[PATCH 07/41] rtems: Add rtems_interrupt_vector_enable()
Sebastian Huber
Mon Jul 12 12:49:29 UTC 2021
Add rtems_interrupt_vector_disable().
Update #3269.
bsps/shared/irq-default-sources.am | 1 +
bsps/shared/irq-sources.am | 1 +
bsps/shared/irq/irq-enable-disable.c | 59 +++++++++++++
c/src/lib/libbsp/m68k/genmcf548x/Makefile.am | 1 +
c/src/lib/libbsp/powerpc/ss555/Makefile.am | 1 +
cpukit/include/rtems/irq-extension.h | 88 ++++++++++++++++++++
spec/build/bsps/m68k/genmcf548x/obj.yml | 1 +
spec/build/bsps/objirq.yml | 1 +
spec/build/bsps/powerpc/ss555/bspss555.yml | 1 +
9 files changed, 154 insertions(+)
create mode 100644 bsps/shared/irq/irq-enable-disable.c
diff --git a/bsps/shared/irq-default-sources.am b/bsps/shared/irq-default-sources.am
index 9f0e4686f7..fe3352f7e5 100644
--- a/bsps/shared/irq-default-sources.am
+++ b/bsps/shared/irq-default-sources.am
@@ -1,6 +1,7 @@
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-affinity.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-default.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-default-handler.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-enable-disable.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-generic.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-handler-iterate.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-info.c
diff --git a/bsps/shared/irq-sources.am b/bsps/shared/irq-sources.am
index 776958dd8f..d2536eb56d 100644
--- a/bsps/shared/irq-sources.am
+++ b/bsps/shared/irq-sources.am
@@ -1,4 +1,5 @@
diff --git a/bsps/shared/irq/irq-enable-disable.c b/bsps/shared/irq/irq-enable-disable.c
new file mode 100644
index 0000000000..792f5e60c6
--- /dev/null
+++ b/bsps/shared/irq/irq-enable-disable.c
@@ -0,0 +1,59 @@
+ * @file
+ * @ingroup bsp_interrupt
+ * @brief This source file contains the implementation of
+ * rtems_interrupt_vector_enable() and rtems_interrupt_vector_disable().
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#include <bsp/irq-generic.h>
+rtems_status_code rtems_interrupt_vector_enable( rtems_vector_number vector )
+ if ( !bsp_interrupt_is_valid_vector( vector ) ) {
+ return RTEMS_INVALID_ID;
+ bsp_interrupt_vector_enable( vector );
+ return RTEMS_SUCCESSFUL;
+rtems_status_code rtems_interrupt_vector_disable( rtems_vector_number vector )
+ bsp_interrupt_vector_disable( vector );
diff --git a/c/src/lib/libbsp/m68k/genmcf548x/Makefile.am b/c/src/lib/libbsp/m68k/genmcf548x/Makefile.am
index 88a1ab0e5b..ecc8c99b26 100644
--- a/c/src/lib/libbsp/m68k/genmcf548x/Makefile.am
+++ b/c/src/lib/libbsp/m68k/genmcf548x/Makefile.am
@@ -40,6 +40,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/m68k/genmcf548x/btimer/btimer.c
# IRQ
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-legacy.c
diff --git a/c/src/lib/libbsp/powerpc/ss555/Makefile.am b/c/src/lib/libbsp/powerpc/ss555/Makefile.am
index e1a79a6293..2dc5a98e33 100644
--- a/c/src/lib/libbsp/powerpc/ss555/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/ss555/Makefile.am
@@ -49,6 +49,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/ss555/start/vectors.S
diff --git a/cpukit/include/rtems/irq-extension.h b/cpukit/include/rtems/irq-extension.h
index d6b5cd5e45..2df18b2b0d 100644
--- a/cpukit/include/rtems/irq-extension.h
+++ b/cpukit/include/rtems/irq-extension.h
@@ -315,6 +315,94 @@ rtems_status_code rtems_interrupt_handler_remove(
void *arg
+/* Generated from spec:/rtems/intr/if/vector-enable */
+ * @ingroup RTEMSAPIClassicIntr
+ * @brief Enables the interrupt vector.
+ * @param vector is the number of the interrupt vector to enable.
+ * The directive enables the interrupt vector specified by ``vector``. This
+ * allows that interrupt service requests are issued to the target processors
+ * of the interrupt vector. Interrupt service requests for an interrupt vector
+ * may be caused by rtems_interrupt_cause(), rtems_interrupt_cause_on(),
+ * external signals, or messages.
+ * @retval ::RTEMS_SUCCESSFUL The requested operation was successful.
+ * @retval ::RTEMS_INVALID_ID There was no interrupt vector associated with the
+ * number specified by ``vector``.
+ * @retval ::RTEMS_UNSATISFIED The request to enable the interrupt vector has
+ * not been satisfied.
+ * @par Notes
+ * The rtems_interrupt_get_attributes() directive may be used to check if an
+ * interrupt vector can be enabled. Interrupt vectors may be disabled by
+ * rtems_interrupt_vector_disable().
+ * @par Constraints
+ * @parblock
+ * The following constraints apply to this directive:
+ * * The directive may be called from within interrupt context.
+ * * The directive may be called from within device driver initialization
+ * context.
+ * * The directive may be called from within task context.
+ * * The directive will not cause the calling task to be preempted.
+ * @endparblock
+rtems_status_code rtems_interrupt_vector_enable( rtems_vector_number vector );
+/* Generated from spec:/rtems/intr/if/vector-disable */
+ * @brief Disables the interrupt vector.
+ * @param vector is the number of the interrupt vector to disable.
+ * The directive disables the interrupt vector specified by ``vector``. This
+ * prevents that an interrupt service request is issued to the target
+ * processors of the interrupt vector.
+ * @retval ::RTEMS_UNSATISFIED The request to disable the interrupt vector has
+ * @par Notes
+ * interrupt vector can be disabled. Interrupt vectors may be enabled by
+ * rtems_interrupt_vector_enable(). There may be targets on which some
+ * interrupt vectors cannot be disabled, for example a hardware watchdog
+ * interrupt or software generated interrupts.
+ * @parblock
+ * context.
+ * @endparblock
+rtems_status_code rtems_interrupt_vector_disable( rtems_vector_number vector );
/* Generated from spec:/rtems/intr/if/get-affinity */
diff --git a/spec/build/bsps/m68k/genmcf548x/obj.yml b/spec/build/bsps/m68k/genmcf548x/obj.yml
index 252b350f70..538279e196 100644
--- a/spec/build/bsps/m68k/genmcf548x/obj.yml
+++ b/spec/build/bsps/m68k/genmcf548x/obj.yml
@@ -40,6 +40,7 @@ source:
- bsps/shared/dev/getentropy/getentropy-cpucounter.c
- bsps/shared/irq/irq-affinity.c
- bsps/shared/irq/irq-default-handler.c
+- bsps/shared/irq/irq-enable-disable.c
- bsps/shared/irq/irq-handler-iterate.c
- bsps/shared/irq/irq-info.c
- bsps/shared/irq/irq-legacy.c
diff --git a/spec/build/bsps/objirq.yml b/spec/build/bsps/objirq.yml
index 616a3ea83f..b6e725832f 100644
--- a/spec/build/bsps/objirq.yml
+++ b/spec/build/bsps/objirq.yml
@@ -11,6 +11,7 @@ install: []
links: []
source:
- bsps/shared/irq/irq-generic.c
diff --git a/spec/build/bsps/powerpc/ss555/bspss555.yml b/spec/build/bsps/powerpc/ss555/bspss555.yml
index e011ceb9b5..a209db3238 100644
--- a/spec/build/bsps/powerpc/ss555/bspss555.yml
+++ b/spec/build/bsps/powerpc/ss555/bspss555.yml
@@ -70,6 +70,7 @@ source:
- bsps/shared/irq/irq-default.c
2.26.2
