Throughput/Goodput analysis on RTEMS
Vijay Kumar Banerjee
vijay at rtems.org
Thu Jul 15 06:30:43 UTC 2021
On Sun, Jul 11, 2021 at 6:42 PM Chris Johns <chrisj at rtems.org> wrote:
> On 10/7/21 1:28 pm, Vijay Kumar Banerjee wrote:
> > On Fri, Jul 9, 2021 at 8:25 PM Chris Johns <chrisj at rtems.org> wrote:
> >> On 2/7/21 4:40 am, Vijay Kumar Banerjee wrote:
> >>> I'm planning to do a throughput analysis on the RTEMS network stacks
> >>> and I'm looking for some suggestions on the tools/applications for
> >>> that if anyone has done something like that before.
> >> This is a great project.
> >>> If such application has not been used with RTEMS, then I might be
> >>> willing to port it to RTEMS or write one from scratch as a net-demo
> >>> maybe. Any resource/advice for that is welcome and much appreciated.
> >> Throughput is one parameter when dealing with networking and it is important in
> >> some applications while latency is another parameter that can be critical.
> >> Consider a voice switch with operators using Push To Talk (PTT) buttons to
> >> activate a radio's transmitter, an enable packet needs to be delivered within
> >> 10msec max in all cases.
> > This is an interesting point. Thanks for mentioning latency.
> In RTEMS and in an RTOS in general I also consider the latency for separate
> socket paths to separate readers and/or concurrent readers and writers as
> something important. A lot of stacks maintain a single giant lock for the stack
> and that serialises the processing through the stack. Libbsd does not have this
> limitation with it's fine grain locking. A protocol such as PTP benefits from
> deterministic handling of packets.
Interesting. I'm making notes, I'll look at latency from different protocols.
> >> I would look at removing the networking fabric from the analysis because it is
> >> subjective and can be effected by the NIC hardware, PHY configuration plus any
> >> externally connected equipment.
> > I'm approaching this by running different network stacks over the same
> > hardware. I have a uC5282 that runs legacy networking and I have
> > ported the driver to libbsd nexus device (dhcp doesn't work yet) and
> > I'm able to see some difference in the round trip time over loopback
> > with different stacks.
> Will your analysis look at architectures that support SMP and have various cache
> configurations? On a Zynq libbsd creates over 4000 locks and so there may be a
> performance hit on smaller single core systems compared with multi-core
> architectures that can run concurrent threads in the stack at the same time.
Yes, we plan to look at multicore architecture as well. Getting the
target to support all three stacks would be the real challenge.
> I think the 5282 may bias the results in a particular way and other archs will
> bias in a different way. I do not see this as wrong or a problem, rather it is
> something that needs to be accounted for so readers of the analysis do not get
> the wrong impression.
We intend to analyze boards over multiple arch.
> >> In terms of network stack performance for RTEMS you need to consider the
> >> protocol, buffering used, size of the buffer pool, transmit and receive paths,
> >> they will have different characteristics, and target's memory effects such as
> >> caches. On top of this is filtering, ie packet filtering, and the types of access.
> > Thanks for these interesting attributes to consider. I have done
> > preliminary analysis over ICMP with packets of same size over
> > different network stacks on the same board.
> >> With libbsd there are a number of sysctl settings that effect the performance.
> >> How will you manage these?
> > I'm not sure. I didn't know about the possible performance difference
> > based on sysctl settings. This would be relevant for any user and I
> > would like to explore it. Could you please point to some resources or
> > examples?
> There are a lot of posts on the net on this topic (search: "freebsd tune network
> sysctl") and the values can be technical but they do make a difference for
> different data workflows. There is no single set of values what work universally
> and for libbsd this is OK because I encourage users to explore the settings and
> see what works for them. There can be a memory used vs performance trade off. We
> support the sysctl API and there is a sysctl command for the shell.
I found some nice articles, thanks. I'll explore it further.
Thank you for the great points, it helped me get a better idea of what
I should be looking at.
Best regards,
Vijay
> Chris
