[PATCH rtems-libbsd] rtemsbsd: Use a separate header for test devices
Fri Jul 9 05:39:11 UTC 2021
On 08/07/2021 03:11, Kinsey Moore wrote:
> I wonder why this never came up with Zynq or QorIQ. Maybe no one wanted
> to run network tests on the alternate interfaces because dev boards with
> those interfaces configured didn't exist? It's possible that the ukphy
> driver could be improved and this entire problem just goes away or we
> ban that driver from the default configuration for multi-interface BSPs
> and the problem goes away.
The QorIQ BSP uses a device tree.
The chips will get more and more complex. Managing this complexity with
hand written C preprocessor defines is a dead end from my point of view.
Device trees allow you to provide a generic BSP which is initialized for
a particular board using the device tree. Compared to other operating
systems, the device tree support and generic device enumeration in RTEMS
is a bit under developed. See for example:
https://docs.zephyrproject.org/latest/guides/dts/index.html#dt-guide
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
