[PATCH] libc: Added sig2str/str2sig prototypes
Matthew Joyce mfjoyce2004 at gmail.com
Wed Jul 7 15:08:55 UTC 2021
Dr. Joel,
Thanks, I will make these changes and resubmit!
Sincerely,
Matt
On Wed, Jul 7, 2021 at 3:57 PM Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Jul 7, 2021 at 5:46 AM Matt Joyce <mfjoyce2004 at gmail.com> wrote:
> > Added definition of SIG2STR_MAX and function prototypes for sig2str
> > and str2sig in sys/signal.h in order to improve POSIX compliance.
> >  newlib/libc/include/sys/signal.h | 12 ++++++++++++
> >  1 file changed, 12 insertions(+)
> > diff --git a/newlib/libc/include/sys/signal.h b/newlib/libc/include/sys/signal.h
> > index 45cc0366c..36dcbdb1a 100644
> > --- a/newlib/libc/include/sys/signal.h
> > +++ b/newlib/libc/include/sys/signal.h
> > @@ -238,6 +238,18 @@ int sigqueue (pid_t, int, const union sigval);
> >  #endif /* __POSIX_VISIBLE >= 199309 */
> > +#if __GNU_VISIBLE
> This is OK for now. When Issue 8 is published, this may need to change.
> > +/* 202x_d2-POSIX-Issue-8, p. 327 adds SIG2STR_MAX ps. 332 adds sig2str()
> > + * and str2sig() */
> Do not reference page number in a draft that is not widely
> distributed. How about:
> POSIX Issue 8 adds sig2str() and str2sig()
> > +#define SIG2STR_MAX sizeof("Unknown signal 4294967295 ")
> We both saw the email requesting the sizeof this string as the max length
> but a comment that this allows for the maximum length signal name and
> longest integer format is probably needed.
> > +int sig2str(int, char *);
> > +int str2sig(const char *__restrict, int *__restrict);
> > +#endif /* __GNU_VISIBLE */
> >  #if defined(___AM29K__)
> >  /* These all need to be defined for ANSI C, but I don't think they are
> >     meaningful.  */
> > 2.31.1
> > devel mailing list
> > devel at rtems.org
