[PATCH v2] libc: Added implementations for sig2str/str2sig methods
Matt Joyce
mfjoyce2004 at gmail.com
Fri Jul 9 08:00:17 UTC 2021
Added implementations for sig2str() and str2sig() in libc/signal in order
to improve POSIX compliance. Added function prototypes added to
sys/signal.h.
newlib/libc/include/sys/signal.h | 12 ++
newlib/libc/signal/sig2str.c | 235 +++++++++++++++++++++++++++++++
2 files changed, 247 insertions(+)
create mode 100644 newlib/libc/signal/sig2str.c
diff --git a/newlib/libc/include/sys/signal.h b/newlib/libc/include/sys/signal.h
index 45cc0366c..847dc59bd 100644
--- a/newlib/libc/include/sys/signal.h
+++ b/newlib/libc/include/sys/signal.h
@@ -238,6 +238,18 @@ int sigqueue (pid_t, int, const union sigval);
#endif /* __POSIX_VISIBLE >= 199309 */
+#if __GNU_VISIBLE
+/* POSIX Issue 8 adds sig2str() and str2sig(). */
+/* This allows for the max length of the error message and longest integer. */
+#define SIG2STR_MAX sizeof("Unknown signal 4294967295 ")
+int sig2str(int, char *);
+int str2sig(const char *__restrict, int *__restrict);
+#endif /* __GNU_VISIBLE */
#if defined(___AM29K__)
/* These all need to be defined for ANSI C, but I don't think they are
meaningful. */
diff --git a/newlib/libc/signal/sig2str.c b/newlib/libc/signal/sig2str.c
new file mode 100644
index 000000000..04b4bb1be
--- /dev/null
+++ b/newlib/libc/signal/sig2str.c
@@ -0,0 +1,235 @@
+ * Copyright (C) 2021 Matthew Joyce
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+/* Defining _GNU_SOURCE to have access to SIG2STR_MAX in signal.h. */
+#define _GNU_SOURCE
+#include <signal.h>
+#include <string.h>
+#include <stdio.h>
+#include <stdlib.h>
+#define SPACES_TO_N 6 /* Allows indexing to RT Signal number in str2sig */
+#define NUM_OF_SIGS (sizeof(sig_array) / sizeof(sig_name_and_num))
+typedef struct sig_name_and_num {
+ const char *sig_name;
+ const int sig_num;
+} sig_name_and_num;
+static const sig_name_and_num sig_array[] = {
+ #ifdef SIGHUP
+ { "HUP", SIGHUP},
+ #endif
+ #ifdef SIGINT
+ { "INT", SIGINT },
+ #endif
+ #ifdef SIGQUIT
+ { "QUIT", SIGQUIT },
+ #endif
+ #ifdef SIGILL
+ { "ILL", SIGILL },
+ #endif
+ #ifdef SIGTRAP
+ { "TRAP", SIGTRAP },
+ #endif
+ #ifdef SIGABRT
+ { "ABRT", SIGABRT },
+ #endif
+ #ifdef SIGIOT
+ { "IOT", SIGIOT},
+ #endif
+ #ifdef SIGEMT
+ { "EMT", SIGEMT },
+ #endif
+ #ifdef SIGFPE
+ { "FPE", SIGFPE },
+ #endif
+ #ifdef SIGKILL
+ { "KILL", SIGKILL },
+ #endif
+ #ifdef SIGBUS
+ { "BUS", SIGBUS },
+ #endif
+ #ifdef SIGSEGV
+ { "SEGV", SIGSEGV },
+ #endif
+ #ifdef SIGSYS
+ { "SYS", SIGSYS },
+ #endif
+ #ifdef SIGPIPE
+ { "PIPE", SIGPIPE },
+ #endif
+ #ifdef SIGALRM
+ { "ALRM", SIGALRM },
+ #endif
+ #ifdef SIGTERM
+ { "TERM", SIGTERM },
+ #endif
+ #ifdef SIGURG
+ { "URG", SIGURG },
+ #endif
+ #ifdef SIGSTOP
+ { "STOP", SIGSTOP },
+ #endif
+ #ifdef SIGTSTP
+ { "TSTP", SIGTSTP },
+ #endif
+ #ifdef SIGCONT
+ { "CONT", SIGCONT },
+ #endif
+ #ifdef SIGCHLD
+ { "CHLD", SIGCHLD },
+ #endif
+ #ifdef SIGCLD
+ { "CLD", SIGCLD },
+ #endif
+ #ifdef SIGTTIN
+ { "TTIN", SIGTTIN },
+ #endif
+ #ifdef SIGTTOU
+ { "TTOU", SIGTTOU },
+ #endif
+ #ifdef SIGIO
+ { "IO", SIGIO },
+ #endif
+ #ifdef SIGPOLL
+ { "POLL", SIGPOLL },
+ #endif
+ #ifdef SIGWINCH
+ { "WINCH", SIGWINCH },
+ #endif
+ #ifdef SIGUSR1
+ { "USR1", SIGUSR1 },
+ #endif
+ #ifdef SIGUSR2
+ { "USR2", SIGUSR2 },
+ #endif
+ #ifdef SIGPWR
+ { "PWR", SIGPWR },
+ #endif
+ #ifdef SIGXCPU
+ { "XCPU", SIGXCPU },
+ #endif
+ #ifdef SIGXFSZ
+ { "XFSZ", SIGXFSZ },
+ #endif
+ #ifdef SIGVTALRM
+ { "VTALRM", SIGVTALRM },
+ #endif
+ #ifdef SIGPROF
+ { "PROF", SIGPROF },
+ #endif
+ #ifdef SIGLOST
+ { "LOST", SIGLOST },
+ #endif
+ /* The Issue 8 standard requires that SIGRTMIN and SIGRTMAX be included
+ * as valid results to be saved from calls to sig2str/str2sig. */
+ #ifdef SIGRTMIN
+ { "RTMIN", SIGRTMIN },
+ #endif
+ #ifdef SIGRTMAX
+ { "RTMAX", SIGRTMAX }
+ #endif
+int
+sig2str(int signum, char *str)
+ const sig_name_and_num *sptr;
+ /* If signum falls in the real time signals range, the Issue 8 standard
+ * gives the option of defining the saved str value as either "RTMIN+n" or
+ * "RTMAX-m".*/
+ if ((SIGRTMIN + 1) <= signum && signum <= (SIGRTMAX -1)) {
+ sprintf(str, "RTMIN+%d", (signum-SIGRTMIN));
+ return 0;
+ /* Otherwise, search for signal matching signum in sig_array. If found,
+ * save its string value in str. */
+ for (sptr = sig_array; sptr < &sig_array[NUM_OF_SIGS]; sptr++) {
+ if (sptr->sig_num == signum) {
+ strcpy(str, sptr->sig_name);
+ return 0;
+ /* If signum is not a recognized signal number, store this message in str. */
+ sprintf(str, "Unknown signal %d", signum);
+ return -1;
+int
+str2sig(const char *restrict str, int *restrict pnum)
+ int j = 0;
+ char dest[SIG2STR_MAX];
+ int is_valid_decimal;
+ is_valid_decimal = atoi(str);
+ /* If str is a representation of a decimal value, save its integer value
+ * in pnum. */
+ if (1 <= is_valid_decimal && is_valid_decimal <= SIGRTMAX) {
+ *pnum = is_valid_decimal;
+ return 0;
+ /* If str is in RT signal range, get number of of RT signal, save it as an
+ * integer. The Issue 8 standard requires */
+ if (strncmp(str, "RTMIN+", SPACES_TO_N) == 0) {
+ j = atoi(&str[SPACES_TO_N]);
+ /* If number is valid, save it in pnum. */
+ if (1 <= j && j <= ((SIGRTMAX - SIGRTMIN)-1)) {
+ *pnum = (SIGRTMIN + j);
+ return 0;
+ return -1;
+ * integer. */
+ if (strncmp(str, "RTMAX-", SPACES_TO_N) == 0) {
+ *pnum = (SIGRTMAX - j);
+ return 0;
+ return -1;
+ /*If str is a valid signal name, save its corresponding number in pnum. */
+ if (strcmp(sptr->sig_name, str) == 0) {
+ *pnum = sptr->sig_num;
+ return 0;
+ return -1;
2.31.1
