[PATCH 12/41] bsps/irq: Add rtems_interrupt_cause()
Mon Jul 12 12:49:34 UTC 2021
Add rtems_interrupt_cause_on() and rtems_interrupt_clear().
Add a default implementation which just returns RTEMS_UNSATISFIED for
valid parameters.
Update #3269.
 bsps/arm/beagle/irq/irq.c                    | 12 +++
 bsps/arm/csb336/irq/irq.c                    | 12 +++
 bsps/arm/csb337/irq/irq.c                    | 12 +++
 bsps/arm/edb7312/irq/irq.c                   | 12 +++
 bsps/arm/gumstix/irq/irq.c                   | 12 +++
 bsps/arm/lpc24xx/irq/irq.c                   | 12 +++
 bsps/arm/lpc32xx/irq/irq.c                   | 12 +++
 bsps/arm/raspberrypi/irq/irq.c               | 23 ++++++
 bsps/arm/rtl22xx/irq/irq.c                   | 12 +++
 bsps/arm/shared/irq/irq-armv7m.c             | 12 +++
 bsps/arm/smdk2410/irq/irq.c                  | 12 +++
 bsps/arm/tms570/irq/irq.c                    | 12 +++
 bsps/i386/shared/irq/irq.c                   | 12 +++
 bsps/include/bsp/irq-generic.h               | 47 +++++++++++
 bsps/lm32/shared/irq/irq.c                   | 12 +++
 bsps/m68k/genmcf548x/irq/irq.c               | 12 +++
 bsps/mips/shared/irq/irq.c                   | 12 +++
 bsps/powerpc/gen5200/irq/irq.c               | 12 +++
 bsps/powerpc/gen83xx/irq/irq.c               | 12 +++
 bsps/powerpc/mpc55xxevb/start/irq.c          | 12 +++
 bsps/powerpc/mpc8260ads/irq/irq.c            | 12 +++
 bsps/powerpc/psim/irq/irq_init.c             | 12 +++
 bsps/powerpc/qemuppc/irq/irq_init.c          | 12 +++
 bsps/powerpc/qoriq/irq/irq.c                 | 46 +++++++++++
 bsps/powerpc/shared/irq/ppc-irq-generic.c    | 12 +++
 bsps/powerpc/t32mppc/irq/irq.c               | 12 +++
 bsps/powerpc/tqm8xx/irq/irq.c                | 12 +++
 bsps/powerpc/virtex/irq/irq_init.c           | 12 +++
 bsps/riscv/griscv/irq/irq.c                  | 23 ++++++
 bsps/riscv/riscv/irq/irq.c                   | 23 ++++++
 bsps/shared/dev/irq/arm-gicv2.c              | 23 ++++++
 bsps/shared/dev/irq/arm-gicv3.c              | 23 ++++++
 bsps/shared/irq-default-sources.am           |  1 +
 bsps/shared/irq-sources.am                   |  1 +
 bsps/shared/irq/irq-cause-clear.c            | 84 ++++++++++++++++++++
 bsps/shared/irq/irq-default.c                | 12 +++
 bsps/sparc/leon3/start/eirq.c                | 23 ++++++
 bsps/sparc/shared/irq/irq-shared.c           | 23 ++++++
 bsps/x86_64/amd64/interrupts/idt.c           | 12 +++
 c/src/lib/libbsp/m68k/genmcf548x/Makefile.am |  1 +
 c/src/lib/libbsp/powerpc/ss555/Makefile.am   |  1 +
 spec/build/bsps/m68k/genmcf548x/obj.yml      |  1 +
 spec/build/bsps/objirq.yml                   |  1 +
 spec/build/bsps/powerpc/ss555/bspss555.yml   |  1 +
 44 files changed, 669 insertions(+)
 create mode 100644 bsps/shared/irq/irq-cause-clear.c
diff --git a/bsps/arm/beagle/irq/irq.c b/bsps/arm/beagle/irq/irq.c
index d0a07d1937..9ba317f64f 100644
--- a/bsps/arm/beagle/irq/irq.c
+++ b/bsps/arm/beagle/irq/irq.c
@@ -95,6 +95,18 @@ static uint32_t omap_get_mir_reg(rtems_vector_number vector, uint32_t *const mas
   return mir_reg;
+rtems_status_code bsp_interrupt_cause(rtems_vector_number vector)
+  bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
+  return RTEMS_UNSATISFIED;
+rtems_status_code bsp_interrupt_clear(rtems_vector_number vector)
 rtems_status_code bsp_interrupt_vector_is_enabled(
   bool               *enabled
diff --git a/bsps/arm/csb336/irq/irq.c b/bsps/arm/csb336/irq/irq.c
index 80914fe28f..4c24c4c09d 100644
--- a/bsps/arm/csb336/irq/irq.c
+++ b/bsps/arm/csb336/irq/irq.c
@@ -26,6 +26,18 @@ void bsp_interrupt_dispatch(void)
   bsp_interrupt_handler_dispatch(vector);
   bool               *enabled
diff --git a/bsps/arm/csb337/irq/irq.c b/bsps/arm/csb337/irq/irq.c
index 5276374a1e..730b680b6a 100644
--- a/bsps/arm/csb337/irq/irq.c
+++ b/bsps/arm/csb337/irq/irq.c
@@ -27,6 +27,18 @@ void bsp_interrupt_dispatch(void)
   AIC_CTL_REG(AIC_EOICR) = 0;
   bool               *enabled
diff --git a/bsps/arm/edb7312/irq/irq.c b/bsps/arm/edb7312/irq/irq.c
index d11cbf78c3..6096bf7023 100644
--- a/bsps/arm/edb7312/irq/irq.c
+++ b/bsps/arm/edb7312/irq/irq.c
@@ -27,6 +27,18 @@ void edb7312_interrupt_dispatch(rtems_vector_number vector)
   bool               *enabled
diff --git a/bsps/arm/gumstix/irq/irq.c b/bsps/arm/gumstix/irq/irq.c
index 3b62b8f42c..dc69274df3 100644
--- a/bsps/arm/gumstix/irq/irq.c
+++ b/bsps/arm/gumstix/irq/irq.c
@@ -24,6 +24,18 @@ void bsp_interrupt_dispatch(void)
   bool               *enabled
diff --git a/bsps/arm/lpc24xx/irq/irq.c b/bsps/arm/lpc24xx/irq/irq.c
index efc7c8beaa..74313b3f10 100644
--- a/bsps/arm/lpc24xx/irq/irq.c
+++ b/bsps/arm/lpc24xx/irq/irq.c
@@ -64,6 +64,18 @@ unsigned lpc24xx_irq_get_priority(rtems_vector_number vector)
 #ifdef ARM_MULTILIB_ARCH_V4
   bool               *enabled
diff --git a/bsps/arm/lpc32xx/irq/irq.c b/bsps/arm/lpc32xx/irq/irq.c
index c8b2f33f51..ca9377cdcc 100644
--- a/bsps/arm/lpc32xx/irq/irq.c
+++ b/bsps/arm/lpc32xx/irq/irq.c
@@ -260,6 +260,18 @@ void bsp_interrupt_dispatch(void)
   lpc32xx.sic_2.er = er_sic_2 & lpc32xx_irq_enable.field.sic_2;
   bool               *enabled
diff --git a/bsps/arm/raspberrypi/irq/irq.c b/bsps/arm/raspberrypi/irq/irq.c
index 625fbc5dad..a08379220a 100644
--- a/bsps/arm/raspberrypi/irq/irq.c
+++ b/bsps/arm/raspberrypi/irq/irq.c
@@ -143,6 +143,29 @@ void bsp_interrupt_dispatch(void)
+#if defined(RTEMS_SMP)
+rtems_status_code bsp_interrupt_cause_on(
+  rtems_vector_number vector,
+  uint32_t            cpu_index
+#endif
   bool               *enabled
diff --git a/bsps/arm/rtl22xx/irq/irq.c b/bsps/arm/rtl22xx/irq/irq.c
index 2653cb07bb..6da7ad927d 100644
--- a/bsps/arm/rtl22xx/irq/irq.c
+++ b/bsps/arm/rtl22xx/irq/irq.c
   VICVectAddr = 0;
   bool               *enabled
diff --git a/bsps/arm/shared/irq/irq-armv7m.c b/bsps/arm/shared/irq/irq-armv7m.c
index b1ab2afa62..1abc04bbf5 100644
--- a/bsps/arm/shared/irq/irq-armv7m.c
+++ b/bsps/arm/shared/irq/irq-armv7m.c
@@ -38,6 +38,18 @@
 #ifdef ARM_MULTILIB_ARCH_V7M
   bool               *enabled
diff --git a/bsps/arm/smdk2410/irq/irq.c b/bsps/arm/smdk2410/irq/irq.c
index 7dc219d447..4300889483 100644
--- a/bsps/arm/smdk2410/irq/irq.c
+++ b/bsps/arm/smdk2410/irq/irq.c
   bool               *enabled
diff --git a/bsps/arm/tms570/irq/irq.c b/bsps/arm/tms570/irq/irq.c
index 231d8f23c9..688aa69e75 100644
--- a/bsps/arm/tms570/irq/irq.c
+++ b/bsps/arm/tms570/irq/irq.c
@@ -96,6 +96,18 @@ void bsp_interrupt_dispatch(void)
  * @retval RTEMS_INVALID_ID vector is invalid.
  * @retval RTEMS_SUCCESSFUL interrupt source enabled.
   bool               *enabled
diff --git a/bsps/i386/shared/irq/irq.c b/bsps/i386/shared/irq/irq.c
index 69cd91e79b..39a49aa57a 100644
--- a/bsps/i386/shared/irq/irq.c
+++ b/bsps/i386/shared/irq/irq.c
@@ -270,6 +270,18 @@ static inline bool bsp_interrupt_vector_is_valid(rtems_vector_number vector)
   return BSP_i8259a_irq_valid((const rtems_irq_number) vector);
   bool               *enabled
diff --git a/bsps/include/bsp/irq-generic.h b/bsps/include/bsp/irq-generic.h
index cc45e63fed..f4de468a49 100644
--- a/bsps/include/bsp/irq-generic.h
+++ b/bsps/include/bsp/irq-generic.h
@@ -273,6 +273,53 @@ void bsp_interrupt_vector_enable(rtems_vector_number vector);
 void bsp_interrupt_vector_disable(rtems_vector_number vector);
+ * @brief Causes the interrupt vector.
+ * @param vector is the number of the interrupt vector to cause.  It shall be
+ *   valid.
+ * @retval ::RTEMS_SUCCESSFUL The requested operation was successful.
+ * @retval ::RTEMS_UNSATISFIED The request to cause the interrupt vector has
+ *   not been satisfied.
+rtems_status_code bsp_interrupt_cause( rtems_vector_number vector );
+ * @brief Causes the interrupt vector on the processor.
+ *   valid.
+ * @param cpu_index is the index of the target processor of the interrupt
+ *   vector to cause.  It shall be valid.
+#endif
+ * @brief Clears the interrupt vector.
+ * @param vector is the number of the interrupt vector to clear.  It shall be
+ *   valid.
+rtems_status_code bsp_interrupt_clear( rtems_vector_number vector );
  * @brief Sequentially calls all interrupt handlers installed at the vector.
diff --git a/bsps/lm32/shared/irq/irq.c b/bsps/lm32/shared/irq/irq.c
index cf15acd1c6..c48ec82fd1 100644
--- a/bsps/lm32/shared/irq/irq.c
+++ b/bsps/lm32/shared/irq/irq.c
@@ -17,6 +17,18 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
   return RTEMS_SUCCESSFUL;
   bool               *enabled
diff --git a/bsps/m68k/genmcf548x/irq/irq.c b/bsps/m68k/genmcf548x/irq/irq.c
index 70999451be..643c1783ac 100644
--- a/bsps/m68k/genmcf548x/irq/irq.c
+++ b/bsps/m68k/genmcf548x/irq/irq.c
@@ -59,6 +59,18 @@ static rtems_vector_number vector_to_exception_vector(
   return vector + 64U;
   bool               *enabled
diff --git a/bsps/mips/shared/irq/irq.c b/bsps/mips/shared/irq/irq.c
index ea9081ae16..ab1101e781 100644
--- a/bsps/mips/shared/irq/irq.c
+++ b/bsps/mips/shared/irq/irq.c
@@ -67,6 +67,18 @@ static inline bool bsp_irq_is_valid(rtems_vector_number vector)
   return vector < BSP_INTERRUPT_VECTOR_COUNT;
   bool               *enabled
diff --git a/bsps/powerpc/gen5200/irq/irq.c b/bsps/powerpc/gen5200/irq/irq.c
index f459bd0489..fafc58ee0a 100644
--- a/bsps/powerpc/gen5200/irq/irq.c
+++ b/bsps/powerpc/gen5200/irq/irq.c
@@ -359,6 +359,18 @@ static inline void BSP_disable_crit_irq_at_siu( rtems_vector_number
  * This function enables a given siu interrupt
   bool               *enabled
diff --git a/bsps/powerpc/gen83xx/irq/irq.c b/bsps/powerpc/gen83xx/irq/irq.c
index acbad2d463..9a452d2b09 100644
--- a/bsps/powerpc/gen83xx/irq/irq.c
+++ b/bsps/powerpc/gen83xx/irq/irq.c
@@ -376,6 +376,18 @@ rtems_status_code mpc83xx_ipic_set_highest_priority_interrupt(
  * functions to enable/disable a source at the ipic
   bool               *enabled
diff --git a/bsps/powerpc/mpc55xxevb/start/irq.c b/bsps/powerpc/mpc55xxevb/start/irq.c
index 2788c8f178..67f6715d52 100644
--- a/bsps/powerpc/mpc55xxevb/start/irq.c
+++ b/bsps/powerpc/mpc55xxevb/start/irq.c
@@ -152,6 +152,18 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
   bool               *enabled
diff --git a/bsps/powerpc/mpc8260ads/irq/irq.c b/bsps/powerpc/mpc8260ads/irq/irq.c
index d4f868fae6..f065b2841f 100644
--- a/bsps/powerpc/mpc8260ads/irq/irq.c
+++ b/bsps/powerpc/mpc8260ads/irq/irq.c
@@ -328,6 +328,18 @@ BSP_CPM_irq_init(void)
   bool               *enabled
diff --git a/bsps/powerpc/psim/irq/irq_init.c b/bsps/powerpc/psim/irq/irq_init.c
index e5e345832f..8c0e1adb5a 100644
--- a/bsps/powerpc/psim/irq/irq_init.c
+++ b/bsps/powerpc/psim/irq/irq_init.c
@@ -102,6 +102,18 @@ static int psim_exception_handler(
   bool               *enabled
diff --git a/bsps/powerpc/qemuppc/irq/irq_init.c b/bsps/powerpc/qemuppc/irq/irq_init.c
index ce85f9ad7a..277aa49830 100644
--- a/bsps/powerpc/qemuppc/irq/irq_init.c
+++ b/bsps/powerpc/qemuppc/irq/irq_init.c
@@ -35,6 +35,18 @@ static int qemuppc_exception_handler(
   return 0;
   bool               *enabled
diff --git a/bsps/powerpc/qoriq/irq/irq.c b/bsps/powerpc/qoriq/irq/irq.c
index 0a59bd4864..23598880c1 100644
--- a/bsps/powerpc/qoriq/irq/irq.c
+++ b/bsps/powerpc/qoriq/irq/irq.c
@@ -77,6 +77,29 @@ void bsp_interrupt_get_affinity(
 	_Processor_mask_From_uint32_t(affinity, destination, 0);
+#endif
   bool               *enabled
@@ -301,6 +324,29 @@ static void pic_vector_enable(rtems_vector_number vector, uint32_t msk)
 	rtems_interrupt_lock_release(&lock, &lock_context);
+#endif
   bool               *enabled
diff --git a/bsps/powerpc/shared/irq/ppc-irq-generic.c b/bsps/powerpc/shared/irq/ppc-irq-generic.c
index ceb4fdc91f..3aed893fe6 100644
--- a/bsps/powerpc/shared/irq/ppc-irq-generic.c
+++ b/bsps/powerpc/shared/irq/ppc-irq-generic.c
@@ -95,6 +95,18 @@ int BSP_rtems_irq_generic_set(rtems_irq_global_settings* config)
   return 1;
   bool               *enabled
diff --git a/bsps/powerpc/t32mppc/irq/irq.c b/bsps/powerpc/t32mppc/irq/irq.c
index 57671d6e11..79dc6de172 100644
--- a/bsps/powerpc/t32mppc/irq/irq.c
+++ b/bsps/powerpc/t32mppc/irq/irq.c
@@ -16,6 +16,18 @@
 #include <bsp/irq-generic.h>
 #include <bsp/vectors.h>
   bool               *enabled
diff --git a/bsps/powerpc/tqm8xx/irq/irq.c b/bsps/powerpc/tqm8xx/irq/irq.c
index 74e55a59aa..c538ed4dc8 100644
--- a/bsps/powerpc/tqm8xx/irq/irq.c
+++ b/bsps/powerpc/tqm8xx/irq/irq.c
@@ -63,6 +63,18 @@ static rtems_status_code bsp_irq_enable_at_CPM(rtems_vector_number irqnum)
   bool               *enabled
diff --git a/bsps/powerpc/virtex/irq/irq_init.c b/bsps/powerpc/virtex/irq/irq_init.c
index f455fee8f3..6582e8a060 100644
--- a/bsps/powerpc/virtex/irq/irq_init.c
+++ b/bsps/powerpc/virtex/irq/irq_init.c
@@ -132,6 +132,18 @@ static void opb_intc_init(void)
     (OPB_INTC_MER_HIE | OPB_INTC_MER_ME);
   bool               *enabled
diff --git a/bsps/riscv/griscv/irq/irq.c b/bsps/riscv/griscv/irq/irq.c
index 915a3b64f6..cfa015e6e8 100644
--- a/bsps/riscv/griscv/irq/irq.c
+++ b/bsps/riscv/griscv/irq/irq.c
@@ -87,6 +87,29 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
+#endif
   bool               *enabled
diff --git a/bsps/riscv/riscv/irq/irq.c b/bsps/riscv/riscv/irq/irq.c
index 535024732b..51ed9cc8de 100644
--- a/bsps/riscv/riscv/irq/irq.c
+++ b/bsps/riscv/riscv/irq/irq.c
@@ -226,6 +226,29 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
+#endif
   bool               *enabled
diff --git a/bsps/shared/dev/irq/arm-gicv2.c b/bsps/shared/dev/irq/arm-gicv2.c
index 045b7822a8..6d59233de4 100644
--- a/bsps/shared/dev/irq/arm-gicv2.c
+++ b/bsps/shared/dev/irq/arm-gicv2.c
@@ -64,6 +64,29 @@ void bsp_interrupt_dispatch(void)
+#endif
   bool               *enabled
diff --git a/bsps/shared/dev/irq/arm-gicv3.c b/bsps/shared/dev/irq/arm-gicv3.c
index 0549b6bd72..3fdc5f9d04 100644
--- a/bsps/shared/dev/irq/arm-gicv3.c
+++ b/bsps/shared/dev/irq/arm-gicv3.c
@@ -164,6 +164,29 @@ void bsp_interrupt_dispatch(void)
+#endif
   bool               *enabled
diff --git a/bsps/shared/irq-default-sources.am b/bsps/shared/irq-default-sources.am
index fe3352f7e5..c739be5f97 100644
--- a/bsps/shared/irq-default-sources.am
+++ b/bsps/shared/irq-default-sources.am
@@ -1,4 +1,5 @@
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-affinity.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-cause-clear.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-default.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-default-handler.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-enable-disable.c
diff --git a/bsps/shared/irq-sources.am b/bsps/shared/irq-sources.am
index d2536eb56d..fddb47599c 100644
--- a/bsps/shared/irq-sources.am
+++ b/bsps/shared/irq-sources.am
@@ -1,4 +1,5 @@
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-generic.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-handler-iterate.c
diff --git a/bsps/shared/irq/irq-cause-clear.c b/bsps/shared/irq/irq-cause-clear.c
new file mode 100644
index 0000000000..f726737dcb
--- /dev/null
+++ b/bsps/shared/irq/irq-cause-clear.c
@@ -0,0 +1,84 @@
+ * @file
+ * @ingroup bsp_interrupt
+ * @brief This source file contains the implementation of
+ *   rtems_interrupt_cause(), rtems_interrupt_cause_on() and
+ *   rtems_interrupt_clear().
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#include <bsp/irq-generic.h>
+#include <rtems/score/processormask.h>
+#include <rtems/score/smpimpl.h>
+#include <rtems/config.h>
+rtems_status_code rtems_interrupt_cause( rtems_vector_number vector )
+  if ( !bsp_interrupt_is_valid_vector( vector ) ) {
+    return RTEMS_INVALID_ID;
+  return bsp_interrupt_cause( vector );
+rtems_status_code rtems_interrupt_cause_on(
+  if ( cpu_index >= rtems_configuration_get_maximum_processors() ) {
+    return RTEMS_NOT_CONFIGURED;
+  if ( !_Processor_mask_Is_set( _SMP_Get_online_processors(), cpu_index ) ) {
+    return RTEMS_INCORRECT_STATE;
+  return bsp_interrupt_cause_on( vector, cpu_index );
+#else
+#endif
+rtems_status_code rtems_interrupt_clear( rtems_vector_number vector )
+  return bsp_interrupt_clear( vector );
diff --git a/bsps/shared/irq/irq-default.c b/bsps/shared/irq/irq-default.c
index 842cdd66e0..627b1df189 100644
--- a/bsps/shared/irq/irq-default.c
+++ b/bsps/shared/irq/irq-default.c
@@ -37,6 +37,18 @@
   bool               *enabled
diff --git a/bsps/sparc/leon3/start/eirq.c b/bsps/sparc/leon3/start/eirq.c
index 0382129271..0067fcb62e 100644
--- a/bsps/sparc/leon3/start/eirq.c
+++ b/bsps/sparc/leon3/start/eirq.c
@@ -61,6 +61,29 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
+#endif
   bool               *enabled
diff --git a/bsps/sparc/shared/irq/irq-shared.c b/bsps/sparc/shared/irq/irq-shared.c
index b06e9e438f..a58cf99c80 100644
--- a/bsps/sparc/shared/irq/irq-shared.c
+++ b/bsps/sparc/shared/irq/irq-shared.c
@@ -32,6 +32,29 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
+#endif
   bool               *enabled
diff --git a/bsps/x86_64/amd64/interrupts/idt.c b/bsps/x86_64/amd64/interrupts/idt.c
index 4763d70f06..478d975e41 100644
--- a/bsps/x86_64/amd64/interrupts/idt.c
+++ b/bsps/x86_64/amd64/interrupts/idt.c
@@ -145,6 +145,18 @@ void bsp_interrupt_vector_disable(rtems_vector_number vector)
   /* XXX */
   bool               *enabled
diff --git a/c/src/lib/libbsp/m68k/genmcf548x/Makefile.am b/c/src/lib/libbsp/m68k/genmcf548x/Makefile.am
index ecc8c99b26..2c8c75f6d6 100644
--- a/c/src/lib/libbsp/m68k/genmcf548x/Makefile.am
+++ b/c/src/lib/libbsp/m68k/genmcf548x/Makefile.am
@@ -39,6 +39,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/m68k/genmcf548x/btimer/btimer.c
 # IRQ
diff --git a/c/src/lib/libbsp/powerpc/ss555/Makefile.am b/c/src/lib/libbsp/powerpc/ss555/Makefile.am
index 2dc5a98e33..ec16b492ee 100644
--- a/c/src/lib/libbsp/powerpc/ss555/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/ss555/Makefile.am
@@ -47,6 +47,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/ss555/start/vectors_init
 librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/ss555/start/vectors.S
diff --git a/spec/build/bsps/m68k/genmcf548x/obj.yml b/spec/build/bsps/m68k/genmcf548x/obj.yml
index 538279e196..07e3760ad9 100644
--- a/spec/build/bsps/m68k/genmcf548x/obj.yml
+++ b/spec/build/bsps/m68k/genmcf548x/obj.yml
@@ -39,6 +39,7 @@ source:
 - bsps/m68k/shared/memProbe.c
 - bsps/shared/dev/getentropy/getentropy-cpucounter.c
 - bsps/shared/irq/irq-affinity.c
+- bsps/shared/irq/irq-cause-clear.c
 - bsps/shared/irq/irq-default-handler.c
 - bsps/shared/irq/irq-enable-disable.c
 - bsps/shared/irq/irq-handler-iterate.c
diff --git a/spec/build/bsps/objirq.yml b/spec/build/bsps/objirq.yml
index b6e725832f..4dda48d465 100644
--- a/spec/build/bsps/objirq.yml
+++ b/spec/build/bsps/objirq.yml
@@ -11,6 +11,7 @@ install: []
 links: []
 source:
 - bsps/shared/irq/irq-generic.c
diff --git a/spec/build/bsps/powerpc/ss555/bspss555.yml b/spec/build/bsps/powerpc/ss555/bspss555.yml
index a209db3238..a3bc8a6226 100644
--- a/spec/build/bsps/powerpc/ss555/bspss555.yml
+++ b/spec/build/bsps/powerpc/ss555/bspss555.yml
@@ -68,6 +68,7 @@ source:
 - bsps/powerpc/ss555/start/vectors_init.c
 - bsps/shared/irq/irq-default.c
2.26.2
