[PATCH 19/41] bsps/irq: Implement new directives for GICv2/3
Sebastian Huber
Tue Jul 13 05:16:13 UTC 2021
On 13/07/2021 04:46, Kinsey Moore wrote:
>> index a1ba5e9112..6f5d4015e4 100644
>> --- a/bsps/shared/dev/irq/arm-gicv2.c
>> +++ b/bsps/shared/dev/irq/arm-gicv2.c
>> @@ -1,5 +1,5 @@
>> - * Copyright (c) 2013, 2019 embedded brains GmbH. All rights reserved.
>> + * Copyright (c) 2013, 2021 embedded brains GmbH. All rights reserved.
>> * embedded brains GmbH
>> * Dornierstr. 4
>> @@ -69,6 +69,28 @@ rtems_status_code bsp_interrupt_get_attributes(
>> rtems_interrupt_attributes *attributes
>> + attributes->is_maskable = true;
>> + attributes->maybe_enable = true;
>> + if ( vector <= ARM_GIC_IRQ_SGI_LAST ) {
>> + attributes->always_enabled = true;
> As far as I'm aware, SGIs can be enabled or disabled using
> GICD_ISENABLER0 just like
> PPI or SPI interrupts for both GICv2 and GICv3. Section 3.1.2 of the
> GICv2 architecture
> spec (IHI0048B) references this, though I have seen implementations
> where certain SGI
> and PPI interrupts are hard-wired enabled or disabled and that state
> can't be changed
> (which is also covered in this section).
Ok, on Qemu and the i.MX7D the SGI are always enabled. I would keep the
attributes like this until we have a system which is different. I will
remove the check in bsp_interrupt_vector_enable/disable(). So, in the
worst case, the attributes are wrong.
>> + attributes->can_enable = true;
>> + attributes->can_cause = true;
>> + attributes->can_cause_on = true;
>> + attributes->cleared_by_acknowledge = true;
>> + } else {
>> + attributes->can_disable = true;
>> + attributes->can_clear = true;
>> + if ( vector > ARM_GIC_IRQ_PPI_LAST ) {
>> + /* SPI */
>> + attributes->can_get_affinity = true;
>> + attributes->can_set_affinity = true;
>> return RTEMS_SUCCESSFUL;
>> @@ -77,16 +99,25 @@ rtems_status_code bsp_interrupt_is_pending(
>> bool *pending
>> - bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
>> - bsp_interrupt_assert(pending != NULL);
>> - *pending = false;
>> - return RTEMS_UNSATISFIED;
>> + volatile gic_dist *dist = ARM_GIC_DIST;
>> + *pending = gic_id_is_pending(dist, vector);
>> + return RTEMS_SUCCESSFUL;
>> rtems_status_code bsp_interrupt_cause(rtems_vector_number vector)
>> + if (vector <= ARM_GIC_IRQ_SGI_LAST) {
>> + arm_gic_trigger_sgi(vector, 1U << _SMP_Get_current_processor());
>> + } else {
>> + gic_id_set_pending(dist, vector);
>> #if defined(RTEMS_SMP)
>> @@ -95,15 +126,27 @@ rtems_status_code bsp_interrupt_cause_on(
>> uint32_t cpu_index
>> + if (vector >= 16) {
>> + return RTEMS_UNSATISFIED;
>> + arm_gic_trigger_sgi(vector, 1U << cpu_index);
>> #endif
>> rtems_status_code bsp_interrupt_clear(rtems_vector_number vector)
>> + gic_id_clear_pending(dist, vector);
>> rtems_status_code bsp_interrupt_vector_is_enabled(
>> @@ -113,8 +156,16 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
>> bsp_interrupt_assert(enabled != NULL);
>> - *enabled = false;
>> + *enabled = true;
>> + } else {
>> + *enabled = gic_id_is_enabled(dist, vector);
>> rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number
>> vector)
>> @@ -133,6 +184,11 @@ rtems_status_code
>> bsp_interrupt_vector_disable(rtems_vector_number vector)
>> + /* SGI cannot be disabled */
I will remove this check here.
>> gic_id_disable(dist, vector);
>> @@ -207,8 +263,8 @@ BSP_START_TEXT_SECTION void
>> arm_gic_irq_initialize_secondary_cpu(void)
>> dist->icdigr[0] = 0xffffffff;
>> #endif
>> - /* Initialize Peripheral Private Interrupts (PPIs) */
>> - for (id = 0; id < 32; ++id) {
>> + /* Initialize priority of SGIs and PPIs */
>> + for (id = 0; id <= ARM_GIC_IRQ_PPI_LAST; ++id) {
>> gic_id_set_priority(dist, id, PRIORITY_DEFAULT);
>> @@ -300,6 +356,10 @@ rtems_status_code bsp_interrupt_set_affinity(
>> uint8_t targets = (uint8_t) _Processor_mask_To_uint32_t(affinity, 0);
>> + if ( vector <= ARM_GIC_IRQ_PPI_LAST ) {
>> gic_id_set_targets(dist, vector, targets);
>> @@ -310,8 +370,13 @@ rtems_status_code bsp_interrupt_get_affinity(
>> - uint8_t targets = gic_id_get_targets(dist, vector);
>> + uint8_t targets;
>> + targets = gic_id_get_targets(dist, vector);
>> _Processor_mask_From_uint32_t(affinity, targets, 0);
>> diff --git a/bsps/shared/dev/irq/arm-gicv3.c
>> b/bsps/shared/dev/irq/arm-gicv3.c
>> index 8db3053ffd..211f4d35c4 100644
>> --- a/bsps/shared/dev/irq/arm-gicv3.c
>> +++ b/bsps/shared/dev/irq/arm-gicv3.c
>> @@ -169,6 +169,25 @@ rtems_status_code bsp_interrupt_get_attributes(
>> + } else {
>> + /* SPI */
> The actual number of SPI interrupts supported by GICv3 can vary
> depending on the configuration
> of the IP. This should check that the provided vector is within that range.
Yes, I will change this to
I would not do the probing here, since this would require to do it also
in bsp_interrupt_vector_is_valid(). The probing could be done using
bsp_interrupt_vector_enable() and bsp_interrupt_vector_is_enabled().
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
