<body>\n"
> -      "<thead>\n"
> -      "<tr>\n"
> -      "<th class=\"table-sortable:default\" align=\"center\">Symbol</th>\n"
> -      "<th class=\"table-sortable:numeric\" align=\"center\">Total<br>Size<br>Bytes</th>\n"
> -      "<th class=\"table-sortable:numeric\" align=\"center\">Total<br>Size<br>Instr</th>\n"
> -      "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Ranges</th>\n"
> -      "<th class=\"table-sortable:numeric\" align=\"center\">Uncovered<br>Size<br>Bytes</th>\n"
> -      "<th class=\"table-sortable:numeric\" align=\"center\">Uncovered<br>Size<br>Instr</th>\n"
> -      "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Branches</th>\n"
> -      "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Always<br>Taken</th>\n"
> -      "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Never<br>Taken</th>\n"
> -      "<th class=\"table-sortable:numeric\" align=\"center\">Percent<br>Uncovered<br>Instructions</th>\n"
> -      "<th class=\"table-sortable:numeric\" align=\"center\">Percent<br>Uncovered<br>Bytes</th>\n"
> -      "</tr>\n"
> -      "</thead>\n"
> -      "<tbody>\n",
> +    (*aFile) << "Symbol Summary Report</div>\n"
> +             << "<body>\n"
> +             << "<thead>\n"
> +             << "<tr>\n"
> +             << "<th class=\"table-sortable:default\" align=\"center\">Symbol</th>\n"
> +             << "<th class=\"table-sortable:numeric\" align=\"center\">Total<br>Size<br>Bytes</th>\n"
> +             << "<th class=\"table-sortable:numeric\" align=\"center\">Total<br>Size<br>Instr</th>\n"
> +             << "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Ranges</th>\n"
> +             << "<th class=\"table-sortable:numeric\" align=\"center\">Uncovered<br>Size<br>Bytes</th>\n"
> +             << "<th class=\"table-sortable:numeric\" align=\"center\">Uncovered<br>Size<br>Instr</th>\n"
> +             << "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Branches</th>\n"
> +             << "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Always<br>Taken</th>\n"
> +             << "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Never<br>Taken</th>\n"
> +             << "<th class=\"table-sortable:numeric\" align=\"center\">Percent<br>Uncovered<br>Instructions</th>\n"
> +             << "<th class=\"table-sortable:numeric\" align=\"center\">Percent<br>Uncovered<br>Bytes</th>\n"
> +             << "</tr>\n"
> +             << "</thead>\n"
> +             << "<tbody>\n";
>      return aFile;
> -  void ReportsHtml::AnnotatedStart(
> -    FILE*                aFile
> +  void ReportsHtml::AnnotatedStart( std::ofstream* aFile )
> -    fprintf(
> -      aFile,
> -      "<hr>\n"
> +    (*aFile) << "<hr>\n";
> -  void ReportsHtml::AnnotatedEnd(
> -    FILE*                aFile
> +  void ReportsHtml::AnnotatedEnd( std::ofstream* aFile )
>    void ReportsHtml::PutAnnotatedLine(
> -    FILE*                aFile,
> -    std::string          line,
>      uint32_t             id
>      std::string stateText;
> -    char        number[10];
> +    std::string number;
> -    sprintf(number,"%d", id);
> +    number = std::to_string( id );
>      // Set the stateText based upon the current state.
> -    switch (state) {
> +    switch ( state ) {
>        case  A_SOURCE:
>          stateText = "</pre>\n<pre class=\"code\">\n";
>          break;
> @@ -460,7 +374,7 @@ namespace Coverage {
>          stateText += "\"></a><pre class=\"codeNeverTaken\">\n";
>          break;
>        default:
> -        throw rld::error( "Unknown state", "ReportsHtml::PutAnnotatedLine");
> +        throw rld::error( "Unknown state", "ReportsHtml::PutAnnotatedLine" );
>          break;
> @@ -468,40 +382,43 @@ namespace Coverage {
>      // format.  If it has changed close out the old format and open up the
>      // new format.
>      if ( state != lastState_m ) {
> -      fprintf( aFile, "%s", stateText.c_str() );
> +      (*aFile) << stateText;
>        lastState_m = state;
>      // For all the characters in the line replace html reserved special
>      // characters and output the line. Note that for a /pre block this
>      // is only a '<' symbol.
> -    for (unsigned int i=0; i<line.size(); i++ ) {
> -      if ( line[i] == '<' )
> -        fprintf( aFile, "<" );
> -      else
> -        fprintf( aFile, "%c", line[i] );
> +    for ( unsigned int i = 0; i < line.size(); i++ ) {
> +      if ( line[i] == '<' ) {
> +        (*aFile) << "<";
> +      } else {
> +        (*aFile) << line[i];
> -    fprintf( aFile, "\n");
> +    (*aFile) << "\n";
> -  bool ReportsHtml::PutNoBranchInfo(
> -    FILE* report
> +  bool ReportsHtml::PutNoBranchInfo( std::ofstream* report )
> -    if (BranchInfoAvailable &&
> -      SymbolsToAnalyze->getNumberBranchesFound(symbolSetName_m) != 0)
> -      fprintf( report, "All branch paths taken.\n" );
> -    else
> -      fprintf( report, "No branch information found.\n" );
> +    if ( BranchInfoAvailable &&
> +         SymbolsToAnalyze->getNumberBranchesFound( symbolSetName_m ) != 0
> +      (*report) << "All branch paths taken." << "\n";
> +    } else {
> +      (*report) << "No branch information found." << "\n";
>      return true;
>    bool ReportsHtml::PutBranchEntry(
> -    FILE*                                            report,
> -    unsigned int                                     count,
> +    unsigned int                           count,
>      const Coverage::Explanation* explanation;
> @@ -512,125 +429,110 @@ namespace Coverage {
>      // Mark the background color different for odd and even lines.
> -    if ( ( count%2 ) != 0 )
> -      fprintf( report, "<tr class=\"covoar-tr-odd\">\n");
> -    else
> -      fprintf( report, "<tr>\n");
> +    if ( ( count % 2 ) != 0 ) {
> +      (*report) << "<tr class=\"covoar-tr-odd\">\n";
> +    } else {
> +      (*report) << "<tr>\n";
>      // symbol
> -    fprintf(
> -      report,
> -      "<td class=\"covoar-td\" align=\"center\">%s</td>\n",
> -      symbolName.c_str()
> +    (*report) << "<td class=\"covoar-td\" align=\"center\">"
> +              << symbolName << "</td>\n";
>      // line
> -    fprintf(
> -      report,
> -      "<td class=\"covoar-td\" align=\"center\"><a href =\"annotated.html#range%d\">%s</td>\n",
> -      range.id,
> -      range.lowSourceLine.c_str()
> +    (*report) << "<td class=\"covoar-td\" align=\"center\"><a href =\"annotated.html#range"
> +              << range.id << "\">"
> +              << range.lowSourceLine << "</td>\n";
>      // File
> -    i = range.lowSourceLine.find(":");
> -    temp =  range.lowSourceLine.substr (0, i);
> -    fprintf(
> -      report,
> -      temp.c_str()
> +    i = range.lowSourceLine.find( ":" );
> +    temp =  range.lowSourceLine.substr( 0, i );
> +              << temp << "</td>\n";
>      // Size in bytes
> -    fprintf(
> -      report,
> -      "<td class=\"covoar-td\" align=\"center\">%d</td>\n",
> -      range.highAddress - range.lowAddress + 1
> +              << range.highAddress - range.lowAddress + 1 << "</td>\n";
>      // Reason Branch was uncovered
> -    if (range.reason ==
> -      Coverage::CoverageRanges::UNCOVERED_REASON_BRANCH_ALWAYS_TAKEN)
> -      fprintf(
> -        report,
> -        "<td class=\"covoar-td\" align=\"center\">Always Taken</td>\n"
> -    else if (range.reason ==
> -      Coverage::CoverageRanges::UNCOVERED_REASON_BRANCH_NEVER_TAKEN)
> -      fprintf(
> -        report,
> -        "<td class=\"covoar-td\" align=\"center\">Never Taken</td>\n"
> +    if (
> +      range.reason ==
> +      Coverage::CoverageRanges::UNCOVERED_REASON_BRANCH_ALWAYS_TAKEN
> +      (*report) << "<td class=\"covoar-td\" align=\"center\">Always Taken</td>"
> +                << "\n";
> +    } else if (
> +      range.reason ==
> +      Coverage::CoverageRanges::UNCOVERED_REASON_BRANCH_NEVER_TAKEN
> +      (*report) << "<td class=\"covoar-td\" align=\"center\">Never Taken</td>"
> +                << "\n";
>      // Taken / Not taken counts
> -    lowAddress = range.lowAddress;
> -    bAddress = symbolInfo.baseAddress;
> +    lowAddress     = range.lowAddress;
> +    bAddress       = symbolInfo.baseAddress;
>      theCoverageMap = symbolInfo.unifiedCoverageMap;
> -    fprintf(
> -      report,
> -      theCoverageMap->getWasTaken( lowAddress - bAddress )
> -        fprintf(
> -      report,
> -      theCoverageMap->getWasNotTaken( lowAddress - bAddress )
> +              << theCoverageMap->getWasTaken( lowAddress - bAddress )
> +              << "</td>\n"
> +              << "<td class=\"covoar-td\" align=\"center\">"
> +              << theCoverageMap->getWasNotTaken( lowAddress - bAddress )
> +              << "</td>" << "\n";
>      // See if an explanation is available and write the Classification and
>      // the Explination Columns.
>      explanation = AllExplanations->lookupExplanation( range.lowSourceLine );
>      if ( !explanation ) {
>        // Write Classificationditr->second.baseAddress
> -      fprintf(
> -        report,
> -        "<td class=\"covoar-td\" align=\"center\">NONE</td>\n"
> -        "<td class=\"covoar-td\" align=\"center\">No Explanation</td>\n"
> +      (*report) << "<td class=\"covoar-td\" align=\"center\">NONE</td>\n"
> +                << "<td class=\"covoar-td\" align=\"center\">No Explanation</td>"
> +                << "\n";
>      } else {
> -      char explanationFile[48];
> -      sprintf( explanationFile, "explanation%d.html", range.id );
> -      fprintf(
> -        report,
> -        "<td class=\"covoar-td\" align=\"center\">"
> -        "<a href=\"%s\">Explanation</a></td>\n",
> -        explanation->classification.c_str(),
> -        explanationFile
> -      WriteExplationFile( explanationFile, explanation );
> +      std::stringstream explanationFile( "explanation" );
> +      explanationFile << range.id << ".html";
> +                << explanation->classification << "</td>\n"
> +                << "<a href=\"" << explanationFile.str()
> +                << "\">Explanation</a></td>" << "\n";
> +      WriteExplanationFile( explanationFile.str(), explanation );
> -    fprintf( report, "</tr>\n");
> +    (*report) << "</tr>\n";
>      return true;
> -  bool ReportsHtml::WriteExplationFile(
> -    const char*                  fileName,
> +  bool ReportsHtml::WriteExplanationFile(
> -    FILE* report;
>      report = OpenFile( fileName );
> -    for ( unsigned int i=0 ; i < explanation->explanation.size(); i++) {
> -      fprintf(
> -        report,
> -        "%s\n",
> -        explanation->explanation[i].c_str()
> +    for ( unsigned int i = 0; i < explanation->explanation.size(); i++ ) {
> +      (*report) << explanation->explanation[i] << "\n";
> +    delete report;
>      return true;
>    void ReportsHtml::putCoverageNoRange(
> -    FILE*         report,
>      Coverage::Explanation explanation;
> @@ -645,425 +547,320 @@ namespace Coverage {
> -    if ( ( count%2 ) != 0 ){
> -      fprintf( noRangeFile,  "<tr class=\"covoar-tr-odd\">\n");
> +      (*report) << "<tr class=\"covoar-tr-odd\">" << "\n";
> +      (*noRangeFile) << "<tr class=\"covoar-tr-odd\">" << "\n";
>      } else {
> -      fprintf( noRangeFile,  "<tr>\n");
> +      (*noRangeFile) << "<tr>\n";
>      // symbol
> -    fprintf(
> -      report,
> -      symbol.c_str()
> -    fprintf(
> -      noRangeFile,
> -      symbol.c_str()
> +              << symbol << "</td>\n";
> +    (*noRangeFile) << "<td class=\"covoar-td\" align=\"center\">"
>      // starting line
> -    fprintf(
> -      report,
> -      "<td class=\"covoar-td\" align=\"center\">unknown</td>\n"
> +    (*report) << "<td class=\"covoar-td\" align=\"center\">unknown</td>\n";
>      // file
> -    fprintf(
> -      report,
>       // Size in bytes
> -    fprintf(
> -      report,
>      // Size in instructions
> -    fprintf(
> -      report,
> -    fprintf(
> -      report,
> -      "<td class=\"covoar-td\" align=\"center\">Unknown</td>\n"
> -      "<a href=\"NotReferenced.html\">No data</a></td>\n"
> -    WriteExplationFile( "NotReferenced.html", &explanation );
> +    (*report) << "<td class=\"covoar-td\" align=\"center\">Unknown</td>\n"
> +              << "<a href=\"NotReferenced.html\">No data</a></td>\n";
> -    fprintf( noRangeFile, "</tr>\n");
> +    WriteExplanationFile( "NotReferenced.html", &explanation );
> +    (*noRangeFile) << "</tr>\n";
>    bool ReportsHtml::PutCoverageLine(
> -    FILE*                                            report,
> -    const Coverage::Explanation*   explanation;
> -    std::string                    temp;
> -    int                            i;
> +    const Coverage::Explanation* explanation;
> +    std::string                  temp;
> +    int                          i;
> -    else
> +    } else {
>      // symbol
> -    fprintf(
> -      report,
>      // Range
> -    fprintf(
> -      report,
> -      "<td class=\"covoar-td\" align=\"center\"><a href =\"annotated.html#range%d\">%s <br>%s</td>\n",
> -      range.id,
> -      range.lowSourceLine.c_str(),
> -      range.highSourceLine.c_str()
> +              << range.lowSourceLine << " <br>"
> +              << range.highSourceLine << "</td>\n";
>      // File
> -    fprintf(
> -      report,
> -      temp.c_str()
>      // Size in bytes
> -    fprintf(
> -      report,
> -    fprintf(
> -      report,
> -      range.instructionCount
> +              << range.instructionCount << "</td>\n";
> -      fprintf(
> -        report,
> -      fprintf(
> -        report,
> +                << "\n";
>      } else {
> -      fprintf(
> -        report,
> -        explanationFile
> +                << "<a href=\""
> +                << explanationFile.str() << "\">Explanation</a></td>\n";
>      return true;
>    bool  ReportsHtml::PutSizeLine(
> -    FILE*                                           report,
> -    std::string  temp;
> -    int          i;
> +    std::string temp;
> +    int         i;
> -    else
> +    } else {
>      // size
> -    fprintf(
> -      report,
>      // symbol
> -    fprintf(
> -      report,
>      // line
> -    fprintf(
> -      report,
> -      range.id,
>      // File
> -    fprintf(
> -      report,
> -      temp.c_str()
> +              << "</tr>\n";
>      return true;
>    bool  ReportsHtml::PutSymbolSummaryLine(
> -    FILE*                                           report,
> -    else
> +    } else {
>      // symbol
> -    fprintf(
> -      report,
> -    if (symbolInfo.stats.sizeInBytes == 0) {
> +    if ( symbolInfo.stats.sizeInBytes == 0 ) {
>        // The symbol has never been seen. Write "unknown" for all columns.
> -      fprintf(
> -        report,
> +                << "<td class=\"covoar-td\" align=\"center\">unknown</td>\n"
> +                << "<td class=\"covoar-td\" align=\"center\">unknown</td>\n";
>      } else {
>        // Total Size in Bytes
> -      fprintf(
> -        report,
> -        symbolInfo.stats.sizeInBytes
> +                << symbolInfo.stats.sizeInBytes << "</td>\n";
>        // Total Size in Instructions
> -      fprintf(
> -        report,
> -        symbolInfo.stats.sizeInInstructions
> +                << symbolInfo.stats.sizeInInstructions << "</td>\n";
>        // Total Uncovered Ranges
> -      fprintf(
> -        report,
> -        symbolInfo.stats.uncoveredRanges
> +                << symbolInfo.stats.uncoveredRanges << "</td>\n";
>        // Uncovered Size in Bytes
> -      fprintf(
> -        report,
> -        symbolInfo.stats.uncoveredBytes
> +                << symbolInfo.stats.uncoveredBytes << "</td>\n";
>        // Uncovered Size in Instructions
> -      fprintf(
> -        report,
> -        symbolInfo.stats.uncoveredInstructions
> +                << symbolInfo.stats.uncoveredInstructions << "</td>\n";
>        // Total number of branches
> -      fprintf(
> -        report,
> -        symbolInfo.stats.branchesNotExecuted + symbolInfo.stats.branchesExecuted
> +                << symbolInfo.stats.branchesNotExecuted +
> +                << "</td>\n";
>        // Total Always Taken
> -      fprintf(
> -        report,
> -        symbolInfo.stats.branchesAlwaysTaken
> +                << symbolInfo.stats.branchesAlwaysTaken << "</td>\n";
>        // Total Never Taken
> -      fprintf(
> -        report,
> -        symbolInfo.stats.branchesNeverTaken
> +                << symbolInfo.stats.branchesNeverTaken << "</td>\n";
>        // % Uncovered Instructions
> -      if ( symbolInfo.stats.sizeInInstructions == 0 )
> -        fprintf(
> -          report,
> -          "<td class=\"covoar-td\" align=\"center\">100.00</td>\n"
> -      else
> -        fprintf(
> -          report,
> -          "<td class=\"covoar-td\" align=\"center\">%.2f</td>\n",
> -          (symbolInfo.stats.uncoveredInstructions*100.0)/
> +      if ( symbolInfo.stats.sizeInInstructions == 0 ) {
> +        (*report) << "<td class=\"covoar-td\" align=\"center\">100.00</td>\n";
> +      } else {
> +                  << ( symbolInfo.stats.uncoveredInstructions * 100.0 ) /
> +                       symbolInfo.stats.sizeInInstructions
> +                  << "</td>\n";
>        // % Uncovered Bytes
> -      if ( symbolInfo.stats.sizeInBytes == 0 )
> -        fprintf(
> -          report,
> -      else
> -        fprintf(
> -          report,
> -          (symbolInfo.stats.uncoveredBytes*100.0)/
> +      } else {
> +                  << ( symbolInfo.stats.uncoveredBytes * 100.0 ) /
> +                       symbolInfo.stats.sizeInBytes
> +                  << "</td>\n";
>      return true;
> -  void ReportsHtml::CloseAnnotatedFile(
> -    FILE*  aFile
> +  void ReportsHtml::CloseAnnotatedFile( std::ofstream* aFile )
> -    fprintf(
> -      aFile,
> -      "</pre>\n"
> -      "</body>\n"
> -      "</html>"
> +    (*aFile) << "</pre>\n</body>\n</html>";
> +    CloseFile( aFile );
> -    CloseFile(aFile);
> +    delete aFile;
> -  void ReportsHtml::CloseBranchFile(
> -    FILE*  aFile,
> -    bool   hasBranches
> +  void ReportsHtml::CloseBranchFile( std::ofstream* aFile, bool hasBranches )
> -    fprintf(
> -      aFile,
> -      TABLE_FOOTER
> -      "</tbody>\n"
> -      "</table>\n"
> +    (*aFile) << TABLE_FOOTER
> +             << "</tbody>\n"
> +             << "</table>\n";
> -    CloseFile(aFile);
> +    delete aFile;
> -  void ReportsHtml::CloseCoverageFile(
> -    FILE*  aFile
> +  void ReportsHtml::CloseCoverageFile( std::ofstream* aFile )
> -    fprintf(
> -      aFile,
> -      TABLE_FOOTER
> -      "</tbody>\n"
> -      "</table>\n"
> -      "</pre>\n"
> -      "</body>\n"
> -      "</html>"
> +             << "</tbody>\n"
> +             << "</table>\n"
> +             << "</pre>\n"
> +             << "</body>\n"
> +             << "</html>";
> -    CloseFile(aFile);
> +    delete aFile;
> -  void ReportsHtml::CloseNoRangeFile(
> -    FILE*  aFile
> +  void ReportsHtml::CloseNoRangeFile( std::ofstream* aFile )
> -    fprintf(
> -      aFile,
> -      TABLE_FOOTER
> -      "</tbody>\n"
> -      "</table>\n"
> -      "</pre>\n"
> -      "</body>\n"
> -      "</html>"
> +             << "</tbody>\n"
> +             << "</table>\n"
> +             << "</pre>\n"
> +             << "</body>\n"
> +             << "</html>";
> -    CloseFile(aFile);
> +    delete aFile;
> -  void ReportsHtml::CloseSizeFile(
> -    FILE*  aFile
> +  void ReportsHtml::CloseSizeFile( std::ofstream* aFile )
> -    fprintf(
> -      aFile,
> -      TABLE_FOOTER
> -      "</tbody>\n"
> -      "</table>\n"
> -      "</pre>\n"
> -      "</body>\n"
> -      "</html>"
> +             << "</tbody>\n"
> +             << "</table>\n"
> +             << "</pre>\n"
> +             << "</body>\n"
> +             << "</html>";
>      CloseFile( aFile );
> +    delete aFile;
> -  void ReportsHtml::CloseSymbolSummaryFile(
> -    FILE*  aFile
> +  void ReportsHtml::CloseSymbolSummaryFile( std::ofstream* aFile )
> -    fprintf(
> -      aFile,
> -      TABLE_FOOTER
> -       "</tbody>\n"
> -      "</table>\n"
> -      "</pre>\n"
> -      "</body>\n"
> -      "</html>"
> +             << "</tbody>\n"
> +             << "</table>\n"
> +             << "</pre>\n"
> +             << "</body>\n"
> +             << "</html>";
>       CloseFile( aFile );
> +     delete aFile;
> diff --git a/tester/covoar/ReportsHtml.h b/tester/covoar/ReportsHtml.h
> index 8d209ae..6144476 100644
> --- a/tester/covoar/ReportsHtml.h
> +++ b/tester/covoar/ReportsHtml.h
> @@ -9,6 +9,9 @@
>  #ifndef __REPORTSHTML_H__
>  #define __REPORTSHTML_H__
> +#include <string>
> +#include <fstream>
>  #include <stdint.h>
>  #include "Explanations.h"
> @@ -22,7 +25,8 @@ namespace Coverage {
>  class ReportsHtml: public ReportsBase {
>    public:
> -    ReportsHtml( time_t timestamp, std::string symbolSetName );
> +    ReportsHtml( time_t timestamp, const std::string& symbolSetName );
>     ~ReportsHtml();
> @@ -30,9 +34,7 @@ class ReportsHtml: public ReportsBase {
>      *  @param[in] fileName identifies the file name.
> -   void WriteIndex(
> +   void WriteIndex( const std::string& fileName );
> @@ -40,9 +42,7 @@ class ReportsHtml: public ReportsBase {
> @@ -50,9 +50,7 @@ class ReportsHtml: public ReportsBase {
> @@ -60,9 +58,7 @@ class ReportsHtml: public ReportsBase {
>      *  @param[in] fileName identifies the size report file name
>    protected:
> @@ -75,140 +71,111 @@ class ReportsHtml: public ReportsBase {
>      AnnotatedLineState_t lastState_m;
>      /* Inherit documentation from base class. */
> -      bool              hasBranches
> +      bool                 hasBranches
> -    FILE* OpenNoRangeFile(
> +    std::ofstream* OpenNoRangeFile( const std::string& fileName );
> -      FILE*  aFile
> -      FILE*  aFile,
> -      bool   hasBranches
> -      FILE*  aFile
> -      FILE*  aFile
> -      FILE*  aFile
> -      FILE*  aFile
> -      FILE*                aFile,
> -      std::string          line,
>        uint32_t             id
> -      FILE*                aFile
> +     virtual void AnnotatedStart( std::ofstream* aFile );
> -      FILE*                aFile
> +     virtual void AnnotatedEnd( std::ofstream* aFile );
> -      FILE* report
> +    virtual bool PutNoBranchInfo( std::ofstream* report );
> -      FILE*                                            report,
> -      FILE*        report,
> -      FILE*                                           report,
> -      FILE*                                           report,
> -      FILE*                                           report,
> -    virtual FILE* OpenFile(
> +    virtual std::ofstream* OpenFile( const std::string& fileName );
> -    virtual bool WriteExplationFile(
> +    virtual bool WriteExplanationFile(
> diff --git a/tester/covoar/ReportsText.cc b/tester/covoar/ReportsText.cc
> index 33be32f..1218ebc 100644
> --- a/tester/covoar/ReportsText.cc
> +++ b/tester/covoar/ReportsText.cc
> @@ -1,6 +1,8 @@
>  #include <stdio.h>
>  #include <string.h>
> +#include <iomanip>
>  #include "ReportsText.h"
> @@ -11,8 +13,10 @@
> -ReportsText::ReportsText( time_t timestamp, std::string symbolSetName ):
> +ReportsText::ReportsText(
> +  time_t             timestamp,
> +): ReportsBase( timestamp, symbolSetName )
>    reportExtension_m = ".txt";
> @@ -21,272 +25,230 @@ ReportsText::~ReportsText()
> -void ReportsText::AnnotatedStart(
> -  FILE*                aFile
> +void ReportsText::AnnotatedStart( std::ofstream* aFile )
> -  fprintf(
> -    aFile,
> -    "=======================================\n"
> +  (*aFile) << "========================================"
> +           << "=======================================\n";
> -void ReportsText::AnnotatedEnd(
> -  FILE*                aFile
> +void ReportsText::AnnotatedEnd( std::ofstream* aFile )
>  void ReportsText::PutAnnotatedLine(
> -  FILE*                aFile,
> -  std::string          line,
>    uint32_t             id
> -  fprintf( aFile, "%s\n", line.c_str());
> +  (*aFile) << line << "\n";
> -bool ReportsText::PutNoBranchInfo(
> -  FILE*           report
> +bool ReportsText::PutNoBranchInfo( std::ofstream* report )
> -    SymbolsToAnalyze->getNumberBranchesFound(symbolSetName_m) != 0 )
> -  else
> +    (*report) << "All branch paths taken.\n";
> +  } else {
> +    (*report) << "No branch information found.\n";
>    return true;
>  bool ReportsText::PutBranchEntry(
> -  FILE*                                            report,
>    // Add an entry to the report
> -  fprintf(
> -    report,
> -    "============================================\n"
> -    "Symbol        : %s (0x%x)\n"
> -    "Line          : %s (0x%x)\n"
> -    "Size in Bytes : %d\n",
> -    symbolName.c_str(),
> -    symbolInfo.baseAddress,
> -    range.lowAddress,
> -    fprintf(
> -      report, "Reason        : %s\n\n", "ALWAYS TAKEN"
> -    fprintf( report, "Reason        : %s\n\n", "NEVER TAKEN" );
> +  (*report) << "============================================\n"
> +            << "Symbol        : " << symbolName
> +            << std::hex << " (0x" << symbolInfo.baseAddress << ")\n"
> +            << "Line          : " << range.lowSourceLine
> +            << " (0x" << range.lowAddress << ")\n"
> +            << "Size in Bytes : " << range.highAddress - range.lowAddress + 1
> +            << std::dec << "\n";
> +  if (
> +    range.reason ==
> +    (*report) << "Reason        : ALWAYS TAKEN\n\n";
> +  } else if (
> +      range.reason ==
> +      (*report) << "Reason        : NEVER TAKEN\n\n";
> -    fprintf(
> -      report,
> -      "Classification: NONE\n"
> -      "\n"
> -      "Explanation:\n"
> -      "No Explanation\n"
> +    (*report) << "Classification: NONE\n"
> +              << "\n"
> +              << "Explanation:\n"
> +              << "No Explanation\n";
>    } else {
> -    fprintf(
> -      report,
> -      "Classification: %s\n"
> -      "\n"
> -      "Explanation:\n",
> -          i < explanation->explanation.size();
> -          i++) {
> -      fprintf(
> -        report,
> -        "%s\n",
> +    (*report) << "Classification: " << explanation->classification << "\n"
> +              << "\n"
> +              << "Explanation:\n";
> -  fprintf(
> -    report, "============================================\n"
> +  (*report) << "============================================\n";
>    return true;
>  void ReportsText::putCoverageNoRange(
> -  FILE*         report,
> -      fprintf(
> -        report,
> -        "Symbol        : %s\n\n"
> -        "          *** NEVER REFERENCED ***\n\n"
> -        "This symbol was never referenced by an analyzed executable.\n"
> -        "Therefore there is no size or disassembly for this symbol.\n"
> -        "This could be due to symbol misspelling or lack of a test for\n"
> -        "this symbol.\n"
> -        "============================================\n",
> -        symbol.c_str()
> -      fprintf( noRangeFile, "%s\n", symbol.c_str() );
> +            << "Symbol        : " << symbol << "\n\n"
> +            << "          *** NEVER REFERENCED ***\n\n"
> +            << "This symbol was never referenced by an analyzed executable.\n"
> +            << "Therefore there is no size or disassembly for this symbol.\n"
> +            << "This could be due to symbol misspelling or lack of a test for\n"
> +            << "this symbol.\n"
> +            << "============================================\n";
> +  (*noRangeFile) << symbol << "\n";
>  bool ReportsText::PutCoverageLine(
> -  FILE*                                           report,
> -  fprintf(
> -    report,
> -    "Index                : %d\n"
> -    "Starting Line        : %s (0x%x)\n"
> -    "Ending Line          : %s (0x%x)\n"
> -    "Size in Instructions : %d\n\n",
> -    range.id,
> -    range.lowAddress,
> -    range.highSourceLine.c_str(),
> -    range.highAddress,
> -    range.highAddress - range.lowAddress + 1,
> +            << "Index                : " << range.id << "\n"
> +            << "Starting Line        : " << range.lowSourceLine
> +            << "Ending Line          : " << range.highSourceLine
> +            << " (0x" << range.highAddress << ")\n"
> +            << std::dec
> +            << range.highAddress - range.lowAddress + 1 << "\n"
> +            << "Size in Instructions : " << range.instructionCount << "\n\n";
> -    fprintf(
> -      report,
> -      "\n"
> -      "Explanation:\n"
> +              << "\n"
>    } else {
> -    fprintf(
> -      report,
> -      "\n"
> -      "Explanation:\n",
> -    for ( unsigned int i=0; i < explanation->explanation.size(); i++) {
> -      fprintf( report,"%s\n", explanation->explanation[i].c_str() );
> +              << "\n"
> -  fprintf(report, "============================================\n");
>    return true;
>  bool  ReportsText::PutSizeLine(
> -  FILE*                                           report,
> -  fprintf(
> -    report,
> -    "%d\t%s\t%s\n",
> +  (*report) << range.highAddress - range.lowAddress + 1 << "\t"
> +            << symbolName << "\t"
> +            << range.lowSourceLine << "\n";
>    return true;
>  bool  ReportsText::PutSymbolSummaryLine(
> -  FILE*                                           report,
>    float uncoveredBytes;
>    float uncoveredInstructions;
> -    fprintf(
> -      report,
> -      "Symbol                            : %s\n"
> -      "this symbol.\n",
> +              << "Symbol                            : " << symbolName << "\n"
>    } else {
>        uncoveredInstructions = 0;
> -    else
> -      uncoveredInstructions = (symbolInfo.stats.uncoveredInstructions*100.0)/
> -                              symbolInfo.stats.sizeInInstructions;
> +    } else {
> +      uncoveredInstructions = ( symbolInfo.stats.uncoveredInstructions*100.0 ) /
> +                                symbolInfo.stats.sizeInInstructions;
>        uncoveredBytes = 0;
> -    else
> -      uncoveredBytes = (symbolInfo.stats.uncoveredBytes*100.0)/
> -                       symbolInfo.stats.sizeInBytes;
> -    fprintf(
> -      report,
> -      "Symbol                            : %s\n"
> -      "Total Size in Bytes               : %d\n"
> -      "Total Size in Instructions        : %d\n"
> -      "Total number Branches             : %d\n"
> -      "Total Always Taken                : %d\n"
> -      "Total Never Taken                 : %d\n"
> -      "Percentage Uncovered Instructions : %.2f\n"
> -      "Percentage Uncovered Bytes        : %.2f\n",
> -      symbolInfo.stats.sizeInBytes,
> -      symbolInfo.stats.sizeInInstructions,
> -      symbolInfo.stats.branchesNotExecuted +  symbolInfo.stats.branchesExecuted,
> -      symbolInfo.stats.branchesAlwaysTaken,
> -      symbolInfo.stats.branchesNeverTaken,
> -      uncoveredInstructions,
> -      uncoveredBytes
> +    } else {
> +      uncoveredBytes = ( symbolInfo.stats.uncoveredBytes * 100.0 ) /
> +                         symbolInfo.stats.sizeInBytes;
> +              << "Symbol                            : "
> +              << symbolName << "\n"
> +              << "Total Size in Bytes               : "
> +              << symbolInfo.stats.sizeInBytes << "\n"
> +              << "Total Size in Instructions        : "
> +              << symbolInfo.stats.sizeInInstructions << "\n"
> +              << "Total number Branches             : "
> +              << symbolInfo.stats.branchesNotExecuted +  symbolInfo.stats.branchesExecuted
> +              << "\n"
> +              << "Total Always Taken                : "
> +              << symbolInfo.stats.branchesAlwaysTaken << "\n"
> +              << "Total Never Taken                 : "
> +              << symbolInfo.stats.branchesNeverTaken << "\n"
> +              << "Percentage Uncovered Instructions : "
> +              << uncoveredInstructions << "\n"
> +              << "Percentage Uncovered Bytes        : "
> +              << uncoveredBytes << "\n";
>    return true;
> diff --git a/tester/covoar/ReportsText.h b/tester/covoar/ReportsText.h
> index 23a1003..d5ce272 100644
> --- a/tester/covoar/ReportsText.h
> +++ b/tester/covoar/ReportsText.h
> @@ -21,7 +21,8 @@ namespace Coverage {
>  class ReportsText: public ReportsBase {
>    public:
> -    ReportsText( time_t timestamp, std::string symbolSetName );
> +    ReportsText( time_t timestamp, const std::string& symbolSetName );
>      virtual ~ReportsText();
> @@ -30,9 +31,7 @@ class ReportsText: public ReportsBase {
> @@ -40,9 +39,7 @@ class ReportsText: public ReportsBase {
> @@ -50,75 +47,67 @@ class ReportsText: public ReportsBase {
>    protected:
> -      FILE*                aFile,
> -      std::string          line,
>        uint32_t             id
> -      FILE*                aFile
> -      FILE*                aFile
> -      FILE* report
> -      FILE*                                            report,
> -      FILE*        report,
> -      FILE*                                           report,
> -      FILE*                                           report,
> -      FILE*                                           report,
