[PATCH v2] bsps/irq: Implement new directives for GICv2/3
Sebastian Huber
Wed Jul 14 11:54:55 UTC 2021
Update #3269.
bsps/include/dev/irq/arm-gic-irq.h | 3 +
bsps/shared/dev/irq/arm-gicv2.c | 83 +++++++++++++++----
bsps/shared/dev/irq/arm-gicv3.c | 125 +++++++++++++++++++++++++----
3 files changed, 180 insertions(+), 31 deletions(-)
diff --git a/bsps/include/dev/irq/arm-gic-irq.h b/bsps/include/dev/irq/arm-gic-irq.h
index 68e0247fd8..398fd8bceb 100644
--- a/bsps/include/dev/irq/arm-gic-irq.h
+++ b/bsps/include/dev/irq/arm-gic-irq.h
@@ -46,6 +46,9 @@ extern "C" {
#define ARM_GIC_IRQ_SGI_13 13
#define ARM_GIC_IRQ_SGI_14 14
#define ARM_GIC_IRQ_SGI_15 15
+#define ARM_GIC_IRQ_SGI_LAST 15
+#define ARM_GIC_IRQ_PPI_LAST 31
#define ARM_GIC_DIST ((volatile gic_dist *) BSP_ARM_GIC_DIST_BASE)
diff --git a/bsps/shared/dev/irq/arm-gicv2.c b/bsps/shared/dev/irq/arm-gicv2.c
index a1ba5e9112..83422218da 100644
--- a/bsps/shared/dev/irq/arm-gicv2.c
+++ b/bsps/shared/dev/irq/arm-gicv2.c
@@ -1,5 +1,5 @@
- * Copyright (c) 2013, 2019 embedded brains GmbH. All rights reserved.
+ * Copyright (c) 2013, 2021 embedded brains GmbH. All rights reserved.
* embedded brains GmbH
* Dornierstr. 4
@@ -69,6 +69,28 @@ rtems_status_code bsp_interrupt_get_attributes(
rtems_interrupt_attributes *attributes
+ attributes->is_maskable = true;
+ attributes->maybe_enable = true;
+ attributes->maybe_disable = true;
+ if ( vector <= ARM_GIC_IRQ_SGI_LAST ) {
+ attributes->can_cause = true;
+ attributes->can_cause_on = true;
+ attributes->cleared_by_acknowledge = true;
+ attributes->trigger_signal = RTEMS_INTERRUPT_NO_SIGNAL;
+ } else {
+ attributes->can_disable = true;
+ attributes->can_clear = true;
+ attributes->trigger_signal = RTEMS_INTERRUPT_UNSPECIFIED_SIGNAL;
+ if ( vector > ARM_GIC_IRQ_PPI_LAST ) {
+ /* SPI */
+ attributes->can_get_affinity = true;
+ attributes->can_set_affinity = true;
return RTEMS_SUCCESSFUL;
@@ -77,16 +99,25 @@ rtems_status_code bsp_interrupt_is_pending(
bool *pending
- bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
- bsp_interrupt_assert(pending != NULL);
- *pending = false;
- return RTEMS_UNSATISFIED;
+ volatile gic_dist *dist = ARM_GIC_DIST;
+ *pending = gic_id_is_pending(dist, vector);
+ return RTEMS_SUCCESSFUL;
rtems_status_code bsp_interrupt_cause(rtems_vector_number vector)
+ if (vector <= ARM_GIC_IRQ_SGI_LAST) {
+ arm_gic_trigger_sgi(vector, 1U << _SMP_Get_current_processor());
+ } else {
+ gic_id_set_pending(dist, vector);
#if defined(RTEMS_SMP)
@@ -95,15 +126,27 @@ rtems_status_code bsp_interrupt_cause_on(
uint32_t cpu_index
+ if (vector >= 16) {
+ return RTEMS_UNSATISFIED;
+ arm_gic_trigger_sgi(vector, 1U << cpu_index);
#endif
rtems_status_code bsp_interrupt_clear(rtems_vector_number vector)
+ gic_id_clear_pending(dist, vector);
rtems_status_code bsp_interrupt_vector_is_enabled(
@@ -111,10 +154,13 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
bool *enabled
bsp_interrupt_assert(enabled != NULL);
- *enabled = false;
+ *enabled = gic_id_is_enabled(dist, vector);
rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
@@ -207,8 +253,8 @@ BSP_START_TEXT_SECTION void arm_gic_irq_initialize_secondary_cpu(void)
dist->icdigr[0] = 0xffffffff;
#endif
- /* Initialize Peripheral Private Interrupts (PPIs) */
- for (id = 0; id < 32; ++id) {
+ /* Initialize priority of SGIs and PPIs */
+ for (id = 0; id <= ARM_GIC_IRQ_PPI_LAST; ++id) {
gic_id_set_priority(dist, id, PRIORITY_DEFAULT);
@@ -300,6 +346,10 @@ rtems_status_code bsp_interrupt_set_affinity(
uint8_t targets = (uint8_t) _Processor_mask_To_uint32_t(affinity, 0);
+ if ( vector <= ARM_GIC_IRQ_PPI_LAST ) {
gic_id_set_targets(dist, vector, targets);
@@ -310,8 +360,13 @@ rtems_status_code bsp_interrupt_get_affinity(
- uint8_t targets = gic_id_get_targets(dist, vector);
+ uint8_t targets;
+ targets = gic_id_get_targets(dist, vector);
_Processor_mask_From_uint32_t(affinity, targets, 0);
diff --git a/bsps/shared/dev/irq/arm-gicv3.c b/bsps/shared/dev/irq/arm-gicv3.c
index 8db3053ffd..b5b11c16f5 100644
--- a/bsps/shared/dev/irq/arm-gicv3.c
+++ b/bsps/shared/dev/irq/arm-gicv3.c
@@ -169,6 +169,28 @@ rtems_status_code bsp_interrupt_get_attributes(
+ } else {
+ /* SPI */
@@ -179,14 +201,39 @@ rtems_status_code bsp_interrupt_is_pending(
- *pending = false;
+ if (vector <= ARM_GIC_IRQ_PPI_LAST) {
+ volatile gic_sgi_ppi *sgi_ppi =
+ gicv3_get_sgi_ppi(_SMP_Get_current_processor());
+ *pending = (sgi_ppi->icspispendr[0] & (1U << vector)) != 0;
+ } else {
+ } else if (vector <= ARM_GIC_IRQ_PPI_LAST) {
+ sgi_ppi->icspispendr[0] = 1U << vector;
+ } else {
@@ -195,15 +242,35 @@ rtems_status_code bsp_interrupt_cause_on(
uint32_t cpu_index
#endif
+ sgi_ppi->icspicpendr[0] = 1U << vector;
+ } else {
@@ -213,8 +280,19 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
- *enabled = false;
+ *enabled = (sgi_ppi->icspiser[0] & (1U << vector)) != 0;
+ } else {
@@ -222,22 +300,24 @@ rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
- if (vector >= 32) {
+ if (vector > ARM_GIC_IRQ_PPI_LAST) {
gic_id_enable(dist, vector);
} else {
/* Set interrupt group to 1 in the current security mode */
#if defined(ARM_MULTILIB_ARCH_V4) || defined(AARCH64_IS_NONSECURE)
- sgi_ppi->icspigrpr[0] |= 1 << (vector % 32);
- sgi_ppi->icspigrpmodr[0] &= ~(1 << (vector % 32));
+ sgi_ppi->icspigrpr[0] |= 1U << vector;
+ sgi_ppi->icspigrpmodr[0] &= ~(1U << vector);
#else
- sgi_ppi->icspigrpr[0] &= ~(1 << (vector % 32));
- sgi_ppi->icspigrpmodr[0] |= 1 << (vector % 32);
+ sgi_ppi->icspigrpr[0] &= ~(1U << vector);
+ sgi_ppi->icspigrpmodr[0] |= 1U << vector;
#endif
/* Set enable */
- sgi_ppi->icspiser[0] = 1 << (vector % 32);
+ sgi_ppi->icspiser[0] = 1U << vector;
@@ -247,13 +327,15 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
gic_id_disable(dist, vector);
} else {
- sgi_ppi->icspicer[0] = 1 << (vector % 32);
+ sgi_ppi->icspicer[0] = 1U << vector;
@@ -407,6 +489,10 @@ rtems_status_code bsp_interrupt_set_affinity(
@@ -417,8 +503,13 @@ rtems_status_code bsp_interrupt_get_affinity(
+ uint8_t targets;
2.26.2
