[PATCH rtems-docs v1 1/2] xilinx-zynqmp.rst: Documented SDIO driver
Stephen Clark
stephen.clark at oarcorp.com
Wed Jul 14 14:44:26 UTC 2021
Added documentation for SDIO driver.
user/bsps/aarch64/xilinx-zynqmp.rst | 14 ++++++++++++++
1 file changed, 14 insertions(+)
diff --git a/user/bsps/aarch64/xilinx-zynqmp.rst b/user/bsps/aarch64/xilinx-zynqmp.rst
index 71b6842..30ae8a3 100644
--- a/user/bsps/aarch64/xilinx-zynqmp.rst
+++ b/user/bsps/aarch64/xilinx-zynqmp.rst
@@ -55,6 +55,20 @@ Console Driver
The console driver supports the default Qemu emulated ARM PL011 PrimeCell UART
as well as the physical ARM PL011 PrimeCell UART in the ZynqMP hardware.
+SDHCI Driver
+The ZynqMP bsp has an SDHCI driver which allows reading to and writing from SD
+cards. These can be tested in qemu using the "-sd" option. For example:
+.. code-block:: shell
+ qemu-system-aarch64 -no-reboot -nographic -serial mon:stdio \
+ -machine xlnx-zcu102 -m 4096 -kernel media01.exe -sd example.img
+The SD card image should have an MSDOS partition table with a single partition
+containing a FAT file system.
Network Configuration
2.27.0
