[PATCH v2] build: Use BSP family for options
chrisj at rtems.org
chrisj at rtems.org
Wed Jul 14 06:51:21 UTC 2021
- Optionally add support for 'default-by-family' to allow
option to be set by a family and so all related BSPs
Close #4468
wscript | 36 +++++++++++++++++++++++-------------
1 file changed, 23 insertions(+), 13 deletions(-)
diff --git a/wscript b/wscript
index 6626fafb74..61253b4a0b 100755
--- a/wscript
+++ b/wscript
@@ -592,9 +592,6 @@ class BSPItem(Item):
arch_bsps = bsps.setdefault(data["arch"].strip(), {})
arch_bsps[data["bsp"].strip()] = self
- def prepare_configure(self, conf, cic):
- conf.env.BSP_FAMILY = self.data["family"]
def prepare_build(self, bld, bic):
return BuildItemContext(
bic.includes + bld.env.BSP_INCLUDES.split(), [], [], []
@@ -695,12 +692,18 @@ class OptionItem(Item):
return True
return False
- def default_value(self, variant):
+ def default_value(self, variant, family):
value = self.data["default"]
for default in self.data["default-by-variant"]:
if OptionItem._is_variant(default["variants"], variant):
value = default["value"]
break
+ if 'default-by-family' in self.data:
+ for default in self.data["default-by-family"]:
+ if 'families' in default:
+ if OptionItem._is_variant(default["families"], family):
+ value = default["value"]
+ break
if value is None:
return value
if isinstance(value, list):
@@ -709,8 +712,8 @@ class OptionItem(Item):
return value
return self.data["format"].format(value)
- def do_defaults(self, variant):
- value = self.default_value(variant)
+ def do_defaults(self, variant, family):
+ value = self.default_value(variant, family)
if value is None:
return
description = self.data["description"]
@@ -917,7 +920,7 @@ class OptionItem(Item):
value = cic.cp.getboolean(conf.variant, name)
cic.add_option(name)
except configparser.NoOptionError:
- value = self.default_value(conf.env.ARCH_BSP)
+ value = self.default_value(conf.env.ARCH_BSP, conf.env.ARCH_FAMILY)
except ValueError as ve:
conf.fatal(
"Invalid value for configuration option {}: {}".format(name, ve)
@@ -933,7 +936,7 @@ class OptionItem(Item):
value = cic.cp.get(conf.variant, name)
if value is None:
return value
try:
@@ -952,7 +955,7 @@ class OptionItem(Item):
value = no_unicode(value)
return value
def _script(self, conf, cic, value, arg):
@@ -1365,12 +1368,23 @@ def configure_variant(conf, cp, bsp_map, path_list, top_group, variant):
conf.setenv(variant)
arch, bsp_name = variant.split("/")
bsp_base = bsp_map.get(bsp_name, bsp_name)
+ try:
+ bsp_item = bsps[arch][bsp_base]
+ except KeyError:
+ conf.fatal("No such base BSP: '{}'".format(variant))
+ family = bsp_item.data['family']
arch_bsp = arch + "/" + bsp_base
+ arch_family = arch + "/" + family
conf.env["ARCH"] = arch
conf.env["ARCH_BSP"] = arch_bsp
+ conf.env["ARCH_FAMILY"] = arch_family
conf.env["BSP_BASE"] = bsp_base
conf.env["BSP_NAME"] = bsp_name
+ conf.env["BSP_FAMILY"] = family
conf.env["DEST_OS"] = "rtems"
# For the enabled-by evaluation we have to use the base BSP defined by the
@@ -1385,10 +1399,6 @@ def configure_variant(conf, cp, bsp_map, path_list, top_group, variant):
items[conf.env.TOPGROUP].configure(conf, cic)
- try:
- bsp_item = bsps[arch][bsp_base]
- except KeyError:
- conf.fatal("No such base BSP: '{}'".format(variant))
bsp_item.configure(conf, cic)
options = set([o[0].upper() for o in cp.items(variant)])
2.24.1
