[PATCH v1 1/6] ReportsBase.cc: Fix formatting
Ryan Long
ryan.long at oarcorp.com
Wed Jul 14 14:59:53 UTC 2021
tester/covoar/ReportsBase.cc | 305 ++++++++++++++++++++++---------------------
1 file changed, 156 insertions(+), 149 deletions(-)
diff --git a/tester/covoar/ReportsBase.cc b/tester/covoar/ReportsBase.cc
index cc3810b..cd65c53 100644
--- a/tester/covoar/ReportsBase.cc
+++ b/tester/covoar/ReportsBase.cc
@@ -24,8 +24,8 @@
namespace Coverage {
ReportsBase::ReportsBase( time_t timestamp, const std::string& symbolSetName ):
- reportExtension_m(""),
- symbolSetName_m(symbolSetName),
+ reportExtension_m( "" ),
+ symbolSetName_m( symbolSetName ),
timestamp_m( timestamp )
@@ -40,8 +40,8 @@ void ReportsBase::OpenFile(
std::ofstream& aFile
- int sc;
- std::string file;
+ int sc;
+ std::string file;
std::string symbolSetOutputDirectory;
rld::path::path_join(
@@ -54,9 +54,9 @@ void ReportsBase::OpenFile(
#ifdef _WIN32
sc = _mkdir( symbolSetOutputDirectory );
#else
- sc = mkdir( symbolSetOutputDirectory.c_str(),0755 );
+ sc = mkdir( symbolSetOutputDirectory.c_str(), 0755 );
#endif
- if ( (sc == -1) && (errno != EEXIST) ) {
+ if ( ( sc == -1 ) && ( errno != EEXIST ) ) {
throw rld::error(
"Unable to create output directory",
"ReportsBase::OpenFile"
@@ -65,7 +65,7 @@ void ReportsBase::OpenFile(
file = symbolSetOutputDirectory;
- rld::path::path_join(file, fileName, file);
+ rld::path::path_join( file, fileName, file );
// Open the file.
aFile.open( file );
@@ -74,9 +74,7 @@ void ReportsBase::OpenFile(
-void ReportsBase::WriteIndex(
- const std::string& fileName
+void ReportsBase::WriteIndex( const std::string& fileName )
@@ -130,64 +128,49 @@ void ReportsBase::OpenSymbolSummaryFile(
OpenFile(fileName, symbolSetName_m, aFile);
-void ReportsBase::CloseFile(
- std::ofstream& aFile
+void ReportsBase::CloseFile( std::ofstream& aFile )
aFile.close();
-void ReportsBase::CloseAnnotatedFile(
+void ReportsBase::CloseAnnotatedFile( std::ofstream& aFile )
CloseFile( aFile );
-void ReportsBase::CloseBranchFile(
- std::ofstream& aFile,
- bool hasBranches
+void ReportsBase::CloseBranchFile( std::ofstream& aFile, bool hasBranches )
CloseFile( aFile );
-void ReportsBase::CloseCoverageFile(
+void ReportsBase::CloseCoverageFile( std::ofstream& aFile )
CloseFile( aFile );
-void ReportsBase::CloseNoRangeFile(
+void ReportsBase::CloseNoRangeFile( std::ofstream& aFile )
CloseFile( aFile );
-void ReportsBase::CloseSizeFile(
+void ReportsBase::CloseSizeFile( std::ofstream& aFile )
CloseFile( aFile );
-void ReportsBase::CloseSymbolSummaryFile(
+void ReportsBase::CloseSymbolSummaryFile( std::ofstream& aFile )
CloseFile( aFile );
-std::string expand_tabs(const std::string& in) {
+std::string expand_tabs( const std::string& in ) {
std::string expanded = "";
int i = 0;
- for (char c : in) {
- if (c == '\t') {
- int num_tabs = 4 - (i % 4);
- expanded.append(num_tabs, ' ');
+ for ( char c : in ) {
+ if ( c == '\t' ) {
+ int num_tabs = 4 - ( i % 4 );
+ expanded.append( num_tabs, ' ' );
i += num_tabs;
} else {
expanded += c;
@@ -201,9 +184,8 @@ std::string expand_tabs(const std::string& in) {
* Write annotated report
-void ReportsBase::WriteAnnotatedReport(
+void ReportsBase::WriteAnnotatedReport( const std::string& fileName )
std::ofstream aFile;
Coverage::CoverageRanges* theBranches;
Coverage::CoverageRanges* theRanges;
@@ -211,8 +193,8 @@ void ReportsBase::WriteAnnotatedReport(
uint32_t bAddress = 0;
AnnotatedLineState_t state;
- OpenAnnotatedFile(fileName, aFile);
- if (!aFile.is_open()) {
+ OpenAnnotatedFile( fileName, aFile );
+ if ( !aFile.is_open() ) {
throw rld::error(
"Unable to open " + fileName,
"ReportsBase::WriteAnnotatedReport"
@@ -221,48 +203,60 @@ void ReportsBase::WriteAnnotatedReport(
// Process uncovered branches for each symbol.
- const std::vector<std::string>& symbols = SymbolsToAnalyze->getSymbolsForSet(symbolSetName_m);
+ const std::vector<std::string>& symbols =
+ SymbolsToAnalyze->getSymbolsForSet( symbolSetName_m );
- for (const auto& symbol : symbols) {
- const SymbolInformation& info = SymbolsToAnalyze->allSymbols().at(symbol);
+ for ( const auto& symbol : symbols ) {
+ const SymbolInformation& info =
+ SymbolsToAnalyze->allSymbols().at( symbol );
// If uncoveredRanges and uncoveredBranches don't exist, then the
// symbol was never referenced by any executable. Just skip it.
- if ((info.uncoveredRanges == NULL) &&
- (info.uncoveredBranches == NULL))
+ if (
+ ( info.uncoveredRanges == NULL ) &&
+ ( info.uncoveredBranches == NULL )
continue;
// If uncoveredRanges and uncoveredBranches are empty, then everything
// must have been covered for this symbol. Just skip it.
- if ((info.uncoveredRanges->set.empty()) &&
- (info.uncoveredBranches->set.empty()))
+ if (
+ ( info.uncoveredRanges->set.empty() ) &&
+ ( info.uncoveredBranches->set.empty() )
continue;
theCoverageMap = info.unifiedCoverageMap;
- bAddress = info.baseAddress;
- theRanges = info.uncoveredRanges;
- theBranches = info.uncoveredBranches;
+ bAddress = info.baseAddress;
+ theRanges = info.uncoveredRanges;
+ theBranches = info.uncoveredBranches;
// Add annotations to each line where necessary
AnnotatedStart( aFile );
- for (const auto& instruction : info.instructions) {
- uint32_t id = 0;
- std::string annotation = "";
- std::string line;
- const std::size_t LINE_LENGTH = 150;
- std::string textLine = "";
- std::stringstream ss;
+ for ( const auto& instruction : info.instructions ) {
+ uint32_t id = 0;
+ std::string annotation = "";
+ std::string line;
+ const std::size_t LINE_LENGTH = 150;
+ std::string textLine = "";
+ std::stringstream ss;
state = A_SOURCE;
if ( instruction.isInstruction ) {
- if (!theCoverageMap->wasExecuted( instruction.address - bAddress )){
+ if ( !theCoverageMap->wasExecuted( instruction.address - bAddress ) ) {
annotation = "<== NOT EXECUTED";
state = A_NEVER_EXECUTED;
id = theRanges->getId( instruction.address );
- } else if (theCoverageMap->isBranch( instruction.address - bAddress )) {
+ } else if (
+ theCoverageMap->isBranch( instruction.address - bAddress )
id = theBranches->getId( instruction.address );
- if (theCoverageMap->wasAlwaysTaken( instruction.address - bAddress )){
+ if (
+ theCoverageMap->wasAlwaysTaken( instruction.address - bAddress )
annotation = "<== ALWAYS TAKEN";
state = A_BRANCH_TAKEN;
} else if (
@@ -276,7 +270,7 @@ void ReportsBase::WriteAnnotatedReport(
- std::string textLineWithoutTabs = expand_tabs(instruction.line);
+ std::string textLineWithoutTabs = expand_tabs( instruction.line );
ss << std::left << std::setw( 90 )
<< textLineWithoutTabs.c_str();
@@ -285,7 +279,7 @@ void ReportsBase::WriteAnnotatedReport(
line = textLine + annotation;
- PutAnnotatedLine( aFile, state, line, id);
+ PutAnnotatedLine( aFile, state, line, id );
AnnotatedEnd( aFile );
@@ -297,37 +291,44 @@ void ReportsBase::WriteAnnotatedReport(
* Write branch report
-void ReportsBase::WriteBranchReport(
+void ReportsBase::WriteBranchReport( const std::string& fileName )
std::ofstream report;
unsigned int count;
bool hasBranches = true;
- if ((SymbolsToAnalyze->getNumberBranchesFound(symbolSetName_m) == 0) ||
- (BranchInfoAvailable == false) )
+ if (
+ ( SymbolsToAnalyze->getNumberBranchesFound( symbolSetName_m ) == 0 ) ||
+ ( BranchInfoAvailable == false )
hasBranches = false;
// Open the branch report file
OpenBranchFile( fileName, hasBranches, report );
- if (!report.is_open())
+ if ( !report.is_open() ) {
return;
// If no branches were found then branch coverage is not supported
- if ((SymbolsToAnalyze->getNumberBranchesFound(symbolSetName_m) != 0) &&
- (BranchInfoAvailable == true) ) {
+ if (
+ ( SymbolsToAnalyze->getNumberBranchesFound( symbolSetName_m ) != 0 ) &&
+ ( BranchInfoAvailable == true )
// Process uncovered branches for each symbol in the set.
count = 0;
- if (theBranches && !theBranches->set.empty()) {
- for (const auto& range : theBranches->set) {
+ if ( theBranches && !theBranches->set.empty() ) {
+ for ( const auto& range : theBranches->set ) {
count++;
PutBranchEntry( report, count, symbol, info, range );
@@ -341,9 +342,7 @@ void ReportsBase::WriteBranchReport(
* Write coverage report
-void ReportsBase::WriteCoverageReport(
+void ReportsBase::WriteCoverageReport( const std::string& fileName )
@@ -353,7 +352,7 @@ void ReportsBase::WriteCoverageReport(
// Open special file that captures NoRange informaiton
NoRangeName = "no_range_";
- NoRangeName += fileName;
+ NoRangeName += fileName;
OpenNoRangeFile( NoRangeName, NoRangeFile );
if ( !NoRangeFile.is_open() ) {
return;
@@ -366,11 +365,13 @@ void ReportsBase::WriteCoverageReport(
// Process uncovered ranges for each symbol.
count = 0;
@@ -378,11 +379,11 @@ void ReportsBase::WriteCoverageReport(
// referenced by any executable. There may be a problem with the
// desired symbols list or with the executables so put something
// in the report.
- if (theRanges == NULL) {
+ if ( theRanges == NULL ) {
putCoverageNoRange( report, NoRangeFile, count, symbol );
count++;
- } else if (!theRanges->set.empty()) {
- for (const auto& range : theRanges->set) {
+ } else if ( !theRanges->set.empty() ) {
+ for ( const auto& range : theRanges->set ) {
PutCoverageLine( report, count, symbol, info, range );
count++;
@@ -391,15 +392,12 @@ void ReportsBase::WriteCoverageReport(
CloseNoRangeFile( NoRangeFile );
CloseCoverageFile( report );
* Write size report
-void ReportsBase::WriteSizeReport(
+void ReportsBase::WriteSizeReport( const std::string& fileName )
@@ -412,16 +410,18 @@ void ReportsBase::WriteSizeReport(
count = 0;
- if (theRanges && !theRanges->set.empty()) {
+ if ( theRanges && !theRanges->set.empty() ) {
PutSizeLine( report, count, symbol, range );
count++;
@@ -431,12 +431,10 @@ void ReportsBase::WriteSizeReport(
CloseSizeFile( report );
-void ReportsBase::WriteSymbolSummaryReport(
+void ReportsBase::WriteSymbolSummaryReport( const std::string& fileName )
- std::ofstream report;
- unsigned int count;
+ std::ofstream report;
+ unsigned int count;
// Open the report file.
OpenSymbolSummaryFile( fileName , report );
@@ -445,11 +443,13 @@ void ReportsBase::WriteSymbolSummaryReport(
// Process each symbol.
count = 0;
PutSymbolSummaryLine( report, count, symbol, info );
count++;
@@ -464,14 +464,14 @@ void ReportsBase::WriteSummaryReport(
// Calculate coverage statistics and output results.
- uint32_t a;
- uint32_t endAddress;
- uint32_t notExecuted = 0;
- double percentage;
- double percentageBranches;
- Coverage::CoverageMapBase* theCoverageMap;
- uint32_t totalBytes = 0;
+ uint32_t a;
+ uint32_t endAddress;
+ uint32_t notExecuted = 0;
+ double percentage;
+ double percentageBranches;
+ Coverage::CoverageMapBase* theCoverageMap;
+ uint32_t totalBytes = 0;
OpenFile( fileName, symbolSetName, report );
@@ -480,21 +480,22 @@ void ReportsBase::WriteSummaryReport(
// Look at each symbol.
- const std::vector<std::string>& symbols = SymbolsToAnalyze->getSymbolsForSet(symbolSetName);
+ SymbolsToAnalyze->getSymbolsForSet( symbolSetName );
- SymbolInformation info = SymbolsToAnalyze->allSymbols().at(symbol);
+ SymbolInformation info = SymbolsToAnalyze->allSymbols().at( symbol );
// If the symbol's unified coverage map exists, scan through it
// and count bytes.
- if (theCoverageMap) {
+ if ( theCoverageMap ) {
endAddress = info.stats.sizeInBytes - 1;
- for (a = 0; a <= endAddress; a++) {
+ for ( a = 0; a <= endAddress; a++ ) {
totalBytes++;
- if (!theCoverageMap->wasExecuted( a ))
+ if ( !theCoverageMap->wasExecuted( a ) )
notExecuted++;
@@ -507,12 +508,12 @@ void ReportsBase::WriteSummaryReport(
percentageBranches = (double) (
- SymbolsToAnalyze->getNumberBranchesAlwaysTaken(symbolSetName) +
- SymbolsToAnalyze->getNumberBranchesNeverTaken(symbolSetName) +
- (SymbolsToAnalyze->getNumberBranchesNotExecuted(symbolSetName) * 2)
+ SymbolsToAnalyze->getNumberBranchesAlwaysTaken( symbolSetName ) +
+ SymbolsToAnalyze->getNumberBranchesNeverTaken( symbolSetName ) +
+ ( SymbolsToAnalyze->getNumberBranchesNotExecuted( symbolSetName ) * 2 )
percentageBranches /=
- (double) SymbolsToAnalyze->getNumberBranchesFound(symbolSetName) * 2;
+ (double) SymbolsToAnalyze->getNumberBranchesFound( symbolSetName ) * 2;
percentageBranches *= 100.0;
report << "Bytes Analyzed : " << totalBytes << std::endl
@@ -527,28 +528,29 @@ void ReportsBase::WriteSummaryReport(
<< SymbolsToAnalyze->getNumberUncoveredRanges( symbolSetName )
<< std::endl << std::endl;
- if ((SymbolsToAnalyze->getNumberBranchesFound(symbolSetName) == 0) ||
- (BranchInfoAvailable == false) ) {
+ if (
+ ( SymbolsToAnalyze->getNumberBranchesFound( symbolSetName ) == 0 ) ||
report << "No branch information available" << std::endl;
} else {
report << "Total conditional branches found : "
<< SymbolsToAnalyze->getNumberBranchesFound( symbolSetName )
<< std::endl << "Total branch paths found : "
<< SymbolsToAnalyze->getNumberBranchesFound( symbolSetName ) * 2
<< std::endl << "Uncovered branch paths found : "
- << SymbolsToAnalyze->getNumberBranchesAlwaysTaken(symbolSetName) +
+ << SymbolsToAnalyze->getNumberBranchesAlwaysTaken( symbolSetName ) +
<< std::endl << " "
<< " branches always taken" << std::endl << " "
- << SymbolsToAnalyze->getNumberBranchesNeverTaken(symbolSetName)
+ << SymbolsToAnalyze->getNumberBranchesNeverTaken( symbolSetName )
<< " branches never taken" << std::endl << " "
- << SymbolsToAnalyze->getNumberBranchesNotExecuted(symbolSetName) * 2
+ << SymbolsToAnalyze->getNumberBranchesNotExecuted( symbolSetName ) * 2
<< " branch paths not executed" << std::endl
<< "Percentage branch paths covered : "
- << std::fixed << std::setprecision(2) << std::setw(4)
+ << std::fixed << std::setprecision( 2 ) << std::setw( 4 )
<< 100.0 - percentageBranches << std::endl;
@@ -556,7 +558,7 @@ void ReportsBase::WriteSummaryReport(
CloseFile( report );
-void GenerateReports(const std::string& symbolSetName)
+void GenerateReports( const std::string& symbolSetName )
typedef std::list<ReportsBase *> reportList_t;
@@ -564,51 +566,56 @@ void GenerateReports(const std::string& symbolSetName)
reportList_t::iterator ritr;
std::string reportName;
ReportsBase* reports;
- time_t timestamp;
+ time_t timestamp;
- timestamp = time(NULL); /* get current cal time */
- reports = new ReportsText(timestamp, symbolSetName);
- reportList.push_back(reports);
- reports = new ReportsHtml(timestamp, symbolSetName);
+ timestamp = time( NULL ); /* get current cal time */
+ reports = new ReportsText( timestamp, symbolSetName );
+ reportList.push_back( reports );
+ reports = new ReportsHtml( timestamp, symbolSetName );
- for (ritr = reportList.begin(); ritr != reportList.end(); ritr++ ) {
+ for ( ritr = reportList.begin(); ritr != reportList.end(); ritr++ ) {
reports = *ritr;
reportName = "index" + reports->ReportExtension();
- if (Verbose)
+ if ( Verbose ) {
std::cerr << "Generate " << reportName << std::endl;
reports->WriteIndex( reportName );
reportName = "annotated" + reports->ReportExtension();
- if (Verbose)
+ if ( Verbose ) {
reports->WriteAnnotatedReport( reportName );
reportName = "branch" + reports->ReportExtension();
- if (Verbose)
+ if ( Verbose ) {
reports->WriteBranchReport( reportName );
reportName = "uncovered" + reports->ReportExtension();
- if (Verbose)
+ if ( Verbose ) {
reports->WriteCoverageReport( reportName );
reportName = "sizes" + reports->ReportExtension();
- if (Verbose)
- std::cerr << "Generate " << reportName << std::endl;
+ if ( Verbose ) {
+ std::cerr << "Generate " << reportName << std::endl;
reports->WriteSizeReport( reportName );
reportName = "symbolSummary" + reports->ReportExtension();
- if (Verbose)
+ if ( Verbose ) {
reports->WriteSymbolSummaryReport( reportName );
reports = *ritr;
delete reports;
1.8.3.1
